2015 Audi SQ5/Q5 Retrofit OEM Tow Module ACC Coding
AUDI_SQU5ME
Bay Area, CA, USA
C?ID=572029
Hello all, I followed instructions on how to code OEM tow module in VCDS, and applied all codes successfully.
However, there were no instructions on how to code ACC (group 13). I get error 01044 - Control Module Incorrectly Coded. I searched these forums and various Audi forums, but can't find the exact coding for B8.5 Audi.
My scan is below. Could someone please help me identify how to code the trailer into ACC and enable ACC again?
Thank you
Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 24.7.1(x64) Data version: 20240919 DS356.3
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,20,January,2025,18:01:29:13188
VIN: WA1VGBFP5FA040508 License Plate:
Mileage: 99730km-61969mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 36 3C 42 44 46 47 52 53
56 5F 62 69 6C 6D 72 A9
VIN: WA1VGBFP5FA040508 Mileage: 99730km-61969miles
Self-Diagnosis Log
Monday,20,January,2025,18:01:30:13188
Page 2
Address 01: Engine (J623-CTUD) Labels:. 06E-907-551-CGW.clb
Part No SW: 8R0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07--- CVN: 8B77F6E0
Coding: 2A2A0034054600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
ROD: EV_ECM30TFS0218R0907551G.rod
VCID: 3C21242B36E89FAA433-8068
VINID: 9D10665D25A0156440100140203BBB09F9
7193 - Function Restriction due to Faults in Other Modules
U1113 00 [00100111] - -
Mileage: 99737 km
Date: 2025.01.20
Time: 17:49:14
Engine RPM: 702.00 /min
Normed load value: 11.8 %
Coolant temperature: 96 °C
Intake air temperature: 62 °C
Voltage terminal 30: 14.421 V
Engine speed: actual: 704 /min
MAF_ENVD: 114.38823 mg/stroke
Coolant temperature (unfiltered): 96.75 °C
Engine: operating status: IS
Engine load: 11.718750 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
Self-Diagnosis Log
Page 3
Part No SW: 8R0 927 158 AB HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H19 1003
Revision: --H19--- CVN: DEE0EE05
VCID: 7DA7E92F6D7256A234D-8028
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 30AD5801
Shop #: WSC 06335 123 12345
VCID: 117FA59F416A42C2C05-8044
Part No SW: 8K0 907 064 JP HW: 8K0 907 064 JP
Component: BCM2 2.0 H14 0650
Coding: 0D854040000000000000
Shop #: WSC 06335 000 00000
VCID: 074B8BC73F2E0C721E1-8052
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000116085009
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AR HW: 8K1 820 043 AR
Revision: C3000000 Serial number: 01280820140948
Coding: 6601228200
VCID: 78A9F83B42D0738A67B-802C
Self-Diagnosis Log
Page 4
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000877074702
Coding: 26000091863CAFF2110048C000003D0D0F9CE608A2090225000008004000010200040034000000
VCID: 7AADE2337CDC619A11F-802E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140725 H12 0050
Serial number: 90243014140718132808
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23114180
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001808140221
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0099FF90
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0110460356
Coding: 0F0000
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: A2588B37000000000001
Self-Diagnosis Log
Page 5
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Coding: 00333E
VCID: 372B3B070F4EBCF2AE1-8062
00234 - Sensor for Automatic Distance Regulation Misadjusted
Reset counter: 183
Mileage: 99737 km
Date: 2025.01.20
Time: 17:49:09
Temperature: 47.0°C
Voltage: 14.46 V
Hex Value: 0x0031
Lateral Accel.: 0.00 m/s^2
Reset counter: 183
Mileage: 99737 km
Date: 2025.01.20
Time: 17:49:09
Temperature: 47.0°C
Voltage: 14.34 V
Hex Value: 0x005D
013 - Check DTC Memory
Fault Status: 01101101
Self-Diagnosis Log
Page 6
Reset counter: 183
Mileage: 99737 km
Date: 2025.01.20
Time: 17:49:09
Temperature: 47.0°C
Voltage: 14.34 V
Hex Value: 0x00BE
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12EE20 Dataset Number: 8R0909602F 0002
Coding: 303334313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC174EB66482F2AF33-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000L62B
Serial number: 6334MSME7E62220EK
Serial number: 6344MSME7E624C5F$
Serial number: 6352QSME1A490644F
Serial number: 6362QSME46444A62I
Serial number: 63732SME32234146O
Serial number: 63832SME01231C60P
Self-Diagnosis Log
Page 7
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372NHC0006F
Coding: 00003F
VCID: 44D15CCB4E98E76A3B3-8010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 D HW: 8R0 920 982 D
Component: KOMBIINSTR. H35 0564
Revision: 00400000 Serial number: ZDV224Y8F
Coding: 8BB722002F01D705020000
VCID: 3C21242B36689FAA433-8068
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z1481102F1
Coding: 80C103FF00
VCID: 4CC174EB66C82F2AF33-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 4692164103
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 0C0000
VCID: 392F3D3F395AAA82585-806C
Self-Diagnosis Log
Page 8
Part No SW: 8R0 959 760 E HW: 8R0 959 760 C
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000111261966
Coding: C0581B000F0000000000
VCID: 43D35FD74B96E052029-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0344295665 Dataset Number: 8R0909535F 0021
Coding: 010221
Shop #: WSC 06334 123 12345
VCID: 3FDB532727FE84B2661-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0344938217
Coding: 010221
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000115573654
Coding: 011D13215E00440004
VCID: 4FFB63E797DE1432961-801A
Self-Diagnosis Log
Page 9
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H41 0510
Revision: 00001000 Serial number: 0013763889 Dataset Number: 8R0909852J 0022
Coding: 010000010000
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D741CF4522DE622CD-8010
Revision: 00002001 Serial number: 0344624785
Coding: 0126023A20FA709584B0053220040000
Component: GTO BF H01 0080
Serial number: 00000000000000873888
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813033747006
VCID: 2D07196FFD120622C4D-8078
Self-Diagnosis Log
Page 10
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000114970669
VCID: 4EC57EE390D41D3A9D7-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001532722
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D22333CDCA19A51F-806E
Revision: AB001007 Serial number: 156H%0E8056256
Coding: 020007010000000001
VCID: 2411FC4BAED8C76A1B3-8070
Self-Diagnosis Log
Page 11
Part No SW: 8R1 035 746 F HW: 8R1 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 204I70E7675857
Coding: 1A0200060205A9EF75028B5E00000403140000000000000000
VCID: 3A2D22333C5CA19A51F-806E
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Subsystem 2 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001962106
Subsystem 3 - Part No: 8R0 060 961 G
Component: CD-Database 5950
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 183
Mileage: 99737 km
Date: 2025.01.20
Time: 17:49:16
Voltage: 14.50 V
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000115239213
Coding: 010C13204000240004
VCID: 46D546C378A4D57A257-8012
Self-Diagnosis Log
Page 12
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000171175244
Coding: 0200000000000000
Shop #: WSC 58071 001 1048576
VCID: 36353603084445FAB57-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J46A1QR
Coding: 1031010
VCID: 34310C0B123857EA8B3-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D27292F2D7296A274D-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000115240495
Self-Diagnosis Log
Page 13
Part No SW: 8R0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140704200431
End----------(Elapsed Time: 02:33, VBatt start/end: 14.5V/14.6V)-----------
Try changing 00333E to 003337.
PS: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
AUDI_SQU5ME
Bay Area, CA, USA
C?ID=572029
I think that worked in that it took the coding! It worked for a few seconds, then shut off and not available again =(. But thank you for helping me code to the trailer module!
Uwe, I read quite a few threads looking for the answer, and you seem to be either helping or guiding help to many a user. Thank you for your hard work!
