Resolved VW caddy Maxi 1.6 Diesel ABS pump coding
Resolved
Beaconleagarage1986
Bristol, UK
C?ID=175281
We have had to change the ABS module and pump due to being unable to communicate with controller. We now have a matching numbers unit which we need to code to the car can anyone help. Details of vehicle and module below
Vin WV1ZZZ2KZCX023015
1K0 907 379BH
Any help would be greatly appreciated we are defiantly not experts on VCDS so bare with us if we ask stupid questions.
Thank you in advance
Jim
Bruce
Near Philadelphia, PA, USA
Hi Jim,
I'm pretty sure that we are going to need a full autoscan from the vehicle to calculate the coding for the ABS. So, would you please post one?
Why you ask... it tells us all the control modules installed in the vehicle and allows us to know what needs to be stated to the ABS module. Make sense?
Beaconleagarage1986
Bristol, UK
C?ID=175281
Thursday,24,April,2025,09:31:51:52513
VCDS Version: 24.7.1.0 (x64)
VIN: WV1ZZZ2KZCX023015   License Plate:
Mileage: 152520km-94771mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZCX023015   Mileage: 152520km-94771miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000 CVN: EF964091
   Coding: 00114014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DF13737EC3C4F7EA0-8028
   VINID: 9E606AAAA09BA93A0008300114FEF84FA3
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Shop #: WSC 33361 790 00999
   VCID: 79F92327F014735E8C-802C
                    Reset counter: 127
                    Mileage: 152521 km
                    Date: 2019.09.15.
                    Time: 00:05:37
                    Count: 7
                    Count: 2
                    Count: 20992
                    Count: 195
                    Count: 42240
                    Count: 65024
                    Count: 1280
                    Fault Status: 01100101
                    Reset counter: 127
                    Mileage: 152521 km
                    Date: 2019.09.15.
                    Time: 00:05:37
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 279
                    Count: 42240
                    Count: 65024
                    Count: 1280
                    Reset counter: 127
                    Mileage: 152521 km
                    Date: 2019.09.15.
                    Time: 00:05:37
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 295
                    Count: 42240
                    Count: 65024
                    Count: 1280
                    Reset counter: 127
                    Mileage: 152521 km
                    Date: 2019.09.15.
                    Time: 00:05:37
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 270
                    Count: 42240
                    Count: 65024
                    Count: 1280
   Part No SW: 7N0 907 426 AT    HW: 7N0 907 426 AT
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004002
   VCID: 060358DBB9EA0CA6F1-8052
          B10AB F0 [00001001] - Too Low
                    Reset counter: 127
                    Mileage: 152521 km
                    Date: 2025.04.24.
                    Time: 00:05:36
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 411A581A8025186B08800082900000640301728852028060648000000040
   Shop #: WSC 35110 377 08192
   VCID: 72EB140BAD620006CD-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 10061  26  0512
   Coding: 009795
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL006EYCL Dataset Number: 2KC003v____ 0221
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3561EF17948C573E28-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90422KFT000EW Dataset Number: 1K5953507M  D005
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 3B75F92FB2A8814EDE-806E
   Part No SW: 2K0 920 965 E    HW: 2K0 920 965 E
   Component: KOMBI         H03 0606
   Coding: 480001
   VCID: 3169DB0760E47B1E74-8064
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 030711F2000624
   Coding: 357401
   VCID: 3561EF179C8C573E28-8060
   Component: IMMO          H03 0606
   VCID: 6ADB0C6B8DB2C8C675-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 489F96E33B7EDAD643-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 3467D21357F64E361F-8060
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 479D95DF3660D5AE4A-8012
   Part No SW: 5K0 035 156     HW: 5K0 035 156
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1L3517057
   Coding: 0500020001
   VCID: 64C7625367969EB64F-8030
End-------------------------(Elapsed Time: 02:23)--------------------------
Hope i have got this right
Thanks in advance
Jim
Reactions: Jef
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Please try: 463C600D092403FD620B06E5901EC081300000
Beaconleagarage1986
Bristol, UK
C?ID=175281
Hi thanks for prompt reply's we have inputted the code and this doesn't seem to work it accepts the code but after a short while it reset codes back to all zeros and traction and ABS light start to flash. This could be our error and any advice would be gratefully received thanks in advance Jim
Jef
HQ
633C400D092403FDC60B02E5901EC081300000
I'm way outside my comfort zone on that, but it might actually work.
Beaconleagarage1986
Bristol, UK
C?ID=175281
Sorry for late reply just to let you all know coding worked and all faults cleared cant thank everyone enough for all your help
Jef
HQ
:thumbs:
If possible, please post a follow up Auto-Scan.
