VW Taigun MQB A0 security access.
Teja_Utac
India
C?ID=496856
Hi, looking to switch off speed alarm in this car. (Taigun 2024 Dec)
In VCDS when I go to 17 instruments and try to change the adaptation, it says security access required. I've tried the regular/usual security codes but not accepted.
Would much appreciate if anyone can give me plausible security codes for me to try. Thank you much appreciated.
Tuesday,22,April,2025,16:10:00:53190
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: MEXM24CW4RT050955   License Plate: TAIGUNBLACK
Mileage: 5845km-3631mi   Repair Order:
Chassis Type: CW-VW27 (2Q0)
Scan: 01 02 03 05 08 09 15 17 19 2B 44 47 5F
VIN: MEXM24CW4RT050955   Mileage: 5845km-3631miles
Address 01: Engine (J623-DUMA)       Labels: None
   Part No SW: 05E 906 018 DP    HW: 05E 907 309 BC
   Component: R4 1.5l TFS   H80 2844
   Revision: 8EH80000    CVN: 9D2D41B9
   Coding: 012500122324090810000000000000000000000000000000
   Shop #: WSC 00000 000 00200
   ASAM Dataset: EV_ECM15TFS01105E906018DP 004002
   ROD: EV_ECM15TFS01105E906018DP_VW27.rod
   VCID: 76BE8A89784BC1DAA5B-8022
   VINID: 755A1D0844E712290014024514983868E1
   Part No SW: 0CW 300 020 L    HW: 0AM 927 769 N
   Component: GSG DQ200G2_M H07 2203
   Revision: 00007009    Serial number: 5ZV02401254247 CVN: 468413A7
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 3B285BBD03E95CB29A5-806E
   Part No SW: 5QP 614 517     HW: 2Q0 614 517 L
   Component: ESC_base      H13 0201
   Serial number: 17607534240925
   Coding: 9A058B645F4659ADD105FA1B72DF42A649B6B106336A262424541254454E4265926D8D60CC566424242A482AA231D6431F8C6BC2F8A8AC5015350A
   Shop #: WSC 00793 648 00200
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
   VCID: 0E4EC26960DB991A0DB-805A
Address 05: Acc/Start Auth. (J518)       Labels:* None
   Part No SW: 3Q1 959 435 C    HW: 3Q1 959 435 C
   Component: VWKESSYMQB    037 1501
   Revision: 00037000    Serial number: 0648759691 Dataset Number: V03935393KK 0001
   Coding: 032C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004056
   ROD: EV_KessyHellaMQBAB_VW27.rod
12718086 - Databus
          [Message WFS_01 missing]
                    Reset counter: 151
                    Date: 2025.04.08
                    Time: 11:19:28
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.576 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Rear left door: closed
                    Rear right door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6JM 907 057 C    HW: 6JM 907 057 C
   Component: Climatronic   035 0215
   Coding: 012100001400003101000401504011050101350000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
   ROD: EV_ACClimaBHBMQBA0Touch.rod
   VCID: 4CCA08615647EB0A23F-8018
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [00001000] - -
                    Reset counter: 176
                    Mileage: 1805 km
                    Date: 2025.02.26
                    Time: 13:12:24
                    Voltage terminal 30: 12.7 V
                    Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
   Part No SW: 2Q0 937 089 F    HW: 2Q0 937 089 F
   Component: BCM A0 Std    H15 0982
   Serial number: 014181024A0888 Dataset Number: V03935441JZ 0001
   ASAM Dataset: EV_BCMA0 209001
   ROD: EV_BCMA0_209_VW27.rod
   VCID: 3D2C55A51DFD5282A41-8068 SFD
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S2Y24M08D06H21M53S16
   Coding: 00184D
   Driver door control module:
   Subsystem 2 - Part No SW: 5QR 959 801 C    HW: 5QR 959 801 A
   Component: FHSG_DRV  003 0012
   Serial number: AP0883RHNA3724002552
   Coding: 0D2203
5642 - Bulb for Rear Left Turn Signal
          B11E9 15 [00001001] - Open or Short to Plus
                    Reset counter: 17
                    Mileage: 386 km
                    Date: 2025.01.07
                    Time: 02:57:32
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
6154 - Bulb for Rear Right Turn Signal
          B11EB 15 [00001001] - Open or Short to Plus
                    Reset counter: 17
                    Mileage: 386 km
                    Date: 2025.01.07
                    Time: 02:57:32
6410 - Bulb for Right Side Turn Signal
          B12D1 15 [00001001] - Open or Short to Plus
                    Reset counter: 17
                    Mileage: 386 km
                    Date: 2025.01.07
                    Time: 02:57:32
8714 - Bulb for Left Fog Lamp
          B121F 15 [00001000] - Open or Short to Plus
                    Reset counter: 166
                    Mileage: 5417 km
                    Date: 2025.04.17
                    Time: 17:18:18
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
14602 - Bulb for Left Brake Lamp / Tail Lamp
          B133A 15 [00001001] - Open or Short to Plus
                    Reset counter: 15
                    Mileage: 386 km
                    Date: 2025.01.06
                    Time: 01:17:39
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [00001001] - Open or Short to Plus
                    Reset counter: 15
                    Mileage: 386 km
                    Date: 2025.01.06
                    Time: 01:17:39
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 AP    HW: 2Q0 959 655 AP
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935398ST 0001
   Coding: 88CCC000000000007C540000008840000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0B48CB7D13C9AC32EA5-805E
   Subsystem 1 - Part No SW: -----------    HW: 442 060 507 24
   Serial number: 3577Y24A514897F26101
   Subsystem 2 - Part No SW: -----------    HW: 442 060 607 24
   Serial number: 3587Y20A5158ED63926C
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 906 24
   Serial number: 35177341E9E527A967F0
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 906 24
   Serial number: 3527732189E527A7156I
   Subsystem 5 - Part No SW: -----------    HW: 442 131 107 24
   Component: FrontSensor_D  290 118A
   Serial number: 355AG03ACAEDF23414BC
   Part No SW: 2GP 920 310 D    HW: 2GP 920 310 D
   Component: KOMBI         075 5882
   Coding: 252400182180000C02082A001000000000000509
   ASAM Dataset: EV_DashBoardJCIMQBAB 012005
   ROD: EV_DashBoardJCIMQBAB_012_VW27.rod
   VCID: 3C2A58A106E75B8A93F-8068 SFD
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 24
                    Mileage: 5234 km
                    Date: 2025.04.15
                    Time: 00:37:46
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 G    HW: 2Q0 937 089 F
   Component: GW MQB A0     H15 0982
   Coding: 030100042F00570000000000000F00010000000000000000000000000000
   GVL: 01403C0000000600400000000080C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013028
   ROD: EV_GatewA0_VW27.rod
   VCID: 363E4A8938CB81DA65B-8062
   Generator:
   Component: 4-00-12-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AA    HW: 3G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-YLG  H07 0120
   Serial number: YLG-0700084280240917
   Coding: 292C00
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 10502A6E
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000171027015
   Coding: 0808000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F47102BFC72AC77-805C SFD
12666387 - Databus
          [Timeout Message WFS_01]
                    Reset counter: 151
                    Date: 2025.04.08
                    Time: 11:19:28
                    Result lock conditions: valid
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Lock sensor: operated
                    Unlock sensor: Not operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: OFF
                    Clamp 15: OFF
                    Clamp 15 Status: valid
                    Remote Start: operated
                    Driver door: Closed
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    Activation lowside lock: OFF
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C cnd haco message: valid
                    I2C state esp 10 or VDSO 05: i2c cnd false
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    Signature IMS OK: No
                    IMS responded: No
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 0.00 km/h
                    UBat internal: 12.1 V
                    UMotorBridge: 6.6 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition E2E clamp status: Condition met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition Mode1: Condition met
                    Lock condition difference distance pulse or PPC status speed: Condition met
                    Lock condition E2E distance pulse or PPC status speed: Condition met
                    Lock condition timeout distance pulse or PPC status speed: Condition not met
                    Clamp enable ESCL: Enabled
                    Lock condition selector lever position parking: Condition met
                    Lock condition drive readiness: Condition met
Address 44: Steering Assist (J500)       Labels:. 2Qx-909-144-V3.clb
   Part No SW: 5QR 909 144 C    HW: 5QR 909 144 A
   Component: EPS_ECU       430 4250
   Serial number: 000006.03.24000 Dataset Number: V03935408NP 0001
   Coding: 00000000000000000101020101000100000001010101
   ASAM Dataset: EV_SteerAssisNSKGEN3MQB 004008
   ROD: EV_SteerAssisNSKGEN3MQB.rod
   VCID: 56FEEA09988BA1DA85B-8002
0012 - Terminal 30
          U140A 00 [00001000] - Open Circuit
          [Ausfallüberwachung Klemme 30/31]
                    Mileage: 5 km
                    Single Additional Freeze Frame: 1
   Part No SW: 5Q6 035 456     HW: 5Q6 035 456
   Component: KonzernAmp 8K H01 2427
   Revision: --------    Serial number: A1117A00318272 Dataset Number: V03935410BD 0001
   Coding: 0302000000AAAA00000000000000
   ASAM Dataset: EV_AMPCAN8C1PASE 001015
   ROD: EV_AMPCAN8C1PASE_VW27.rod
   VCID: 73B8B39D6B39D4F2825-8026
Address 5F: Information Electr. (J794)       Labels:| 2GM-035-MIB-REG.clb
   Part No SW: 6JR 035 180     HW: 6JR 035 180
   Component: MU-R--R2      H04 0709
   Serial number: VWZ7Z2CN300382  Dataset Number: V03935436RG 0001
   Coding: 22162608000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUREGIO 001010
   ROD: EV_MUREGIO.rod
   VCID: 0358E35D3B99E472925-8056
End----------(Elapsed Time: 01:00, VBatt start/end: 12.2V/12.1V)-----------
------------------------------11 Faults Found------------------------------
Your instrument cluster is locked down with SFD.
vrpram
India
C?ID=550004
VW vehicles made in India after last quarter 2024 and after have SFD locked modules installed in them to make modifying adaptations touger. You just have to wait until ross tech updates their software after getting clearances from Volkswagen. I have a MY2022 Virtus GT and fortunately don't have SFD locked modules. Car manufacturers are increasingly becoming intolerant like Apple and locking modules to prevent simple adaptation modifications. As of now you just have to wait and watch.
