2009 TDi Having issues with Turbo, seeking some advise.
Geoff
C?ID=226192
Hello, yesterday, car suddenly lost power, check engine light and "workshop: came up on screen, ran codes today. Any advice much appreciated.
Wednesday,23,December,2015,11:10:48:22623
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: 3VWRL71K99M065556   License Plate: MATTS JETTA
Mileage: 203540km-126473mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K99M065556   Mileage: 203540km-126473miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 N    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000SG  8680
   Revision: 12H01---    Serial number: VWX7Z0H824U00R
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 3D5FD7036429F1D65A-8068
006472 - Control Module 2 for Cooling Fan
               P1948 - 000 - Output Short Circuit - Intermittent
                    Fault Frequency: 16
                    Mileage: 203233 km
                    Time: 03:53:36
                    RPM: 2530 /min
                    Speed: 89.0 km/h
                    Temperature: 26.1°C
                    Temperature: 90.0°C
                    Temperature: 12.6°C
                    Lambda: 13.4 %
                    Lambda: 0.0 %
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 203265 km
                    Time: 04:36:51
                    RPM: 1817 /min
                    Speed: 79.0 km/h
                    Temperature: 24.3°C
                    Temperature: 90.9°C
                    Temperature: 13.5°C
                    Lambda: 26.8 %
                    Lambda: 0.0 %
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 203238 km
                    Time: 04:05:23
                    RPM: 1334 /min
                    Speed: 34.0 km/h
                    Temperature: 29.7°C
                    Temperature: 84.6°C
                    Temperature: 13.5°C
                    Lambda: 9.5 %
                    Lambda: 0.0 %
000175 - Actuator Module for Turbocharger 1
               P00AF - 000 - Stuck - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 8
                    Mileage: 203500 km
                    Time: 03:44:52
                    RPM: 828 /min
                    Speed: 1.0 km/h
                    Load: 100.0 %
                    Lambda: 15.0 %
                    Absolute Pres.: 989.4 mbar
                    Temperature: 24.3°C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D492800FF881002E9921F00423000
   VCID: 74C93227D7E3709E65-8020
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78D106170B8B14FE49-802C
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001089339
   Coding: 14018E234004150007140000001400000008730B5C000120000000000000
   VCID: 3245F43FAD773EAEB7-8066
   Component: Wischer 091008 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0435814
   Coding: 0000100
   VCID: 334BF13B526D37A6BC-8066
            000 -  -
                    Reset counter: 1
                    Mileage: 199773 km
                    Time: 11:43:31
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M074UYV
   Coding: 0013889
   VCID: 6CF92A474FD3A85EBD-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3E636421A
   Subsystem 3 - Serial number: 6342MSME3E632D59R
   Subsystem 4 - Serial number: 6351HSME181C1D317
   Subsystem 5 - Serial number: 6361HSME18022E3FD
   Subsystem 6 - Serial number: 63727SME18141820S
   Subsystem 7 - Serial number: 63827SME177C083A9
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0002021
   VCID: 042962E74743401E55-8050
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0H824U00R
   Coding: 0023203
   VCID: 3957C3137001CDF676-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 230808F2001817
   Coding: E9807F070013021002
   VCID: 354FCF235C19299692-8060
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T3E9504
   Coding: 0000003
   Component: IMMO            3HL 2418
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000507188913
   Coding: 0001205
   VCID: 6FC33D4B7EC5534698-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A75EC5F85A7766E0F-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 13900F880186281B0904058FB0880F0488DC00
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000028488830
   Coding: 0001204
   VCID: 70C13E3763FB4CBE81-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Fault Status: 00101100
                    Fault Frequency: 20
                    Reset counter: 132
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2239917
   Coding: 0010401
   VCID: 2977135380A17D7606-807C
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003487709
   Coding: 0001168
   VCID: 76CD082F019F628E5B-8022
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003537727
   Coding: 0001168
   VCID: 77D3052B06951B8640-8022
End-------------------------(Elapsed Time: 01:29)--------------------------
Address 01: DTCs cleared
dubTECH
Northern ireland
C?ID=104757
I would presume it's a common rail engine? To me the fault code is very similar to ones needing a new actuator (electronic version) and the other code is possibly the smaller fan being faulty, but do check your fuses as I know there has been a few where it has blown/ been pulled by someone else.
I agree, the small fan fails with more regularity but checking the wiring and power would be best.
This Wiki page and the thread linked on it may be helpful.
Geoff
C?ID=226192
Thank you, I will check the fuses and the suggestions in the Wiki page.
Geoff
C?ID=226192
Using the software I monitored the blocks 011, 012, 034. I'm having a hard time figuring out if this is good or bad. I should order a copy of the repair manual.
Also what should normal vacuum at idle be ? and which block is it contained in ? I could not find a descriptions which says "vacuum" in any of the blocks
Thursday,24,December,2015,10:55:29:22623
VIN: License Plate: MATTS
Mileage: 126000 Repair Order:
Address 01: Engine (03L 997 016 N)
10:54:25 Group 011: Charge Pressure Control
828 /min Engine Speed (G28)
1009.8 mbar Boost Pressure (specified)
979.2 mbar Boost Pressure (actual)
9.8 % Charge Pressure Control Duty Cycle
10:54:25 Group 001: Injection Quantity
6.0 mg/str Injection Quantity
296.0 bar High Fuel Pressure (actual)
45.0°C Coolant Temperature (G62)
10:54:25 Group 034
828 /min RPM
9.8 % Load
15.8 % Lambda
4.7 % Lambda
11:06:58 Group 011: Charge Pressure Control
989.4 mbar Boost Pressure (actual)
11:06:58 Group 034
828 /min RPM
9.8 % Load
15.0 % Lambda
4.7 % Lambda
11:06:58 Group 026
828 /min RPM
9.3 °BTDC Ign. Timing
200.0 (no units)
320.0 bar Pressure
ivagp
C?ID=95551
merry Christmas and happy holidays to everyone. a diesel engine wont produce vacuum and that's why it has a vacuum pump. the vacuum pump should produce about 18-22 in.
Geoff
C?ID=226192
VW Community, I appreciate some of us are living with the old Imperial (British) units of measurement, so I'm going to assume its inches of Mercury. To the nice folks at Ross-Tech if the car has a sensor which measures the actual produced vacuum Level, does your software measure this important variable ? if so please advise which measuring block in your software can tell me this ? or do I need to connect an actual vacuum gauge to measure it. PS 18-22 Inches of Mercury is =to 609- 745 Millibars.
The software doesn't measure anything. It can only show you diagnostic data that the ECU is willing to report.
As bar&kevs already stated, diesel engines don't produce vacuum (i.e. pressure less than ambient in the intake manifold). They may have a vacuum pump to produce vacuum needed to operate things that are traditionally actuated by vacuum such as a brake booster, but there's not much reason for the ECU to monitor this.
Geoff
C?ID=226192
I measured the vacuum coming of the Vacuum pump, got 22" Mercury. Measured vacuum coming off the N75 valve without it connected to the "VNT Actuator" got same 22", however with gauge in parallel with Actuator connected got just 10". After a minute or two, I heard a click and the Vacuum went to zero, (I suspect seeing as the car did not see correct behavior N75 closed) Turned engine off, connected hose directly to Actuator, sucking on this tube, I could not create any vacuum. I'm concluding the actuator diaphragm must have a leak. I will replace and see if that is the issue. Any comments appreciated.
carkey351
C?ID=263267
i was going to say that 9 times out of 10 the P00AF code is a bad VNT actuator. Low mileage for that to fail, but not unheard of. Mine failed at 360,000 miles. Replaced it just the the video suggests. What sucked was driving for a week at 50% engine power because when the actuator goes the ECU puts it in some sort of "protect" mode. That and the fact the turbo isn't producing boost....fun times.
