Good morning.
I replaced the ESP on a Seat Leon 1P and installed an HW46 (I've done this before without any problems).
It accepts the new coding (113B2012092400FE880D04E59022004121080023)
The problem comes when I start the basic setup.
It doesn't accept any of the access codes, always giving me error 37.
I managed to code it, and then by driving and performing the sequence of steering wheel turns from side to side, I adapted the G85, although I still get the error "basic setup not performed."
As you may know, when I turn off the ignition and haven't performed the basic setup, the coding is erased again.
I don't understand why it doesn't accept the code for the basic setup.
Any suggestion please?
Autoscan:
Autoscan:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZBR024219 Mileage: 195010km-121173miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AB HW: 03L 906 023 GG
Component: R4 1.6l TDI H23 9980
Revision: --H23--- Serial number: CVN: BADE2189
Coding: 00114016032400080000
ASAM Dataset: EV_ECM16TDI02103L906023AB 003014
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 66C43F1B99FFFBAB5D-8032
VINID: 9A38EAAAA060A928800840812471748315
Address 03: ABS Brakes (J104) Labels:. User\1K0-907-379-60EC1F.lbl
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 09086 167 12345
VCID: 75E66857DC590033E4-8020
Reset counter: 107
Mileage: 195012 km
Date: 2019.09.07.
Time: 12:26:40
Count: 7
Count: 29184
Count: 195
Count: 51712
Count: 510
03190 - Incorrect Vehicle Type
Reset counter: 107
Mileage: 195012 km
Date: 2019.09.07.
Time: 12:31:02
Count: 3
Count: 25088
Count: 4160
Count: 51712
Count: 64256
Count: 512
Fault Status: 01100101
Reset counter: 107
Mileage: 195012 km
Date: 2019.09.07.
Time: 12:26:39
Count: 2
Count: 25088
Count: 212
Count: 51456
Count: 256
Reset counter: 107
Mileage: 195012 km
Date: 2019.09.07.
Time: 12:26:39
Count: 2
Count: 25088
Count: 279
Count: 51456
Count: 256
Reset counter: 107
Mileage: 195012 km
Date: 2019.09.07.
Time: 12:26:39
Count: 2
Count: 25088
Count: 295
Count: 51456
Count: 256
Reset counter: 107
Mileage: 195012 km
Date: 2019.09.07.
Time: 12:26:39
Count: 2
Count: 25088
Count: 270
Count: 51456
Count: 256
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0702
Revision: 00001001
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3D76B077ACE99873EC-8068
Part No SW: 5K0 937 086 F HW: 5K0 937 086 F
Component: BCM PQ35 M 011 0035
Revision: BC011001
Coding: 46180A3E9833B2C0428800809100858446719DA8427D81605C8040000040
Shop #: WSC 04941 000 00000
VCID: 377AA25F86D5B22336-8062
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 09091 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 5P0 919 475
Component: PARKHILFE 4K H07 0005
Revision: -------- Serial number: 89321022100573
VCID: 3A7CBB6BB5C7AF4BC9-806E
Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
Component: J234__A0A VW10 HI 1916
Revision: 21014000 Serial number: 003GHPHTJCAJ
Coding: 0012353
Shop #: WSC 06402 785 00200
VCID: 4898D1A33B2BCDDB4F-801C
Subsystem 1 - Serial number: 6332MTS607492020
Subsystem 2 - Serial number: 6342MTS637492020
Subsystem 3 - Serial number: 6351HTS6I491C6KR
Subsystem 4 - Serial number: 6361HTS6BKTTA6KJ
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100902200873
Coding: 108A140002
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 79FE6467F841645380-802C
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: E20000
Part No SW: 1P0 920 853 C HW: 1P0 920 853 C
Component: KOMBI H05 0404
Coding: 110A00
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2F6A9A3F76857AE36E-807A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 220810F2001605
Coding: E9A07F0600061200000202
VCID: 6DD640377409C8F31C-8038
Component: IMMO H05 0404
VCID: 6ADC4B2B8DE7DFCB79-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668536005
VCID: 275A721F567522A3A6-8072
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0311
Revision: 12101005 Serial number: 0001185323
Coding: 0010B0
ROD: EV_DCU42BroseDriveSide.rod
VCID: 7CF07D73F773517B9B-8028
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005125805
Coding: 000090
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 65 3001
Revision: 00H17000
VCID: 316E9C47A8B16C1378-8064
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0311
Revision: 14101005 Serial number: 0001198121
Coding: 0010B0
ROD: EV_DCU52BrosePasseSide.rod
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005154852
Coding: 000090
131072 - Rear Door Control Module
B11ED 04 [00001001] - Internal System Fault
Mileage: 31729 km
Date: 2016.01.29.
Time: 16:06:55
Part No SW: 5P0 035 186 HW: 5P0 035 186
Component: Media2.0 H01 0007
Revision: 01000001 Serial number: SEZ1Z3K9447751
Coding: 0106040004
VCID: 6CD04D338F13C1FB0B-8038
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668322290 Dataset Number: 7P6035730C 0001
Coding: 0500000001010110
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 326C934B65B7570B01-8066
U1014 00 [00000000] - -
