Hello when i scan my car i get these fault codes.
Can somebody help me to solve these.
Saturday,19,April,2025,16:30:55:53240
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: TMBGK6NW0P3022453 License Plate: 1-NUY-871
Mileage: 11049km-6865mi Repair Order: kelly voor reparatie
Chassis Type: NW-SK27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F 75 A5 CA D6 D7
VIN: TMBGK6NW0P3022453 Mileage: 11049km-6865miles
CA-Sunroof -- Status: Malfunction 0010
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 CG HW: 05E 907 309 H
Component: R4 1.5l TFS H20 1906
Revision: 8AH20000 Dataset Number: V03935319HG 0001 CVN: AB367EC4
Coding: 0125003223041D0800000000000000000000000000000000
Shop #: WSC 31000 074 00058
ASAM Dataset: EV_ECM15TFS01105E906018CG 004005
ROD: EV_ECM15TFS01105E906018CG_004_SK27.rod
VCID: 6C8508E0860708EA433-8038
VINID: 91D4976C67A70200C00821050C02AD5A35
34193 - Implausible Data Received from ESP Control Module
U0416 00 [00101100] - -
Fault Frequency: 19
Mileage: 10896 km
Date: 2025.03.27
Time: 18:30:15
Engine speed: 1427.00 /min
Normed load value: 14.1 %
Vehicle speed: 1 km/h
Coolant temperature: 79 °C
Intake air temperature: 50 °C
Voltage terminal 30: 13.060 V
Drive train coordinator irreversible switch off conditions: 0
Drive train coordinator reversible switch off conditions: 2147516416
Drivetrain coordinator: brake fault status: 4
12888 - Implausible Data Received from ABS Control Module
U0415 00 [00101100] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 10896 km
Date: 2025.03.27
Time: 18:30:15
Normed load value: 13.3 %
Outside temperature: 27 °C
Absolute intake pressure: 56 kPa abs
Engine torque: 33.2 Nm
Fuel: tank fill level: 12.0 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Particulate filter: loading stage: 0
Overrun cut-off-Bits 0-7: 0
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [00101100] - -
[ABS brake control moduleRead out DTC]
Fault Frequency: 19
Mileage: 10896 km
Date: 2025.03.27
Time: 18:30:16
Engine speed: 1496.00 /min
Normed load value: 22.4 %
Voltage terminal 30: 13.200 V
Absolute intake pressure: 73 kPa abs
Engine torque: 58.5 Nm
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 051 M HW: 0AM 927 769 N
Component: GSG DQ200G2_M H07 1927
Revision: 00007009 Serial number: CU502208095698 CVN: 9BBE00B2
Shop #: WSC 31000 074 00034
ROD: EV_TCMDQ200021.rod
VCID: 40DD8C50DA0F3C8ACFB-8014
Address 03: ABS Brakes (J104) Labels:. 2Q0-614-517.clb
Part No SW: 2Q0 614 517 AP HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0262
Serial number: 08500778220720
Coding: B2108C643D434DAF3100BC1B12DD11A64976B106336A24482454225545488865926E8D60CC562412242A44AAA249D64B3F926BD2FCB0AC500D350A
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005_SK27.rod
VCID: 7CA538A0F667986AD33-8028
1264 - Display for Tire Pressure Monitoring
C1146 02 [00001000] - Signal Failure
Fault Frequency: 12
Reset counter: 169
Mileage: 10966 km
Date: 2025.04.08
Time: 11:50:53
1157 - ESC Temporarily Not Available
C1319 00 [00001000] - -
Reset counter: 168
Mileage: 10965 km
Date: 2025.04.08
Time: 11:49:29
0365 - Front Right Wheel Speed Sensor
C101B 14 [00001000] - Open or Short to Ground
Fault Frequency: 16
Reset counter: 169
Mileage: 10965 km
Date: 2025.04.08
Time: 11:49:18
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 654 907 044 F HW: 654 907 044 F
Component: Climatronic H05 0807
Dataset Number: V03935345FW 0001
Coding: 111000020800010001100800524401051050000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004028
ROD: EV_ACClimaBHBMQBA0.rod
VCID: 1D6315240D3D316284D-8048
Part No SW: 2Q0 937 090 E HW: 2Q0 937 090 C
Component: BCM A0 Std+ H12 0963
Serial number: 00102218200701 Dataset Number: V03935373PM 0001
ASAM Dataset: EV_BCMA0 208001
ROD: EV_BCMA0_208_VW27.rod
VCID: 3435D0809EB7902A5B3-8060
Driver door control module:
Subsystem 1 - Part No SW: 2Q1 959 405 C HW: 2Q1 959 163 C
Component: FHSG_DRV 002 0003
Serial number: 00000000000061202145
Coding: 030200
Front passenger door control module:
Subsystem 2 - Part No SW: 2Q1 959 406 C HW: 2Q1 959 164 C
Component: FHSG_PSG 002 0003
Serial number: 00000000000061729008
Coding: 190208
Humidity sensor: interior:
Subsystem 3 - Part No SW: 81A 907 658 HW: 81A 907 658
Component: G397_FSS H02 0003
Serial number: 40043733X81A90765800
Coding: C0005D
Subsystem 4 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000061974648
Coding: 130200
Subsystem 5 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000061983188
Coding: 0B0200
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H10 0075
Serial number: 000150058322206 Dataset Number: V03935343AB 0001
Coding: 8471151051
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 53F7B31C3B79B712629-8006
13637412 - Databus
[Bremsensteuergerät - ESP_10.ESP_WegimpulsVR - Fehlerspeicher auslesen]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
13637425 - Databus
[ESP - ESP_19.ESP_VR_Radgeschw_02 - Fehlerspeicher auslesen]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
13637426 - Databus
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935369BG 0001
Coding: 3204600200FF8748949C810500508700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 73B7139CDB39D712829-8026
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:46
Voltage terminal 15: 14.3 V
Control Module temperature: 56 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.59 m/s²
Adaptive distance regulation: status: ACC_reversible_error
0811 - Databus
[FAULT_ESP_VR_RADGESCHWINDIGKEIT_LOWVOLT_OR_ERROR]
Fault Frequency: 12
Reset counter: 129
Mileage: 10923 km
Date: 2025.04.04
Time: 14:27:48
Voltage terminal 15: 14.5 V
Control Module temperature: 52 °C
Vehicle speed: 2.11 m/s
Longitudinal acceleration: -2.31 m/s²
0815 - Databus
[FAULT_ESP_WEGIMPULS_HL_ERROR]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:46
0837 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_ESP_QBIT_V_SIGNAL_INIT_OR_ERROR_VALUE]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:46
Voltage terminal 15: 14.2 V
Longitudinal acceleration: 0.56 m/s²
0863 - Databus
[FAULT_ESP_QBIT_WEGIMPULS]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:46
Voltage terminal 15: 14.1 V
Longitudinal acceleration: 1.47 m/s²
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 AP HW: 2Q0 959 655 AP
Component: VW22Airbag 020 0511
Revision: -------- Dataset Number: V03935368TF 0001
Coding: 88CCC0C0000000005C5400CF000840000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0B476B7CA3C9AFD2EA9-805E
Subsystem 1 - Part No SW: ----------- HW: 442 061 407 22
Serial number: 3577Y24A509C0D41A0B8
Subsystem 2 - Part No SW: ----------- HW: 442 060 407 22
Serial number: 3587Y51AD099A2704367
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 507 22
Serial number: 3517783C70A67175341B
Subsystem 4 - Part No SW: ----------- HW: 442 0B1 507 22
Serial number: 3527783C50A6717292CM
Subsystem 5 - Part No SW: ----------- HW: 442 130 804 22
Component: FrontSensor_D 290 118A
Serial number: 355AG73AD08F7B1172D8
1053190 - Databus
[NWD: 0x0B2 ESP_19 error value ESP_VR_Radgeschw_02]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:46
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 654 920 746 B HW: 654 920 746 B
Component: KOMBI 201 7000
Dataset Number: V03935373RR 0001
Coding: 07A40A096980000801882A031001000800000000
ASAM Dataset: EV_DashBoardMMMQBA0 001026
ROD: EV_DashBoardMMMQBA0_VW27.rod
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 04082210522305 Dataset Number: V03935355AU 0001
Coding: 030100042F2A570001100242100F00010001070000000000000000000000
GVL: 01443C0000000000408090008000C80010000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 7F5FCFACE7718372F61-802A
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 5E3 919 719 H HW: 5E3 919 719 H Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H02 0110
Serial number: PR6-0440061212220358
Coding: 240000
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H03 2012
Serial number: 102B73BE
Address 44: Steering Assist (J792) Labels:| 2Qx-909-144-V1.clb
Part No SW: 2Q1 909 144 AB HW: 2Q1 909 144 AB
Component: TRW_G4L_MQBA0 613 6050
Serial number: 01M730KYCB2N231 Dataset Number: V03935375QF 0001
Coding: 010000000100000001010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 72B91698A423DE1A89F-8026
10494976 - Databus
[DEM_WHEEL_SPD_INVALID_FAULT]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
Engine speed: 1710 /min
System status: Driving mode
Terminal 15 status: On
Voltage terminal 30: 14.45 V
Power steering current consumption: 0.0 A
max.value: 43.4 A
End stage temperature: 31 °C
Steering assistance: engine output: 100 %
Engine angle: 171 °
Electric motor speed: -585 /min
Steering assistance: target engine torque: 0.1 Nm
Steering torque: -0.1 Nm
10621440 - Databus
[DEM_VEHICLE_SPEED_QBIT_INVALID_FAULT]
Fault Frequency: 11
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
Engine speed: 1717 /min
Voltage terminal 30: 14.42 V
max.value: 43.4 A
Engine angle: 237 °
Electric motor speed: -489 /min
Steering torque: -0.2 Nm
10622208 - Databus
[DEM_CAN_WHEEL_PULSE_FR_INVALID_FAULT]
Fault Frequency: 11
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
max.value: 43.4 A
Engine angle: 171 °
10624000 - Databus
[DEM_VEH_MOT_FR_INVALID_FAULT]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
max.value: 43.4 A
Engine angle: 171 °
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: -------------- Dataset Number: V03935313CX 0001
Coding: 04C800002D200103
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DB8954D1053582C05-8014
13705986 - Databus
[Fehlerwert im Signal ESP_VR_Radgeschw]
Fault Frequency: 20
Reset counter: 169
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:46
Part No SW: 654 035 869 H HW: 654 035 869 B
Component: MU-E-D-ER 040 1760
Serial number: CVRV4BXCAEA0069 Dataset Number: V03935358AK 0001
Coding: 33704000008000000000000000000000000000000000000000
ASAM Dataset: EV_MUEI 001007
ROD: EV_MUEI_VW27.rod
VCID: 26113AC8586BF2BAD57-8072
6720 - Rear View Camera
B1102 31 [00001000] - No Signal
Fault Frequency: 8
Reset counter: 36
Mileage: 10909 km
Date: 2025.04.02
Time: 17:27:10
Voltage terminal 30: 12.0 V
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0092
Serial number: 0000000207NVLZ0 Dataset Number: V03935337QC 0001
Coding: 03370410196828808005460160050607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_AU27.rod
VCID: 015B49549185F582805-8054
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1401
Serial number: EA1567403222150 Dataset Number: V03935374FE 0001
Coding: 0002088800404020409E00000020000001018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_SK27.rod
VCID: 3631EA8888CB823A657-8062
4195331 - Databus
[LH_EPS_03_EPS_HCA_Status]
Fault Frequency: 20
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Fault Frequency: 20
Mileage: 10904 km
Date: 2025.04.02
Time: 01:35:47
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935341HG 0001
Coding: 400000637041
VCID: 76B12A88C84BC23AA57-8022
0376 - Databus
[Brake control module: message counter error ESP_21]
Mileage: 10902 km
Date: 2025.04.02
Time: 01:12:25
Part No SW: 992 941 571 AC HW: 992 941 571 A
Component: LED1L H08 9201
Dataset Number: V03935370HX 0001
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 639763DC6BD94792F29-8036
Component: LED1R H08 9201
Dataset Number: V03935370KR 0001
End----(Elapsed Time: 01:27, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
------------------------------24 Faults Found------------------------------
