2011 Touareg 3.0 TDI
cmrboston2004
South Carolina, USA
C?ID=376315
Hello, new to the forum but not new to VCDS. Need help diagnosing issues with my Touareg. Yesterday I was just leaving the house and the glow plug light started flashing and it went into limp mode. I parked the car and returned a few hours later to find the light was no longer flashing but found that a rattling noise had developed. Immediately turned the car off and hooked to VCDS and found these faults. If anyone could tell me if there is any correlation between these faults or even point me in the right direction I would greatly appreciate it.
Sunday,20,April,2025,19:47:03:07939
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WVGFK9BPXBD005992   License Plate: TOUREAG[[
Mileage: 269515km-167468mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 65 69
          6C 6D 72
VIN: WVGFK9BPXBD005992   Mileage: 269515km-167468miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI FSA    H17 0008
   Revision: 56H17---    CVN: 66FD960056573130755A2113
   Coding: 292A4012233600050000
   Shop #: WSC 22602 444 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
   ROD: EV_ECM30TDI0117P0907401J_002.rod
   VCID: 363526B718C68D8A656-8062
   VINID: 9E65D66C94A0A1250000524908DA88FAAC
7 Faults Found:
16551 - EGR during Cold Start
          P04DD 00 [01100101] - Insufficient Flow
                    Mileage: 269310 km
                    Date: 2025.04.18
                    Time: 11:27:41
                    Engine speed: 981.00 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 13 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 13.400 V
                    Mean injection quantity: 7.56 mg/stroke
                    Control Module temperature: 24.6 °C
                    EGR_governor_deviation: -74.7 mg/stroke
                    Inj Ctl q Curr: 7.48 mg/stroke
                    Standardized air flow ratio: 1.3229
                    Air mass at air mass meter 1: 60.7 kg/h
                    Actual charge pressure: 972 hPa
5171 - Boost Pressure Regulation
          P0299 00 [01100000] - Control Range Not Reached
                    Mileage: 269485 km
                    Date: 2025.04.20
                    Time: 10:40:01
                    Engine speed: 1842.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 53 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 14.300 V
                    Charge Pressure Actuator: activation: 94.35 %
                    Charge air pressure actuator: acknowledgment: 94.45 %
                    Ambient temperature: 27.0 °C
                    Charge air pressure: specified value: 2305 hPa
                    Accelerator pedal travel: 42.40 %
                    Air mass: actual value (mg/stroke): 736.5 mg/stroke
                    Actual charge pressure: 1914 hPa
8863 - Particulate Filter
          P2459 00 [01100000] - Regeneration Frequency
                    Mileage: 268159 km
                    Date: 2025.04.03
                    Time: 12:48:31
                    Engine speed: 1334.00 /min
                    Normed load value: 81.6 %
                    Vehicle speed: 7 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 14.160 V
                    Unlearning counter according OBD: 12
                    Exhaust gas jet volume in particle filter: 125.7 m³/h
                    Particle filter: difference pressure: 122 hPa
                    Particle filter: soot mass measured: 23.95 g
                    Particle filter: soot mass calculated: 10.30 g
                    Exhaust gas temperature sensor 3: 439.5 °C
                    Exhaust gas temperature sensor 4: 115.9 °C
12896 - Boost Pressure Regulation
                    Mileage: 269485 km
                    Date: 2025.04.20
                    Time: 10:40:01
                    Charge Pressure Actuator: activation: 94.58 %
26253 - NOx Sensor 1 Bank 1
          P2201 00 [01100000] - Implausible Signal
                    Mileage: 268086 km
                    Date: 2025.04.02
                    Time: 21:49:09
                    Engine speed: 1453.50 /min
                    Normed load value: 78.4 %
                    Vehicle speed: 88 km/h
                    Coolant temperature: 85 °C
                    Voltage terminal 30: 14.360 V
                    Accelerator pedal: sensor voltage 1: 737.8 mV
                    Accelerator pedal: sensor voltage 2: 371.2 mV
                    Accelerator pedal: switch positions-Bits 0-7: 0
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Limitation: torque: 260.8 Nm
                    Control Module temperature: 35.0 °C
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [01100000] - Incorrect Correlation
                    Mileage: 269515 km
                    Date: 2025.04.20
                    Time: 13:15:08
                    Engine speed: 1020.50 /min
                    Normed load value: 6.3 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 11.620 V
                    Engine start: start synchronization: EPM_MODE_OK
                    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
21227 - Fuel Trim; Bank 1
          P0172 00 [01100100] - System Too Rich
                    Mileage: 268721 km
                    Date: 2025.04.07
                    Time: 07:44:09
                    Engine speed: 1664.50 /min
                    Normed load value: 78.8 %
                    Vehicle speed: 101 km/h
                    Coolant temperature: 58 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.260 V
                    Unlearning counter according OBD: 34
                    Accelerator pedal travel: 28.98 %
                    Accelerator pedal: sensor voltage 1: 1510.0 mV
                    Accelerator pedal: sensor voltage 2: 757.4 mV
                    Accelerator pedal: switch positions-Bits 0-7: 1
                    Limitation: torque: 271.3 Nm
                    Control Module temperature: 26.6 °C
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 3407
   Serial number:                CVN: CB5A7D50
   Coding: 001368
   Shop #: WSC 00234 005 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 303910AFFAA2A3BA3FA-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 408410010EC010 Dataset Number: 7P0012v____ 7P10
   Coding: 5B7613C349242558DAFDC89C92D4A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45D7517B55201612FCC-8010
   Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
   Component: BCM2 2.0      H24 0217
   Coding: 09860000000000000000
   VCID: 72BDDAA734AED1AA89E-8026
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0811000001234011
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000054804015
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
   Component: Klima 2 Zonen H18 0613
   Coding: B606200880
   VCID: 79AFED8B6958A2F2C84-802C
          U1101 00 [00001000] - Active
                    Reset counter: 172
                    Mileage: 267956 km
                    Date: 2025.03.24
                    Time: 18:19:05
0325 - Control Module for Auxiliary Heater
          B10C0 16 [00001000] - Voltage Too Low
                    Reset counter: 136
                    Mileage: 267933 km
                    Date: 2025.03.11
                    Time: 10:29:40
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
                    Fault Frequency: 11
                    Reset counter: 156
                    Mileage: 267951 km
                    Date: 2025.03.21
                    Time: 09:43:48
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000000845556
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 313F15ABF128AAB2304-8064
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110321  31  0020
   Serial number: 90243400110329052400
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10143970
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002403110654
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0B2J06
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag025 H05 0023
   Revision: --------    Serial number: 003JX0021Y39 Dataset Number: 7P6003v____ 0785
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 40D9406F4A02333ACFA-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R10B09023NH
   Serial number: 3575LRB40570EACCDG99
   Serial number: 3585LRB40530EACC7GNE
   Serial number: 3515RRB405R0G2I2C9OQ
   Serial number: 3525RRB405H0HBQUL0A6
   Serial number: 3555NRB405V0HBQU8GS/
   Serial number: 3565NRB405J0BEE688IF
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KCI0006V
   Coding: 000015
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0000302
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658170311592028
   Coding: 8B6733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 47CB5B736F2C04020E0-8012
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000117781
   Coding: 0001037500
   GVL: FB0F40051D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3829288F12D27BFA77A-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005653002163
12290 - Quiescent Current
          U1406 00 [00001000] - Too High
                    Reset counter: 137
                    Mileage: 267942 km
                    Date: 2025.03.12
                    Time: 13:56:58
                    Voltage terminal 30: 12.5 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 28 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000114490787
   Coding: 011D07200000453005080000
   VCID: 3C21349F266A57DA932-8068
   Revision: 00002001    Serial number: 0146044480
   Coding: 0186123A28B9500080A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 012115028
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 96
                    Mileage: 267931 km
                    Date: 2025.03.07
                    Time: 10:10:25
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000114273093
   VCID: 3B233783236450E29A8-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
   Component: EPB           H51 1100
   Revision: 00000000    Serial number: A1130200105    Dataset Number:             A001
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 353721BB05C086926CC-8060
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0007
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1F49F666A97DAD32-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0001
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0001
   Coding: 130000
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471CY0B7566522
   Coding: 020007020100000001
   VCID: 5DE7991BDD307ED2C4C-8008
   Part No SW: 7P6 035 664     HW: 7P6 035 664
   Component: H-BN-NA       H43 0170
   Revision: --------    Serial number: 445CT0B7512237
   Coding: 010200050040E1EE01022B0C00000003F0080101
   VCID: 75B7E1BB45C0C692ACC-8020
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H24 0045
   Serial number: VWZ8Z9L29005LX
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000114570851
   Coding: 011C07200000253005080000
   VCID: 3A2D32872C5E69EA81E-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000025998 Dataset Number: 7P6096v____ 0016
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDB439337FC4CC2B60-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000145853190
   Coding: 020D000000000000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H04000    Serial number: 525 PA8J120187
   Coding: 0110001
   VCID: 372B2BB3134C74827E0-8062
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 22010001    Serial number: 077100141 Dataset Number: 7p0771v____ 0009
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000114571073
                    Fault Status: 01101000
                    Reset counter: 133
                    Mileage: 269515 km
                    Date: 2025.04.20
                    Time: 13:00:51
End----(Elapsed Time: 02:03, VBatt start/end: 11.8V/12.0V. VIgn 12.0V)-----
------------------------------13 Faults Found------------------------------
My first two reactions are a blocked DPF and timing chain problems, the latter is much worse than the former.
cmrboston2004
South Carolina, USA
C?ID=376315
I was suspecting the timing chain. Would that mean the tensioner failed and it jumped timing?
They become very slack, I have done many V6TDI oil changes which have nearly induced a brown trouser moment :eek:
Check value
 IDE00182   Camshaft adaptation intake bank 1: phase position
Yup... Timing jumped. Start praying.
