ABS software codes?
Welder75
Canada
C?ID=261654
have a 2000 VW NB mk4 chassis 1c
my ABS module has software Coding: 03504
with says the car is AWD. but it is not.
what would the code be for front wheel drive?
tried googling it and search here, found nothing.
if someone could post value codes for the abs module that would be awesome.
Address 03: ABS Brakes (1J0 907 379 P)
10:13:56 Group 125: CAN-Databus Communication (Powertrain)
Engine 0 Engine
Transm. 0 All-Wheel-Drive (J492)
N/A Transmission
N/A
Santos
Can you post a complete auto scan from the car?
Welder75
Canada
C?ID=261654
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Tuesday,22,December,2015,16:58:08:49733
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
   Mileage: 174930km-108696miles
Address 01: Engine        Labels: 06A-906-018-AEG.lbl
   Part No: 06A 906 018 JQ
   Component: 2.0l R4/2V  MOTR AT V01
   Coding: 00033
   Shop #: WSC 91471
   VCID: 7AFBAFC2661D1CEE3F-4AE8
18044 - Powertrain Data Bus
            P1636 - 35-00 - Missing Message from Airbag Controller
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 HM
   Component: AG4 Getriebe 01M    4544
   Coding: 00011
   VCID: 020BD7220ECD542E67-095E
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E7363D23AB5F0CE43-4B1A
Address 17: Instruments        Labels: 1C0-920-xx0.lbl
   Part No: 1C0 920 801
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 02312
   VCID: 58BFD54AB8D12EFE69-4AE8
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0X5221496
   Ident.-Nr. Wegfahrs.:VWZ5Z0X5221496
            49-00 - No Communications
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00007
   Shop #: WSC 91487
   VCID: 70EF8DEA306156BE81-4B00
   Part No: 1J0 959 799 AJ
   Component: 5X Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00066
   VCID: 0603CB3222E5680E4B-4B00
   Subsystem 1 - Part No: 1J2959802C
   Component: 5X Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 5X Tõrsteuerger. BF0002r
No Faults Found
End-------------------------(Elapsed Time: 06:23)--------------------------
i have the airbag module unplugged
Welder75
Canada
C?ID=261654
bingo.....found a posting with a auto scan showing software code AS 13504. SO I CHANGE MY ABS CODE.
have a working tach.
thanks anyway. goes to show if u dig hard enough, u will find a answer.
