- Jun 10, 2023
- 1,935
- 929
- Netherlands
- C?ID=547002
Ignore the faults, I re-flashed engine ecu with same software and cleared all errors. Didn't had time to re-scan all. Blockmap done with engine off, it was prior re-flashing.
AutoScan: WVWZZZAWZKY166981
blockmap-01-05C-906-034_WVWZZZAWZKY166981-20250421-1559.CSV
blockmap-03-2Q0-614-517-AG_WVWZZZAWZKY166981-20250421-1600.CSV
blockmap-08-2G1-820-045-F_WVWZZZAWZKY166981-20250421-1600.CSV
blockmap-09-2Q0-937-085-A_WVWZZZAWZKY166981-20250421-1601.CSV
blockmap-13-2Q0-907-572-Q_WVWZZZAWZKY166981-20250421-1603.CSV
blockmap-15-2Q0-959-655-AG_WVWZZZAWZKY166981-20250421-1603.CSV
blockmap-17-2G0-920-730-B_WVWZZZAWZKY166981-20250421-1557.CSV
blockmap-19-2Q0-909-901-B_WVWZZZAWZKY166981-20250421-1558.CSV
blockmap-44-2Q1-909-144-M_WVWZZZAWZKY166981-20250421-1604.CSV
blockmap-5F-17A-035-869_WVWZZZAWZKY166981-20250421-1604.CSV
blockmap-OBD_WVWZZZAWZKY166981-20250421-1605.CSV
Monday,21,April,2025,16:05:48:15566
VCDS Version: 25.3.1.0 (x64) HEX-NET2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVWZZZAWZKY166981 License Plate:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 13 15 17 19 44 5F
VIN: WVWZZZAWZKY166981 Mileage: 124004km-77052miles
Address 01: Engine (J623-DFNA) Labels:. 05C-907-445-V1.clb
Part No SW: 05C 906 034 HW: 05C 907 445
Component: R3 1.0l MPI H01 9605
Revision: GVMuDSer
Coding: 011100140204050800000000000000000000000000000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI04205C906034 004009
ROD: EV_ECM10MPI04205C906034_004.rod
VCID: 5EEEF372B0B4591ADD7-800A
VINID: 9E69EAAAA467A9BA4118624804389F6329
37424 - Throttle Body (J338)
P1559 00 {00100111} - Fault in basic settings
Mileage: 124004 km
Date: 2025.01.22
Time: 03:58:32
Engine speed: 0.00 /min
Coolant temperature: 17 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.100 V
Throttle valve position 1: 0.922 V
Throttle valve position 2: 4.082 V
Throttle valve angle: specified value: 2.0 °
Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 0.922 V
Mass flow through throttle valve: 0 kg/h
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 10.00 %
Adaptation of throttle valve: Adaptation and testing of emergency operating position
37428 - Internal Control Module
P060B 00 {10100111} - A/D Processing Performance
Mileage: 124004 km
Date: 2025.01.22
Time: 03:20:42
Voltage terminal 30: 11.900 V
Engine status: Stop
Coolant temperature at engine start: 0.0 °C
Engine oil temperature: 17.1 °C
Time since engine start: 0 s
Shut-off timer: last engine shut-off time: 13 s
Engine torque: -12.8 Nm
Starter activation: status-Bit 0: OK
Starter activation: status-Bit 1: Before starter activation
Starter activation: status-Bit 2: Before starter activation
37518 - Internal Control Module
Mileage: 124004 km
Date: 2025.01.22
Time: 03:20:42
Engine status: Stop
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 2Q0-614-517.clb
Part No SW: 2Q0 614 517 AG HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0242
Serial number: 08501817190310
Coding: 09034A64154790B35205A81E24DB42A649124526114A245844541254452442659248A2648852241A222A482AA249D6433D926BC2BC
Shop #: WSC 36213 004 1048576
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0_004_VW27.rod
VCID: 73B8B2C62B36E472829-8026
8 Faults Found:
1119 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 {00001000} - -
{ComScl_Motor_11_Timeout}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:52
1123 - Databus
U1121 00 {00001000} - Missing Message
{ComScl_Motor_12_Timeout}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:52
1127 - No Communication with Engine Control Module (SAE ECM/PCM)
{ComScl_Motor_14_Timeout}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:53
1131 - Databus
{ComScl_Motor_20_Timeout}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:52
0077 - No Communication with Engine Control Module (SAE ECM/PCM)
{ComScl_Motor_Code_01_Timeout}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:58
0724 - Function Restriction due to Faults in Other Modules
U1113 00 {00001000} - -
{Scl_MO_Fahrpedalrohwert_01_Error}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:09:46
0834 - Databus
U1123 00 {00001000} - Received Error Message
{SCL_MO_Timeout_ESP_Error}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 02:04:01
0889 - Control Module Incorrectly Coded
U1014 00 {00001000} - -
{VAR_Checking_GearboxTypeNotAvailable}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:58
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 2G1 820 045 F HW: 2G1 820 045 F
Component: SG_AC_Manuell H50 0301
Serial number: 00000000000000 Dataset Number: V03935264DP 0001
Coding: 012000000800010011000400020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
ROD: EV_ACManuePrehMQBA0.rod
VCID: 23188286DB5634F2B29-8076
459023 - Databus
{Motorsteuergerät - kein Signal/Kommunikation}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:52
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 {00001000} - -
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:11:26
Voltage terminal 30: 14.8 V
Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
Part No SW: 2Q0 937 085 A HW: 2Q0 937 085
Component: BCM A0 Std H98 0926
Serial number: 00001905200636 Dataset Number: V03935291NU 0001
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204_VW27.rod
VCID: 343A71DA6EB8A34A5B3-8060
Driver door control module:
Subsystem 1 - Part No SW: 2Q1 959 881 HW: 2Q1 959 881
Component: FHSG_DRV 001 0001
Serial number: 00000000000028445926
Coding: 130000
Front passenger door control module:
Subsystem 2 - Part No SW: 2Q1 959 882 HW: 2Q1 959 882
Component: FHSG_PSG 001 0001
Serial number: 00000000000028602685
Coding: 090000
Subsystem 3 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000028761174
Coding: 030000
Subsystem 4 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000028783908
Coding: 1B0000
136740 - Terminal 75
B18FB F0 {00001000} - Limp Mode Active
Fault Frequency: 8
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:53
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: 0
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: 45
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
541973 - Databus
{Motor_04 Datenbus fehlende Botschaft}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:55
Zusaetzliche Umgebungsdaten-last wakeup: 33
589829 - Window Regulator; Rear Driver Side
B131F 54 {00001001} - Missing Calibration / Basic Setting
Reset counter: 176
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:25
Zusaetzliche Umgebungsdaten-voltage measurement: 12.4 V
590853 - Window Regulator; Front Drivers Side
B14D1 54 {00001001} - Missing Calibration / Basic Setting
Reset counter: 176
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:25
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Dataset Number: V03935284KJ 0001
Coding: 2A04600100F78748949C810500408700000000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 42D62702240C1DFAD9F-8016
15 Faults Found:
1064 - Databus
{FAULT_TIMEOUT_MOTOR_14}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:55
Voltage terminal 15: 12.4 V
Control Module temperature: 29 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_reversible_error
1065 - Databus
{FAULT_TIMEOUT_MOTOR_16}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:59
Control Module temperature: 30 °C
Longitudinal acceleration: -0.03 m/s²
1067 - Databus
{FAULT_TIMEOUT_MOTOR_20}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:54
1133 - Databus
{FAULT_TIMEOUT_MOTOR_CODE_01}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:59
2101 - Databus
{FAULT_ESP_STATUS_SYSTEM}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:26
2059 - Databus
{FAULT_GP_FAIL}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:26
0936 - Databus
U1123 00 {00001001} - Received Error Message
{FAULT_VEHICLE_WEIGHT_FAIL}
Reset counter: 177
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:26
Voltage terminal 15: 12.3 V
2126 - Databus
{FAULT_TSK_ROAD_SLOPE_FAIL}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 02:04:00
Voltage terminal 15: 12.2 V
Control Module temperature: 46 °C
1116 - Databus
U1122 00 {00001000} - Implausible Message
{FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 02:04:29
Voltage terminal 15: 12.1 V
Control Module temperature: 47 °C
0822 - Databus
{FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:58
0828 - Databus
{FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:58
Voltage terminal 15: 12.5 V
0855 - Databus
{FAULT_EGO_FZG_GIERRATE}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:58
0854 - Databus
{FAULT_EGO_FZG_LAENGSBESCHLEUNIGUNG}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:58
2131 - Databus
{FAULT_RPM_INVALID}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 01:14:10
Control Module temperature: 35 °C
2058 - Databus
{FAULT_GP_INVALID}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 02:04:01
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
Component: VW22Airbag 010 0248
Revision: -------- Dataset Number: V03935272NL 0001
Coding: 88CCC0C0000000005C5400CF000800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0256E702648CDDFA99F-8056
Subsystem 1 - Part No SW: ----------- HW: 442 062 203 19
Serial number: 3577Y209929973D4F18I
Subsystem 2 - Part No SW: ----------- HW: 442 062 203 19
Serial number: 3587Y209929973D49217
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 303 19
Serial number: 3517782AB2F28075B32N
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 803 19
Serial number: 3527783BB2FA9FE5609D
Subsystem 5 - Part No SW: ----------- HW: 442 131 403 19
Component: FrontSensor_D 290 118A
Serial number: 355AG11C12F424E5F23Y
Part No SW: 2G0 920 730 B HW: 2G0 920 730 B
Component: KOMBI 210 2660
Dataset Number: V03935285UC
Coding: 04A4010021000008018800010000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001037
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 20128D8ACA402FEAAFB-8074
16776971 - Databus
{Motor keine Kommunikation}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:52
16776988 - Databus
{TSK_07 keine Kommunikation}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:52
13639427 - Databus
{Steuergerät für Motor: bitte Fehlerspeicher auslesen}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 02:02:21
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 2Q0 909 901 B HW: 2Q0 937 085
Component: GW MQB A0 H98 0926
Serial number: 00001905200636 Dataset Number: V03935286DT 0001
Coding: 030000046F086400FA000048080E00010001070000000000000000000000
GVL: 01403C0000000000400080000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0 013024
ROD: EV_GatewA0_VW27.rod
VCID: 313478CE91AA9662305-8064
Generator:
Subsystem 2 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 100FC783
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
{Timeout Knoten 0x76 / 01 - Motorsteuergerät}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:41:04
Terminal 30 power supply: 12.6 V
Terminal 15: OFF
Address 44: Steering Assist (J792) Labels:| 2Qx-909-144-V1.clb
Part No SW: 2Q1 909 144 M HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 611 6041
Serial number: 01113193CP3K093 Dataset Number: V03935291GW 0001
Coding: 010000000000000001010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 3C2A59FA46E86B0A933-8068
15 Faults Found:
10491648 - Databus
{DEM_ES_ABSENT_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:55
Engine speed: 1500 /min
System status: Cut_off
Voltage terminal 30: 12.49 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 17 °C
Steering assistance: engine output: 100 %
Engine angle: 1 °
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.0 Nm
10489600 - Databus
{DEM_CAN_HYBRID_ABSENT_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:55
max.value: 0.5 A
Engine angle: 1 °
10496768 - Databus
{DEM_ENG_TORQUE_MSG_ABSENT_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:55
max.value: 0.5 A
Engine angle: 1 °
10538752 - Databus
{DEM_DRIVE_PEDAL_STATUS_MSG_ABSENT_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:55
max.value: 0.5 A
Engine angle: 1 °
10531584 - Databus
{DEM_MOTOR_CODE_01_ABSENT_FAULT}
Reset counter: 177
Mileage: 124004 km
Date: 2025.01.22
Time: 00:44:00
System status: Driving mode
Voltage terminal 30: 12.46 V
max.value: 0.5 A
Engine angle: 1 °
10535168 - Databus
{DEM_CAN_YAW_RATE_INVALID_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:59
Voltage terminal 30: 12.47 V
max.value: 0.5 A
Engine angle: 1 °
10535424 - Databus
{DEM_CAN_LONG_ACCEL_INVALID_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:59
max.value: 0.5 A
Engine angle: 1 °
10535680 - Databus
{DEM_CAN_LAT_ACCEL_INVALID_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:59
max.value: 0.5 A
Engine angle: 1 °
10513664 - Databus
{DEM_DRIVER_PEDAL_INVALID_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:31
Engine speed: 0 /min
Voltage terminal 30: 12.41 V
max.value: 0.5 A
End stage temperature: 14 °C
Engine angle: 0 °
10621184 - Databus
{DEM_DRIVER_PEDAL_QBIT_INVALID_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 02:04:01
Voltage terminal 30: 12.19 V
Power steering current consumption: 0.4 A
max.value: 0.5 A
End stage temperature: 23 °C
Engine angle: 359 °
10624768 - Databus
{DEM_MOTOR_TORQUE_QBIT_INVALID_FAULT}
Reset counter: 176
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:31
max.value: 0.5 A
Engine angle: 0 °
11141120 - Databus
{DEM_CAN_MOTOR_07_MSG_ABSENT_FAULT}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:44:00
max.value: 0.5 A
Engine angle: 1 °
11143680 - Databus
{DEM_MOTOR_TORQUE_NOMINAL_QBIT_INVALID_FAULT}
Reset counter: 176
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:31
max.value: 0.5 A
Engine angle: 0 °
11143936 - Databus
{DEM_MOTOR_TORQUE_SUM_INERTIA_QBIT_INVALID_FAULT}
Reset counter: 176
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:31
max.value: 0.5 A
Engine angle: 0 °
11144192 - Databus
{DEM_MOTOR_TORQUE_THRUST_QBIT_INVALID_FAULT}
Reset counter: 176
Mileage: 124004 km
Date: 2025.01.22
Time: 00:10:31
max.value: 0.5 A
Engine angle: 0 °
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 17A 035 869 HW: 17A 035 869
Component: MU-E--ER 695 8742
Serial number: 21031900012020 Dataset Number: V03935294YR 0001
Coding: 027200003C00000041110001000002001F0000C40000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 6882D5AA62F017AA27B-803C
6708 - Databus
{Engine: no communication}
Reset counter: 217
Mileage: 124004 km
Date: 2025.01.22
Time: 00:43:56
Voltage terminal 30: 12.4 V
Network diagnosis-Status: Enabled
End----------(Elapsed Time: 08:25, VBatt start/end: 14.4V/14.4V)-----------
------------------------------52 Faults Found------------------------------
;SW:05C-906-034 HW:05C-907-445 --- Engine
;Component:R3 1.0l MPI H01 9605, Coding:011100140204050800000000000000000000000000000000
;EV_ECM10MPI04205C906034,004009,EV_ECM10MPI04205C906034_004.rod
;Monday,21,April,2025,15:59:35:15566
;VCDS Version: Release 25.3.1 (x64) Data version: 20250408 DS365.0
;VCID: 5EEEF372B0B4591ADD7-800A
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),||WVWZZZAWZKY166981|,
IDE00019,Voltage terminal 30,14.100, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,17, °C
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),18.4, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,13.3, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00145,Clutch status,closed,
IDE00151,Oil fill level,69, mm
IDE00155,Ignition timing angle retard cylinder 1,0.00, °
IDE00156,Ignition timing angle retard cylinder 2,0.00, °
IDE00157,Ignition timing angle retard cylinder 3,0.00, °
IDE00167,Exhaust temperature 1 bank 1,346.0, °C
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,0.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,0.0, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-1.1, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.0, °
IDE00186,Fuel low pressure: actual value,6.133, bar
IDE00187,Coolant temperature at engine start,0.0, °C
IDE00189,Activation of fuel pump electronics,14.99, %
IDE00193,Coolant temperature at engine outlet: specified value,105.0, °C
IDE00196,Engine oil temperature,17.1, °C
IDE00202,Low fuel pressure: specified value,6.250, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,8, l
IDE00348,Intake air temperature,17, °C
IDE00349,Throttle valve position: normed,9.8, %
IDE00350,Air mass: specified value,0, kg/h
IDE00355,Cruise Control System (CCS): status,passive,
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,0.00, %
IDE00381,Coolant fan 2: activation,0.00, %
IDE00392,Accelerator pedal: sensor voltage 1,0.683, V
IDE00393,Accelerator pedal: sensor voltage 2,0.693, V
IDE00404,Throttle valve: activation,50.00, %
IDE00405,Crankshaft speed (RPM),0, /min
IDE00406,Camshaft RPM,0, /min
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416-MAS07386,Starter control: terminal 50 feedback-Terminal 50 on CAN,not active,
IDE00416-MAS09390,Starter control: terminal 50 feedback-Terminal 50 CAN valid,not active,
IDE00416-MAS09391,Starter control: terminal 50 feedback-Terminal 50 via cable,not active,
IDE00416-MAS09392,Starter control: terminal 50 feedback-Starter relay,not active,
IDE00416-MAS09394,Starter control: terminal 50 feedback-Starter operation read back wire T50Ret,not active,
IDE00416,Starter control: terminal 50 feedback,0,
IDE00417-MAS00077,Starter control: shut-off conditions 1-Immobilizer,not active,
IDE00417-MAS00357,Starter control: shut-off conditions 1-Starter shift malfunction,not active,
IDE00417-MAS01456,Starter control: shut-off conditions 1-Speed,not active,
IDE00417-MAS05133,Starter control: shut-off conditions 1-Drivetrain,not active,
IDE00417-MAS06857,Starter control: shut-off conditions 1-Speed,active,
IDE00417-MAS09395,Starter control: shut-off conditions 1-RPM aborted starts,not active,
IDE00417-MAS09396,Starter control: shut-off conditions 1-Engag. duration,not active,
IDE00417-MAS09397,Starter control: shut-off conditions 1-Engag. duration aborted starts,not active,
IDE00417-MAS09398,Starter control: shut-off conditions 1-Engag. duration panic start,not active,
IDE00417-MAS09399,Starter control: shut-off conditions 1-new errors,not active,
IDE00417-MAS09400,Starter control: shut-off conditions 1-manual start/error,not active,
IDE00417-MAS09401,Starter control: shut-off conditions 1-ignition,not active,
IDE00417-MAS09402,Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction,not active,
IDE00417-MAS09403,Starter control: shut-off conditions 1-Direct start function,not active,
IDE00417-MAS09404,Starter control: shut-off conditions 1-Engag. duration defrost.,not active,
IDE00417,Starter control: shut-off conditions 1,256,
IDE00451,Currently running routine,Unknown (0)
IDE00474,Ambient air pressure,100, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00556,Outside temperature,15, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.000 Lambda / 0.000 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.000, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,0.0, %
IDE00582,Specified value of equivalence ratio,0.999, Lambda
IDE00583,Throttle valve specified value,0.0, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00588,Fuel tank fill level,17.6, %
IDE00590,Terminal 87 status,On,
IDE00592,Status of oxygen sensor control,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
IDE00594,Absolute intake pressure,100, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00973,Outside temperature,15.0, °C
IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
IDE01405-MAS05513,Starter activation: status-Bit 0,OK,
IDE01405-MAS05514,Starter activation: status-Bit 1,Before starter activation,
IDE01405-MAS05515,Starter activation: status-Bit 2,Before starter activation,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.003, V
IDE01649,Throttle valve position 1,0.922, V
IDE01650,Throttle valve position 2,18, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,0, %
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,active,
IDE01834,Battery voltage,14.100, V
IDE01869,Long-term fuel trim bank 1 at idle,100.00, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test not started,
IDE01876,Adaptation of loss torque,-12.8, Nm
IDE01878,Adaptation of throttle valve,Adaptation and testing of emergency operating position,
IDE01880,Accelerator pedal position 2,13.7, %
IDE01884,Camshaft adjustment intake bank 1: activation,0.00, %
IDE01893,Fuel pump: specified value,14.99, %
IDE01898,Load value: specified value,9.52, %
IDE01901,Lost torque adaptation: idle,12.8, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01911,Leakage air,0, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,124004, km
IDE02116,Exhaust gas temperature before catalytic converter,-40.0, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02742,Oil pressure actual value,0.999, bar
IDE02756,Number of manual engine starts,0,
IDE02757,Number of automatic engine starts,2617,
IDE03008-ENG118016,Stop process prevented-StartStopProhibitionReason_1,On,
IDE03008-ENG249273,Stop process prevented-StartStopProhibitionReason_10,OFF,
IDE03008-ENG249274,Stop process prevented-StartStopProhibitionReason_11,OFF,
IDE03008-ENG249275,Stop process prevented-StartStopProhibitionReason_12,OFF,
IDE03008-ENG249276,Stop process prevented-StartStopProhibitionReason_13,OFF,
IDE03008-ENG249277,Stop process prevented-StartStopProhibitionReason_14,OFF,
IDE03008-ENG249278,Stop process prevented-StartStopProhibitionReason_15,OFF,
IDE03008-ENG249279,Stop process prevented-StartStopProhibitionReason_16,OFF,
IDE03008-ENG118017,Stop process prevented-StartStopProhibitionReason_2,OFF,
IDE03008-ENG118018,Stop process prevented-StartStopProhibitionReason_3,OFF,
IDE03008-ENG118019,Stop process prevented-StartStopProhibitionReason_4,OFF,
IDE03008-ENG118020,Stop process prevented-StartStopProhibitionReason_5,On,
IDE03008-ENG249269,Stop process prevented-StartStopProhibitionReason_6,OFF,
IDE03008-ENG249270,Stop process prevented-StartStopProhibitionReason_7,OFF,
IDE03008-ENG249271,Stop process prevented-StartStopProhibitionReason_8,OFF,
IDE03008-ENG249272,Stop process prevented-StartStopProhibitionReason_9,OFF,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,0,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03235,Neutral position sensor: current transmission angle,-1.12, °
IDE03236,Neutral position sensor: adapted transmission angle,-1.12, °
IDE03246,Neutral position sensor: upper adaptation value,2.562, V
IDE03247,Neutral position sensor: lower adaptation value,1.195, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.502, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.501, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.947, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.052, V
IDE03361,Driver intention torque,30.0, Nm
IDE03375,Adaptation status of neutral position sensor,62,
IDE03585,System status for the start/stop function master,active: stop releases participant present,
IDE03587-ENG118093,Stopping requirements for active participants-Active_Member_1,OFF,
IDE03587-ENG118102,Stopping requirements for active participants-Active_Member_10,OFF,
IDE03587-ENG118103,Stopping requirements for active participants-Active_Member_11,OFF,
IDE03587-ENG118104,Stopping requirements for active participants-Active_Member_12,OFF,
IDE03587-ENG118105,Stopping requirements for active participants-Active_Member_13,OFF,
IDE03587-ENG118106,Stopping requirements for active participants-Active_Member_14,OFF,
IDE03587-ENG118107,Stopping requirements for active participants-Active_Member_15,OFF,
IDE03587-ENG118108,Stopping requirements for active participants-Active_Member_16,OFF,
IDE03587-ENG118094,Stopping requirements for active participants-Active_Member_2,On,
IDE03587-ENG118095,Stopping requirements for active participants-Active_Member_3,OFF,
IDE03587-ENG118096,Stopping requirements for active participants-Active_Member_4,OFF,
IDE03587-ENG118097,Stopping requirements for active participants-Active_Member_5,OFF,
IDE03587-ENG118098,Stopping requirements for active participants-Active_Member_6,OFF,
IDE03587-ENG118099,Stopping requirements for active participants-Active_Member_7,OFF,
IDE03587-ENG118100,Stopping requirements for active participants-Active_Member_8,OFF,
IDE03587-ENG118101,Stopping requirements for active participants-Active_Member_9,OFF,
IDE03588-ENG118093,System malfunctions for active participants start/stop-Active_Member_1,OFF,
IDE03588-ENG118102,System malfunctions for active participants start/stop-Active_Member_10,OFF,
IDE03588-ENG118103,System malfunctions for active participants start/stop-Active_Member_11,OFF,
IDE03588-ENG118104,System malfunctions for active participants start/stop-Active_Member_12,OFF,
IDE03588-ENG118105,System malfunctions for active participants start/stop-Active_Member_13,OFF,
IDE03588-ENG118106,System malfunctions for active participants start/stop-Active_Member_14,OFF,
IDE03588-ENG118107,System malfunctions for active participants start/stop-Active_Member_15,OFF,
IDE03588-ENG118108,System malfunctions for active participants start/stop-Active_Member_16,OFF,
IDE03588-ENG118094,System malfunctions for active participants start/stop-Active_Member_2,OFF,
IDE03588-ENG118095,System malfunctions for active participants start/stop-Active_Member_3,OFF,
IDE03588-ENG118096,System malfunctions for active participants start/stop-Active_Member_4,OFF,
IDE03588-ENG118097,System malfunctions for active participants start/stop-Active_Member_5,OFF,
IDE03588-ENG118098,System malfunctions for active participants start/stop-Active_Member_6,OFF,
IDE03588-ENG118099,System malfunctions for active participants start/stop-Active_Member_7,OFF,
IDE03588-ENG118100,System malfunctions for active participants start/stop-Active_Member_8,OFF,
IDE03588-ENG118101,System malfunctions for active participants start/stop-Active_Member_9,OFF,
IDE03589-ENG118109,Error status for start-stop related sensors-Sensor_1,On,
IDE03589-ENG118110,Error status for start-stop related sensors-Sensor_2,On,
IDE03589-ENG118111,Error status for start-stop related sensors-Sensor_3,On,
IDE03589-ENG118112,Error status for start-stop related sensors-Sensor_4,OFF,
IDE03589-ENG118113,Error status for start-stop related sensors-Sensor_5,OFF,
IDE03589-ENG118114,Error status for start-stop related sensors-Sensor_6,OFF,
IDE03589-ENG118115,Error status for start-stop related sensors-Sensor_7,OFF,
IDE03589-ENG118116,Error status for start-stop related sensors-Sensor_8,OFF,
IDE03711,Mass flow through throttle valve,0, kg/h
IDE03767,Engine status,Stop,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.00, %
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,0, Ohm
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,65535, Ohm
IDE03953,Oxygen control: adaptation value at partial load: bank 1,100.00, %
IDE03957,Throttle valve angle: specified value,2.0, °
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:610/--- kPa,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04404,Reduced throttle valve surface active total correction,0.00, %
IDE04409,Intake manifold pressure: corrected,1.003, bar
IDE04410,Intake manifold pressure: specified value,0.094, bar
IDE04414,Cat conv temp: modeled,346.0, °C
IDE04615,Segment adaptation for rough running: status,not completed successfully,
IDE04616,Segment adaptation for rough running: limit value correction,0, µs
IDE04637,Engine temperature control actuator,0.43, %
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,1,
IDE04858,Brake booster low pressure actual value,604.0, hPa
IDE04937,Sensor for engine block temperature: raw value,18.3, °C
IDE05138,Shut-off timer: last engine shut-off time,31, s
IDE05139,Shut-off timer: last ECM after-run time,15464, s
IDE05259,Gear position sensor: raw value,37.00, %
IDE05438,Rear cat conv temp main cat conv model value,53.0, °C
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00000,
IDE05470,Cat converter oxygen storage capacity,0.00, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0.00000,
IDE06006,Idle speed specified value,1159, /min
IDE06049,Pressure in brake booster: raw value,0.0, hPa
IDE06099,Number of cylinder 1 misfires in drive cycle,0,
IDE06100,Number of cylinder 2 misfires in drive cycle,0,
IDE06101,Number of cylinder 3 misfires in drive cycle,0,
IDE06158,Coolant temperature longterm model value,17.00, °C
IDE06159,Coolant temperature model value,18.00, °C
IDE06195,Knock sensor: cylinder 1: voltage,0.000, V
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06443,Oper. readiness status oxyg. sensor bank 1 before cat. conv.,not active,
IDE06567,Frequency counter deactivate start/stop function,0,
IDE06568,Stop prevention by driver frequency counter,0,
IDE06569,Frequency counter vehicle standstill,0,
IDE06610,Frequency counter vehicle standstill with stop,0,
IDE06707,CCS Switch,Limiter only operating unit,
IDE06710,Cruise control system: permanent deactivation,Implausible control switch signals,
IDE06758,Air mass since engine start,0.00, g
IDE07018,Catalytic converter damaging misfires intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,0, J
IDE07051,Engaged gear: raw signal,0,
IDE07164,Number injections,0,
IDE07376,Intake manifold pressure: act. value calculated,1.003, bar
IDE07475,Throttle valve position 2,4.082, V
IDE07543,Vehicle speed,0.00, km/h
IDE07548,Engine temp. mangmt. actuator: specified value of angle,0.00, °
IDE07550,Engine temp. management actuator: raw value,132,
IDE07554,Engine temperature management actuator: stop open,910,
IDE07571,Engine torque,-12.8, Nm
IDE07575,Driver intention torque,-12.8, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07605,Cruise control system: temporary deactivation,ESP/ASR set to passive during ACC without brake intervention,
IDE07608,Standard test of current section,0,
IDE07725,Coolant temperature sensor 1: B1: on cylinder head: raw value,17.0, °C
IDE07726,Coolant temperature sensor 1: B1: on cylinder head: raw voltage,3.652, V
IDE07768,Throttle valve adapter 1 bank 1: activation,0.00, %
IDE07769,Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage,0.922, V
IDE07770,Throttl.valve adapt. 1 bank 1: posit feedback - Specified value,1.66, %
IDE07771,Throttl.valve adapt. 1 bank 1: posit feedback - Actual value,10.00, %
IDE07772,Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed,0.00, %
IDE07832,Coolant fan 1: activation,0.00, %
IDE07833,Coolant fan 2: activation,0.00, %
IDE07834-MAS09443,Status of starter activation relay-Relay 1 activated,not active,
IDE07834-MAS09444,Status of starter activation relay-Relay 2 activated,not active,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07928,Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated,-40.0, °C
IDE08729,Oxygen sensor bank 1 sensor 2: checking response time,Test off,
IDE08877,Protocol Identification,ISO 27145-4,
IDE09879,O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current,0.000, A
IDE09983,Torque limitation due to high intake air temperature,-12.80, %
IDE09984,Torque limit due to knock regulation,0.00, %
IDE09985,Overall torque limit,-12.80, %
IDE09990,Amount of fuel in engine oil,0, g
IDE10043,intake camshaft bank 1 status adaption,Not adapted,
IDE10049,Ignition angle cyl. 1,0.0, °
IDE10050,Ignition angle cyl. 2,0.0, °
IDE10051,Ignition angle cyl. 3,0.0, °
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,0.00, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,0, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,0, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,OFF,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,OFF,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.00, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,OFF,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,OFF,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.00, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,OFF,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,OFF,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.00, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,OFF,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,OFF,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.00, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,OFF,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,OFF,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.00, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,OFF,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,OFF,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.00, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,OFF,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,OFF,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.00, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,OFF,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,OFF,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.00, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,OFF,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,OFF,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.00, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,OFF,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,OFF,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10302,Time since engine start,0, s
IDE10580,Engine oil level: test method 1,98.00, %
IDE10581,Engine oil level: test method 2,111.00, %
IDE10582,Engine oil level: test method 3,0.00, %
IDE10732,Engine oil level: factor volume,1.00,
IDE10848,Accelerator pedal position,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11203,Oil pressure setpoint,0.000, bar
IDE11267,Oil level: max. value: relative,0.00, %
IDE11268,Oil level: min. value: relative,-0.10, %
IDE11302-MAS05513,Engine oil level: test method 1 qualification-Bit 0,8,
IDE11302,Engine oil level: test method 1 qualification,Current mean value,
IDE11303-MAS05513,Engine oil level: test method 3 qualification-Bit 0,0,
IDE11303,Engine oil level: test method 3 qualification,Malfunction,
IDE11326,Manifold press. sensor: signal quality,0.00, %
IDE11328,Oil press. sensor: signal quality,0.00, %
IDE11330,Oil press. control valve: activation pulse duty factor,72.31, %
IDE11356,O2 sensor resistance: plausibility,0,
IDE11519,Number of deicing trials of the starter,0,
IDE11594,Oxygen sensor 1 bank 1: raw value,1.000, counts
IDE11596,Oxygen sensor 1 bank 1: reference value,1.000, counts
IDE12131,Status of knock sensor diagnostic,not checked,
IDE12131,Status of knock sensor diagnostic,0,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
IDE12468,Login counter of the simulation interface,0,
IDE14488-ENG161258,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiDay_Stop,0,
IDE14488-ENG161259,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiDay_Strt,0,
IDE14488-ENG161260,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiDurExtSti,0, s
IDE14488-ENG161261,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiHour_Stop,0,
IDE14488-ENG161262,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiHour_Strt,0,
IDE14488-ENG161263,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiMinute_Stop,0,
IDE14488-ENG161264,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiMinute_Strt,0,
IDE14488-ENG161265,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiMonth_Stop,0,
IDE14488-ENG161266,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiMonth_Strt,0,
IDE14488-ENG161267,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiScnd_Stop,0,
IDE14488-ENG161268,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiScnd_Strt,0,
IDE14488-ENG161269,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiYear_Stop,2000,
IDE14488-ENG161270,Stimulation interface historical data-BasSvrAppl_StTExtSti_tiYear_Strt,2000,
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,0, no unit
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,0, no unit
ENG101413,Calibration Identification,||05C034 9605BEAD|,
ENG99697,Calibration Verification Numbers,||D0 57 4E 2D|,
ENG100152,ECUNAME,|ECU,ECUNAME|ECM
ENG100634-ENG299122,In-use Performance Tracking: 16 or 20 counters-Counters 3-EOP,|Completion Condition Counts,Conditions Encountered Counts|1144
ENG100634-ENG102823,In-use Performance Tracking: 16 or 20 counters-Ignition Cycle Counter,0, counts
ENG100634-ENG99988,In-use Performance Tracking: 16 or 20 counters-OBD Monitoring Conditions Encountered Counts,0, counts
ENG100634-ENG250449,In-use Performance Tracking: 16 or 20 counters-Raw Data,00,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
Elapsed Time: 00:27
;SW:2Q0-614-517-AG HW:2Q0-614-517-N --- ABS Brakes
;Component:ESC_base_vFGS H23 0242, Coding:09034A64154790B35205A81E24DB42A649124526114A245844541254452442659248A2648852241A222A482AA249D6433D926BC2BC
;EV_Brake1BOSCHESPMQBA0,004036,EV_Brake1BOSCHESPMQBA0_004_VW27.rod
;Monday,21,April,2025,16:00:10:15566
;VCID: 73B8B2C62B36E472829-8026
IDE00609-ENG103365,Communication status of data bus 1-CAN Communication Status,|Control module,Communication status|Engine Electronics
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0.00, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,No,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,Not available due to specific system,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,Not operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,AW66981,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.000, m/s²
IDE02486,Data logger triggering,not initialized,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03009-MAS01299,Start process requested-Offroad,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,1,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,2,
IDE03011-MAS01299,Number of requested start processes-Offroad,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2020,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,8,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,24,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,29,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,9,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,23,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,12,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,10,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,35,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,35,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,20,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,11,
IDE03127,Prevented stop processes (ring memory),Unknown (255)
IDE03127,Prevented stop processes (ring memory),Inclination limit,
IDE03127,Prevented stop processes (ring memory),Emerg.brake,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128,Requested start processes (ring memory),Unknown (255)
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,All releases are present,
IDE03527-IDE02070,CAN signals-Wake-up cause,0,
IDE03527-IDE02445,CAN signals-Transmission type,15,
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.0, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,Not available due to specific system,
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.30, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,14.20, V
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,0.60, bar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.18, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,0.30, V
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,0,
IDE04425-IDE04436,Left front ABS wheel speed sensor-Minimum division value,0.00, ms
IDE04425-IDE04437,Left front ABS wheel speed sensor-Maximum division value,0.00, ms
IDE04425-IDE04438,Left front ABS wheel speed sensor-Average division value,0.00, ms
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,0,
IDE04426-IDE04436,Right front ABS wheel speed sensor-Minimum division value,0.00, ms
IDE04426-IDE04437,Right front ABS wheel speed sensor-Maximum division value,0.00, ms
IDE04426-IDE04438,Right front ABS wheel speed sensor-Average division value,0.00, ms
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-IDE04436,Left rear ABS wheel speed sensor-Minimum division value,0.00, ms
IDE04427-IDE04437,Left rear ABS wheel speed sensor-Maximum division value,0.00, ms
IDE04427-IDE04438,Left rear ABS wheel speed sensor-Average division value,0.00, ms
IDE04427-IDE04440,Left rear ABS wheel speed sensor-Validity of direction of rotation,valid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,Reverse,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,1,
IDE04428-IDE04436,Right rear ABS wheel speed sensor-Minimum division value,0.00, ms
IDE04428-IDE04437,Right rear ABS wheel speed sensor-Maximum division value,0.00, ms
IDE04428-IDE04438,Right rear ABS wheel speed sensor-Average division value,0.00, ms
IDE04428-IDE04441,Right rear ABS wheel speed sensor-Validity of gap information,valid,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04442-IDE00010,Vacuum sensor-Serial number,00 05 4A CF A7,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Available,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,5,
IDE04442,Vacuum sensor,604, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,3,
IDE04442-MAS13477,Vacuum sensor-Manufacturing date: year,2007,
IDE04442-MAS16551,Vacuum sensor-Production date: calendar week,19,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.128, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.000, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.098, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.000, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,85.969, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,87.981, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,123986, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,13.00.10.01,
IDE04461-MAS04484,Internal measured values-Flashloader version,0009,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,604, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.18, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE03735,Counter steer support-Steering torque,0.000, Nm
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,119929, km
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,Available,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,252,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,252,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,252,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,252,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,122920.0, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,124004.0, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,100868.0, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,89460.0, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,69356.0, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,124004.0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,124004.0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,124004.0, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE04939-MAS14291,Tire Pressure Monitoring System (TPMS)-Analysis data of the current condition,03 00 20 03 00 C2 02 40 00 00,
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,10 55 00 28 02 00 A8 22 0F 07,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,0F 50 25 01 00 C1 02 40 00 00,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,0A 50 15 01 00 00 02 40 00 00,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,00 00 00 02 00 00 00 10 00 00,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,00 02 80 05 00 00 00 10 03 02,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,00 02 80 05 00 00 00 10 03 02,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,0F 00 20 03 00 C2 02 40 03 02,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,00 02 80 05 00 00 00 10 03 02,
IDE07015-MAS00106,Date functional event memory erase-Year,2025,
IDE07015-MAS00107,Date functional event memory erase-Month,1,
IDE07015-MAS00108,Date functional event memory erase-Day,22,
IDE07015-MAS00109,Date functional event memory erase-Hours,0,
IDE07015-MAS00110,Date functional event memory erase-Minutes,44,
IDE07015-MAS00111,Date functional event memory erase-Seconds,59,
IDE07159-MAS01155,Control module switch-off: counter-Control module,00,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,00,
IDE13239-IDE04947,Wheel loose detection-Odometer reading of last warning,0, km
IDE13239-MAS00106,Wheel loose detection-Year,2000,
IDE13239-MAS00107,Wheel loose detection-Month,0,
IDE13239-MAS00108,Wheel loose detection-Day,0,
IDE13239-MAS00109,Wheel loose detection-Hours,0,
IDE13239-MAS00110,Wheel loose detection-Minutes,0,
IDE13239-MAS00111,Wheel loose detection-Seconds,0,
IDE13239-MAS04541,Wheel loose detection-Odometer reading of next-to-last warning,0, km
IDE13239-MAS04542,Wheel loose detection-Odometer reading of third-to-last warning,0, km
IDE13239-MAS16487,Wheel loose detection-Wheels affected by the latest warning,no warning,
IDE13239-MAS16489,Wheel loose detection-Wheels affected by the penultimate warning,no warning,
IDE13239-MAS16491,Wheel loose detection-Wheels affected by the third last warning,no warning,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,20.00, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,20.00, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,20.00, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,20.00, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Not available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Not available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Not available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Not available,
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,Not available due to specific system,
MAS06948,Brake bleeding and replacement check hydraulic connections,Stop requested,
MAS11603-MAS01853,Wheel speed step sensor counter-Left front,0,
MAS11603-MAS01854,Wheel speed step sensor counter-Right front,0,
MAS11603-MAS01855,Wheel speed step sensor counter-Left rear,125,
MAS11603-MAS01856,Wheel speed step sensor counter-Right rear,0,
ENG157834,Entwicklerfunktion_4,6,
Elapsed Time: 00:10
;SW:2G1-820-045-F HW:2G1-820-045-F --- Auto HVAC
;Component:SG_AC_Manuell H50 0301, Coding:012000000800010011000400020000000000000000000000000000000000
;EV_ACManuePrehMQBA0,001011,EV_ACManuePrehMQBA0.rod
;Monday,21,April,2025,16:00:36:15566
;VCID: 23188286DB5634F2B29-8076
IDE00019,Voltage terminal 30,14.4, V
IDE00198,Refrigerant pressure,5.8, bar
IDE00323,Security Access: Number of invalid keys,1,
IDE00767,No. of unscheduled ECU resets,22,
IDE00965,Compressor shut-off condition,Shut-off of engine control module via CAN (T > 15 sec.),
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,0, /min
IDE00969,Compressor load,0.6, Nm
IDE00970,Coolant fan activation: actual value,0.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00974,Outside air temperature internally calculated,15.0, °C
IDE00982,Temperature downstream of evaporator,16.6, °C
IDE00987,Blower voltage: specified value,0.0, V
IDE00989,Blower status,not active,
IDE00992,Recirculation flap specified value,Fresh air,
IDE01063,Status of recirculation air,Fresh air,
IDE01076,Time since ignition off,Measuring value not available,
IDE01268,Windshield wiper,OFF,
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,5935,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,6518,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off of engine control module via CAN (T > 15 sec.),
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01442-MAS01533,Pressing a button-Defrost,operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01564,Pressing a button-Windshield defogger,Not operated,
IDE01442-MAS01577,Pressing a button-Parking heater,Not operated,
IDE01442-MAS05214,Pressing a button-Steering wheel heating,Not operated,
IDE01714,Status reverse gear,not selected,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,5,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,63,
IDE03011-MAS01517,Number of requested start processes-Defrost active,1,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,22,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2024,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,7,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,18,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,58,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,49,
IDE03127,Prevented stop processes (ring memory),max A/C,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2023,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,8,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,20,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,14,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,59,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,54,
IDE03128,Requested start processes (ring memory),max A/C,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,208, s
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,100,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12499-MAS15804,A/C compressor initial running in: start prevention-Fresh air blower off,not active,
IDE12500-IDE00020,A/C compressor initial running in: interruption conditions-Terminal 15 status,not active,
IDE12500-IDE00973,A/C compressor initial running in: interruption conditions-Outside temperature,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS09197,heater,On,
MAS09219,Terminal X,On,
Elapsed Time: 00:06
;SW:2Q0-937-085-A HW:2Q0-937-085 --- Cent. Elect.
;Component:BCM A0 Std H98 0926, Coding:
;EV_BCMA0,204001,EV_BCMA0_204_VW27.rod
;Monday,21,April,2025,16:01:03:15566
;VCDS Version: Release 25.3.1 (x64) Data version: 20250408 DS365.0
;VCID: 343A71DA6EB8A34A5B3-8060
Group,Description,Actual
IDE00329-MAS00232,Buttons for multi-function display-MFI button UP,Not operated,
IDE00329-MAS00233,Buttons for multi-function display-MFI button DOWN,Not operated,
IDE00329-MAS00234,Buttons for multi-function display-MFI button RESET / OK,Not operated,
IDE00329-MAS00236,Buttons for multi-function display-MFI buttons: number 3/4,3,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Speed limiter,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,4 Position operating unit,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,Not operated,
IDE00356-ENG180575,Cruise Control System (CCS): switch position-cc_fas_button,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,Open,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE01985-MAS06855,FAZIT identification test sum-Test sum,2C 61 AA D6,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded/not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,not coded/not installed,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,143,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,143,
IDE02266,Passenger side rear power window button,Not operated,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,143,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,144,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded/not installed,
IDE02515,Low beam,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,not coded/not installed,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,not active,
IDE02588-ENG130241,Terminal signals and start release-Terminal_75_relais,active,
IDE02614-MAS02788,Reversing light switch-CAN,not coded/not installed,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02694-MAS01288,Signal horn activation-Horn,Not operated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Not operated,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 1,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,not coded/not installed,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,not coded/not installed,
IDE02711,Rear wiper,not coded/not installed,
IDE02743,High Beam,|Connector number,Connector terminal number
IDE02745-MAS08202,Ignition Switch Key Lock Solenoid-CAN p locked,Malfunction,
IDE02745-MAS08203,Ignition Switch Key Lock Solenoid-CAN p locked: qualified,not coded/not installed,
IDE02745-MAS08204,Ignition Switch Key Lock Solenoid-Hardware input: p_verriegelt,not coded/not installed,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,not coded/not installed,
IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,0,
IDE02857-ENG128454,Activation current-Cockpittaster_1,0,
IDE02857-ENG128455,Activation current-Cockpittaster_2,0,
IDE02857-ENG128456,Activation current-Cockpittaster_3,0,
IDE02857-ENG128457,Activation current-Cockpittaster_4,0,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0,
IDE02857-ENG162896,Activation current-Hec,65533,
IDE02857-ENG159621,Activation current-Interior_Monitoring_Deactivation_Button,65533,
IDE02857-ENG126436,Activation current-signal_horn,65533,
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,|Connector number,Connector terminal number
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,not coded/not installed,
IDE03388-MAS02201,Left front heated seat: status-Temperature,252,
IDE03388-ENG160972,Left front heated seat: status-Energymanagement_Seat_Heating,OFF,
IDE03388-ENG163427,Left front heated seat: status-PWM_output,0,
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,not coded/not installed,
IDE03389-MAS02201,Right front heated seat: status-Temperature,252,
IDE03389-ENG160972,Right front heated seat: status-Energymanagement_Seat_Heating,OFF,
IDE03389-ENG163427,Right front heated seat: status-PWM_output,0,
IDE03638,Stationary cornering lamp,|Connector number,Connector terminal number
IDE04213,Central locking button,Not operated,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,OFF,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,not installed,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04254-MAS00222,Play protection for central locking-Rear lid,0,
IDE04254-MAS02444,Play protection for central locking-Central locking,0,
IDE04347-IDE00104,Expanded freeze frame conditions-DTC,09 04 05,
IDE04347-IDE07836,Expanded freeze frame conditions-Log data,00 0A 00 32 0D 0D 0D 0D 00 00 00 00 00 00 00 00 02 00 00 1D 00 01 00 00 0D 86 00 00 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 0A 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 08 00 00 00 00 10 10 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 26 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04411,Child safety button,Not operated,
IDE04925,Daytime running lights,|Connector number,Connector terminal number
IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,not active,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,16.0, %
IDE05045-IDE05183,Front wiper module-Malfunction left,not coded/not installed,
IDE05045-IDE05184,Front wiper module-Malfunction right,not coded/not installed,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS02506,Front wiper module-Wiper active,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,0,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02339,Window washer system-Windshield washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not coded/not installed,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded/not installed,
IDE05742-IDE07956,Light switch position-redundant signal line,not coded/not installed,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,Not operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Year
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not coded/not installed,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05834-MAS09607,Driver info-Switch p locked,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,14,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,14,
IDE05836-MAS04806,Rain recognition sensor-Splash,not coded/not installed,
IDE05836-MAS04807,Rain recognition sensor-park position,not coded/not installed,
IDE05838-MAS01632,Light recognition sensor-Status,Lights OFF,
IDE05838-MAS02851,Light recognition sensor-Brightness,0, lx
IDE05838-MAS04121,Light recognition sensor-Voltage,4.3, V
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,Additional information
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,|Connector number,clamp
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,0,
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,0,
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,0,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,0,
IDE06096-IDE03111,Interior lights-Interior lighting,100, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,0.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,10.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,81.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06096-ENG127073,Interior lights-light_sensor_supply,active,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.0, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,No,
IDE06206-MAS03548,Front window regulator status: driver side-Motor current,215, A
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle condition,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.0, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,215, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,not active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.0, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,No,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,215, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,not active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Idle condition,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0,
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,255,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-IDE02322,Button in center console-Parking aid indicator light,not coded/not installed,
IDE06507-IDE04806,Button in center console-Driving profile selection button,not coded/not installed,
IDE06507-IDE05532,Button in center console-Indicator light in button for start/stop mode,OFF,
IDE06507-IDE05572,Button in center console-Button for start-stop operation,Not operated,
IDE06507-IDE05575,Button in center console-Indicator lamp in the driving profile selection button,not coded/not installed,
IDE06507-ENG159821,Button in center console-Button 4,not coded/not installed,
IDE06507-ENG160971,Button in center console-Wind_shield_heating_,not coded/not installed,
IDE06507-ENG127076,Button in center console-Wind_shield_heating_button,not coded/not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving
IDE06864,Daytime running lights,|Connector number,Connector terminal number
IDE06872,Front passenger power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,BA09,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,BA09,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,0.0, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,0.0, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,0.0, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,0.0, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,0.0, %
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,53.0, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,0.0, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,0.0, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,0.0, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,0.0, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,25.0, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,26.0, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,45.5, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.5, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,09,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not coded/not installed,
IDE07344-IDE03114,Sunroof shade-Comfort function,not coded/not installed,
IDE07344-MAS01979,Sunroof shade-Adapting,not coded/not installed,
IDE07344-MAS02282,Sunroof shade-Position,254,
IDE07344-MAS02447,Sunroof shade-Release,not coded/not installed,
IDE07344-MAS03656,Sunroof shade-Reverse,not coded/not installed,
IDE07344-MAS05563,Sunroof shade-Norming,not coded/not installed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,not coded/not installed,
IDE07345,Sunroof front closed position switch,not coded/not installed,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,not coded/not installed,
IDE07346,Sunroof shade switches,not coded/not installed,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,205, °C
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,205, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,205, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,205, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.0, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,0.0, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,0.0, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,0.0, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,0.0, %
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,Open,
IDE08162-MAS06432,TSG driver side: signals for central locking-Button for interior lock,not coded/not installed,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Open contact switch in locking cylinder,Not available,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Button for interior lock,not coded/not installed,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,not coded/not installed,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,not coded/not installed,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09895,Central locking-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08260-MAS01159,Ident. of front window regulator programming: driver side-Version number,BA12,
IDE08261-MAS01159,Ident. of front window regulator programming: frt. pass. side-Version number,BA12,
IDE08343,Immobilizer Challenge,85 27 DB 0B,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,357, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,329, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,No malfunction,
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,No malfunction,
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,No malfunction,
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,No malfunction,
IDE09058-IDE02744,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-IDE04216,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01563,Energy management: consumer releases-Auxiliary Air Heater,No enabling,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,No enabling,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09062-MAS06555,Counter: energy management-Maximum switch-off priority while driving,0,
IDE09062-MAS06558,Counter: energy management-Current negative charge balance,0, %
IDE09062-MAS08248,Counter: energy management-Shutdown counter,47,
IDE09062-MAS08249,Counter: energy management-Emergency shutdown counter,0,
IDE09062-MAS08250,Counter: energy management-Short trip operation counter,4,
IDE10285-MAS02447,Release of rear lid exterior button-Release,Enabled,
IDE10421,Terminal 58xd dimmer: drvr. side,0,
IDE10422,Dimming of inside door handle lighting: drvr. side,255,
IDE10423,Dimming for interior ambient lighting: drvr. side,255,
IDE10425,Ambient illumination: driver side,255,
IDE10426,Inside door handle switch: drvr. side,not installed,
IDE10429,Mirror adjustment (X/Y direction): drvr. side,not installed,
IDE10430,Mirror fold-in activation: drvr. side,not installed,
IDE10431,Play protection: mirror fold-in: drvr. side,not active,
IDE10432,Mirror fold-in: current consumption: drvr. side,255,
IDE10434,Terminal 58xd dimmer: frt. pass. side,255,
IDE10435,Dimming of inside door handle lighting: frt. pass. side,255,
IDE10436,Dimming for interior ambient lighting: frt. pass. side,255,
IDE10438,Ambient illumination: frt. pass. side,255,
IDE10439,Inside door handle switch: frt. pass. side,not installed,
IDE10440,Switch for outside door handle: frt. pass. side,not installed,
IDE10442,Mirror adjustment (X/Y direction): frt. pass. side,not installed,
IDE10443,Mirror fold-in activation: frt. pass. side,not installed,
IDE10444,Play protection: mirror fold-in: frt. pass. side,not active,
IDE10445,Mirror fold-in: current consumption: frt. pass. side,255,
IDE10446-MAS01634,Mirror memory: frt. pass. side-Supply voltage,not active,
IDE10446-MAS02228,Mirror memory: frt. pass. side-X coordinate,255,
IDE10446-MAS02229,Mirror memory: frt. pass. side-Y coordinate,255,
IDE10446-MAS02476,Mirror memory: frt. pass. side-installed,not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,installed_not_active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,installed_not_active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,installed_not_active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,installed_not_active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,installed_not_active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,installed_not_active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not_installed_not_active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,installed_not_active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,installed_not_active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,installed_not_active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,installed_not_active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,installed_not_active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,installed_not_active,
IDE11134-MAS11025,Light sequence HU test result-Status,ohne Einschraenkungen,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,65534,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,65534,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12346,Coding incorrect,|Record Data Identifier,Byte position
IDE12466,Unlocking central locking system history data,|Control-section / cause,Key number
IDE12767-IDE04447,Emergency switch off by knockout counter-Function status,not active,
IDE12767-MAS03129,Emergency switch off by knockout counter-Reset counter,0,
IDE12941-MAS15416,Radio key: field strength-Field strength: UHF,0,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.45, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.45, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.40, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.40, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,14.35, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00043-ENG127078,Terminal 30 power supply-KL30 Außenspiegelheizung,14.35, V
MAS00043-ENG127080,Terminal 30 power supply-KL30 Frontwischer,14.30, V
MAS00043-ENG127079,Terminal 30 power supply-KL30 Heckscheibenheizung,14.30, V
MAS00043-ENG127077,Terminal 30 power supply-KL30 Signalhorn,14.35, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,Not operated,
MAS00829-MAS00244,Access/start authorization-Prompt wire,not coded/not installed,
MAS00829-MAS01763,Access/start authorization-Signal Strength,0, T
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,0, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06361,Vehicle key with remote control-fixed code,Not available,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not coded/not installed,
MAS01597-IDE03114,Sunroof-Comfort function,not coded/not installed,
MAS01597-MAS01979,Sunroof-Adapting,not coded/not installed,
MAS01597-MAS02282,Sunroof-Position,254,
MAS01597-MAS02447,Sunroof-Release,not coded/not installed,
MAS01597-MAS03656,Sunroof-Reverse,not coded/not installed,
MAS01597-MAS05563,Sunroof-Norming,not coded/not installed,
MAS01597-MAS05737,Sunroof-Position,not coded/not installed,
MAS02101,Child safety,not active,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
ENG122170,control_event_memory_driver_side_front,24 01 11 1B 00 B3 D8 71 9F 18 E5 A3 A8 01 42 BF 00 26 E0 91 A8 18 84 A8 8F 01 11 31 00 88 E2 A1 A6 18 F7 74 BB,
ENG117313,control_event_memory_driver_side_rear,24 01 42 72 02 10 C1 B1 9C 17 60 2B 9A 02 11 97 00 6B D9 71 A5 18 81 DA AF 02 42 78 02 64 E4 11 48 19 0B A8 A2,
ENG122171,control_event_memory_passenger_side_front,18 01 42 51 00 76 D1 61 A4 18 0F 13 95 01 42 1B 00 03 DD 81 A2 18 A2 93 9B 01 11 15 00 A9 C9 41 A3 18 80 44 9E,
ENG117314,control_event_memory_passenger_side_rear,18 04 42 C2 01 32 A8 71 A1 17 A6 83 B8 01 42 04 01 A8 A8 71 A1 17 79 8B 9A 04 42 BD 01 A7 A5 61 A3 17 8C CC 8C,
ENG157741,Door_exterior_handle_switch_driver_side,not installed,
ENG157285-ENG122199,DWA-Software-Arbeitsstand,00,
ENG157285-ENG122197,DWA-Software-Schnittstellenversion,17,
ENG157285-ENG122196,DWA-Software-Zielrelease,10,
ENG157285-ENG122198,DWA-Software-Zwischenversion,01,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,1022, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,883400,
ENG127054-ENG122199,KFT_SW-Arbeitsstand,00,
ENG127054-ENG122197,KFT_SW-Schnittstellenversion,17,
ENG127054-ENG122196,KFT_SW-Zielrelease,10,
ENG127054-ENG122198,KFT_SW-Zwischenversion,03,
ENG130144-ENG130193,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_0,0,
ENG130144-ENG130194,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_1,0,
ENG130144-ENG130203,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_10,0,
ENG130144-ENG130204,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_11,0,
ENG130144-ENG130205,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_12,0,
ENG130144-ENG130206,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_13,0,
ENG130144-ENG130207,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_14,0,
ENG130144-ENG130208,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_15,0,
ENG130144-ENG130209,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_16,0,
ENG130144-ENG130210,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_17,0,
ENG130144-ENG130211,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_18,0,
ENG130144-ENG130212,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_19,0,
ENG130144-ENG130195,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_2,0,
ENG130144-ENG130213,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_20,0,
ENG130144-ENG130214,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_21,0,
ENG130144-ENG130215,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_22,0,
ENG130144-ENG130216,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_23,0,
ENG130144-ENG130217,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_24,0,
ENG130144-ENG130218,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_25,0,
ENG130144-ENG130219,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_26,0,
ENG130144-ENG130220,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_27,0,
ENG130144-ENG130221,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_28,0,
ENG130144-ENG130222,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_29,0,
ENG130144-ENG130196,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_3,0,
ENG130144-ENG130223,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_30,0,
ENG130144-ENG130224,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_31,0,
ENG130144-ENG130225,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_32,0,
ENG130144-ENG130226,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_33,0,
ENG130144-ENG130227,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_34,0,
ENG130144-ENG130197,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_4,0,
ENG130144-ENG130198,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_5,0,
ENG130144-ENG130199,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_6,0,
ENG130144-ENG130200,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_7,0,
ENG130144-ENG130201,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_8,0,
ENG130144-ENG130202,Leuchtentreiber_Kurzsschlusszaehler-Leuchte_9,0,
ENG122983-MAS01794,Light_Sensor-Freeway,not coded/not installed,
ENG122983-MAS02248,Light_Sensor-Signal state,not coded/not installed,
ENG122983-MAS02475,Light_Sensor-Brightness infrared,5600, lx
ENG122983-MAS02851,Light_Sensor-Brightness,21522, lx
ENG122983-MAS04808,Light_Sensor-Rain,not coded/not installed,
ENG122983-MAS04809,Light_Sensor-Darkness,not coded/not installed,
ENG122983-MAS04810,Light_Sensor-Request for light activation,not coded/not installed,
ENG127045-ENG115630,lin_mon_msg_1-Botschaft,00 00 00 00 00 00 00 00,
ENG127046-ENG115630,lin_mon_msg_2-Botschaft,00 00 00 00 00 00 00 00,
ENG127047-ENG115630,lin_mon_msg_3-Botschaft,00 00 00 00 00 00 00 00,
ENG127048-ENG115630,lin_mon_msg_4-Botschaft,00 00 00 00 00 00 00 00,
ENG127049-ENG115630,lin_mon_msg_5-Botschaft,00 00 00 00 00 00 00 00,
ENG127050-ENG115630,lin_mon_msg_6-Botschaft,02 00 00 00 00 00 00 00,
ENG107568,Main_Beam_Switch_Setting,Not operated,
ENG127040-ENG114948,Network_Management_Monitor-LIN 3,active,
ENG127040-ENG114949,Network_Management_Monitor-LIN 4,not coded/not installed,
ENG127040-ENG114950,Network_Management_Monitor-LIN 5,not coded/not installed,
ENG127040-ENG114951,Network_Management_Monitor-LIN 6,not coded/not installed,
ENG116806,Parametermonitor_1,82 14 64 64 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 64 00 64 3C 01 00 00 0A 04 00 00 00 00 00 00 00 00 00 00 06 06 28 00 1E 03 1E 08 0A 04 19 05 08 01 01 28 05 0A 32 02 1E 64 00 B4 1E 02 00 00 00 00 0A 1D 6E 96 02 05 0A 6E 96 00 08 0A 02 64 03 0F 0A 28 0A 1E 3C 32 0F 0A 32 05 14 01 50 14 C8 A0 00 C8 00 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 05 F5 0A 0A 0A 00 14 28 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 0A 0A 64 14 32 64 64 19 19 19 05 05 05 0A 0A 0A 14 19 64 0A 0A 05 07 05 05 05 05 05 05 05 05 05 05 19 14 05 05 64 64 0A 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 CB,
ENG130145,Parametermonitor_10,5A 00 F0 00 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A 86 9A 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6C AF,
ENG116807,Parametermonitor_2,0F 05 0A 14 0A 16 08 14 28 32 00 14 32 5A 32 0A 1E 0A 02 4B 0A 28 14 5A 0F 3C 3C 05 0A 02 00 78 03 FA 02 64 14 0F 0A 05 0A 14 00 00 00 00 00 00 00 00 00 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 50 50 64 3C 64 C8 0A 00 14 04 19 0A 23 04 C8 FF 18 16 88 00 1E 05 01 01 C8 00 C8 14 00 5F 00 00 00 00 0A 01 32 00 00 00 00 00 00 00 00 1E 14 1E 02 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 32 0A 0A 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 95 ED,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,00 02 00 14 5A 14 6C 0A 0A 00 00 00 00 00 00 00 6C 00 02 32 5A 14 0A 14 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0D 32 07 14 03 FF 03 04 01 64 0A 14 28 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 64 59 88 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 52,
ENG116809,Parametermonitor_4,04 04 05 0A 03 B4 00 0A 05 05 0A 4B 00 32 0A 03 00 1E 32 00 00 00 00 00 00 00 00 00 00 00 00 00 01 02 02 00 FF FF 14 14 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 04 0A 0A 32 00 00 04 0A 00 00 00 00 00 00 00 00 04 32 28 04 32 28 04 32 28 04 32 28 00 00 05 05 3C 14 01 01 01 01 96 01 01 C8 01 01 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 27,
ENG116810,Parametermonitor_5,00 00 00 00 05 0A 05 0A 0A 0F 08 12 03 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 00 03 09 01 0F 05 00 00 00 00 00 00 00 00 00 00 32 32 30 03 0B 30 96 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 32,
ENG116811,Parametermonitor_6,00 46 32 06 3C 00 05 32 02 00 3C 00 08 05 01 64 64 64 64 64 FF FF FF FF C8 C8 C8 C8 C8 0F 0F 0F 0F 0F 0F 0F 0F 64 28 64 64 64 60 60 60 60 60 C8 FA 00 14 00 0A 19 19 00 00 19 00 01 01 00 05 00 14 00 01 00 00 00 09 10 00 00 01 FF C8 64 64 01 0F 0F 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 0A 0A 05 00 00 00 00 00 00 00 00 00 00 1B 4D,
ENG116911,Parametermonitor_7,00 00 0A 28 0A FF 0A 0A 0A 0A 0A 0A 0A FF FF 32 32 32 32 32 32 32 32 32 32 32 32 32 0A 32 32 FE 0A 32 00 00 FF FF FF FF 0A 0A 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4D F6,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 02 01 64 03 03 05 00 00 00 00 00 00 00 00 00 00 05 05 64 03 03 05 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 05 64 03 03 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B A3,
ENG116792,Power up history,|Funktionsanforderung|27|9|0|0|0|0|0|0|0|0|,
ENG124902-ENG101098,Priotabellen Energiemanagement-Crash,0,
ENG124902-ENG124950,Priotabellen Energiemanagement-Innenraumkonditionierung,0,
ENG124902-ENG162955,Priotabellen Energiemanagement-kein Motorlauf_Zuendung aus,1,
ENG124902-ENG142172,Priotabellen Energiemanagement-Reichweitenverlaengerung,0,
ENG124902-ENG116703,Priotabellen Energiemanagement-Switchoff_Priority_Driving,0,
ENG124902-ENG164370,Priotabellen Energiemanagement-Vermeidung Spannungseinbrueche,0,
ENG249090-MAS00106,reset_historie-Year,25,
ENG249090-MAS00107,reset_historie-Month,1,
ENG249090-MAS00108,reset_historie-Day,22,
ENG249090-MAS00109,reset_historie-Hours,0,
ENG249090-MAS00110,reset_historie-Minutes,0,
ENG249090-ENG114872,reset_historie-last cause of reset,0,
ENG249090-ENG115805,reset_historie-Number of resets,59,
ENG127051,steuergeraetinterne Messwert 1(Zulieferer),00 0A 00 32 0D 0D 0D 0D 00 00 00 00 00 00 00 00 02 00 00 AA 00 0D 00 00 0D 87 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 01 00 00 00 00 47 4A 0B 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 08 00 00 08 08 00 00 00 00 0B 10 00 6A 12 00 00 35 00 11 00 00 00 00 00 1B 00 00 00 00 00 00 0C 9F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 33 00 00 00 00 00 00 00 00 00,
ENG127055,steuergeraetinterne Messwert 2(Zulieferer),02 1A 01 A2 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 00 02 00 00 00 D5 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 39 3B 07 0E 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 9D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 00 00 00 00 00 00 00 22 00 11 44 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-Odometer reading,124004,
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,16.1, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.4, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.4, V
ENG117309,Window_Regulator_Driver_Side_Rear_Sleep_Indication,not active,
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,4A 39 32 36 20,
ENG122172,Window_Regulator_Driver_Side_Sleep_Indication,not active,
ENG122169-ENG163906,Window_Regulator_Driver_Side_VW_Workshop_System_Name-System_short_sign,4A 33 38 36 20,
ENG122982-ENG163906,Window_Regulator_Passenger_Side_Front_VW_Workshop_System_Name-System_short_sign,4A 33 38 37 20,
ENG117310,Window_Regulator_Passenger_Side_Rear_Sleep_Indication,not active,
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,4A 39 32 37 20,
ENG122173,Window_Regulator_Passenger_Side_Sleep_Indication,not active,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-MAS00063,Zusaetzliche Umgebungsdaten-OFF,operated,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,130,
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,Not operated,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,Not operated,
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-ENG124953,Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv,On,
ENG116907-ENG162972,Zusaetzliche Umgebungsdaten-last wakeup,45,
ENG116907-ENG115838,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN),OFF,
ENG116907-ENG115837,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW),OFF,
ENG116907-ENG159622,Zusaetzliche Umgebungsdaten-voltage measurement,14.4, V
ENG122174-ENG122199,ZV_Software-Arbeitsstand,00,
ENG122174-ENG122197,ZV_Software-Schnittstellenversion,17,
ENG122174-ENG122196,ZV_Software-Zielrelease,10,
ENG122174-ENG122198,ZV_Software-Zwischenversion,02,
Elapsed Time: 00:46
;SW:2Q0-907-572-Q HW:2Q0-907-572-B --- Auto Dist. Reg
;Component:ACCCONTIMQB H03 0342, Coding:2A04600100F78748949C810500408700000000000000000000
;EV_ACCMRRCONTIVW376,003015,EV_ACCMRRCONTIVW376_003_VW27.rod
;Monday,21,April,2025,16:03:31:15566
;VCID: 42D62702240C1DFAD9F-8016
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.3, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,42, °C
IDE00391,Adaptive distance regulation: status,ACC_reversible_error,
IDE01794-ENG161032,ACC operating lever signal-ACC_main_switch,operated,
IDE01794-ENG98480,ACC operating lever signal-Cancel,Not operated,
IDE01794-ENG161043,ACC operating lever signal-Control_lever_coding,limiter_only,
IDE01794-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
IDE01794-ENG161056,ACC operating lever signal-distance_control_minus,Not operated,
IDE01794-ENG161057,ACC operating lever signal-distance_control_plus,Not operated,
IDE01794-ENG161132,ACC operating lever signal-part_control_lever,control_lever_4_positions,
IDE01794-ENG159615,ACC operating lever signal-Resume,Not operated,
IDE01794-ENG98911,ACC operating lever signal-Set,Not operated,
IDE01794-ENG161234,ACC operating lever signal-tip_down_in_step_1,Not operated,
IDE01794-ENG161235,ACC operating lever signal-tip_down_in_step_2,Not operated,
IDE01794-ENG161236,ACC operating lever signal-tip_up_in_step_1,Not operated,
IDE01794-ENG161237,ACC operating lever signal-tip_up_in_step_2,Not operated,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,C9 E5 A2 6C,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead starts driving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead starts driving: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,6172,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,394,
IDE03660,Longitudinal acceleration,-0.03, m/s²
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,83 D8 A9 C6 A2 5F 95 2F 9A C7 07 19 CE 81 32 39 60 7F 0F D0 B2 94 86 3E 82 8C 6E 19 B5 2D 10 04 55 7F E1 1D 37 CC AA 45 46 81 1C 27 FC 2B F2 07 70 6D DB 7B B4 F2 A4 92 00 FF C0 96 82 48 8D E2 81 FD 83 D6 B5 E3 F7 E4 67 2E D3 F9 9D 81 9C E5 C9 71 C8 76 21 BE 13 C4 26 06 D9 15 EE 1A 8D A0 DF 31 66 C3 AA 82 99 AD 2B 38 92 4F BD C5 D6 3C C2 2A 6C 5C AB 63 ED 39 D2 0E B5 FA 98 58 37 EF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE05228,Operating hour counter,133281, min
IDE05814,Individualization characteristic,27 61 0E 28 54,
IDE06307-MAS00106,Stop prevention history data-Year,2025,
IDE06307-MAS00107,Stop prevention history data-Month,1,
IDE06307-MAS00108,Stop prevention history data-Day,21,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,12,
IDE06307-MAS00111,Stop prevention history data-Seconds,44,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2024,
IDE06308-MAS00107,Start request history data-Month,9,
IDE06308-MAS00108,Start request history data-Day,21,
IDE06308-MAS00109,Start request history data-Hours,14,
IDE06308-MAS00110,Start request history data-Minutes,59,
IDE06308-MAS00111,Start request history data-Seconds,7,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06308,Start request history data,not active,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08936,Misalignment angle: horiz,0.444, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.21, °
IDE09380-MAS00106,Performed adjustment-Year,2023,
IDE09380-MAS00107,Performed adjustment-Month,11,
IDE09380-MAS00108,Performed adjustment-Day,9,
IDE09380-MAS05610,Performed adjustment-Calibration,Dynamic,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.42, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,-0.62, °
IDE09906,Vertical deadjustment,0.752, °
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,1,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,1,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,2,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,2,
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.420, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,-0.620, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.440, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,0.750, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,0.140, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,0.040, °
IDE12062,Counter for terminal 15 reset,10523,
ENG131998,Number_of_boost_function_active,0,
ENG131999,Number_of_deactivation_ASR_active,0,
ENG132000,Number_of_deactivation_ESC_active,0,
ENG107928,Operating_time_ACC,0, min
ENG131991,Operating_time_ACC_active_driving_programm_auto,0, min
ENG131990,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG131989,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG131992,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG131993,Operating_time_ACC_active_timegap_1,0, min
ENG131994,Operating_time_ACC_active_timegap_2,0, min
ENG131995,Operating_time_ACC_active_timegap_3,0, min
ENG131996,Operating_time_ACC_active_timegap_4,0, min
ENG131997,Operating_time_ACC_active_timegap_5,0, min
ENG132001,Operating_time_ACC_active_v-delta_0,0, min
ENG132004,Operating_time_ACC_active_v-delta_large,0, min
ENG132003,Operating_time_ACC_active_v-delta_medium,0, min
ENG132002,Operating_time_ACC_active_v-delta_small,0, min
Elapsed Time: 00:14
;SW:2Q0-959-655-AG HW:2Q0-959-655-AG --- Airbags
;Component:VW22Airbag 010 0248, Coding:88CCC0C0000000005C5400CF000800000065
;EV_AirbaVW22BPAVW27X,001010,EV_AirbaVW22BPAVW27X.rod
;Monday,21,April,2025,16:03:58:15566
;VCDS Version: Release 25.3.1 (x64) Data version: 20250408 DS365.0
;VCID: 0256E702648CDDFA99F-8056
Group,Description,Actual
IDE00821,Seat belt switch 2nd row driver's side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Seat belt switch 2nd row center,not connected,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.9, Ohm
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.4, Ohm
IDE01106,Driver side head curtain airbag igniter ohm value,2.3, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,too large,
IDE01110,Driver side belt tensioner igniter ohm value,2.3, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.4, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.5, Ohm
IDE01119,Battery open circuit igniter ohm value,too large,
IDE01193,Driver belt tensioner ohm value,0.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,0.0, Ohm
IDE01195,Front passenger side seat occupancy detection: Ohm value,400.0, Ohm
IDE01197,Key switch contact 1 ohm value,620.0, Ohm
IDE01198,Key switch contact 2 ohm value,1440.0, Ohm
IDE01205,Safety belt switch 2nd row driver side ohm value,0.0, Ohm
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,0.0, Ohm
IDE01207,Safety belt switch center 2nd row ohm value,0.0, Ohm
IDE01208,Seat belt switch 3rd row driver side ohm value,too large,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too large,
IDE01271,Number of rollover bar deployments,0,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,16.0, %
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,16.0, %
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,0.0, %
IDE10187,Supply voltage {V},14.3, V
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger airbag igniter,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,not installed,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00022,Battery Interrupt Igniter,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,On,
MAS00033,Key switch terminal 2,On,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:12
;SW:2G0-920-730-B HW:2G0-920-730-B --- Instruments
;Component:KOMBI 210 2660, Coding:04A4010021000008018800010000000000000000
;EV_DashBoardVDDMQBA0,001037,EV_DashBoardVDDMQBA0_001_VW27.rod
;Monday,21,April,2025,15:57:28:15566
;VCID: 20128D8ACA402FEAAFB-8074
IDE00019,Voltage terminal 30,14.4, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,14.25, °C
IDE00196,Engine oil temperature,17, °C
IDE00301,Distance,124004, km
IDE00310,Outside temperature,15.0, °C
IDE00316-IDE00500,Time-Hour,4, H
IDE00316-IDE00501,Time-Minute,3, min
IDE00316-MAS00111,Time-Seconds,27, s
IDE00317-IDE00502,Date-Year,2025, yr
IDE00317-IDE00503,Date-Month,1, Months
IDE00317-IDE00504,Date-Day,22, d
IDE00510,ESI: distance driven from inspection,0, km
IDE00511,ESI: time from inspection,0, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,good oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,0, km
IDE00520,Photo transistor,1,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,25400, km
IDE00698,ESI: remaining running time,618, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,2112, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,1908, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,1984, mm
IDE00935,ESI: Theoretical service interval,25400, km
IDE01076,Time since ignition off,131068, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,15.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,64,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,4085,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,365, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
IDE03352,FIX: Time since last time-dependent inspection,0, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,5.2, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,15.1, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,16.6, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,6.7, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,4.0, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,14.5, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,16.5, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,6.0, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,7.2, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,14.8, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,16.2, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,8.6, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,4.5, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,28.8, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,28.8, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,6.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,123900,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,123800,
IDE03472-MAS06155,Volume after refueling-Third to last distance,123700,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,123300,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,240, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,-0, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,2242,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,1369,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,8.5, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,240, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,8.3, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-8.3, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,8.4, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,8.4, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,8.3, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.01,
IDE03474-ENG101623,Calculated volume-reference_volume,8.4, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,28,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0005550,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,0, H
IDE03477-IDE00501,GPS time-Minute,0, min
IDE03477-IDE00502,GPS time-Year,2000, yr
IDE03477-IDE00503,GPS time-Month,1, Months
IDE03477-IDE00504,GPS time-Day,1, d
IDE03477-MAS00111,GPS time-Seconds,0, s
IDE03477-MAS03493,GPS time-last synchronization year,2000, yr
IDE03506,Distance: high resolution,07 64 26 A0,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,8F F0 00 07,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,CF F0 00 11,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,4F F0 00 11,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,0F F0 00 07,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 01 C3,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,0F F0 5E C4,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 5E C4,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 01 C3,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,BF F0 D3 F3,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,3F F0 D3 F3,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,0F F1 0E EE,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,4F F0 02 CA,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,8F F1 0E EE,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,CF F0 02 CA,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,3F F1 78 A8,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,BF F1 84 1F,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,7F F0 05 61,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,CF F0 05 A4,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,8F F1 8A 07,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,4F F0 05 AD,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,0F F1 8A 07,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,7F F0 08 20,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,AF F1 E4 64,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,EF F0 08 40,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,4F F0 08 40,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,0F F1 E4 64,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,365, d
IDE06566-IDE00008,Key identification-Software version,S305,
IDE06566-IDE00016,Key identification-Hardware version,H82,
IDE06566-MAS04970,Key identification-Part Number,2G6959753AD,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,02,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,00,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,00,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,FC,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,DC 46 E5 C0,
IDE08239,Transponder ID Key 1,76 09 E5 C0,
IDE08240,Transponder ID Key 2,DC 46 E5 C0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,52 00 62 7B,
IDE08343,Immobilizer Challenge,9E E4 82 2C,
MAS00077-ENG99298,Immobilizer-State,02 01 03 28 02 00 00 00 04 00,
ENG250331-ENG250595,Condition_check_1-State_info_1,0,
ENG250331-ENG250481,Condition_check_1-State_info_2,0,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,DC 46 E5 C0,
ENG250332-ENG250595,Condition_check_2-State_info_1,0,
ENG250332-ENG250481,Condition_check_2-State_info_2,0,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,4294967295,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,15, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,24, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,24, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,11, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,37, km
ENG99439,Instrument_recorder,03 03 75 00 4D 51 42 41 30 08 02 31 38 09 02 42 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 01 BD 00 49 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 0D 0D 0D 06 05 06 0D 0D 0D 00 00 0B 00 5D 00 01 C1 00 00 13 00 00 00 16 00 4D 01 00 00 00 00 02 00 00 00 0B 00 5D 00 01 C1 00 00 13 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7F FB,
ENG107920-ENG98868,onboard_computer-Range,83, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,6.9, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,6.3, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,8.0, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,83, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,130,
ENG103405,read_out_measured_value_block,124,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108925-ENG103300,Service_Key_Data_Current_Page-Service_Data,F3 14 02 23 08 C0 19 01 15 00 04 19 64 E4 01 00 17 18 29 18 45 10 47 10 04 DF 02 DF 01 A4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A FF FF 00 00 30 08,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,A5 51 02 23 08 C0 18 02 19 10 1D 0F ED C7 01 00 63 10 2A 11 8E 10 92 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 FF FF 00 00 30 08,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,4217,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,2146,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,2063,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,2,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,Update_Error,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,16, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,25, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,25, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,21, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,2, Months
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,2, Months
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,9, Months
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,1, Months
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2024, yr
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2024, yr
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2020, yr
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2025, yr
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,116550,
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,116717,
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,42203,
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,124004,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,Bank_2,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,2069,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,2069,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,2069,
Elapsed Time: 00:19
;SW:2Q0-909-901-B HW:2Q0-937-085 --- CAN Gateway
;Component:GW MQB A0 H98 0926, Coding:030000046F086400FA000048080E00010001070000000000000000000000
;EV_GatewA0,013024,EV_GatewA0_VW27.rod
;Monday,21,April,2025,15:58:30:15566
;VCID: 313478CE91AA9662305-8064
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056,History data 1,|Life Cycle Data String|2025-01-22-03:17*02.1*00*03124***
2025-01-22-18:22*08.9*00**
2025-01-15-19:17*00.6*00**
2023-06-02-09:20*05.8*00*01744***
2023-06-02-02:25*00.1*00**
2023-04-08-11:40*00.0*00**
2025-01-22-03:17*00.1*00*00274***
2025-01-22-03:51*00.1*00**
2025-01-20-01:11*00.6*00**|,
IDE00057,History data 2,|Life Cycle Data String|2025-01-18-07:01*010*000*-0.531*0-0-0-0-0-0-0*-*00*00079**
2025-01-17-19:45*009*011*-0.528*0-0-0-0-0-0-0*-*00**
2025-01-17-05:44*012*017*-0.525*0-0-0-0-0-0-0*-*00**
2025-01-11-01:44*043*000*-0.604*0-0-0-0-0-0-0*-*00**
2023-06-01-22:39*005*000*-3.664*0-1-0-0-0-0-0*-*00**|,
IDE00058,History data 3,|Life Cycle Data String|2025-01-21-00:01*3*0*002*000*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-21-00:16*3*0*002*000*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-20-00:08*3*0*009*000*0-0-1-0-1-0-0*-*0*00.0*00.0**
2025-01-18-15:50*3*0*031*000*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-18-15:05*2*0*034*002*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-18-13:03*1*0*040*006*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-17-00:10*3*0*010*000*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-17-00:03*3*0*010*000*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-17-00:01*3*0*010*000*0-0-0-0-0-0-0*-*0*00.0*00.0**
2025-01-17-00:00*1*0*010*000*0-0-0-0-0-0-0*-*0*00.0*00.0**|,
IDE00059,History data 4,|Life Cycle Data String|-------------:--*--*---*---*----------*-----*-----*---.-*---.-*---.-**
IDE00060,History data 5,|Life Cycle Data String|2025-01-12-23:46*3*-0.604*11.66*000*05*+00.0*03699*10010*124004*0-0-0-0-0-0-0*-*1*0*00.0*00.0*118.5*07*00*00*01*05**
2024-09-11-06:54*3*+0.000*10.45*000*09*+00.0*03590*10010*122751*0-0-1-1-1-0-0*-*1*1*00.0*00.0*000.0*03*01*00*01*04**
2023-06-02-03:09*3*-3.664*11.39*000*06*+00.0*02851*10010*106146*0-1-0-0-0-0-0*-*1*0*00.0*00.0*009.3*10*00*00*01*03**|,
IDE00061,History data 6,|Life Cycle Data String|2025-01-22-00:11*051*+14*+000.6*00.00*0.00*000**
2025-01-22-04:26*053*+21*+001.4*00.10*0.00*000**
2025-01-22-04:16*052*+21*+002.2*00.10*0.00*000**
2025-01-22-04:12*050*+20*+001.0*00.00*0.00*000**
2025-01-22-03:51*051*+20*+000.1*00.00*0.00*000**
2025-01-22-01:22*052*+20*+000.3*00.00*0.00*000**
2025-01-22-01:13*051*+20*+000.7*00.00*0.00*000**
2025-01-22-01:10*051*+20*+000.1*00.00*0.00*000**
2025-01-22-01:06*052*+20*+000.2*00.00*0.00*000**
2025-01-22-01:06*051*+20*+000.1*00.00*0.00*000**|,
IDE00062,History data 7,|Life Cycle Data String|2025-01-22-00:14*049*+000.0*000.2*00.0*00.0**
2025-01-22-00:00*051*+000.0*000.1*00.0*00.0**
2025-01-22-03:55*049*+000.0*000.2*00.2*00.2**
2025-01-22-01:23*050*+000.0*002.4*00.0*00.0**
2025-01-22-01:15*052*+000.0*000.1*00.0*00.0**
2025-01-22-00:21*051*+000.0*000.6*00.6*00.6**
2025-01-22-00:00*040*+000.0*000.2*00.2*00.2**
2025-01-22-19:33*034*+000.0*000.3*00.1*00.1**
2025-01-22-19:12*033*+000.0*000.1*00.1*00.1**
2025-01-22-18:52*035*+000.0*000.2*00.0*00.0**|,
IDE00063,History data 8,|Life Cycle Data String|2025-01-21-00:00*3*00*00*02*01*-------------:--*00**
2025-01-21-00:00*3*00*00*01*01*-------------:--*00**
2024-09-21-14:35*4*00*00*00*01*2024-09-21-03:51*00**|,
IDE00064,History data 9,|Life Cycle Data String|-------------:--*---*---*---*---*-----*--.--*---*--*--*--.--*-----*-----**
IDE00065,History data 10,|Life Cycle Data String|2025-01-21-00:00*1*016.0*0017.4*0*000.0*0000.0*00.20*9999999**
IDE00066,History data 11,|Life Cycle Data String|-------------:--*---*---*---*---*----*---*--.-*--.-*---*---*---*---*--*-----*-----*-----*-----*-----**
IDE00067,History data 12,|Life Cycle Data String|2024-09-09-20:56*0-0-0-1-0-0-0-0**
2024-09-09-20:30*0-0-0-1-0-0-0-0**
2024-09-09-07:01*0-0-0-1-0-0-0-0**
2024-09-07-14:59*0-0-0-1-0-0-0-0**
2024-09-07-14:33*0-0-0-1-0-0-0-0**
00000*00000*00000*00014*00000*00001*00005*00000**
2023-07-22-10:38*0-0-0-1-0-0-0-0**
2023-01-24-14:50*0-0-0-1-0-0-0-0**
2023-01-22-13:03*0-0-0-1-0-0-0-0**
2023-01-22-12:54*0-0-0-1-0-0-0-0**
2023-01-22-12:45*0-0-0-1-0-0-0-0**
00000*00000*00000*00053*00000*00000*00000*00000**
2025-01-21-00:00*2*031*008*+21*05*025*+00.02*14.5*1**
2024-09-06-07:00*1*071*020*+29*08*025*-22.81*11.4*1**
2024-09-04-07:00*1*067*022*+23*08*025*+22.41*13.4*1**
2024-03-08-10:37*1*076*023*+03*07*025*+07.89*13.4*1**
2024-01-10-20:26*1*077*021*+01*07*025*-31.74*11.6*0**
00006*00001*00000**|,
IDE00068,History data 13,|Life Cycle Data String|-------------:--*---------*---.-*-----**
IDE00071,History data 16,|Life Cycle Data String| 0124004km**
00332*02309*03248*00046*00033**
05324*00839*00046*00003**
15268*00386*00024*00002**
01039*02526*00402*01816**
03125*01846*00812**
03347*00116*00186**
00032*00004*00003**
00162*00023*00003**
00398*00246*00245*00178*00129*00110*00149*00116*00095*00435*00003**|,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE01459,Energy management heat output control status,not active,
IDE01805,History data 19,|Life Cycle Data String|-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.5, H
IDE01807-MAS00106,History data 21-Year,2025,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,22,
IDE01807-MAS00109,History data 21-Hours,3, H
IDE01807-MAS00110,History data 21-Minutes,53, min
IDE01807-MAS14375,History data 21-Cycle counter,10513,
IDE01807-MAS14376,History data 21-ECU 1,Engine Electronics,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.5, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Instrument cluster,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.5, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.4, H
IDE01816-MAS00106,History data 30-Year,2020,
IDE01816-MAS00107,History data 30-Month,9,
IDE01816-MAS00108,History data 30-Day,25,
IDE01816-MAS00109,History data 30-Hours,1, H
IDE01816-MAS00110,History data 30-Minutes,14, min
IDE01816-MAS14375,History data 30-Cycle counter,3567,
IDE01816-ENG151642,History data 30-Bus_1,Powertrain data bus,
IDE01816-ENG151644,History data 30-Bus_2,Comfort data bus,
IDE01816-ENG151646,History data 30-Bus_3,Unknown,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,0.4, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.4, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2020,
IDE01823-MAS00107,History data 37-Month,9,
IDE01823-MAS00108,History data 37-Day,25,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,15, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,10515,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Specified generator voltage,10.6, V
IDE01828,Generator DF Signal,0.025, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,Generator recognition 60-110A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,14.375, V
IDE01836,Battery current,-4.574, A
IDE01837,Temperature of battery sensor,17, °C
IDE01838,Battery temperature,16, °C
IDE01839,Battery charge level,74, %
IDE01841,Battery internal resistance,5.0, mOhm
IDE01842,Usable battery charge,36, Ah
IDE01843,Battery voltage at rest,12.4, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Initialization,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,0.0, A
IDE01948,Battery internal resistance not normed,5.4, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,27 89 4C 4A,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG137113,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG137115,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG137116,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG137117,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG137118,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG137119,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG137120,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG137121,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG137114,Play protection status-function_calls_counter_1,0,
IDE02578-ENG137122,Play protection status-function_calls_counter_2,0,
IDE02578-ENG137123,Play protection status-function_calls_counter_3,0,
IDE02578-ENG137124,Play protection status-function_calls_counter_4,0,
IDE02578-ENG137125,Play protection status-function_calls_counter_5,0,
IDE02578-ENG137126,Play protection status-function_calls_counter_6,0,
IDE02578-ENG137127,Play protection status-function_calls_counter_7,0,
IDE02578-ENG137128,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,4,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,1,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,8,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,16,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,135,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2024,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,9,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,9,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,7,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,14,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,20,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,7,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,21,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,30,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,56,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,59,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,52,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,16,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,39,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,48,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,38,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,Possible standing time too short,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Possible standing time too short,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Possible standing time too short,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Possible standing time too short,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Possible standing time too short,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2023,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,1,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,7,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,22,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,24,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,13,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,12,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,14,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,10,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,45,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,38,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,3,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,54,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,50,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,23,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,28,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,32,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,38,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,15,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,Charge contingency,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,Charge contingency,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,Charge contingency,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,Charge contingency,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,Charge contingency,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,All releases are present,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,59, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,No malfunction,
IDE05583-MAS03095,Break recommendation-Function status,Initialization,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,not active,
IDE05740-ENG136079,Driving profile selection: system status-profile_state_1,not engaged,
IDE05740-ENG136080,Driving profile selection: system status-profile_state_2,not engaged,
IDE05740-ENG136081,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG136082,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG136083,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG136084,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG136085,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG136086,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,82 07 46 74 6D,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG136071,Selected driving profile-driving_profile_1,no function,
IDE06011-ENG136072,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG136073,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG136074,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG136075,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG136076,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG136077,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG136078,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2023,
IDE06230-MAS00107,Break recommend.: last message-Month,8,
IDE06230-MAS00108,Break recommend.: last message-Day,7,
IDE06230-MAS00109,Break recommend.: last message-Hours,2,
IDE06230-MAS00110,Break recommend.: last message-Minutes,1,
IDE06230-MAS00111,Break recommend.: last message-Seconds,33,
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,02,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,0,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,0,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,0,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,Timeout,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,0,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,not engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,0,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,0,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,not engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,0,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,Timeout,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,0,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,not engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,0,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,not engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,0,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,0,
IDE07431-IDE04447,Status: driv prof.select.for corn.light & headlamp range ctrl-Function status,not engaged,
IDE07431-IDE06260,Status: driv prof.select.for corn.light & headlamp range ctrl-ID number,0,
IDE07431-MAS01156,Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status,Timeout,
IDE07431-MAS01447,Status: driv prof.select.for corn.light & headlamp range ctrl-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,Timeout,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,not engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,0,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,not engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,Timeout,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,not engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,Timeout,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,no request,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,14.3, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,active,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07639-MAS06342,Methods for support of high voltage side-Operating range support request,no request,
IDE07639-MAS06343,Methods for support of high voltage side-Voltage decrease range extension,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,Initialization,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,Initialization,
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,Initialization,
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,1, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,1, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,3951.4, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,1677721.3, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Not Used,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,Not Used,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Not Used,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Not Used,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,Not Used,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,Not Used,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Not Used,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,3B FE F5 10,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,14.3, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,20, °C
IDE08347,adapted battery capacity,65, Ah
IDE08354-IDE04447,Status: driv.profile select. for front axle differential lock-Function status,not engaged,
IDE08354-IDE06260,Status: driv.profile select. for front axle differential lock-ID number,0,
IDE08354-MAS01156,Status: driv.profile select. for front axle differential lock-Communication status,Timeout,
IDE08354-MAS01447,Status: driv.profile select. for front axle differential lock-Act.val.,0,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,Timeout,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,OK,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,not installed,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,not installed,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,OK,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,not installed,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,not installed,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,OK,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,not installed,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,not installed,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT271901,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT271921,Allocation LIN system number-Multifunction steering wheel control module,00 31,
IDE08684-SFT271927,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT271977,Allocation LIN system number-Inverter for electrical outlet,00 69,
IDE08684-SFT271986,Allocation LIN system number-Analog clock,00 00,
IDE08684-SFT272175,Allocation LIN system number-Control head driving profile,00 00,
IDE08684-SFT272190,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,00 00,
IDE08685-SFT271901,Status LIN user-Generator,active,
IDE08685-SFT271921,Status LIN user-Multifunction steering wheel control module,not active,
IDE08685-SFT271927,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT271977,Status LIN user-Inverter for electrical outlet,not active,
IDE08685-SFT271986,Status LIN user-Analog clock,not active,
IDE08685-SFT272175,Status LIN user-Control head driving profile,not active,
IDE08685-SFT272190,Status LIN user-Steering Wheel Touch Recognition Control Module,not active,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,not engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,0,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,not engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08797-IDE04447,Status: drive profile for area view-Function status,not engaged,
IDE08797-IDE06260,Status: drive profile for area view-ID number,0,
IDE08797-MAS01156,Status: drive profile for area view-Communication status,Timeout,
IDE08797-MAS01447,Status: drive profile for area view-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,not engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,Timeout,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,not engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,Timeout,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE09561,Static current last LIN sleep phase,-1.717, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10737-IDE04447,Status: driving profile selection for range calculation-Function status,not engaged,
IDE10737-IDE06260,Status: driving profile selection for range calculation-ID number,0,
IDE10737-MAS01156,Status: driving profile selection for range calculation-Communication status,Timeout,
IDE10737-MAS01447,Status: driving profile selection for range calculation-Act.val.,0,
IDE10738-IDE04447,Status driving profile selection for electronic brake booster-Function status,not engaged,
IDE10738-IDE06260,Status driving profile selection for electronic brake booster-ID number,0,
IDE10738-MAS01156,Status driving profile selection for electronic brake booster-Communication status,Timeout,
IDE10738-MAS01447,Status driving profile selection for electronic brake booster-Act.val.,0,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,0,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE12084,Component protection participant status,00 14 1B 00 00 00 0E 11 00 00 00 57 13 00 00 00 15 13 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 2C 20 00 00 00 4E 20 00 00 00 8A 20 00 00 00 4F 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,22,
MAS00464-MAS00109,Standard - ambient data 1-Hours,4,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,54,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,177,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,124004, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,0,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,0,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine off,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG137111,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG137112,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG152042,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG137110,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG137108,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118787-ENG137138,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_AGK,0,
ENG118787-ENG137142,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_EDS,0,
ENG118787-ENG152023,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_FMA,0,
ENG118787-ENG137146,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_HHC,0,
ENG118787-ENG118757,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_IVB,0,
ENG118787-ENG137150,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_PLA,0,
ENG118787-ENG137139,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_AGK,OK,
ENG118787-ENG137143,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_EDS,Timeout,
ENG118787-ENG152024,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_FMA,OK,
ENG118787-ENG137147,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_HHC,Timeout,
ENG118787-ENG118759,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_IVB,Timeout,
ENG118787-ENG137151,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_PLA,OK,
ENG118787-ENG137137,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_AGK,not engaged,
ENG118787-ENG152025,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_EDS,not engaged,
ENG118787-ENG152026,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_FMA,not engaged,
ENG118787-ENG137145,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_HHC,not engaged,
ENG118787-ENG118755,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_IVB,not engaged,
ENG118787-ENG137149,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_PLA,not engaged,
ENG118787-ENG137136,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_AGK,0,
ENG118787-ENG137144,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_BAS,0,
ENG118787-ENG137140,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_EDS,0,
ENG118787-ENG152027,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_FMA,0,
ENG118787-ENG118753,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_IVB,0,
ENG118787-ENG137148,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_PLA,0,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,1,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,not active,
ENG118766,eASS_operation_status,Terminal 15 on,
ENG137076-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG137076-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG137076-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG137076-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG137076-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG137076-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,OFF,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG151180,EM_electrical_system_current,4.564, A
ENG118437,EM_IAlternatorReserve,0.0, A
ENG118434,EM_LoadResponse Time,6, s
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,100, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,100, %
ENG106157,EM_RecuMode_Engine,not coded/not installed,
ENG118780-ENG246261,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG167301,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG167323,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,0,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG252593,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG167381,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG167382,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG125889,Gateway app. software identification-software_version_agw,----,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,100D,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,1914,
ENG118782-ENG137098,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,2203,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9060,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0600,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,-80-,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3168,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7190,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60041,
Elapsed Time: 00:30
;SW:2Q1-909-144-M HW:2Q1-909-144-F --- Steering Assist
;Component:TRW_G4L_MQBA0 611 6041, Coding:010000000000000001010201010001000000010101
;EV_SteerAssisTRWG4LMQBA0,011016,EV_SteerAssisTRWG4LMQBA0.rod
;Monday,21,April,2025,16:04:22:15566
;VCDS Version: Release 25.3.1 (x64) Data version: 20250408 DS365.0
;VCID: 3C2A59FA46E86B0A933-8068
Group,Description,Actual
IDE00019,Voltage terminal 30,14.41, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,0,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Not blocked,
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,0, s
IDE02202,End stage temperature,19, °C
IDE02955,System status,Waiting for start request,
IDE03682-IDE04457,motor position sensor-Electric motor speed,0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,0, °
IDE03735,Steering torque,-0.2, Nm
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,0, %
IDE04448,Steering angle sensor: angle,88.2, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,1505.8, °
IDE04459,Steering angle sensor: offset index mark mechanical middle,-417.5, °
IDE04460,Steering angle sensor: offset straight line running,0.7, °
IDE04787,Hybrid status,not active,
IDE05155,Power steering current consumption,0.5, A
IDE05155-MAS01424,Power steering current consumption-max.value,0.5, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,88.3,
IDE05162-MAS11514,Software end stop-End stop right,556.5,
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,Condition met,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,Condition met,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,valid,
IDE05713-MAS06528,Network diagnosis-Release status,Enabled,
IDE07543,Vehicle speed,0, km/h
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,Steering Assistance,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,Steering Assistance,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Preconditions met,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,Steering Assistance,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,Steering Assistance,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,7.8, %
IDE11865-IDE00021,Reason for engagement steering support-Engine speed,not met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,not met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08071,Reason for engagement steering support-Hybrid drive,not met,
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,not active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
ENG157712,Current_gradient_limiting,0.0, %
ENG157713,Current_limiting,0.0, %
Elapsed Time: 00:06
;SW:17A-035-869 HW:17A-035-869 --- Information Electr.
;Component:MU-E--ER 695 8742, Coding:027200003C00000041110001000002001F0000C40000010001
;EV_MUEnt4CGen2LGE,001041,EV_MUEnt4CGen2LGE_VW27.rod
;Monday,21,April,2025,16:04:38:15566
;VCID: 6882D5AA62F017AA27B-803C
IDE00019,Voltage terminal 30,14.3, V
IDE00021,Engine speed,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,87, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-6, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,43, °C
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,5.90, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,6, counts
IDE00916-IDE02127,Speaker status-Left front speaker,OK,
IDE00916-IDE02128,Speaker status-Right front speaker,OK,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measuring value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measuring value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measuring value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measuring value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measuring value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measuring value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measuring value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measuring value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measuring value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measuring value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measuring value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measuring value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measuring value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01442-MAS06123,Pressing a button-Eject button,Not available,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measuring value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measuring value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measuring value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measuring value not available,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,255, dBµV
IDE01700-MAS01765,Status of tuner for digital radio (DAB)-Audio Signal,Not available,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not activated,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,0, kHz
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,Not available,
IDE01700-ENG117350,Status of tuner for digital radio (DAB)-Audio_Mode,00,
IDE01700-ENG117354,Status of tuner for digital radio (DAB)-Audio_Quality,0,
IDE01700-ENG117330,Status of tuner for digital radio (DAB)-availability_traffic_data_TMC,Not available,
IDE01700-ENG117329,Status of tuner for digital radio (DAB)-availability_traffic_data_TP,Not available,
IDE01700-ENG117348,Status of tuner for digital radio (DAB)-Bit_Rate,65535, kbps
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG117327,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_FIC,16.777215,
IDE01700-ENG117326,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_MSC,16.777215,
IDE01700-ENG117328,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_NET,16.777215,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label, ,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117331,Status of tuner for digital radio (DAB)-Ensemble_ID,00 00 00 00,
IDE01700-ENG117332,Status of tuner for digital radio (DAB)-Ensemble_Label, ,
IDE01700-ENG117333,Status of tuner for digital radio (DAB)-Ensemble_Label_Mask,00 00,
IDE01700-ENG117334,Status of tuner for digital radio (DAB)-Extended_Country_Code,00,
IDE01700-ENG117342,Status of tuner for digital radio (DAB)-Label_Masks,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,00 00 00 00,
IDE01700-ENG117351,Status of tuner for digital radio (DAB)-Protection_Level,Not available,
IDE01700-ENG117349,Status of tuner for digital radio (DAB)-Sample_Rate,65535, kHz
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,00,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label, ,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117325,Status of tuner for digital radio (DAB)-signal_quality,0,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,00,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label, ,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01700-ENG117353,Status of tuner for digital radio (DAB)-SYNC/OFDM_Lock,not activated,
IDE01700-ENG117352,Status of tuner for digital radio (DAB)-Transmission_Mode,0,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,66, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,46, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,36, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,0, dBµV
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,0, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01771-ENG117327,Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC,1.068390,
IDE01771-ENG117326,Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC,1.068387,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Infotainment data bus,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,12, min
IDE04317-MAS00108,Total system run time-Day,132, d
IDE04317-MAS00109,Total system run time-Hours,21, H
IDE04317-MAS00110,Total system run time-Minutes,24, min
IDE04329,Status of all SWaP functions,|ID number,Release code for a SWaP function
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,B4 CF 3F 44 7C B9 D4 C5 21 6D 4A 2F 2B 1A 20 5F E9 9E 80 90 EB BF 1C 29 EE 40 C2 C8 9F 54 41 7E 1E E2 AD 0C 42 E2 28 A7 7E 20 1F BB D8 61 70 21 DC 61 A6 00 5A 15 05 EA E6 24 85 A8 45 50 4E B8 AA FC F5 AC 93 02 8F 27 89 14 26 07 6B 49 3A BD F4 94 57 E7 44 E8 60 61 A2 76 5D 68 5B C3 9D 13 ED 44 00 C6 23 F0 F3 B9 B4 43 83 70 41 06 49 EF EE B9 94 98 C4 95 7D 6E 51 AF 23 15 D8 67 45 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04547,Traffic information,OFF,
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Infotainment data bus,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth: device address,B4 EC 02 52 2A D5,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05597-IDE03615,Bluetooth: Paired device 1-Variant,Ûêñ{Ô iPhone
"Appl
Inc." iPhone15,4 Version 17.6.1 (Build 21G93) ÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth: device address,0C DB EA F1 7B D4,
IDE05597-MAS01483,Bluetooth: Paired device 1-Software version,Ûêñ{Ô iPhone
"Appl
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),0C DB,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),0C DB,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,Ûêñ{Ô iPhone
"Appl
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,iPhone
"Apple Inc."
iPhone15,4
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,0C DB,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,0C DB,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,0C DB,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,0C DB,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,0C DB,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,0C DB,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,0C DB,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,0C DB,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,0C DB,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,0C DB,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,0C DB,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,0C DB,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,0C DB,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,0C DB,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,0C DB,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,0C DB,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,0C DB,
IDE05598-IDE03615,Bluetooth: Paired device 2-Variant,Ã̹¹w iPhone van Chelsey-Cheyenne "Apple Inc." iPhone14,2 Version 16.2 (Build 20C65) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth: device address,F8 C3 CC B9 B9 77,
IDE05598-MAS01483,Bluetooth: Paired device 2-Software version,Ã̹¹w iPhone van Chelsey-Cheyenne "Apple Inc." iPhone14,2 Version 16.2 (Build 20C65) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),F8 C3,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),F8 C3,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,Ã̹¹w iPhone van Chelsey-Cheyenne "Apple Inc." iPhone14,2 Version 16.2 (Build 20C65) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,iPhone van Chelsey-Cheyenne
"Apple Inc."
iPhone14,2
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,F8 C3,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,F8 C3,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,F8 C3,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,F8 C3,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,F8 C3,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,F8 C3,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,F8 C3,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,F8 C3,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,F8 C3,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,F8 C3,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,F8 C3,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,F8 C3,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,F8 C3,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,F8 C3,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,F8 C3,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,F8 C3,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,F8 C3,
IDE05599-IDE03615,Bluetooth: Paired device 3-Variant,ì±a( iPhone van 6H "Apple Inc." iPhone14,2 Version 16.4 (Buil
20E247) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth: device address,7C EC B1 61 17 28,
IDE05599-MAS01483,Bluetooth: Paired device 3-Software version,ì±a( iPhone van 6H "Apple Inc." iPhone14,2 Version 16.4 (Buil
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),7C EC,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),7C EC,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,ì±a( iPhone van 6H "Apple Inc." iPhone14,2 Version 16.4 (Buil
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,iPhone van 6H
"Apple Inc."
iPhone14,2
Version 16.4 (Build 20E247)
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,7C EC,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,7C EC,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,7C EC,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,7C EC,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,7C EC,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,7C EC,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,7C EC,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,7C EC,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,7C EC,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,7C EC,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,7C EC,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,7C EC,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,7C EC,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,7C EC,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,7C EC,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,7C EC,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,7C EC,
IDE05600-IDE03615,Bluetooth: Paired device 4-Variant,µ§2 iPhone "Apple Inc." iPhone11,8 Version 17
0.3 (Build 21A360) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿ,
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth: device address,74 B5 87 A7 02 32,
IDE05600-MAS01483,Bluetooth: Paired device 4-Software version,µ§2 iPhone "Apple Inc." iPhone11,8 Version 17
ÿÿÿÿÿÿÿÿÿ,
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),74 B5,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),74 B5,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,µ§2 iPhone "Apple Inc." iPhone11,8 Version 17
ÿÿÿÿÿÿÿÿÿ,
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,iPhone
"Apple Inc."
iPhone11,8
Version 17.0.3 (Build 21A360)
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,74 B5,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,74 B5,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,74 B5,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,74 B5,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,74 B5,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,74 B5,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,74 B5,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,74 B5,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,74 B5,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,74 B5,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,74 B5,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,74 B5,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,74 B5,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,74 B5,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,74 B5,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,74 B5,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,74 B5,
IDE05601-IDE03615,Bluetooth: Paired device 5-Variant,£Z0*° iPhone van Elbery ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth: device address,F0 A3 5A 30 2A B0,
IDE05601-MAS01483,Bluetooth: Paired device 5-Software version,£Z0*° iPhone van Elbery ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),F0 A3,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),F0 A3,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,£Z0*° iPhone van Elbery ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,iPhone van Elbery
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,F0 A3,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,F0 A3,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,F0 A3,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,F0 A3,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,F0 A3,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,F0 A3,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,F0 A3,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,F0 A3,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,F0 A3,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,F0 A3,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,F0 A3,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,F0 A3,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,F0 A3,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,F0 A3,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,F0 A3,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,F0 A3,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,F0 A3,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,39.50, %
IDE05814,Individualization characteristic,FF 5A 1C EB 05,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,FF,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06425,Dynamometer mode: functional,not activated,
IDE06516-MAS01424,Temperature: optical drive-max.value,205, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,205, °C
IDE06516-MAS02238,Temperature: optical drive-Current,205, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,86, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,-6, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,40, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,205, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,205, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,205, °C
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardware version,---,
IDE10479-MAS01483,Interface for external media: identification-Software version,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-ENG126986,Function module: identification-Function_module_identification,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE12277-MAS01632,External optical drive (USB): status-Status,Measuring value not available,
IDE12420-MAS01482,iPod chip: identification-Hardware version,01,
IDE12420-MAS01483,iPod chip: identification-Software version,03,
IDE12420-MAS02832,iPod chip: identification-Malfunction status,00,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,10,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00481-ENG117777,BAP-BAP_Function_ID,00,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,8,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,91.8, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,46, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,38, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, Months
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,960219000565349,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,Mute,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,0, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,36, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,25, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,1, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,22, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,3, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,57, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,44, s
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,0,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,0,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
Elapsed Time: 00:19
;33-OBD2
;Monday,21,April,2025,16:05:39:15566
03,Fuel system 1/2 status,Engine off,Engine off
04,Calculated load value,0.0 %
05,Engine coolant temperature,17 °C
06,Short Term Trim - Bank 1,0.0 %
07,Long Term Trim - Bank 1,0.0 %
0B,Intake Manifold Absolute Pressure,100 kPa abs
0C,Engine RPM,0 /min
0D,Vehicle speed,0 km/h
0E,Ignition timing advance for cyl #1,0.0 Degrees
0F,Intake air temperature,17 °C
11,Absolute Throttle Position,18.4 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.000 V,0.00 %()
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,0 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,0.0 %
2F,Fuel Level Input,17.6 %
30,Warm-ups since DTC cleared,0
33,Barometric pressure,100 kPa abs
34,Bank 1 Sensor 1 Status,1.000 Lambda,0.000 mA
3C,B1S1 Cat. Temp.,346.0 °C
42,Control module voltage,14.100 V
43,Absolute Load Value,0 %
44,Commanded Equivalence Ratio,0.999 Lambda
45,Relative Throttle Position,9.8 %
46,Ambient Air Temp,15 °C
47,Absolute Throttle Position B,18 %
49,Accelerator Pedal Position D,13.3 %
4A,Accelerator Pedal Position E,13.7 %
4C,Commanded Throttle Actuator Control,0.0 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
65,Auxiliary Input/Output,GEAR_RCMD: N
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:610/--- kPa
A4,Transm gear,N
Type 02 - VIN : WVWZZZAWZKY166981 (Address E8)
Type 04 - Calibration ID : 05C034 9605BEAD (Address E8)
Type 06 - Calibration Verification Number : D0574E2D (Address E8)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 1948
Ignition cycle count : 6334
Catalyst monitor bank 1 : 1144 / 1928
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 1296 / 1928
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 5999 / 1948
AIR monitor : 0 / 0
EVAP monitor : 0 / 0
Secondary O2 Sensor monitor bank 1 : 1803 / 1928
Secondary O2 Sensor monitor bank 2 : 0 / 0
