2018 2.0L TDI Tiguan 7SP - Clutch Position Sensor
dude04
New Zealand
C?ID=266974
Hi all,
Thanks for stopping by.
I have been receiving P1735 00 intermittently over the last few weeks. Doing some Google research it seems that this can be related to faulty sensors within the mechatronics unit.
My symptom is that only even gears (R-2-4-6) work, if I turn the car on and off a few times I can get all gears working eventually.
I have attached a full scan as well as a data log and some screenshots showing, what appears to be, a ~0.75 bar difference between the requested pressure and the actual pressure for "Clutch 1". Even with the car off Clutch 1 reads "-0.75 bar".
I assume the sensors need changing and I am shopping for new sensors.
What I came here to ask, please, is:
1. Am I on the right track?
2. Once the physical work of changing the sensors is done what procedure in VCDS do I need to complete to adjust the oil level?
3. " " what procedure do I need to complete to adjust the transmission after replacing the pressure/position sensors?
Thank you very much and a Happy Easter to you all.
Some screenshots from VCDS showing pressure values:
Scan (please ignore the multitude of errors, I had recently disconnected the battery):
Tuesday,15,April,2025,12:23:24:38319
VCDS Version: 25.3.1.0 (x64)
Data version: 20250408 DS365.0
VIN: WVGZZZ5NZJW814xxx   License Plate:
Mileage: 75261km-46765mi   Repair Order:
Chassis Type  5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 42 44 4B 52 5F
          6C 6D A5 BB BC
VIN: WVGZZZ5NZJW814xxx   Mileage: 75261km-46765miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3661
   Revision: B4H25---    CVN: 0B4296574C6C0C4B
   Coding: 0125003204271D083000
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004003
   ROD: EV_ECM20TDI01104L906026EJ_004.rod
   VCID: 76E38334C952922BE1-8022
   VINID: 9E65EAAAA15EA9A9C80441881C1A74CB3F
17158 - Databus
          U1123 00 [00100000] - Received Error Message
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:49
                    Engine speed: 793.50 /min
                    Normed load value: 40.8 %
                    Coolant temperature: 19 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 11.220 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
          U0428 00 [00100000] - -
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:49
                    Engine speed: 836.50 /min
                    Normed load value: 40.4 %
                    Voltage terminal 30: 11.500 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
4631 - ECM Power Relay Load Circuit
          P068B 00 [00100000] - Opens Too Late
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2014
   Revision: 00H06V07    CVN: D49DD98B
   ROD: EV_TCMDQ500021.rod
   VCID: 33657A209AA0C70306-8066
10666 - Position Sensor for Clutch 1
          P1735 00 [10101000] - Electrical Malfunction
                    Fault Frequency: 18
                    Mileage: 75032 km
                    Date: 2025.04.12
                    Time: 14:49:10
                    Engine speed: 1578.00 /min
                    Vehicle speed: 75 km/h
                    Coolant temperature: 90 °C
                    Clutch: primary stat: Driving
                    selected gear: GANG_6
                    Driving position: d
                    Engine torque: 240 Nm
                    Control Module temperature: 95 °C
                    Accelerator pedal position: 15.2 %
                    DTC memory status: 37
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51527000000103
   Coding: 0AEE939A54210B70477D070862CA4950C92AD0E2E046927D30625038C22A4200002F641A1B13111435351919323200
0297 - Steering Angle Sensor
          B1168 F2 [00001000] - Not Initialized
                    Reset counter: 142
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:49
32833 - Switch for Electric Parking Brake
          C100C 01 [00001000] - Electrical Failure
                    Reset counter: 228
                    Mileage: 71790 km
32837 - Lamp in Switch for Electronic Parking Brake
          C1145 13 [00001000] - Open Circuit
                    Reset counter: 228
                    Mileage: 71790 km
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0446299776 Dataset Number: V03935260TY 0001
   Coding: 132C2C0723
   VCID: 3E735B14A1E21A6BF9-806A
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98205828
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00555801 Dataset Number: 0000
   Coding: 0012010420010000110510001210142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 4A9B07C4ED2AA6CB55-801E
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [00001001] - Internal System Fault
                    Reset counter: 103
                    Mileage: 58991 km
                    Date: 2023.08.03
                    Time: 15:41:48
                    Outside temperature: 20.5 °C
                    Voltage terminal 30: 12.2 V
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001717001733 Dataset Number: V03935288SF 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081FFDCCB3A694DB83-805C
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 020617  033 0372
   Serial number: 00000001705300304146
   Component: RLHS  042 0105
   Serial number: S8Y17M06D24H02M56S00
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 48
                    Mileage: 66287 km
                    Date: 2024.04.10
                    Time: 14:16:39
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 19.5 °C
204546 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 248
                    Mileage: 72522 km
                    Date: 2025.01.20
                    Time: 00:36:24
                    CAN-Bus_aktiv: OFF
                    OFF: Not operated
                    Voltage: 12.4 V
                    Outside temperature: 25.5 °C
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 001106177478090 Dataset Number: V03935263AX 0001
   Coding: 0331563051
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000_VW37.rod
   VCID: 3C77511CB7FE087BD7-8068
13637426 - Databus
                    Reset counter: 142
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:50
   Component: ACCCONTIMQB   H02 0233
   Dataset Number: V03935265DD 0001
   Coding: 320060C350FF8728749C8145004087
   ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
0803 - Databus
                    Reset counter: 142
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:51
                    Voltage terminal 15: 11.5 V
                    Control Module temperature: 17 °C
                    Longitudinal_acceleration_vehicle_reference: 0.78 m/s²
2101 - Databus
                    Reset counter: 142
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:50
2055 - Databus
          U1122 00 [00001000] - Implausible Message
                    Reset counter: 142
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:51
                    Control Module temperature: 18 °C
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR33RAMT Dataset Number: V03935255DY 0001
   Coding: 98CCC0C00C0000005C540000008800000065
   VCID: 0919F8C8A8ACEDD39C-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 002 306 17
   Serial number: 35700000000E9B34B42U
   Subsystem 2 - Part No SW: -----------    HW: 480 002 306 17
   Serial number: 35800000000E7B34B42T
   Subsystem 3 - Part No SW: -----------    HW: 480 401 706 17
   Serial number: 3510001B526441E4613S
   Subsystem 4 - Part No SW: -----------    HW: 480 402 006 17
   Serial number: 3520001BB26441E4D241
   Subsystem 5 - Part No SW: -----------    HW: 480 402 206 17
   Serial number: 3550001C126441E2751U
   Subsystem 6 - Part No SW: -----------    HW: 480 402 006 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C926441E487A8
   Subsystem 7 - Part No SW: -----------    HW: 480 402 006 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A126441E2C3D0
   Subsystem 8 - Part No SW: -----------    HW: 480 402 006 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 23000019F26441E6B541
   Subsystem 9 - Part No SW: -----------    HW: 480 001 806 17
   Serial number: I0M00000000C218C4520
   Subsystem 10 - Part No SW: -----------    HW: 480 001 806 17
   Serial number: I0N0000000094B65252%
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170623400213
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73E5BA20DA208703C6-8026
   Part No SW: 5NA 920 751 B    HW: 5NA 920 751 B
   Component: KOMBI         302 0310
   Coding: 27A400186B80000801886B031401000080000000
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006454439 Dataset Number: V03935258SJ 0001
   Coding: 030500345F087300FB07224A1E0F00010001070000000000000000000000
   GVL: 01D63C0008000600409C80000002C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1531714531601611AN2B
   Coding: 290000
   Serial number: 3214104204
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00001000] - -
                    Reset counter: 141
                    Mileage: 75136 km
                    Date: 2025.04.14
                    Time: 14:11:05
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: OFF
   Serial number: HA1-00003.05.17 Dataset Number: v1260x015G0 0000
   Coding: 0101
   Serial number: 17000149365016
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71E9B028A03CB51334-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QFG11743
   Coding: 0014000000000500018281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
          U1400 00 [00001000] - -
                    Reset counter: 125
                    Mileage: 74619 km
                    Date: 2025.03.31
                    Time: 09:47:24
   Serial number: 200517EEJ36457 Dataset Number: V03935247WD 0001
   Coding: 003F1B20D201040000000000
   VCID: 43852AE0CA00778396-8016
   Component: EPS_MQB_ZFLS  128 1072
   Dataset Number: V03935255HX 0001
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 458134F8C43449B3B8-8010
16272 - Steering Angle Sensor
                    Reset counter: 107
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.25 V
                    Temperature: 17.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 12.38 V
                    uAdSensI_SwitchedKl30_xdu16: 12.36 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 150517EEF16949 Dataset Number: V03935248NH 0001
   Coding: 003F1120DE01040000000000
   VCID: 428B2FE4D51A7E8B9D-8016
   Part No SW: 5NA 035 045 A    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1121
   Serial number: A849F0HS003583 Dataset Number: V03935311FY 0001
   Coding: 02730608FF00000051510001000808001F0100C601200502DF
   VCID: 3663433489D2D22B21-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9216
   Serial number: VWZ6ZJY1190674
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Compact disc data bank:
   Component: Gracenote2  --- 4012
   Dataset Number: V03935254KA 0001
   Coding: 0123060122002017000040
   VCID: 39794808B8CC3D53CC-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31405264900000 Dataset Number: V03935261RY 0001
   Coding: 0A28
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 10061711K21818 Dataset Number: V03935260KQ 0001
   Coding: 000307060000010100022344C150A90084000E200000
1123173 - Databus
                    Reset counter: 142
                    Mileage: 75138 km
                    Date: 2025.04.14
                    Time: 00:00:50
                    Outside temperature: 16.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    Voltage terminal 15: 11.3 V
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 290517EET12927 Dataset Number: V03935250KZ 0001
   Coding: 002A11200100040000000000
   ROD: EV_DCURearDriveMAXKLO.rod
   Serial number: 040417ED307706 Dataset Number: V03935250L0001
   ROD: EV_DCURearPasseMAXKLO.rod
End-------------------------(Elapsed Time: 06:02)--------------------------
------------------------------18 Faults Found------------------------------
Data log for some transmission data (sorry I forgot to record the gear... duh):
Monday,21,April,2025,17:03:56:38319-VCID:33657A209AA0C70306-8066,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
0DL 300 011 N,ADVMB,GSG DQ500     H06 2014,
,,G149,F0,G150,F0,G151,F0,G152,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE05988-ENG110505,TIME,Loc. IDE05989-ENG110503,TIME,Loc. IDE05990-ENG110506,TIME,Loc. IDE05991-ENG110504,,,,,,,,,,,,,,,,,
,STAMP,Pressure of clutch 2: actual value-Clutch_2_actual_value,STAMP,Pressure of clutch 1: actual value-Clutch_1_actual_value,STAMP,Pressure of clutch 2: specified value-Clutch_2_commanded_value,STAMP,Pressure of clutch 1: specified value-Clutch_1_commanded_value,,,,,,,,,,,,,,,,,
,, bar,, bar,, bar,, bar,,,,,,,,,,,,,,,,,
,0.33,0.03,0.53,1.52,0.74,0.00,0.13,2.25,,,,,,,,,,,,,,,,,
,1.14,0.03,1.35,1.53,1.55,0.00,0.94,2.26,,,,,,,,,,,,,,,,,
,1.96,0.03,2.16,1.54,2.36,0.00,1.75,2.25,,,,,,,,,,,,,,,,,
,2.77,0.03,2.99,1.70,3.19,0.00,2.57,2.39,,,,,,,,,,,,,,,,,
,3.60,0.03,3.80,1.34,4.00,0.00,3.40,2.03,,,,,,,,,,,,,,,,,
,4.41,0.03,4.61,1.33,4.81,0.00,4.22,2.03,,,,,,,,,,,,,,,,,
,5.23,0.03,5.44,1.14,5.66,0.00,5.02,1.91,,,,,,,,,,,,,,,,,
,6.07,0.06,6.27,-0.80,6.49,1.93,5.87,1.29,,,,,,,,,,,,,,,,,
,6.90,1.94,7.10,-0.80,7.31,1.93,6.69,0.00,,,,,,,,,,,,,,,,,
,7.75,2.00,7.96,-0.80,8.17,2.36,7.53,0.00,,,,,,,,,,,,,,,,,
,8.60,2.40,8.81,-0.80,9.03,2.43,8.39,0.00,,,,,,,,,,,,,,,,,
,9.46,2.44,9.66,-0.80,9.87,2.43,9.25,0.00,,,,,,,,,,,,,,,,,
,10.27,2.41,10.48,-0.80,10.68,2.28,10.07,0.00,,,,,,,,,,,,,,,,,
,11.08,2.35,11.30,-0.80,11.51,2.27,10.88,0.00,,,,,,,,,,,,,,,,,
,11.93,2.22,12.13,-0.80,12.33,1.89,11.72,0.00,,,,,,,,,,,,,,,,,
,12.74,2.03,12.95,-0.80,13.17,1.89,12.54,0.00,,,,,,,,,,,,,,,,,
,13.58,0.03,13.79,0.85,13.99,0.00,13.38,1.16,,,,,,,,,,,,,,,,,
,14.40,0.03,14.60,1.02,14.80,0.00,14.20,1.70,,,,,,,,,,,,,,,,,
,15.21,0.03,15.41,1.02,15.62,0.00,15.01,1.70,,,,,,,,,,,,,,,,,
,16.02,0.03,16.23,1.02,16.43,0.00,15.82,1.70,,,,,,,,,,,,,,,,,
,16.83,0.03,17.04,1.02,17.24,0.00,16.63,1.70,,,,,,,,,,,,,,,,,
,17.64,0.03,17.85,1.02,18.05,0.00,17.44,1.70,,,,,,,,,,,,,,,,,
,18.47,0.03,18.69,1.27,18.89,0.00,18.26,1.92,,,,,,,,,,,,,,,,,
,19.31,0.03,19.52,1.57,19.74,0.00,19.10,2.04,,,,,,,,,,,,,,,,,
,20.16,0.03,20.37,1.54,20.57,0.00,19.95,2.26,,,,,,,,,,,,,,,,,
,20.99,0.03,21.19,1.60,21.40,0.00,20.78,2.32,,,,,,,,,,,,,,,,,
,21.81,0.03,22.02,1.73,22.24,0.00,21.60,2.39,,,,,,,,,,,,,,,,,
,22.65,0.03,22.85,1.80,23.05,0.00,22.44,2.54,,,,,,,,,,,,,,,,,
,23.46,0.04,23.66,1.82,23.86,0.00,23.26,2.54,,,,,,,,,,,,,,,,,
,24.27,0.05,24.48,1.74,24.68,0.00,24.07,2.52,,,,,,,,,,,,,,,,,
,25.08,0.04,25.29,1.72,25.49,0.00,24.88,2.46,,,,,,,,,,,,,,,,,
,25.90,0.04,26.10,1.70,26.30,0.00,25.69,2.45,,,,,,,,,,,,,,,,,
,26.70,0.04,26.89,1.67,27.11,0.00,26.50,2.42,,,,,,,,,,,,,,,,,
,27.55,2.28,27.76,1.31,27.97,2.52,27.33,2.38,,,,,,,,,,,,,,,,,
,28.38,2.51,28.59,0.51,28.79,2.60,28.18,1.22,,,,,,,,,,,,,,,,,
,29.19,2.71,29.40,0.53,29.60,2.78,28.99,1.23,,,,,,,,,,,,,,,,,
,30.01,2.87,30.22,0.53,30.41,2.70,29.80,1.24,,,,,,,,,,,,,,,,,
,30.82,2.61,31.02,-0.81,31.23,2.78,30.61,0.00,,,,,,,,,,,,,,,,,
,31.63,2.76,31.84,-0.81,32.04,2.75,31.43,0.00,,,,,,,,,,,,,,,,,
,32.44,2.78,32.65,-0.81,32.85,2.76,32.24,0.00,,,,,,,,,,,,,,,,,
,33.26,2.78,33.46,-0.80,33.67,2.75,33.05,0.00,,,,,,,,,,,,,,,,,
,34.09,2.54,34.29,1.03,34.49,2.43,33.88,0.00,,,,,,,,,,,,,,,,,
,34.90,2.47,35.10,1.51,35.31,2.26,34.69,2.35,,,,,,,,,,,,,,,,,
,35.75,0.03,35.97,1.39,36.18,1.54,35.53,2.71,,,,,,,,,,,,,,,,,
,36.59,1.65,36.79,0.66,36.99,1.54,36.38,1.34,,,,,,,,,,,,,,,,,
,37.41,1.65,37.62,0.67,37.82,1.54,37.21,1.34,,,,,,,,,,,,,,,,,
,38.24,1.66,38.44,0.67,38.65,1.54,38.02,1.34,,,,,,,,,,,,,,,,,
,39.05,1.65,39.25,0.67,39.46,1.54,38.85,1.34,,,,,,,,,,,,,,,,,
,39.86,1.66,40.07,0.67,40.27,1.54,39.66,1.34,,,,,,,,,,,,,,,,,
,40.67,1.66,40.89,0.68,41.10,1.54,40.48,1.34,,,,,,,,,,,,,,,,,
,41.52,1.66,41.72,0.68,41.94,1.54,41.30,1.34,,,,,,,,,,,,,,,,,
,42.37,1.67,42.58,0.69,42.79,1.54,42.16,1.34,,,,,,,,,,,,,,,,,
,43.21,1.66,43.41,0.67,43.61,1.54,43.01,1.34,,,,,,,,,,,,,,,,,
,44.02,1.65,44.22,0.66,44.43,1.54,43.82,1.34,,,,,,,,,,,,,,,,,
,44.83,1.66,45.03,1.02,45.25,1.96,44.63,1.34,,,,,,,,,,,,,,,,,
,45.68,2.01,45.88,0.77,46.08,1.89,45.47,0.00,,,,,,,,,,,,,,,,,
,46.50,2.02,46.72,0.55,46.93,2.04,46.29,0.00,,,,,,,,,,,,,,,,,
,47.34,0.03,47.56,1.39,47.77,0.00,47.13,2.12,,,,,,,,,,,,,,,,,
,48.18,0.03,48.38,1.50,48.58,0.00,47.98,2.25,,,,,,,,,,,,,,,,,
,49.00,0.03,49.22,1.51,49.44,0.00,48.78,2.29,,,,,,,,,,,,,,,,,
,49.87,1.77,50.08,1.54,50.29,2.32,49.66,2.28,,,,,,,,,,,,,,,,,
,50.71,2.49,50.92,0.49,51.13,2.42,50.51,1.47,,,,,,,,,,,,,,,,,
,51.54,2.49,51.75,-0.82,51.96,2.46,51.33,1.22,,,,,,,,,,,,,,,,,
,52.37,2.58,52.57,-0.81,52.77,2.45,52.16,0.00,,,,,,,,,,,,,,,,,
,53.17,2.44,53.38,-0.81,53.58,2.49,52.98,0.00,,,,,,,,,,,,,,,,,
,54.01,2.54,54.23,-0.81,54.43,2.47,53.78,0.00,,,,,,,,,,,,,,,,,
,54.85,2.52,55.05,-0.81,55.25,2.45,54.64,0.00,,,,,,,,,,,,,,,,,
,55.66,2.53,55.86,-0.80,56.07,2.44,55.46,0.00,,,,,,,,,,,,,,,,,
,56.47,2.47,56.67,-0.81,56.88,2.47,56.27,0.00,,,,,,,,,,,,,,,,,
,57.29,2.55,57.50,-0.81,57.71,2.57,57.08,0.00,,,,,,,,,,,,,,,,,
,58.11,2.48,58.33,-0.81,58.55,2.45,57.91,0.00,,,,,,,,,,,,,,,,,
,58.98,2.57,59.17,-0.81,59.38,2.47,58.77,0.00,,,,,,,,,,,,,,,,,
,59.80,2.49,60.02,-0.81,60.23,2.51,59.59,0.00,,,,,,,,,,,,,,,,,
,60.65,2.61,60.86,-0.81,61.08,2.57,60.44,0.00,,,,,,,,,,,,,,,,,
,61.50,2.71,61.71,-0.80,61.92,2.62,61.29,0.00,,,,,,,,,,,,,,,,,
,62.34,2.85,62.56,-0.81,62.76,2.88,62.13,0.00,,,,,,,,,,,,,,,,,
,63.16,2.90,63.37,-0.81,63.57,3.07,62.96,0.00,,,,,,,,,,,,,,,,,
,64.00,3.31,64.22,-0.81,64.42,3.20,63.78,0.00,,,,,,,,,,,,,,,,,
,64.83,3.15,65.04,-0.81,65.25,3.13,64.63,0.00,,,,,,,,,,,,,,,,,
,65.66,2.77,65.87,-0.82,66.07,2.88,65.46,0.00,,,,,,,,,,,,,,,,,
,66.47,2.96,66.67,-0.81,66.88,2.57,66.27,0.00,,,,,,,,,,,,,,,,,
,67.28,2.59,67.51,-0.81,67.72,3.06,67.08,0.00,,,,,,,,,,,,,,,,,
,68.15,3.20,68.35,-0.81,68.56,3.33,67.94,0.00,,,,,,,,,,,,,,,,,
,68.97,3.38,69.18,-0.81,69.39,3.36,68.76,0.00,,,,,,,,,,,,,,,,,
,69.81,3.32,70.03,-0.81,70.25,3.32,69.60,0.00,,,,,,,,,,,,,,,,,
,70.66,3.32,70.86,-0.82,71.06,3.12,70.46,0.00,,,,,,,,,,,,,,,,,
,71.48,2.32,71.69,1.75,71.90,0.46,71.27,2.37,,,,,,,,,,,,,,,,,
,72.32,0.04,72.53,2.26,72.74,0.00,72.11,2.96,,,,,,,,,,,,,,,,,
,73.17,0.04,73.38,2.31,73.58,0.00,72.95,3.19,,,,,,,,,,,,,,,,,
,73.99,0.04,74.19,2.22,74.39,0.00,73.79,3.03,,,,,,,,,,,,,,,,,
,74.80,0.04,75.01,1.86,75.21,0.00,74.60,2.98,,,,,,,,,,,,,,,,,
,75.61,0.04,75.82,1.68,76.02,0.00,75.41,2.33,,,,,,,,,,,,,,,,,
,76.42,0.03,76.63,1.65,76.83,0.00,76.22,2.26,,,,,,,,,,,,,,,,,
,77.24,0.03,77.44,1.75,77.66,0.00,77.04,2.62,,,,,,,,,,,,,,,,,
,78.09,1.56,78.31,1.75,78.53,2.20,77.88,2.42,,,,,,,,,,,,,,,,,
,78.95,3.01,79.17,1.95,79.39,3.28,78.74,2.57,,,,,,,,,,,,,,,,,
,79.81,3.47,80.04,1.71,80.25,2.84,79.61,2.78,,,,,,,,,,,,,,,,,
,80.67,2.80,80.88,-0.81,81.08,2.53,80.47,1.87,,,,,,,,,,,,,,,,,
,81.50,2.74,81.71,-0.81,81.92,2.61,81.28,0.00,,,,,,,,,,,,,,,,,
,82.34,2.61,82.54,-0.81,82.76,2.52,82.13,0.00,,,,,,,,,,,,,,,,,
,83.18,2.60,83.39,-0.81,83.60,2.53,82.96,0.00,,,,,,,,,,,,,,,,,
,84.04,2.61,84.24,0.36,84.45,2.52,83.81,0.00,,,,,,,,,,,,,,,,,
,84.87,2.70,85.07,8.94,85.28,2.80,84.66,9.28,,,,,,,,,,,,,,,,,
,85.69,2.59,85.90,0.44,86.10,2.51,85.49,14.50,,,,,,,,,,,,,,,,,
,86.51,2.61,86.71,-0.81,86.91,2.73,86.30,12.00,,,,,,,,,,,,,,,,,
,87.32,3.18,87.53,-0.80,87.74,2.83,87.11,0.00,,,,,,,,,,,,,,,,,
,88.14,2.78,88.35,-0.81,88.55,3.16,87.94,0.00,,,,,,,,,,,,,,,,,
,88.96,3.36,89.16,-0.81,89.37,3.49,88.76,0.00,,,,,,,,,,,,,,,,,
,89.78,3.81,89.99,-0.81,90.19,3.87,89.57,0.00,,,,,,,,,,,,,,,,,
,90.60,3.76,90.80,-0.81,91.01,3.81,90.40,0.00,,,,,,,,,,,,,,,,,
,91.41,3.66,91.62,-0.82,91.82,2.77,91.21,0.00,,,,,,,,,,,,,,,,,
,92.24,2.94,92.44,-0.81,92.65,2.55,92.03,0.00,,,,,,,,,,,,,,,,,
,93.06,2.32,93.26,0.92,93.46,2.22,92.85,0.00,,,,,,,,,,,,,,,,,
,93.86,2.45,94.06,1.37,94.27,2.18,93.66,1.99,,,,,,,,,,,,,,,,,
,94.69,0.03,94.89,2.13,95.10,0.00,94.48,3.14,,,,,,,,,,,,,,,,,
,95.51,0.04,95.71,1.60,95.91,2.47,95.30,2.70,,,,,,,,,,,,,,,,,
,96.31,9.17,96.54,1.55,96.74,14.50,96.11,2.40,,,,,,,,,,,,,,,,,
,97.16,13.92,97.37,1.53,97.57,14.50,96.95,2.31,,,,,,,,,,,,,,,,,
,97.99,0.47,98.20,1.64,98.41,0.00,97.78,2.25,,,,,,,,,,,,,,,,,
,98.84,0.04,99.04,1.54,99.25,0.00,98.63,2.25,,,,,,,,,,,,,,,,,
,99.68,0.03,99.89,1.56,100.10,0.00,99.47,2.25,,,,,,,,,,,,,,,,,
,100.52,0.03,100.73,1.55,100.93,0.00,100.32,2.34,,,,,,,,,,,,,,,,,
,101.33,0.04,101.54,1.56,101.74,0.00,101.13,2.25,,,,,,,,,,,,,,,,,
,102.15,0.04,102.35,1.56,102.56,0.00,101.94,2.26,,,,,,,,,,,,,,,,,
,102.97,0.04,103.17,1.55,103.38,0.00,102.77,2.27,,,,,,,,,,,,,,,,,
,103.79,0.04,104.00,1.74,104.21,0.00,103.59,2.34,,,,,,,,,,,,,,,,,
,104.62,0.04,104.82,1.80,105.02,0.00,104.41,2.48,,,,,,,,,,,,,,,,,
,105.43,0.04,105.63,1.87,105.83,2.55,105.22,2.45,,,,,,,,,,,,,,,,,
,106.24,2.69,106.44,-0.80,106.65,2.86,106.03,2.48,,,,,,,,,,,,,,,,,
,107.08,3.66,107.31,-0.37,107.51,4.13,106.86,0.40,,,,,,,,,,,,,,,,,
,107.92,4.21,108.11,1.12,108.32,3.95,107.72,0.00,,,,,,,,,,,,,,,,,
,108.73,2.34,108.93,2.96,109.14,0.47,108.52,3.38,,,,,,,,,,,,,,,,,
,109.58,0.51,109.79,3.37,109.99,0.00,109.36,4.06,,,,,,,,,,,,,,,,,
,110.40,0.04,110.60,3.29,110.82,0.00,110.19,4.24,,,,,,,,,,,,,,,,,
,111.23,0.04,111.43,3.26,111.63,0.00,111.02,4.18,,,,,,,,,,,,,,,,,
,112.04,0.04,112.24,3.24,112.45,0.00,111.84,4.13,,,,,,,,,,,,,,,,,
,112.87,0.04,113.08,3.20,113.29,0.00,112.66,4.03,,,,,,,,,,,,,,,,,
,113.69,0.03,113.91,3.15,114.12,0.00,113.49,3.96,,,,,,,,,,,,,,,,,
,114.54,0.04,114.74,3.12,114.95,0.00,114.33,3.90,,,,,,,,,,,,,,,,,
,115.38,2.07,115.59,1.62,115.79,2.96,115.17,3.97,,,,,,,,,,,,,,,,,
,116.20,0.03,116.42,1.37,116.62,0.00,115.99,0.00,,,,,,,,,,,,,,,,,
,117.04,0.05,117.24,1.93,117.45,0.00,116.83,2.82,,,,,,,,,,,,,,,,,
,117.87,0.04,118.09,1.65,118.31,0.00,117.67,2.36,,,,,,,,,,,,,,,,,
,118.71,0.04,118.92,1.72,119.12,0.00,118.51,2.36,,,,,,,,,,,,,,,,,
,119.54,0.04,119.74,1.71,119.95,0.00,119.33,2.38,,,,,,,,,,,,,,,,,
,120.37,0.03,120.58,1.74,120.80,0.00,120.16,2.41,,,,,,,,,,,,,,,,,
,121.19,0.03,121.40,1.58,121.60,0.00,120.99,2.46,,,,,,,,,,,,,,,,,
,122.02,2.21,122.22,-0.83,122.44,3.02,121.81,0.00,,,,,,,,,,,,,,,,,
,122.87,2.67,123.09,-0.83,123.29,2.49,122.66,0.00,,,,,,,,,,,,,,,,,
,123.70,2.64,123.91,-0.83,124.12,2.49,123.49,0.00,,,,,,,,,,,,,,,,,
,124.54,2.58,124.74,-0.83,124.94,2.46,124.33,0.00,,,,,,,,,,,,,,,,,
,125.36,2.56,125.59,-0.83,125.81,2.44,125.15,0.00,,,,,,,,,,,,,,,,,
,126.22,2.83,126.43,-0.83,126.64,2.81,126.01,0.00,,,,,,,,,,,,,,,,,
,127.08,2.79,127.29,-0.84,127.50,2.66,126.86,0.00,,,,,,,,,,,,,,,,,
,127.92,2.79,128.14,-0.84,128.35,2.68,127.71,0.00,,,,,,,,,,,,,,,,,
,128.76,2.77,128.96,-0.84,129.16,2.67,128.56,0.00,,,,,,,,,,,,,,,,,
,129.58,2.74,129.79,-0.84,129.99,2.69,129.37,0.00,,,,,,,,,,,,,,,,,
,130.39,2.74,130.60,-0.84,130.81,2.71,130.19,0.00,,,,,,,,,,,,,,,,,
,131.21,2.76,131.41,-0.84,131.61,2.72,131.01,0.00,,,,,,,,,,,,,,,,,
,132.04,2.76,132.24,-0.84,132.44,2.68,131.83,0.00,,,,,,,,,,,,,,,,,
,132.85,2.75,133.06,-0.84,133.25,2.63,132.64,0.00,,,,,,,,,,,,,,,,,
,133.69,2.71,133.90,-0.85,134.11,2.66,133.47,0.00,,,,,,,,,,,,,,,,,
,134.54,2.74,134.75,0.82,134.96,2.44,134.34,0.00,,,,,,,,,,,,,,,,,
,135.39,2.98,135.61,2.03,135.83,2.93,135.17,2.48,,,,,,,,,,,,,,,,,
,136.25,2.62,136.46,1.96,136.67,0.00,136.04,2.88,,,,,,,,,,,,,,,,,
,137.08,0.04,137.28,1.66,137.49,0.00,136.87,2.53,,,,,,,,,,,,,,,,,
,137.89,0.04,138.10,1.70,138.31,0.00,137.69,2.55,,,,,,,,,,,,,,,,,
,138.71,0.04,138.91,1.64,139.11,0.00,138.51,2.34,,,,,,,,,,,,,,,,,
,139.52,0.04,139.72,1.60,139.92,0.00,139.32,2.35,,,,,,,,,,,,,,,,,
,140.36,0.04,140.58,1.50,140.79,0.00,140.14,2.30,,,,,,,,,,,,,,,,,
,141.21,1.62,141.41,0.62,141.62,1.54,141.00,1.34,,,,,,,,,,,,,,,,,
,142.04,1.64,142.24,1.05,142.44,2.27,141.83,1.34,,,,,,,,,,,,,,,,,
,142.85,2.10,143.06,-0.86,143.27,1.89,142.64,0.00,,,,,,,,,,,,,,,,,
,143.68,2.01,143.89,-0.86,144.10,1.89,143.48,2.48,,,,,,,,,,,,,,,,,
,144.53,1.51,144.75,0.98,144.96,0.00,144.32,2.19,,,,,,,,,,,,,,,,,
,145.37,0.04,145.58,0.97,145.79,0.00,145.16,1.70,,,,,,,,,,,,,,,,,
,146.19,0.04,146.41,0.97,146.61,0.00,145.99,1.70,,,,,,,,,,,,,,,,,
,147.04,0.04,147.24,-0.86,147.45,0.00,146.84,1.70,,,,,,,,,,,,,,,,,
,147.85,0.02,148.06,-0.87,148.26,0.00,147.65,0.00,,,,,,,,,,,,,,,,,
,148.66,0.02,148.87,-0.88,149.08,0.00,148.46,0.00,,,,,,,,,,,,,,,,,
,149.49,0.02,149.70,-0.88,149.91,0.00,149.29,0.00,,,,,,,,,,,,,,,,,
,150.33,0.02,150.54,-0.88,150.74,0.00,150.12,0.00,,,,,,,,,,,,,,,,,
,151.15,0.02,151.35,-0.88,151.56,0.00,150.94,0.00,,,,,,,,,,,,,,,,,
,151.96,0.02,152.16,-0.87,152.37,0.00,151.76,0.00,,,,,,,,,,,,,,,,,
,152.78,0.05,152.97,1.21,153.17,0.00,152.58,2.15,,,,,,,,,,,,,,,,,
,153.57,0.04,153.78,1.36,153.98,0.00,153.36,1.90,,,,,,,,,,,,,,,,,
,154.41,0.04,154.63,1.90,154.84,0.00,154.19,2.58,,,,,,,,,,,,,,,,,
,155.25,0.04,155.46,1.79,155.67,0.00,155.04,2.94,,,,,,,,,,,,,,,,,
,156.08,0.04,156.29,1.84,156.50,0.00,155.87,2.71,,,,,,,,,,,,,,,,,
,156.93,0.04,157.13,1.74,157.34,0.00,156.72,2.67,,,,,,,,,,,,,,,,,
,157.75,0.04,157.97,1.65,158.19,0.00,157.54,2.62,,,,,,,,,,,,,,,,,
,158.62,0.04,158.83,1.64,159.04,0.00,158.41,2.52,,,,,,,,,,,,,,,,,
,159.46,0.04,159.66,1.59,159.87,0.00,159.25,2.36,,,,,,,,,,,,,,,,,
,160.28,1.89,160.47,1.49,160.67,2.09,160.08,2.36,,,,,,,,,,,,,,,,,
,161.11,2.49,161.33,-0.52,161.54,2.84,160.89,0.32,,,,,,,,,,,,,,,,,
,161.97,3.10,162.18,-0.87,162.39,2.84,161.75,0.36,,,,,,,,,,,,,,,,,
,162.80,2.76,163.01,-0.86,163.21,2.58,162.60,0.00,,,,,,,,,,,,,,,,,
,163.62,2.80,163.83,-0.86,164.04,2.59,163.41,0.00,,,,,,,,,,,,,,,,,
,164.44,2.59,164.65,-0.87,164.85,2.48,164.24,0.00,,,,,,,,,,,,,,,,,
,165.26,2.54,165.46,1.55,165.66,0.43,165.06,2.37,,,,,,,,,,,,,,,,,
,166.09,0.03,166.29,2.07,166.50,0.00,165.86,2.84,,,,,,,,,,,,,,,,,
,166.92,0.05,167.12,1.91,167.33,0.00,166.71,2.77,,,,,,,,,,,,,,,,,
,167.74,0.04,167.94,1.86,168.14,0.00,167.54,2.63,,,,,,,,,,,,,,,,,
,168.55,0.04,168.75,1.81,168.97,0.00,168.35,2.64,,,,,,,,,,,,,,,,,
,169.39,0.04,169.61,1.83,169.83,0.00,169.18,2.65,,,,,,,,,,,,,,,,,
,170.25,0.04,170.46,1.83,170.67,0.00,170.04,2.65,,,,,,,,,,,,,,,,,
,171.08,0.04,171.29,1.77,171.49,0.00,170.87,2.62,,,,,,,,,,,,,,,,,
,171.90,0.04,172.10,1.48,172.31,0.00,171.69,2.27,,,,,,,,,,,,,,,,,
,172.72,0.04,172.94,1.58,173.15,0.00,172.50,2.36,,,,,,,,,,,,,,,,,
,173.59,0.04,173.79,1.92,174.00,0.00,173.36,2.74,,,,,,,,,,,,,,,,,
,174.41,0.04,174.62,1.54,174.83,0.00,174.21,2.49,,,,,,,,,,,,,,,,,
,175.24,0.04,175.44,1.58,175.65,0.00,175.04,2.45,,,,,,,,,,,,,,,,,
,176.05,0.04,176.26,1.56,176.46,0.00,175.85,2.33,,,,,,,,,,,,,,,,,
,176.86,0.04,177.07,1.49,177.27,0.00,176.66,2.30,,,,,,,,,,,,,,,,,
,177.67,1.77,177.86,1.17,178.08,2.27,177.47,2.02,,,,,,,,,,,,,,,,,
,178.49,2.33,178.69,-0.89,178.89,2.27,178.29,1.25,,,,,,,,,,,,,,,,,
,179.30,2.33,179.51,-0.89,179.71,2.28,179.10,0.00,,,,,,,,,,,,,,,,,
,180.12,2.61,180.33,-0.89,180.54,2.86,179.91,0.00,,,,,,,,,,,,,,,,,
,180.94,2.90,181.16,-0.89,181.38,2.97,180.74,0.00,,,,,,,,,,,,,,,,,
,181.80,3.09,182.02,-0.89,182.23,3.25,181.59,0.00,,,,,,,,,,,,,,,,,
,182.65,3.21,182.85,-0.89,183.06,3.24,182.44,0.00,,,,,,,,,,,,,,,,,
,183.46,3.21,183.66,-0.89,183.86,3.20,183.26,0.00,,,,,,,,,,,,,,,,,
,184.28,3.16,184.49,-0.89,184.69,3.12,184.08,0.00,,,,,,,,,,,,,,,,,
,185.10,3.06,185.30,-0.89,185.50,3.08,184.90,0.00,,,,,,,,,,,,,,,,,
,185.91,3.05,186.12,-0.89,186.32,3.10,185.71,0.00,,,,,,,,,,,,,,,,,
,186.72,3.08,186.92,-0.89,187.11,3.06,186.52,0.00,,,,,,,,,,,,,,,,,
,187.55,3.01,187.76,-0.89,187.96,2.71,187.33,0.00,,,,,,,,,,,,,,,,,
,188.37,2.72,188.58,-0.89,188.79,2.47,188.17,0.00,,,,,,,,,,,,,,,,,
,189.22,2.72,189.43,-0.90,189.64,2.99,189.00,0.00,,,,,,,,,,,,,,,,,
,190.08,2.89,190.29,-0.89,190.49,2.65,189.86,0.00,,,,,,,,,,,,,,,,,
,190.89,2.67,191.10,-0.89,191.30,2.60,190.70,0.00,,,,,,,,,,,,,,,,,
,191.71,2.64,191.91,-0.90,192.11,2.57,191.51,0.00,,,,,,,,,,,,,,,,,
,192.52,2.63,192.73,-0.90,192.93,2.59,192.32,0.00,,,,,,,,,,,,,,,,,
,193.34,2.64,193.54,-0.89,193.75,2.56,193.13,0.00,,,,,,,,,,,,,,,,,
,194.18,2.71,194.39,-0.89,194.61,2.75,193.97,0.00,,,,,,,,,,,,,,,,,
,195.02,2.77,195.22,-0.89,195.43,2.66,194.82,0.00,,,,,,,,,,,,,,,,,
,195.84,2.73,196.04,-0.89,196.24,2.64,195.63,0.00,,,,,,,,,,,,,,,,,
,196.64,2.67,196.85,-0.89,197.06,2.54,196.44,0.00,,,,,,,,,,,,,,,,,
,197.47,2.61,197.67,-0.90,197.88,2.50,197.27,0.00,,,,,,,,,,,,,,,,,
,198.29,2.56,198.49,-0.90,198.69,2.53,198.08,0.00,,,,,,,,,,,,,,,,,
,199.13,2.62,199.34,-0.90,199.54,2.48,198.91,0.00,,,,,,,,,,,,,,,,,
,199.95,2.55,200.16,-0.90,200.37,2.43,199.74,0.00,,,,,,,,,,,,,,,,,
,200.79,2.47,200.99,-0.90,201.20,2.45,200.58,0.00,,,,,,,,,,,,,,,,,
,201.63,2.65,201.83,-0.90,202.03,2.66,201.41,0.00,,,,,,,,,,,,,,,,,
,202.44,2.73,202.64,-0.90,202.86,2.69,202.24,0.00,,,,,,,,,,,,,,,,,
,203.28,2.71,203.48,-0.90,203.68,2.73,203.07,0.00,,,,,,,,,,,,,,,,,
,204.12,2.80,204.32,-0.90,204.54,2.78,203.89,0.00,,,,,,,,,,,,,,,,,
Dr Sheldon
Windsor UK
C?ID=334979
Looking at your DTC
Your data log above ^^
Have you tried reading it and making any sense of it ?? It is horrible !! It hurt my eyes !!
The DTC refers to the Position Sensor for Clutch 1 - I would guess that is a Hall Effect Affair taking a linear measurement ??
Yet you are concerned about pressures ??
NO !
It is well documented in >> ERWIN <<
Again >> ERWIN << You would be well advised to replace the complete Mechatronic Unit
dude04
New Zealand
C?ID=266974
Hi Dr Sheldon,
Thank you for answering questions about "where to do what" in VCDS with the Erwin reference - I was not aware and apologies for the redundancy.
Regarding the log data yes I do agree it's hard to read... you will need to copy+paste it into Excel/Sheets/similar to use the comma tabulation. I thought it better to share the data and let the viewer do their own tabulation rather than try to post a spreadsheet file.
I accept that the DTC specifically says "Position" and not "Pressure".
I guess the reason I am looking at the pressure sensors is that when I research P1735 on Google etc. a lot of the forums threads and repair shop blogs seem to be conflating the two, e.g.:
There seems to be a correlation between P1735 and the pressure sensor. However I accept that I may be totally wrong...
Thank you
dude04
New Zealand
C?ID=266974
Hi Dr Sheldon,
I have received the following information from the sensor supplier:
The error code is a bit confusing, but what pressure sensor in this transmission does is to use pressure readings to correlate with adaptation data to calculate the position of the clutch.
So, I believe I am indeed on the right track with the sensors.
What is left to establish is what are the expected readings on these sensors and what readings indicate issue. E.g. the 0.75bar difference I allude to in my first post.. is this normal/expected?
