2013 Touareg, Steering Angle Sensor (signal implausible) Australia
Daz069
Australia
C?ID=511201
Hi there, this is my first time posting in the forum.
Couple of years ago I replaced the bearings & seals in the front diff. Upon replacement, I don't believe that the steering box was aligned to center due to the way the diff had to go back in. My calibration was out & in my infinite wisdom at the time thought that I'd just rest the calibration.
Since that moment, I've had the Christmas tree light up with ABS, Head Light, Traction Control, Height Control, ect. The car still drives fine, height control still works, the steering assisted headlight don't work, ABS & Traction I can't comment on as I don't drive it that hard.
I have tried several times to clear the fault codes, most of initially do, then reappear after a new scan.
I assume all of this is relevant to my SAS recalibration.
I have included the latest scan, including one after the initial refit in 2023, Unfortunately I have nothing prior. I have however noticed in module 34 that the Kms & Dates are way out. Any help towards this matter would be greatly appreciated.
I am not competent with the full VCDS workings, nor am I tech savvy, mainly learnt with the help of YouTube so please forgive my ignorance in advance.
Darryl
Monday,21,April,2025,11:00:12:15672
VCDS Version: 25.3.1.1 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WVGZZZ7PZDD031994   License Plate: 500EY2
Mileage: 319594km-198586mi   Repair Order: 21/04/25
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
          6C 6D 72
VIN: WVGZZZ7PZDD031994   Mileage: 319594km-198586miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H40 0003
   Revision: 53H40---    CVN: F49CE9BD
   Coding: 292A4012232E01020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001004
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 323675C504ACB21A49E-8066
   VINID: 9E65EAAAA1E0A945000C1249106745590B
10585 - Door Control Module - Passenger's Door
          U0200 00 [00101000] - No Communications
                    Mileage: 319073 km
                    Date: 2025.04.12
                    Time: 10:21:29
                    Engine speed: 716.00 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 75  C
                    Intake air temperature: 48  C
                    Voltage terminal 30: 11.900 V
                    Cruise Control System (CCS): status-Bits 0-7: 47
                    selected gear-Bits 0-7: 1
10586 - Door Control Module - Rear Left
          U0201 00 [00101000] - No Communications
                    Fault Frequency: 8
                    Mileage: 319073 km
                    Date: 2025.04.12
                    Time: 10:21:29
7150 - Please Check DTC Memory of Steering Wheel Electronics
          P1698 00 [00101111] - -
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:45:53
                    Engine speed: 0.00 /min
                    Coolant temperature: 26  C
                    Intake air temperature: 29  C
                    Voltage terminal 30: 11.800 V
                    CAN TimeOut meter - battery manager-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    CAN TimeOut meter - gateway-Bits 0-7: 0
                    CAN TimeOut meter - steering angle-Bits 0-7: 0
                    CAN TimeOut meter - parking brake-Bits 0-7: 0
                    CAN TimeOut meter - transmission-Bits 0-7: 0
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 BK    HW: 0C8 927 750 BK
   Component: AL1000 AISIN  002 2268
   Serial number:                CVN: 3CF24403
   Coding: 001568
   Shop #: WSC 08248 004 1048576
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031_002.rod
   VCID: 76BE89D5A844EE3AA56-8022
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 405330010EC815
   Coding: 5B6B13C34B272554DAFDC89CD2D6A450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4AC60D258C3CDADA11E-801E
199304 - Steering angle sensor
          B1168 29 [10001001] - Signal Implausible
                    Reset counter: 16
                    Mileage: 319594 km
                    Date: 2025.04.21
                    Time: 10:09:18
                    Standard Freeze  Frame Dynamic: 00 46 00 00 00 00 00 00 01 00 01 20 18
199182 - Steering angle sensor
          B1168 04 [10001001] - Internal System Fault
                    Reset counter: 16
                    Mileage: 319594 km
                    Date: 2025.04.21
                    Time: 10:09:18
                    Standard Freeze  Frame Dynamic: 00 46 00 00 00 00 00 00 01 00 01 01 24
   Part No SW: 4H0 907 064 CM    HW: 4H0 907 064 CM
   Component: BCM2 2.0      H33 0433
   Coding: 01B60010000000000000
   VCID: 76BE89D5A8C4EE3AA56-8022
   Subsystem 1 - Part No SW: 7P6 959 754 AC    HW: 7P6 959 754 AC
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0812000189513009
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2313000022415004
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 249
                    Mileage: 318532 km
                    Date: 2025.04.04
                    Time: 13:27:52
                    Fault Status: 00101101
                    Fault Frequency: 11
                    Reset counter: 55
                    Mileage: 318611 km
                    Date: 2025.04.05
                    Time: 12:39:18
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: 3626200890
   VCID: 7EAE91F58074A67AFD6-802A
0249 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
                    Reset counter: 55
                    Mileage: 318645 km
                    Date: 2025.04.05
                    Time: 16:55:30
0318 - Function Restricted due to Missing Message(s)
                    Fault Frequency: 8
                    Reset counter: 55
                    Mileage: 318645 km
                    Date: 2025.04.05
                    Time: 16:55:30
0410 - Function Restriction due to Implausible Message(s)
          U1112 00 [00001001] - -
          [LWI_01: unplausibles Signal]
                    Reset counter: 248
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:45:51
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001517492
   Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
   VCID: 6C8AABBDE68824EA432-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    130208  031 0021
   Serial number: 90243401130219065802
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20047877
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002102130316
                    Fault Status: 01101101
                    Reset counter: 248
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:45:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261303802244
   Coding: 300501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D82001AB160B92D28-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag00T H05 0025
   Revision: --------    Serial number: 003L0006PW34 Dataset Number: 7P5003p____ 0019
   Coding: 000000000000000000000000000000003054
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41D42A09B10A1982C04-8014
   Serial number: 3575LRB401I4UPPOEHQ9
   Serial number: 3585LRB401C50EV49Q1F
   Serial number: 3515RRB401450ET89PIO
   Serial number: 3525RRB401450ET8K0TM
   Serial number: 3555NRB400650DEKQ8RU
   Serial number: 3565NRB400650DEKGPIT
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372ODA0006S
   Coding: 000035
   Shop #: WSC 32606 002 104857
   VCID: 382247EDE250584A77A-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0238683
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 248
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:48:14
                    (no units): 44.0
                    Text: 2C97FFFFFFFF00C0FF
                    Idle Stabilization: 323.85 KW
                    Raw, Index/Key Err.: 255 255 000
                    Text: 369A0000371FCD070D
                    Angle: 0
                    Time: 31.78 s
                    Speed: 15.3 km/h
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 881 G    HW: 7P6 920 881 G
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658190213592014
   Coding: 332731003A00000800000C
   Shop #: WSC 30088 959 00000
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 40D22F0DBA00108ACFA-8014
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H11 6028
   Revision: --------    Serial number: 00000000841623 Dataset Number: 7P6067v____ 0026
   Coding: 000D07AD00
   GVL: FB4F40851D67000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3B2858E1D3E673529A8-806E
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000004190192478
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 13044000546011200181
5073 - Door Control Module - Passenger's Door
          U0200 00 [00001000] - No Communications
                    Fault Frequency: 11
                    Reset counter: 55
                    Mileage: 318611 km
                    Date: 2025.04.05
                    Time: 12:38:32
                    Voltage terminal 30: 12.3 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 29  C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
5074 - Door Control Module - Rear Left
          U0201 00 [00001000] - No Communications
                    Fault Frequency: 11
                    Reset counter: 55
                    Mileage: 318611 km
                    Date: 2025.04.05
                    Time: 12:38:32
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
16385 - Pause Suggestion
          B13CF 00 [00001000] - -
                    Reset counter: 54
                    Mileage: 318515 km
                    Date: 2025.04.04
                    Time: 12:39:59
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 34  C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
   Component: PASM          H04 1800
   Revision: 00000000    Serial number: 00000130380323
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
0807 - Function restriction
          C10C2 00 [10001001] - -
          [D mpferregelung - differenzierter D mpfer-Feststrom - Notlauf 5]
                    Fault Frequency: 16
                    Reset counter: 4
                    Mileage: 792832 km
                    Date: 2066.02.29
                    Time: 10:28:58
                    Default: 00
                    Default: 72
                    Default: 00
12656777 - Databus
          [CAN-Signalfehler LWS]
                    Fault Frequency: 16
                    Reset counter: 4
                    Mileage: 792832 km
                    Date: 2066.02.29
                    Time: 10:32:57
                    Default: 00
                    Default: 72
                    Default: 00
0644 - Level control system
          C10D3 07 [00001000] - Mechanical Failure
                    Fault Priority: 9
                    Fault Frequency: 47
                    Reset counter: 4
                    Mileage: 838912 km
                    Date: 2067.04.08
                    Time: 20:21:07
                    Default: 00
                    Default: 59
                    Default: 00
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000052226427
   Coding: 011D0620D001451005080002
   VCID: 44DA231DAE980CAAEB2-8010
                    Reset counter: 45
                    Mileage: 318645 km
                    Date: 2025.04.05
                    Time: 16:55:34
                    Reset counter: 45
                    Mileage: 318645 km
                    Date: 2025.04.05
                    Time: 16:55:34
   Revision: 00002001    Serial number: 0301189661
   Coding: 0100162028BA108003200624010000000000000000000000000000000000
00165 - Switch for Transmission Position P/N
                    Reset counter: 33
                    Mileage: 318563 km
                    Date: 2025.04.04
                    Time: 16:20:57
                    Fault Frequency: 12
                    Reset counter: 55
                    Mileage: 318611 km
                    Date: 2025.04.05
                    Time: 12:39:18
                    Fault Frequency: 11
                    Reset counter: 55
                    Mileage: 318611 km
                    Date: 2025.04.05
                    Time: 12:39:18
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000052228622
   Coding: 011D0620D001451005080000
   VCID: 3B2858E1D36673529A8-806E
02111 - Motor for Window Regulator
                    Fault Status: 01101100
                    Reset counter: 248
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:51:58
                    Reset counter: 248
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:51:58
                    Fault Frequency: 14
                    Reset counter: 56
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 12:17:00
02117 - Motor for Mirror Folding
                    Fault Status: 00101011
                    Reset counter: 54
                    Mileage: 319510 km
                    Date: 2025.04.17
                    Time: 15:21:03
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1322200167    Dataset Number:             A001
   Coding: 01040100
   Shop #: WSC 05787 002 1048576
   ROD: EV_ParkbA7.rod
   VCID: 363E49D5E8C4AE3A656-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0009
   Coding: 01AE00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CAA9BFD9668B46AD32-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
13705992 - Databus
          U1123 00 [10001001] - Received Error Message
          [Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 248
                    Mileage: 318489 km
                    Date: 2025.04.04
                    Time: 11:45:51
   Part No SW: 4G1 035 053 G    HW: 4G1 035 053
   Component: Radio U Basic H41 0121
   Revision: AB001007    Serial number: 227B.0D7698140
   Coding: 040005020100000003
   VCID: 231880814BD62B92B28-8076
   Part No SW: 7P6 035 764 D    HW: 7P6 035 764
   Component: H-BNT-RW      H46 0593
   Revision: --------    Serial number: 479BZ0D7524034
   Coding: 010A01050040C1EF01000B0E00000003F00001030000000000
   VCID: 3A265DE5DC5C4A5A81E-806E
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M78022WA
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  4949
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000052901780
   Coding: 011C04200001251005080000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H06000    Serial number: 525 PA8J320280
   Coding: 0020001
   VCID: 372044D1E34E57327E0-8062
                    Reset counter: 14
                    Mileage: 319510 km
                    Date: 2025.04.17
                    Time: 17:13:22
                        Reverse OFF
                    Count: 3
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 029301428 Dataset Number: 7P6959107C  D045
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   VCID: 3FD02CF1C7FE6F72B60-806A
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000052905756
End----(Elapsed Time: 01:53, VBatt start/end: 11.9V/12.1V. VIgn 11.9V)-----
------------------------------29 Faults Found------------------------------
Address 03: DTCs cleared
Address 16: DTCs cleared
Address 0x16,4H0 953 568 H,Basic Settings,Group 001
                Address 16: Steering wheel  (4H0 953 568 H)
11:10:26 Group 001: Steering Angle Sensor (G85) Calibration
  SteerAng n.Init  Status
  0.00
       111
  N/A
11:18:05 Group 001: Steering Angle Sensor (G85) Calibration
  0.00
       111
  N/A
11:18:07 Group 001: Steering Angle Sensor (G85) Calibration
  0.00
       111
  N/A
Wednesday,08,November,2023,15:09:55:15672
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
Mileage: 291651km-181223mi   Repair Order:
          6C 6D 72
VIN: WVGZZZ7PZDD031994   Mileage: 291651km-181223miles
   ROD: EV_ECM30TDI011_VW52.rod
   VCID: 323675C504ACB21AE97-8066
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:34:57
                    Engine RPM: 0.00 /min
                    Coolant temperature: 65  C
                    Intake air temperature: 47  C
                    Voltage terminal 30: 12.020 V
   Coding: 001568
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: 76BE89D5A844EE3A05F-8022
   VCID: 4AC60D258C3CDADAB17-801E
                    Reset counter: 94
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:39:09
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 00 00 00 01 20 18
                    Reset counter: 94
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:39:09
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 00 00 00 01 01 24
   VCID: 76BE89D5A8C4EE3A05F-8022
   Coding: 3626200890
   VCID: 7EAE91F58074A67A5DF-802A
                    Reset counter: 94
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:27:31
   VCID: 6C8AABBDE68824EAE3B-8038
   Coding: 004DBD
   Coding: 025223
                    Reset counter: 94
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:43:00
   Coding: 308501
   VCID: 43D82001AB160B92721-8016
   VCID: 41D42A09B10A198260D-8014
   Coding: 000015
   Shop #: WSC 32606 002 1048576
   VCID: 382247EDE250584AD73-806C
            014 - Defective
                    Reset counter: 94
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:43:42
                    (no units): 44.0
                    Angle: 0
                    Time: 31.78 s
                    Speed: 15.3 km/h
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 40D22F0DBA00108A6F3-8014
   Coding: 000D07AD00
   VCID: 3B2858E1D3E673523A1-806E
   Voltage stabilizer:
                    Reset counter: 150
                    Mileage: 291002 km
                    Date: 2023.10.26
                    Time: 03:19:44
                    Voltage terminal 30: 14.4 V
                    Control Module temperature: 33  C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Coding: 14210000
                    Fault Priority: 11
                    Fault Frequency: 116
                    Reset counter: 4
                    Mileage: 40448 km
                    Date: 2044.12.21
                    Time: 10:44:60
                    Default: 00
                    Default: 6B
                    Default: 00
12656777 - Databus
                    Fault Priority: 10
                    Reset counter: 4
                    Mileage: 40448 km
                    Date: 2044.12.21
                    Time: 10:44:60
                    Default: 00
                    Default: 6B
                    Default: 00
   VCID: 44DA231DAE980CAA4BB-8010
   VCID: 3B2858E1D36673523A1-806E
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 363E49D5E8C4AE3AC5F-8062
   Slave 3:
   VCID: 7CAA9BFD9668B46A73B-8028
   Coding: 130000
   Coding: 130000
13705992 - Databus
                    Reset counter: 94
                    Mileage: 290974 km
                    Date: 2023.10.25
                    Time: 18:47:49
   VCID: 231880814BD62B92121-8076
   VCID: 3A265DE5DC5C4A5A217-806E
   Coding: 0020001
   VCID: 372044D1E34E5732DE9-8062
                    Reset counter: 94
                    Mileage: 290974 km
                        Reverse OFF
                    Count: 3
   Coding: 0533314002
   VCID: 3FD02CF1C7FE6F72169-806A
End----------(Elapsed Time: 01:52, VBatt start/end: 14.4V/14.4V)-----------
                Address 16: Steering wheel       Labels: 4H0-953-568.clb
Control Module Part Number: 4H0 953 568 H    HW: 4H0 953 568 H
  Component and/or Version: Lenks.Modul   H04 0005
           Software Coding: 000015
            Work Shop Code: WSC 32606 002 1048576
Fault Codes have been Erased
EuroX
Northern NJ USA
C?ID=208579
SAS defective fault I would assume steering wheel was turned during some sort of removal or steering shaft disconnected. I would check to see if SAS is seeing steering angle change when you steer. If not I would say clock spring is fucked. Does the horn work or the buttons on the steering wheel? If not well then we know clock spring is fucked.
Daz069
Australia
C?ID=511201
Thank you both for your input. I have followed the steering wheel electronics page without any joy & with the SAS component, all functions on the wheel work & it comes up fine with the vcds on the computer, I'm just unable to access some of the functions.
EuroX
Northern NJ USA
C?ID=208579
Did you input the SA as required to perform the calibration? did you look to see if the steering angle is changing when you turn the steering wheel? All things that were mentioned that are kind of important.
