Resolved What does this fault mean? 2021 Audi A8 D5
Resolved
91quattro
C?ID=280133
I recently bought a 2021 A8 D5, 44K miles. I had limited access to past service records but all service was done by the Audi dealer in Costa Mesa, CA. The car is still under warranty. All service was regular routine maintenance, but I noticed that at 38K miles, the steering wheel was replaced. I upgraded my VCDS and got a HEX-V2 and ran a scan to check it out, and found very strange results for 19 - CAN Gateway.
The car has almost every Driver Assistance option - Adaptive Cruise, Lane Departure, Parking Aid, Pre Sense front and rear, Cross Traffic, etc. The only option it doesn't have is Parking Assistance which is fine with me, I'd probably never use it. But I do notice that the steering wheel does not vibrate even though it is enabled and should do that when changing lanes without signaling.
Does anyone know what the 19 - CAN Gateway fault means? It's like the car is expecting one thing and finding something different. I have wondered if the wrong steering wheel was installed at 38K, or if the coding is not correct. Any ideas are appreciated.
Chassis Type: F8-AU65 (4KL)
Scan: 01 02 03 06 09 13 15 16 17 19 1B 29 36 39 3C 42 44 46 52 5F
          61 6D 74 75 81 82 A5 BB BC C4 CA CB CC CD CF D6 D7 DB DC DD
          DE E0
VIN: WAU8DAF8XMN006002   Mileage: 75218km-46738miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
E0-Auxiliary Display 1 -- Status: OK 0000
Address 01: Engine (J623-CZSE)       Labels: None
   Part No SW: 4N0 907 559 AA    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0002
   Revision: B8H11000    CVN: 7D510D92
   Coding: 0A2A0012256E010E34286000000400000000000000000000
   Shop #: WSC 02664 785 00200
   ASAM Dataset: EV_ECM30TFS0114N0907559AA 001004
   ROD: EV_ECM30TFS0114N0907559AA.rod
   VCID: 77AC35F8FF47AB22BED-8022
   VINID: 9D1948511588A1D78000600008D34359B8
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4N0 927 158 H    HW: 0D5 927 156 P
   Component: 0D5  30TSINAR H05 1004
   Revision: --H05---    CVN: 66C3868400005592
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011.rod
   VCID: 3A2AECCC8CD5764A813-806E
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 2009091655
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4N0 907 379 AQ    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0857
   Dataset Number: 4N0909504BB 0001 CVN: F5315B11
   Coding: 28AA169D31A24B9C119E4C911A7FD1E2F5398914688CD28832588B47AF9C91
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 074C45388FA7DBA2CED-8052
   Part No SW: 4M6 959 760 D    HW: 4M4 959 760 D
   Component: MEM-BFS       009 0064
   Serial number: 00000420321192 Dataset Number: 4N0909866E  0018
   Coding: 011CB2400005BEA148438181A101A10081A100070700878700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3FDC9DD897F75362B6D-806A
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ80011009204025876D
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ8001150920114701E7
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 JE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 4N0909514M  0036
   Coding: 07500363E0691CCD070E57A81CEE9C2A131BB7511406049381000A000201160008690002001000000000070300470818380210304001F107000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7AAA2CCCCC55B64AC13-802E
   Subsystem 1 - Part No SW: 4N1 955 119     HW: 4N1 955 119
   Component: WWS651 190720  052 0915
   Serial number: 904753F0301920103445
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 20047593X81A955555B0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4N1 941 501 C    HW: 4N1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 21S12.08.2000690587
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z01HW02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR108092023311210
   Interior Light Module:
   Subsystem 6 - Part No SW: 4N0 947 135 CT    HW: 4N0 947 135 CT
   Component: Dachelektroni  H42 0063
   Serial number: 00000701030000000000
   Coding: 200000
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H07 0200
   Serial number: WA143881000090023872
   Coding: 0A0700
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK24739674
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK24752643
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK24739663
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK24739684
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 B    HW: 4N0 907 605
   Component: J1100/SWP  H21 0015
   Serial number: 00000000002025400204
   Coding: 020000
   Interior Light Module 2:
   Subsystem 13 - Part No SW: 4N0 947 111 G    HW: 4N0 947 111 G
   Component: Dachelektroni  H42 0060
   Serial number: 00000715780000000000
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4N0 907 561 L    HW: 4N0 907 561
   Component: LRR4          H12 0641
   Dataset Number: 4N0909863VE 0002
   Coding: D5659F5478082C00010360E0000000BE4A1246484481409E25
   Shop #: WSC 02613 007 1048576
   ASAM Dataset: EV_ACCBOSCHAU65X 002036
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   Part No SW: 4N0 959 655 AC    HW: 4N0 959 655 AC
   Component: AirbagVW31    H05 2844
   Serial number: 0031JM00754I Dataset Number: 4N0909602BB 0010
   Coding: BFFCF0C080C00500A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
   VCID: 7DA027D0DD7B8172E41-8028
   Left seat belt tensioner:
   Serial number: 00AI2020265709800000
   Coding: 0A0301
   Right seat belt tensioner:
   Serial number: 00AI2020267679800000
   Coding: 0A0301
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D20000ED7RJ0C
   Coding: 303237
   Subsystem 4 - Part No SW: -----------    HW: 480 001 709 20
   Serial number: 35700000000E7A98EB46
   Subsystem 5 - Part No SW: -----------    HW: 480 001 709 20
   Serial number: 35800000000326152C48
   Subsystem 6 - Part No SW: -----------    HW: 480 032 209 20
   Serial number: 351002C0C124AE203C63
   Subsystem 7 - Part No SW: -----------    HW: 480 032 209 20
   Serial number: 352002C0C1352AB09887
   Subsystem 8 - Part No SW: -----------    HW: 480 032 209 20
   Serial number: 355002C0C13D2C10DAEM
   Subsystem 9 - Part No SW: -----------    HW: 480 032 209 20
   Serial number: 356002C0C1362A50BA9B
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 709 20
   Component: CentrSensorXY  005 0148
   Serial number: I0O0001C0F52BCD0E75A
   Part No SW: 4N0 907 129 KD    HW: 4N0 907 129 KD
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_VW53.rod
   Part No SW: 4N0 920 890 E    HW: 4N0 920 890 E
   Component: FBenUSA------ H24 0053
   Coding: 0BE65EE17E88CF050290E3609800430008000000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 3334C1E8ABBF8702425-8066
   Part No SW: 4KL 907 468 F    HW: 4K1 907 468 C
   Component: Gateway       H06 0613
   Serial number: F0454941339011 Dataset Number: 4N0909515VA 0003
   Coding: 02010001000406405496000000590132DC980048180000000900008E00000000
   Shop #: WSC 28252 005 1048576
   GVL: F1517C080800000002FC88008100C800110E0070010000000000000000006700
   ASAM Dataset: EV_Gatew31xAU65x 003250
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 53F4A1680B7FA702625-8006
   Subsystem 1 - Part No SW: 4N0 951 523 L    HW: 4N0 951 523 L
   Component: E221__MFL  H50 0054
   Subsystem 2 - Part No SW: 4N0 915 181 A    HW: 4N0 915 181 A
   Serial number: 758854030020070800D5
   Subsystem 3 - Part No SW: 4N0 419 508 B    HW: 4N0 419 508 B
   Component: J1158 KLR  H03 0020
   Serial number: 22154010502S0020H032
67072 - Local Databus
          U1125 00 [00001001] - Additional Installations Detected
          [Local_Data_Bus_Component_List_detected]
                    Reset counter: 156
                    Mileage: 75218 km
                    Date: 2025.04.04
                    Time: 12:21:04
                    Install. list of subsystems: act. install.-Generator: Not available
                    Install. list of subsystems: act. install.-Multifunction steering wheel control module: Not available
                    Install. list of subsystems: act. install.-Battery Monitoring Control Module: Available
                    Install. list of subsystems: act. install.-Inverter for electrical outlet: Not available
                    Install. list of subsystems: act. install.-Starter generator: Not available
                    Install. list of subsystems: act. install.-Steering Wheel Touch Recognition Control Module: Not available
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x01: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x02: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x03: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x1E: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x93: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x94: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x95: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x04: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x05: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x06: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x07: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x08: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0A: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0B: 15
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0E: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0F: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x12: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x13: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x14: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x15: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x16: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1A: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1B: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x23: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x24: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x27: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2A: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2B: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2D: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2E: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x30: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x31: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x3B: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x41: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x42: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x43: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x44: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x46: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x47: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x49: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4A: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4B: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4D: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4E: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4F: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x53: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x56: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x57: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x59: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x60: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x61: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x63: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x64: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x67: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x69: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x6A: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x73: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x76: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x77: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x78: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7B: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x80: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x84: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x87: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x88: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x89: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8A: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8B: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8C: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8E: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8F: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9D: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9E: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xA0: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAE: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB5: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB7: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB8: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xBA: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC3: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC4: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC5: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC6: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC7: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC8: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF0: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF1: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF2: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF3: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF5: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF6: 0
                    Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF7: 0
   Part No SW: 4N0 907 144 D    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0803
   Serial number: 30303030303030 Dataset Number: 4N0909848J  0001
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2F3CCD984797A3E226D-807A
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   Dataset Number: 4N0909519D  0019
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 303ECEE45AA9BC1A3F7-8064
   Component: MEM-FS        009 0064
   Serial number: 00000420328243 Dataset Number: 4N0909856C  0016
   Coding: 011C9A400005BEA1480301012101210081A100070700878700000000004000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800109092040258488
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ8001150920114701E9
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 4N0909520D  0019
   Part No SW: 4N0 907 566 AM    HW: 4N0 907 566 A
   Component: MRR_HR H14 0588
   Dataset Number: 4N0909535H  0024
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 01585B20A183E592809-8054
   Part No SW: 4M1 959 953 J    HW: 4M1 959 953 C
   Component: TSG FS005 0430
   Serial number: YE007TI402977 Dataset Number: 4N0909872C  0051
   Coding: 001DCB00520014C2B009A036
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 44D69234FE1130BAEBF-8010
   Dataset Number: 4N0909852N  0001
   Coding: E1000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323AC4EC54A58E0A493-8066
   Part No SW: 4N0 907 064 EG    HW: 4N0 907 064 G
   Component: BCM2 MLBevo H16 0224
   Dataset Number: 4N0909501H  0059
   Coding: 013400004FB000C0650FA0046C05090E0B004000810426502F0400200F04823F001E0681010015
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   VCID: 78AE36C4F259A45AB77-802C
   ID - sensor:
   Serial number: 3620000103993011
   Serial number: 000000000ZY2022031DG
   Serial number: 00000000000033355035
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14805449
   Rear spoiler control module:
   Part No SW: 4M1 959 952 J    HW: 4M1 959 952 C
   Component: TSG BFS005 0430
   Serial number: YE007TFO26239 Dataset Number: 4N0909873C  0051
   Coding: 001DCB005E0014C2B009A034
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 43D49128FB1F3782D25-8016
   Part No SW: 4M2 035 092 J    HW: 4M2 035 092
   Component: MU-TP-NS-US   042 3696
   Serial number: GRO-63323.06.20 Dataset Number: 4N4909545C  0019
   Coding: 16510010802000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 4N0 919 605 J    HW: 4N0 919 605 F
   Component: DU AU651 Top   H31 0055
   Serial number: INX00107072000210299
   Subsystem 2 - Part No: V03 959 822 QB
   Component: MIB3_NA_       1346
   Compact disc data bank:
   Component: Gracenote2     3004
   Multimedia display unit 5:
   Subsystem 4 - Part No SW: 4N0 919 603 J    HW: 4N0 919 603 F
   Component: DU AU651 Bot   H32 0054
   Serial number: INX00112072000170902
   Volume Control 1:
   Subsystem 5 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00007520000109440052
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: HHA-07324.09.2034860
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290823807973CDD2F89-807C
   Part No SW: 8W5 959 107 D    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8791-2 Dataset Number: 4N0909541B  0005
   Coding: 1430
   VCID: 47CC8538CF271BA20ED-8012
Address 74: Chassis Control (J775)       Labels:* 4N0-907-777.clb
   Part No SW: 4N0 907 777 AQ    HW: 4N0 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 1909200189  Dataset Number: 4N0909576AC 0008
   Coding: 745C4843F850
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 0948430099B3ADD2D89-805C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132061468
   Coding: 303030
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4KE 035 283 F    HW: 4KE 035 283 B
   Component: CB_H_NAR      039 0372
   Serial number: A971I0LS058961 Dataset Number: 4K0909612F  0011
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 20081461380354
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 270C25B86F67FBA2EED-8072
Address 82: Head Up Display (J898)       Labels:| 4Nx-919-617-V1.clb
   Part No SW: 4N1 919 617 C    HW: 4N1 919 617 C
   Component: HeadupDisplay H15 5951
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 372CF5F8BFC76B227ED-8062
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* Redir Fail!
   Part No SW: 4K4 907 117 J    HW: 4K4 907 117
   Component: zFAS Var C    H09 0381
   Dataset Number: 4N0909466VB 0065
   Coding: 020184000000000000FFD60000B4D50C131F5600000000D8000000000096D401019BA8000000000000000080000000000000000000000000F980400000000000000012040080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 003010
   ROD: EV_ZFASAU516_003.rod
   VCID: 3632F8FCB8CD922A65B-8062
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0430
   Serial number: YE007TGT04554 Dataset Number: 4N0909897C  0051
   Coding: 000DCB00000014C2E008A024
   VCID: 48CE8604C23914DA077-801C
   Component: TSG HBFS004 0430
   Serial number: YE007TGT0463A Dataset Number: 4N0909896C  0051
Address C4: DC/DC Converter (A7)       Labels: 4K0-959-663.clb
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC20383000639 Dataset Number: 4N0909475B  0016
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 75B03FF0E54BD932AC1-8020
   Dataset Number: 4N0909469D  0005
   Coding: 279050065113
Address CB: Rear Axle Steering (J1019)       Labels:* 4M0-909-145.clb
   Part No SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0398
   Revision: --------    Serial number: CCC_098_B_9056_ Dataset Number: 4N0909904K  0001
   Coding: 42244200
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
   VCID: 3928F3C089D37D52889-806C
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N1 903 028     HW: 4N1 903 028
   Component: BSG-HP1-65    H18 0562
   Serial number: 04012500020747
   Coding: 20000400000000
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
   VCID: 69886380B9F30DD2389-803C
Address CD: Laser Scanner (J1122)       Labels: 4N0-907-660.clb
   Part No SW: 4N0 907 660 E    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0306
   Dataset Number: 4N0909639T  0002
   ASAM Dataset: EV_LaserScannAU651 015021
   ROD: EV_LaserScannAU651_015.rod
11546627 - Laser for Adaptive Cruise
          C12EB F1 [00001001] - Malfunction
          [Heater_Resistance_too_high_error]
                    Mileage: 75190 km
                    Date: 2025.04.03
                    Time: 13:40:28
                    Control Module temperature-Host: external temperature: 38  C
                    Control Module temperature-Zynq: internal temperature: 54  C
                    Control Module temperature-Host: internal temperature: 36  C
                    Control Module temperature-Zynq: external temperature: 35  C
                    Voltage terminal 15: 13.775 V
                    Vehicle speed: 0.00 km/h
                    heating_resistor: 108.42 Ohm
                    heater-Medium power: 0.000 W
                    heater-Voltage: 0.000 V
                    heater-PWM value: 0 %
                    heater-Current draw (mean value): 0.000 A
                    Heating and cleaning management-Visibility: 0 %
                    Heating and cleaning management-Degree of contamination: 3 %
                    Heating and cleaning management-Heating status: 02
                    Heating and cleaning management-Cleaning status: 02
                    Outside temperature: 22  C
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0588
   Dataset Number: 4N0909468H  0024
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
   Part No SW: 7PP 941 571 AF    HW: 7PP 941 571 A
   Component: LED1L         H13 0010
   Dataset Number: 4N0909471E  0015
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 1968134029135D52689-804C
   Component: LED1R         H13 0010
   Dataset Number: 4N0909472E  0015
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 AM    HW: 4N0 907 669 A
   Component: MRR_VR H14 0588
   Dataset Number: 4N0909482G  0018
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 05504F30B5ABC9B2BC1-8050
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H14 0588
   Dataset Number: 4N0909483G  0018
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     006 0002
   Dataset Number: 4N0909581C  0004
   Coding: 23B030065114
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623_VW37.rod
   VCID: 76B238FCF84DD22AA5B-8022
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 231431A81B5F1782B25-8076
Address E0: Auxiliary Display 1 (E857)       Labels: None
   Part No SW: 4N0 035 705 A    HW: 4N0 035 705
   Component: E859          H42 0019
   Serial number: KE0 MK90046876P
   ASAM Dataset: EV_SCC1AU651 001004
   ROD: EV_SCC1AU651.rod
End----(Elapsed Time: 02:56, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------2 Faults Found---------
Dr Sheldon
Windsor UK
C?ID=334979
1 Fault Found: 67072 - Local Databus U1125 00 [00001001] - Additional Installations Detected
That there is telling you that components are installed and the Gateway has not been updated to welcome and involve them to the family !
Exactly that !!
91quattro
C?ID=280133
Thanks - I suspected that. So the gateway is not coded correctly....I need to tell the gateway what is installed. But I can't seem to find any info on how it should be coded based on the car's installed options. The Ross-Tech Wiki has no info on the D5. How can I match up what is installed with how the gateway should be configured? How reliable is the data in the "Experimental" Long Coding helper?
TTT
C?ID=547002
Fault code additional information tells you what is installed and what not.
Since we cannot see what you see, go for it and try!
Right. However, the Gateway Installation List shows no obvious problems, nor do I see anything anywhere else that would explain this.
That's the Installation List, which is shown at the top. Normally, if there was something installed that the Gateway hasn't been told about, you'd see it show up there as "Not Registered". But I don't see anything like that.
Are there any functional problems with this car or are you just trying to make it fault-free?
FWIW, I'm guessing it has something to do with the steering wheel replacement.
Dr Sheldon
Windsor UK
C?ID=334979
That said, although the consensus is that it is a "Coding" issue, there is nothing to say that it is the coding of / in the Gateway !
Address 16: Steering Wheel Electrics would not be the worst place to go looking ?
Was this by the dealer ? Was it a like for like replacement or an Upgrade / Retrofit ?
TTT
C?ID=547002
This?
91quattro
C?ID=280133
California Audi dealer that had done all service on the car since delivery replaced the steering wheel - under warranty. I don't know why - the dealer will not talk to me about the car's past service, or provide any form of copies of the work, or even what the customer complaint might have been to cause the wheel to be replaced - for "liability" reasons. But I suspect the wheel is somehow related to the fault codes. Could a standard wheel have been installed rather than a capacitive one? Or vice versa? I am taking the car to the dealer in the next few days (90VC recall) and they are going to contact the CA dealer and ask for the details of the steering wheel replacement - so I hope to learn new information about it.
Recently I tried out the Lane Departure system, and I can't detect any vibration from the wheel when the Lane Departure function responds to the car drifting into another lane - but the wheel certainly keeps the car in the lane. Yes, the setting in MMI is turned on for the wheel to vibrate. That seems like a clue to me!
Yet, gateway address 16 - Steering Wheel shows no fault codes. But its "subsystems" are not available, looking at 19 - CAN Gateway.
The 27BQ recall (replacement of the belt-starter-generator) was just performed a month ago, and that might somehow be involved in all this, since the Generator and Starter Generator subsystems show as "not available" in the scan. Those, and the steering wheel subsystems, and the Battery Monitoring module and the Inverter for the Electrical Outlet, also show as not available.
Overall the car performs fine as far as I can tell. Everything, except the lack of vibration of the wheel using Lane Departure, appears to work correctly. Keep in mind, I've only had the car for 2 months, buit I think I've probed all functions I'm aware of.
Having said all this, the fault codes in 19 - CAN Gateway seems to me to indicate something is wrong. The fault will not clear. That seems like a problem. So I'm just trying to find out what the fault really is.
As a side note, based on a cursory look at the Gateway Installation List, I also notice:
The car has a backup camera, but the CAN gateway setting for 6C - Backup camera is unchecked.
The car is a quattro but CAN gateway setting for 22 - AWD is unchecked. Not sure what the "AWD" setting is for....
The car has TPMS, but the gateway setting for 65 - Tire Pressure is unchecked.
The car has heat and A/C but the gateway setting for 08 - HVAC is unchecked.
I am used to the concept that the Gateway List represents the equipment that is installed. So I don't understand why these 4 items are not checked in the Gateway List.
Thanks to all for your help with this..
MasterTommy
Amsterdam
C?ID=295586
The units you mention are not checked in the installation list because they are either not installed (Your AWD system is mechanical, no haldex clutch that would need a control unit, TPMS is probably the indirect variant, handled by the ABS without active sensors in the wheels), or have a different address than you think (360° cameras is what your car appears to have, handled by module A5. The BCM at 09 handles HVAC on your car and 5F handles the controls).
Assuming that work was done at a dealership, those details should be in VW/Audi's "Paperless" records that are available to any dealership.
91quattro
C?ID=280133
Thank you MasterTommy. All makes sense. Most of my VCDS experience is from the 2005-2010 era when there weren't so many subsystems. I'll scratch those off my list. And thanks Uwe, I'll mention that to the dealer when I take it in tomorrow.
91quattro
C?ID=280133
Got the car back from the dealer. Well, that was a waste, I might as well have been speaking Swahili to an eighth grader. They didn't bother to check the previous repair records or contact the California dealer, instead they decided to stumble through it. The result, after one day, was the service tech telling me that my car simply doesn't have the steering wheel vibration feature as part of Lane Departure. So I then showed them the on-off MMI setting for.....the steering wheel vibration feature and asked why would you have that MMI setting for a feature that isn't in the car?? No answer.
There is also something in the VCDS scan called "Steering Wheel Touch Recognition Control Module." I assume this so your hands can be detected on the wheel....but the car doesn't have the self-driving or self-parking feature. This is why I wonder if they put a capacitive steering wheel in instead of a standard multifunction wheel when the dealer replaced the wheel in 2023. When that touch recognition wheel is detected, VCDS then tries to look for the multiple sensors around the wheel that will detect your hands, and finds nothing - ?
They did say there are 4 different steering wheels for that car - I am guessing with or without capacitive detection, and LH/RH drive.
So I am back to square one, but I have escalated through Audi Customer Service. And after a "frank" discussion they are escalating on their side as well.
Maybe I should take a look at the coding of the Steering Wheel (16) and the Starter Generator (C29) since those are the things that seem to have missing subsystems...?
One other question - long coding in the CAN gateway (19), Byte 5, Bit 2 is set to "Intelligent Hybrid Installed." This is according to VCDS "experimental long coding data." There is another option, Bit 5, called "Mild Hybrid installed." Since the car is well-known to be a Mild Hybrid, maybe that should be selected instead?
91quattro
C?ID=280133
The first line of the scan reads
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
I just confirmed there is no label file in VCDS for CAN-19. Could that cause these errors?
Nope. Label files just add information to some things. The lack of one cannot cause faults.
Since this car has a starter/generator and a 48V battery, I don't think VAG thinks of this as a "mild" hybrid. No, it's not a plug-in, and no it can't drive on electric power alone, but I believe VAG reserves the the term "mild" for cars that do hybrid stuff with 12V systems.
91quattro
C?ID=280133
Looking at CAN - 19 gateway coding, Byte 01 seems to be the steering wheel type. There are two options, MFL and KLR. MFL (which is checked) is Multi-Function Leather I am guessing. The other option is KLR - is that a capacitive steering wheel?
JeniCzech92
Prague, Czech Republic
C?ID=594546
MFL stands for Multi-Funktion Lenkrad - German for Multi-Function Steering wheel. KLR is Kapacitiv Lenkrad. Yes, German K in places where an English-speaking person would expect C is confusing sometimes :)
When I started with VCDS, I found stuff like "Message received by MSG" a bit confusing.. what message? From where? Turns out from Motor Steuer Gerät - ECU.
The European Commission has just announced an agreement whereby English will be the official language of the EU rather than German, which was the other possibility. As part of the negotiations, Her Majesty's government conceded that English spelling had some room for improvement and has accepted a 5-year phase-in plan that would be known as "Euro English".
In the first year, "s" will replace the soft "c". Sertainly, this will make the sivil servants jump with joy. The hard "c" will be dropped in favor of the "k". This should klear up konfusion and keyboards kan have 1 less letter.
There will be growing publik enthusiasm in the sekond year, when the troublesome "ph" will be replaced with the "f". This will make words like "fotograf" 20% shorter.
In the 3rd year, publik akseptanse of the new spelling kan be expekted to reach the stage where more komplikated changes are possible. Governments will enkorage the removal of double letters, which have always ben a deterent to akurate speling. Also, al wil agre that the horible mes of the silent "e"'s in the languag is disgracful, and they should go away.
By the 4th yar, peopl wil be reseptiv to steps such as replasing "th" with "z" and "w" wiz "v". During ze fifz year, ze unesesary "o" kan be dropd from vords kontaining "ou" and similar changes vud of kors be aplid to ozer kombinations of leters.
After zis fifz yer, ve vil hav a reli sensibl riten styl. Zer vil be no mor trubls or difikultis and evrivun vil find it ezi tu understand ech ozer…
ZE DREM VIL FINALI KUM TRU!!
:cool:
91quattro
C?ID=280133
This morning I changed the wheel type to KLR and re-ran the scan. Same result - no difference in the fault code.
91quattro
C?ID=280133
Happy to report PROBLEM SOLVED!
In the CAN gateway, there are two options for the steering wheel - MFL and KLR. I assumed they were either/or. Didn't consider that it could be both. When both were checked, I saved, and lo and behold, fault is gone. So it was a coding error, the dealer that installed the new steering wheel must not have known to check both MFL and KLR.
Thanks to everyone who chimed in - yes, it was steering wheel related. Yes, it was coding. My mistake was assuming!
