Hello guys,
so I tried lowering my A7 with the following steps:
In chassis control 74
Basic setting
Activate level control
Approach reference level
Adjustment Enter new values
Body height of front left wheel arch edge (value old plus x)
Body height, wheel housing edge, front right (value old plus x)
Body height of rear left wheel housing edge (value old plus x)
Body height of rear right wheel arch edge (value old plus x)
Basic setting
Switch to normal level control function
Clear fault memory
The car lowered, however it got stuck in Service Mode, and I get the error in the dash.
I tried multiple times to switch to normal level control, but that didnt work. I reverted the values to stock, but still doesnt work.
What I noticed however, when I try to activate level control, it never says "running", it instantly goes to "not running", and the same goes for the "switch to normal level control function". After pressing go, it instantly goes to not running, not even showing running, like how i have seen on videos.
Also worth to mention, is that the car got retrofitted a OEM towing hitch, installed by Audi.
I will attach the Autoscan, and the Scan of Module 74. Hope someone can help me out, Im already really frustrated.
Basic setting
Basic setting
Clear fault memory
1B-Active Steering -- Status: Malfunction 0010
32-Differential Locks -- Status: Malfunction 0010
74-Chassis Control -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: Malfunction 0010
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DDVB) Labels: Redir Fail!
Part No SW: 4K0 907 401 K HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0003
Revision: CAH26--- CVN: 17249E2E7965F614755A2113755A211300000000D6C3ECFE
Coding: 1A2A401A037E05033C286000000400000000000000000000
Shop #: WSC 45379 006 1048576
ASAM Dataset: EV_ECM30TDI0114K0907401K 001003
ROD: EV_ECM30TDI0114K0907401J.rod
VCID: 2F3AECEA6799B992260-807B
VINID: 9D196AAAA58219B7800430C41C6FBDE1B8
34193 - Implausible Data Received from ESP Control Module
U0416 00 [00100000] - -
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Engine speed: 0.00 /min
Coolant temperature: 42 ∞C
Intake air temperature: 19 ∞C
Voltage terminal 30: 11.400 V
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s≤
Engine status: COENG_READY
4814 - Voltage Supply 1 for Control Module
U3501 00 [00100000] - Too Low
Mileage: 72004 km
Date: 2025.04.19
Time: 15:25:33
Coolant temperature: 32 ∞C
Intake air temperature: 17 ∞C
Voltage terminal 30: 10.840 V
33352 - Front Sensors for Driver-Assist Systems
U12EF 00 [00100000] - Implausible Signal
[Front sensor system for driver assistance systemsImplausible signal]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Com st X Set2 Val1-Bits 0-7: 0
Com st X Set2 Val2-Bits 0-7: 0
Com st X Set2 Val3-Bits 0-7: 0
Com st X Set2 Val4-Bits 0-7: 0
Com st X Set2 Val5-Bits 0-7: 0
Com st X Set2 Val6-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 1
23402 - Ride Level Control Module
U0132 00 [00100000] - No Communications
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Com st X Set1 Val1-Bits 0-7: 0
Com st X Set1 Val2-Bits 0-7: 0
Com st X Set1 Val3-Bits 0-7: 0
Com st X Set1 Val4-Bits 0-7: 0
Com st X Set1 Val5-Bits 0-7: 0
Com st X Set1 Val6-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 1
Part No SW: 4K0 927 158 AP HW: 0D5 927 156 P
Component: 0D5 30TDIRdW H05 0001
Revision: --H05--- CVN: 7D0A815600009238
Coding: 100000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMALX52011 002015
ROD: EV_TCMALX52011.rod
VCID: 00587F568A87F6EA8FA-8055
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H01 0705
Serial number: 1806190466
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4N0 907 379 AC HW: 4N0 907 379 P
Component: ESP9 Premium H06 0850
Dataset Number: 4K8909504H 0001 CVN: D11B0B40
Coding: 1CAA329731A30B9951A14C95588411E7F5B9C9384C8CD08A321A88E7AF9D93
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 79AE12B2E95DA722C84-802D
7 Faults Found:
13568 - Databus
U1121 00 [00101000] - Missing Message
[ComScl:_PDU_Fahrwerk_01-_Timeout_error]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
72 00 82 00 C2 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
168192 - Databus
[ComScl:_PDU_Fahrwerk_03-_Timeout_error]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:08
482048 - Databus
[ComScl:_Signal_Group_SG_Daempfer_02-_Timeout_error]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
12659201 - Control Module for Suspension
U012A 00 [00101000] - No Communication
[ComScl:_Signal_Group_SG_FDR_02-_Timeout_error]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
72 00 80 00 C2 24 00 00 00 00
12659202 - Control Module for Suspension
[ComScl:_Signal_Group_SG_FDR_05-_Timeout_error]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
275456 - Databus
[ComScl:_Signal_Group_SG_Fahrwerk_06-_Timeout_error]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
200960 - Databus
U1123 00 [00101000] - Received Error Message
[Signal_LWR_Hoehenwert_VL_error_(255)]
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Dataset Number: 4K0909514B 0023
Coding: 07000143C13900DD070C87081CFB9E68131B3710040E009781050A001B3316810A450A028010000000000100004108190D02000144010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74B02386CE3FDA4A9B2-8021
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0730
Serial number: 00000001803260406277
Coding: 7DC727
Serial number: 21527455X81A955555A0
Coding: 0200FF
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H09 0086
Serial number: 13S18.06.1800300353
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z004202
Coding: 210000
Subsystem 5 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE112041823512088
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 E HW: 4K0 947 135 E
Component: Dachmodul H42 0413
Serial number: C00044578
Coding: 0D0104
Front windshield washer pump:
Subsystem 7 - Part No SW: 4N0 907 605 A HW: 4N0 907 605 A
Component: J1100/SWP H09 0005
Serial number: 00000000001815601174
Coding: 040000
405507 - Functional Limitation due to Energy Management
B10CD 00 [00001000] - -
[Function limitation due to energy management system]
Fault Frequency: 19
Reset counter: 234
Mileage: 71971 km
Date: 2025.04.19
Time: 00:38:16
average_Voltage_terminals: 11.80 V
Outside air temperature sensor-Outside air temperature on CAN: 18.00 ∞C
interior_temperature: 21.00 ∞C
Vehicle speed: 0.00 km/h
131073 - Databus
[EFP control module: no signal/communication]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
average_Voltage_terminals: 11.30 V
Outside air temperature sensor-Outside air temperature on CAN: 16.00 ∞C
interior_temperature: 20.00 ∞C
System run time-Engine running time: 65535 s
System run time-Terminal 15 on: 0 s
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 D HW: 4K0 907 561
Component: LRR4R H04 0332
Dataset Number: 4K2909863L 0001
Coding: 5665FF5C78082C00010360E0000000BE4A1246484481009E00
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Control Module temperature: 30 ∞C
Voltage terminal 15: 11.3 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s≤
Adaptive distance regulation: status: ACC_reversible_error
Steering_angle-Data: 1.700 ∞
Yaw_rate-Data: 0.000 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.307 ∞
Misalignment angle: horiz: fast algorithm: 0.174 ∞
Congestion pilot: status: OFF
Outside temperature: 16.00 ∞C
Sensor blindness: radar: no blindness detected
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Voltage terminal 15: 11.2 V
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
2115 - Databus
[FAULT_HMS_FAILURESTATE]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
2341 - Databus
[FAULT_LIDAR_ERROR]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 R HW: 4N0 959 655 R
Component: AirbagVW31 H10 2710
Serial number: 003Z0M004E1- Dataset Number: 4K0909602AC 0004
Coding: AACCF0C00CC00000985400FFF01D41AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 4BC2987AF341E5B22A8-801F
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H09 0115
Serial number: 00AI2018162682000000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H09 0115
Serial number: 00AI2018159331400000
Coding: 04F001
Subsystem 3 - Part No SW: ----------- HW: 480 000 405 18
Serial number: 357000000004E3F44E2W
Subsystem 4 - Part No SW: ----------- HW: 480 000 405 18
Serial number: 35800000000A18054E2H
Subsystem 5 - Part No SW: ----------- HW: 480 032 405 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C10B150D10CE93
Subsystem 6 - Part No SW: ----------- HW: 480 032 405 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C103F114E0BD33
Subsystem 7 - Part No SW: ----------- HW: 480 031 106 18
Component: FrontSensor_D 002 0149
Serial number: 355001C103C961713AD6
Subsystem 8 - Part No SW: ----------- HW: 480 031 106 18
Component: FrontSensor_P 002 0149
Serial number: 356001C103C168B1390$
Subsystem 9 - Part No SW: ----------- HW: 480 031 106 18
Component: PedP_Sensor_C 002 0149
Serial number: 230001C10399A690DAAC
Subsystem 10 - Part No SW: ----------- HW: 480 001 905 18
Serial number: I0M0000000028594FFAM
Subsystem 11 - Part No SW: ----------- HW: 480 001 905 18
Serial number: I0N0000000067594FFAQ
Part No SW: 4N0 907 129 AF HW: 4N0 907 129 AF
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 75B61E82C545C342ACC-8021
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 790 A HW: 4K0 920 790 A
Component: FBenRDWACC--- H11 0151
Dataset Number: 4K0909525B 0021
Coding: 858450E27CA800080093E1609080E80008002000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2B02F8FA5381C5B20A8-807F
16777007 - Databus
[Fahrwerk_Anzeige_01 communication error can_error_timeout]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Address 18: Aux. Heat (J364) Labels:| 4M0-265-105.clb
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H11 0090
Dataset Number: 4K0909858B 0011
Coding: 0D0B01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: 290E02F2597DD7A2F84-807D
Part No SW: 4N4 907 468 AB HW: 4N4 907 468 AB
Component: Gateway H14 0036
Revision: 8W000001 Serial number: 0188W253618320 Dataset Number: 4K0909515B 0028
Coding: 02010005008406408C960000005B0132DC9A004F98000000097F07CF10000000
GVL: F1597C488804000082DC88000104C800110E0070000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 7BA208BAE3619532DA8-802F
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 741863110018060504FC
8519683 - Energy Management Active
U140B 00 [00001000] - -
Fault Frequency: 11
Reset counter: 234
Mileage: 71971 km
Date: 2025.04.19
Time: 00:38:06
EM_vehicle_state: 02 1C
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
131712 - Ride Level Control Module
U0132 00 [00001000] - No Communications
[Timeout_Node_0x80_DiagAdress_74_EFP]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:08
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 C HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0802
Serial number: 30303030303030 Dataset Number: 4K8909848G 0001
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
VCID: 2E04F1EE6093B09A2D6-807B
45568 - Databus
[KFC_IL_02_TIMO]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Expanded ambient data 10-Malfunction type: 00 00
Expanded ambient data 10-Terminal 30 power supply: 11.90 V
Expanded ambient data 10-Steering wheel angle: internal value: 0 ∞
Expanded ambient data 10-Engine current: 0.60 A
Expanded ambient data 10-System status: Engine off
Expanded ambient data 10-Calculated vehicle speed: -140 km/h
Expanded ambient data 10-Active_steering_internal_status: Initializing
Expanded ambient data 10-position_control_mode: NormalPositionControl
Expanded ambient data 10-Steering wheel angle velocity: 0 ∞/s
Expanded ambient data 10-Steering_torque_eps: 0.00 Nm
35328 - Dynamic All Wheel Steering
C12A3 29 [00001000] - Signal Implausible
[KFC_SECURE_RATIO_BY_DAS_TEMP]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Expanded ambient data 10-Malfunction type: 00 01
Expanded ambient data 10-Engine current: 0.70 A
38144 - Databus
[KFC_IL_01_TIMO]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Expanded ambient data 10-Engine current: 0.90 A
46336 - Databus
[KFC_IL_02_SNA]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:38:07
Expanded ambient data 10-Malfunction type: 00 06
Expanded ambient data 10-Engine current: 0.80 A
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605824220201407
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
33263 - Databus
Reset counter: 232
Mileage: 72008 km
Date: 2025.04.19
Time: 17:47:26
Active Backup Function: TEMPORARY SHUTDOWN 20
Status of QSP: Temp_Shutdown
Program Counter: 00 00 00 00
Reset Fault Code: SCM_E_NONE
Number of resets: 0
Active fault: SCM_E_NONE
Active extended fault: SCM_E_EXTENT_NONE
SCM_E_PFM_NOK: inactive
SCM_E_ASIL_RAM_PROT: inactive
SCM_E_ASIL_RAM_DEFECT: inactive
SCM_E_ASIL_ROM: inactive
SCM_E_MC_SUPPLIES: inactive
SCM_E_HW_TSBC_RST_UNLIMITED: inactive
SCM_E_MPT_AUDI: inactive
SCM_E_BSW: inactive
SCM_E_TRAP_X2: inactive
SCM_E_TRAP_X3: inactive
SCM_E_TRAP_NMI: inactive
SCM_E_TRAP_ECC_FLASH: inactive
SCM_E_TRAP_UNKNOWN: inactive
SCM_E_PCP: inactive
SCM_E_HW_MU_RST: inactive
SCM_E_OS_TASK_NOK: inactive
SCM_E_HW_BIST: inactive
SCM_E_HW_MU_CFG: inactive
SCM_E_HW_MU_INVALID_QUESTION: inactive
SCM_E_HW_MU_WRONG_BEHAVIOR: inactive
SCM_E_INT_RST: inactive
SCM_E_HW_TSBC_RST: inactive
SCM_E_LVL2: inactive
SCM_E_TRAP_X1: inactive
Reserved: inactive
SCM_E_SW_RESTART: inactive
SCM_E_SOPC: inactive
SCM_E_VSOUTx: inactive
SCM_E_ADC_REF: inactive
SCM_E_ADC_STUCK_AT__MULTIPLEX: inactive
SCM_E_VDD5: inactive
SCM_E_HW_DEV_ID: inactive
Unlearning counter according OBD: 37
Occurrence_counter_over_length_of_life: 121
FR_ESP_VL_VR_HL_HR_FR_QBit: 0
Front left wheel speed: 0.0 km/h
Wheel speed: right front: 0.0 km/h
Left rear wheel speed: 0.0 km/h
Right rear wheel speed: 0.0 km/h
State EFP: 5
FR_FDR_TV_SollRadDiff_Moment: 0.0 Nm
FR_KBI_Standzeit_02: 837 s
Lateral acceleration sensor 1: -0.04000 m/s≤
Lateral acceleration sensor 1: status: 0
Lateral acceleration sensor 2: -0.22000 m/s≤
Lateral acceleration sensor 2: status: 0
FR_KBI_Reifenumfang: 2156 mm
FR_Motor_Code_01: 2
29562 - Databus
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Status of QSP: Init
Number of resets: 0
SCM_E_BSW: inactive
SCM_E_PCP: inactive
Reserved: inactive
Occurrence_counter_over_length_of_life: 22
State EFP: 2
FR_KBI_Standzeit_02: 3693 s
Lateral acceleration sensor 1: -0.02000 m/s≤
Lateral acceleration sensor 2: -0.14000 m/s≤
FR_Motor_Code_01: 2
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000327265492 Dataset Number: 4K8909856B 0013
Coding: 00581A400000B4010003010101010000000000000000000000000000004000
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 E HW: 4N0 907 566 A
Component: MRR_HR H12 0265
Dataset Number: 4K8909535D 0024
Coding: 1FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
VCID: 3828D7B692D77E2A77A-806D
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS001 0188
Serial number: YE007RFD02974 Dataset Number: 4K8909872B 0027
Coding: 001FDA4252000480A009B432
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 40D8BF56CA0736EACFA-8015
196665 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.19
Time: 23:25:31
196724 - Motors for Central Locking
B122B 13 [00001000] - Open Circuit
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.19
Time: 23:25:29
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H20 0504
Dataset Number: 4KF909852G 0002
Coding: E1002101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313EEA9271ADAF62304-8065
3158277 - Databus
[COMI_TIMEOUT_IL02]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
FreezeFrame_mw_120C_Timeout-Engine speed: 0.00 /min
FreezeFrame_mw_120C_Timeout-System status: 0
FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 11.48 V
FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: 2.42 ∞
FreezeFrame_mw_120C_Timeout-ARA_signal_red_cyclic: 00
FreezeFrame_mw_120C_Timeout-PLA_signal_red_cyclic: 00
FreezeFrame_mw_120C_Timeout-SCU state: System OK
FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
Part No SW: 4N0 907 064 BD HW: 4N0 907 064 D
Component: BCM2 MLBevo H14 0145
Dataset Number: 4K8909501D 0037
Coding: 013400030FB103606309A0046C004C0203004005804F02502F0400000504823B001F0100011F01
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM2CONTIAU651 008007
ROD: EV_BCM2CONTIAU651_008_VW53.rod
VCID: 72BC259EB42BD47A89E-8027
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1814514B7
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099465665
Heated Windshield Control Module:
Subsystem 4 - Part No SW: 4N0 907 133 HW: 4N0 907 133
Component: J505-FSH H08 0040
Serial number: 18164001121011120081
left tail lamp 1:
Subsystem 5 - Part No SW: 4K8 945 069 B HW: 4K8 945 069 B
Component: Slali1AU583 H03 0404
Serial number: ˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇ
Subsystem 6 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58500471
Rear spoiler control module:
Subsystem 7 - Part No SW: 4K8 959 252 HW: 4K8 959 252
Component: J223 HSP 0304 H02 0200
Serial number: WA132189000049886394
Coding: 00FF00
Antenna for short-range communication:
Subsystem 8 - Part No SW: 4N1 927 753 HW: 4N1 927 753
Component: NFCTGS H12 0020
Serial number: 986059561
Antenna 2 for short-range communication:
Subsystem 9 - Part No SW: 4N0 959 428 A HW: 4N0 959 428 A
Component: NFCMIKO H41 0034
Serial number: 44180001125850159561
left tail lamp 2:
Subsystem 10 - Part No SW: 4K8 945 217 B HW: 4K8 945 217 B
Component: Slali2AU583 H03 0404
Right rear tail lamp 1:
Subsystem 11 - Part No SW: 4K8 945 070 B HW: 4K8 945 070 B
Component: Slare1AU583 H03 0404
Right rear tail lamp 2:
Subsystem 12 - Part No SW: 4K8 945 218 B HW: 4K8 945 218 B
Component: Slare2AU583 H03 0404
65669 - Control Module for Rear Lid Opening
U1152 00 [00001000] - No Communications
[Control module for tailgate spoiler opening: no communication]
Reset counter: 234
Mileage: 71971 km
Date: 2025.04.19
Time: 01:09:07
Supply voltages-Terminal 30 power supply: 11.817 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.782 V
Supply voltages-Supply voltage Terminal 30 - 3: 11.727 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 ∞C
general_additional_freeze_frame-interior_temperature: -50.0 ∞C
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 3
general_additional_freeze_frame-terminal_control_intern_status: 40 80 0A 12 04 18
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAJ6S000RMF Dataset Number: 4K8909510A 0004
Coding: 0185030000AAAA2FAA0000010000
Shop #: WSC 03646 182 00000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 241013C63E5F0ACACB2-8071
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS001 0188
Serial number: YE007RFD1132A Dataset Number: 4K8909873B 0027
Coding: 001FDA025E000480A009B430
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 3FDABCAAB7F94912B60-806B
Address 57: TV Tuner (R78) Labels:* None
Part No SW: 4N0 919 191 D HW: 4N0 919 191 A
Component: DVB2CI H08 1310
Serial number: 261740180003000
Coding: 0105200003010100000000
ASAM Dataset: EV_TVTunerMIB2Plus 001005
ROD: EV_TVTunerMIB2Plus.rod
VCID: 3430E3868EBF9A4A5B2-8061
Card Reader for TV tuner:
Subsystem 1 - Part No SW: 4N0 919 805 HW: 4N0 919 805
Component: R204 CI CRU H06 0130
Serial number: 2617300600176604
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 063 D HW: 4K0 035 063 A
Component: MU-H-LND-EU 046 2711
Dataset Number: 4K8909545C 0026
Coding: 0185030100000000C3111102C00800302F0001E401F008008E
Subsystem 1 - Part No: V03 959 807 T
Component: MIB2P_EU_Q224 0730
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00101051800060060
Compact disc data bank:
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000108430033
Multimedia display unit 5:
Subsystem 5 - Part No SW: 4K0 919 603 B HW: 4K0 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00117041800080082
6918 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Air suspension (0x06) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:10
Voltage terminal 30: 11.3 V
7174 - Function Restricted due to Missing Message(s)
[Air suspension (0x06) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:18
BAP-BAP_Function_ID: 02
1637 - Interface for External Media
U11B8 00 [00001001] - No Communications
[USB - communication error]
Reset counter: 191
Mileage: 71971 km
Date: 2025.04.18
Time: 23:39:35
Voltage terminal 30: 12.0 V
Interface for external media: status-Status: Open circuit
1663 - Interface 2 for External Media
U13F3 00 [00001001] - No Communication
[USB - communication error (rear)]
Reset counter: 191
Mileage: 71971 km
Date: 2025.04.18
Time: 23:39:35
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 40000000019958 Dataset Number: 4K8909850A 0002
ROD: EV_RDKHUFAU736_AU38.rod
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 8W1 907 383 C HW: 8W1 907 383
Component: Anhaenger H10 0058
Serial number: 000000000005963 Dataset Number: 8Y0909527C 0014
Coding: 0100000202001100
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 41DEBA52C10D3FE2C04-8015
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 31993521100000 Dataset Number: 4K8909541A 0004
Coding: 16B0
VCID: 48C8A776E2370EAA07A-801D
Address 74: Chassis Control (J775) Labels:* 4N0-907-777.clb
Part No SW: 4K0 907 777 AS HW: 4K0 907 777 A
Component: Fahrwerk-SG H51 2016
Serial number: 2110180432 Dataset Number: 4K8909576G 0004
Coding: F46C383BDA40
ASAM Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 08486776A2B7CEAAC7A-805D
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130332738
Coding: 303030
3342338 - Function block
B2003 00 [00001000] - -
[Function_block_normal_level]
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.20
Time: 00:13:55
Internal DTC: 101
5439488 - Inertial Sensor Package
C115E 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.20
Time: 00:07:46
Internal DTC: 180
196609 - Basic Setting of Deflected Position not Performed
C10C5 00 [10001001] - -
Reset counter: 194
Mileage: 72096 km
Date: 2025.04.20
Time: 00:05:52
Internal DTC: 819
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 G HW: 4K1 713 041 H
Component: GSM-LL H14 0050
Serial number: 18.159 40077
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 270A04CA4F69E1D2EE0-8073
4008 - Unlock Button
P17ED 00 [00001000] - Stuck
[UNLOCK_BUTTON_MECH_ERROR]
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.20
Time: 00:00:14
Voltage terminal 30: 12.20 V
Selec. range display: spec. val.-Text: P
Selector lever position-Text: Basic setting X
Inside temperature: 25.50 ∞C
System run time-Hours: 0 H
System run time-Minutes: 4 min
System run time-Seconds: 49 s
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4K8 919 617 B HW: 4K8 919 617 B
Component: HeadupDisplay H13 1815
Coding: 5700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 3A2CCDBEACDB6C3A81E-806F
Address 84: Night Vision (J853) Labels:| 4K0-907-547.clb
Part No SW: 4K0 907 547 HW: 4M0 907 547
Component: NV-ECU-Gen3 H11 0145
Serial number: 643208500201824
Coding: 200113
ASAM Dataset: EV_NightVisioG3AUTOLAU58x 001003
ROD: EV_NightVisioG3AUTOLAU58x.rod
VCID: 6FBA2CEAA719F992660-803B
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 A HW: 4G0 980 552
Component: NV-CAM-Gen3 H06 0007
Serial number: 639589400B1816600149
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
Component: zFAS Var C H09 0291
Dataset Number: 4K0909466J 0041
Coding: 040184000000000000FFD60000F0D74C5B9F720000000000000000000096D401009BA8000000000000000080000000000000000000000000F98040000000000000009CD0008000B000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001005
ROD: EV_ZFASAU516_001.rod
14 Faults Found:
2114853 - Databus
[LWR_Soll_Fkt_SOL_FehlPos_L]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
2114854 - Databus
[LWR_Soll_Fkt_SOL_FehlPos_R]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
2114847 - Databus
[TIMEOUT_SARA_08]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
Supply voltages-Terminal 30: 11.30 V
Supply voltages-Terminal 30 local: 11.40 V
2114638 - Databus
[LS1_SensorHeader_LS1_Fehler]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
2113544 - Databus
[Timeout_Fahrwerk_01]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
2114883 - Databus
[TIMEOUT_IL_01]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
2117691 - Ethernet Databus
U11C4 00 [00001000] - No Communications
[Databus_Ethernet_no_communication]
Reset counter: 234
Mileage: 71971 km
Date: 2025.04.19
Time: 01:06:57
Ethernet signal quality: no link
2117692 - Control unit for information electronics 1
U1054 00 [00001000] - No Communication
[Databus_Ethernet_missing_PDU]
Reset counter: 234
Mileage: 71971 km
Date: 2025.04.19
Time: 01:06:54
282656 - Video Cable for Information Electronics 1
B13B9 01 [00001000] - Electrical Failure
Reset counter: 234
Mileage: 71971 km
Date: 2025.04.19
Time: 01:06:52
98333 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Control Module temperature-Printed circuit: 28 ∞C
Control Module temperature-Average temperature: -50 ∞C
Control Module temperature-Application service computer: 30 ∞C
Control Module temperature-Sensor service computer: 26 ∞C
Control Module temperature-Environment recognition service computer: 36 ∞C
98334 - Databus
[ESP_15_HMS_Fehlerstatus]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
4157 - Databus
[ESP_Error]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
65540 - Following-Distance Warning (High)
C12DA F0 [00001000] - Status Feedback for HMI Implausible
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:11
Profile master status distance warning high-Nominal status: On
Profile master status distance warning high-Actual status:: Malfunction
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H07 0004
Dataset Number: 4K8909571D 0003
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C00FBE6568FC28A032-8079
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS003 0188
Serial number: YE007RFK04876 Dataset Number: 4K8909897B 0027
Coding: 000FD80200000480A008B020
VCID: 42DCB55EC40B24FAD9E-8017
Component: TSG HBFS003 0188
Serial number: YE007RFC21822 Dataset Number: 4K8909896B 0027
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
Dataset Number: 4K0909475A 0007
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
Part No SW: 4M0 907 594 BG HW: 4M0 907 594
Component: SAD_STG_1 014 0007
Dataset Number: 4K0909469C 0009
Coding: 668040058301
ASAM Dataset: EV_SunRoofCONTIAU736 008010
ROD: EV_SunRoofCONTIAU736_008.rod
VCID: 7CA00BA6E66F920AD32-8029
Address CB: Rear Axle Steering (J1019) Labels:* 4M0-909-145.clb
Part No SW: 4N0 909 145 K HW: 4N0 909 145 C
Component: HAL_MLBevoH03 0398
Revision: -------- Serial number: CCC_098_B_9056_ Dataset Number: 4KF909904J 0002
Coding: 42246200
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
VCID: 392ED2B2A9DD6722884-806D
0232 - Databus
[KFC_FLEXRAY_IL02_TIMEOUT]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Expanded ambient data 17-Terminal 75 status: 0
Expanded ambient data 17-Vehicle speed: 0.00 km/h
Expanded ambient data 17-Steering angle sensor: -800.00 ∞
Expanded ambient data 17-Internal malfunction: 0
Expanded ambient data 17-Target angle: -8.19 ∞
Expanded ambient data 17-System status: 5
Expanded ambient data 17-Terminal 15 signal: 1
Expanded ambient data 17-Terminal 30 voltage filtered: 11.25 V
Expanded ambient data 17-Status of start-stop bus own diagnostic: 0
Expanded ambient data 17-Status of bus self diagnostics: 0
Expanded ambient data 17-Status of bus self-diagnosis: terminal 15: 0
Expanded ambient data 17-Status of bus self diagnostics voltage threshold: 1
Expanded ambient data 17-Status of bus self-diagnosis FlexRay synchronous: 0
Expanded ambient data 17-Status of trailer CAB signal: 0
Expanded ambient data 17-FlexRay synchronization fault status: 1
Expanded ambient data 17-Specified position of the PAG regulator: 0
Expanded ambient data 17-Fault value of PAG regulator: 0.00
0229 - Databus
[KFC_FLEXRAY_IL01_TIMEOUT]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:05
Expanded ambient data 17-System status: 12
0240 - Databus
[KFC_FLEXRAY_FAHRWERK_06_TIMEOUT]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
0224 - Dynamic All Wheel Steering
[KFC_FLEXRAY_IL_STATUS_1]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:38:07
Expanded ambient data 16-Vehicle speed: 0.00 km/h
Expanded ambient data 16-Steering angle sensor: -800.00 ∞
Expanded ambient data 16-Internal malfunction: 0
Expanded ambient data 16-Target angle: -8.19 ∞
Expanded ambient data 16-System status: 12
Expanded ambient data 16-Terminal 15 signal: 1
Expanded ambient data 16-Terminal 30 voltage filtered: 11.25 V
Expanded ambient data 16-Dynamic all wheel drive: regulator status: 1
Expanded ambient data 16-Dynamic all wheel drive: HAL part specified angle: -0.00 ∞
Expanded ambient data 16-Dynamic all wheel drive: steering intervention status: 0
Expanded ambient data 16-Status qualifier for specified steering angle: 1
Expanded ambient data 16-Status of substitute measures for switch-off: 0
Expanded ambient data 16-Status of replacement actions for the all wheel drive malfunction: 0
Expanded ambient data 16-Status of replacement actions for continuous faults: 0
Expanded ambient data 16-Status of differential value for gradient monitoring: 0
Expanded ambient data 16-Integral steering part specified angle fault value: 2046
Expanded ambient data 16-Upper monitoring threshold for DAS part specified angle: -0.00 ∞
Expanded ambient data 16-Lower monitoring threshold for DAS part specified angle: -0.00 ∞
Expanded ambient data 16-Dynamic all wheel drive: HAL part specified angle: old: -0.00 ∞
Expanded ambient data 16-Internal status of rear axle steering and dynamic all wheel drive: 5
Expanded ambient data 16-Communication security at normal status: 0
Expanded ambient data 16-Rear axle steering: wheel angle: 0.01 ∞
Address CC: Starter-Generator (----) Labels:* None
Part No SW: 4N0 903 028 H HW: 4N0 903 028 H
Component: BSG-HP1-65 H16 0523
Serial number: 22061800020201
Coding: 28000000000000
ASAM Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
VCID: 3038EF967AA7A66A3FA-8065
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0200
Dataset Number: 4K8909639K 0002
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 3536DE8285C583426CC-8061
10510404 - Databus
[EML_HIGHT_AND_ANGLES_ERROR]
Reset counter: 233
Mileage: 72004 km
Date: 2025.04.19
Time: 16:37:06
Control Module temperature-Host: external temperature: 29 ∞C
Control Module temperature-Zynq: internal temperature: 44 ∞C
Control Module temperature-Host: internal temperature: 28 ∞C
Control Module temperature-Zynq: external temperature: 27 ∞C
Voltage terminal 15: 11.302 V
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0265
Dataset Number: 4K8909468D 0024
Coding: 1FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Part No SW: 4K0 941 592 AC HW: 4K0 941 592 A
Component: LMS_MLBevo H11 0030
Dataset Number: 4K0909471H 0014
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 71BE2A92B12DEF62704-8025
Dataset Number: 4K0909472H 0014
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089) Labels:| 4N0-907-669.clb
Part No SW: 4N0 907 669 E HW: 4N0 907 669 A
Component: MRR_VR H12 0265
Dataset Number: 4K8909482C 0018
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_VW53.rod
VCID: 3C20CBA6A6EF520A932-8069
Address DC: Frt Corner Rdar 2 (J1088) Labels:| 4N0-907-669.clb
Component: MRR_VL H12 0265
Dataset Number: 4K8909483C 0019
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4K0 035 773 A HW: 4K0 035 773 A
Component: WLC Front NFC H11 0061
Coding: 808000
End----------(Elapsed Time: 02:57, VBatt start/end: 12.8V/14.6V)-----------
------------------------------57 Faults Found------------------------------
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.20
Time: 00:13:55
Internal DTC: 101
Reset counter: 234
Mileage: 72096 km
Date: 2025.04.20
Time: 00:07:46
Internal DTC: 180
Reset counter: 194
Mileage: 72096 km
Date: 2025.04.20
Time: 00:05:52
Internal DTC: 819
