2001 allroad air suspension
rAudi
C?ID=17183
The bags are completely down on this parts car. The only thing wrong with the car is that the timing belt broke and ruined the engine. I would like to inflate the bags to make it easy to roll the car around, but note that repair/inflation/adjusting procedures for the bags say to have the engine running! Is there a work-around for this situation?
rAudi
C?ID=17183
This is the last one I have for the system.
I had reset fault codes first and then tried to run the system.
The compressor tried to run momentarily, but stopped immediately.
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
VCID: 478048F26520E419EF5-5140
01772 - Signal from Level Control Pressure Sensor (G291)
31-00 - Open or Short to Ground
00806 - Suspension Strut Valve; Front Right (N149)
Gone But Not Forgotten
This is not an auto-scan..........no fun tickets = no help.
Fix the issues hook up battery charger, or pull the line, add Schrader...... and blow into it to raise the car.
