- Nov 15, 2024
- 17
- 1
- Wellington, New Zealand
- C?ID=595001
Hello
I have had a look at a friend of mines golf and it keeps coming up with random misfire codes, I have changed over 2 coils and moved others around. It has had recent spark plug replacement. Also it had a blown vacuum pump fuse. Mainly the misfire occurs under load. another shop told him this was likely head gasket failure. What's everyone's thoughts?
Thanks in advance Damo
Saturday,19,April,2025,20:54:17:04166
VCDS Version: 25.3.0.4 (x64) HEX-NET2 CB: 0.4671.5
Data version: 20250311 DS365.0
VIN: WVWZZZ1KZBW300977 License Plate: LCQ695
Mileage: 173820km-108006mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
VIN: WVWZZZ1KZBW300977 Mileage: 173820km-108006miles
Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
Part No SW: 03C 906 016 AM HW: 03C 907 309 A
Component: MED17.5.5 8547
Revision: LCH12--- Serial number:
Coding: 0000077
VCID: 6A86B195207EED3A313-803E
VINID: 9E69EAAAA05BA929C30002471C40A6E57E
005241 - Brake Boost Vacuum System
P1479 - 000 - Mechanical Failure
Mileage: 173820 km
Date: 2025.04.19.
Time: 11:35:05
RPM: 1012 /min
Load: 30.6 %
Speed: 6.0 km/h
Temperature: 85.0 C
Temperature: 37.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Readiness: 0110 0001
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 D HW: 0AM 927 769 D
Component: GSG DSG AG7 431 9033
Revision: 00043014 Serial number: CU501305236123
Shop #: WSC 27944 002 1048576
VCID: 2A067195E0FE2D3AF13-807E
006247 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Reset counter: 10
Mileage: 171247 km
Date: 2025.01.23.
Time: 23:31:10
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 133B400D092200FAC81402EB90200080310000
VCID: 76BE95E568C639DAA5B-8022
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000001002
VCID: 0052F33D3A82076A8F7-8054
Part No SW: 1K0 937 086 L HW: 1K0 937 086 L
Component: BCM PQ35 M 104 0615
Revision: 00104 AF
Coding: 40180A3A88251AC0400000803400812443510088536D8960648000200040
VCID: 39245ED9195896A2889-806C
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 09031 26 0512
Coding: 009795
Component: RLS 060411 05 54 0403
Coding: 0B30AD
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 14
Mileage: 173816 km
Date: 2025.04.18.
Time: 05:34:23
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Part No SW: 5C0 959 655 D HW: 5C0 959 655 D
Component: AirbagVW10G 013 0613
Serial number: 003G7RA046UH Dataset Number: 5K0003v____ 0140
Coding: 00003947
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 33386CF13BB46CF2425-8066
Serial number: 3572MSME3C21565EZZZ+
Serial number: 3582MSME672D435EZZZ5
Serial number: 3512QSME72500A3DZZZV
Serial number: 3522QSME4A381E0EZZZ3
Part No SW: 5K0 953 507 AC HW: 5K0 953 549
Revision: -------- Serial number: 90422KCT00143 Dataset Number: 5K0953507AC D005
Coding: 5880040000
ROD: EV_SMLSNGKUDS_A05_VW32.rod
VCID: 71B4A6F901281EE2709-8024
Part No SW: 5K0 920 861 HW: 5K0 920 861
Component: KOMBI H21 0204
Revision: X0021010 Serial number: 00000000000000
Coding: 570B00
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 6A86B1952CFEED3A313-803E
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 110411F2002179
Coding: 350003
VCID: 303263FDCA2257EA3F7-8064
Reset counter: 92
Mileage: 171247 km
Date: 2025.01.23.
Time: 23:31:13
Part No SW: 5K0 953 234 HW: 5K0 920 861
Component: IMMO H21 0204
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
Part No SW: 5K0 959 701 J HW: 5K0 959 701 J
Component: Tuer-SG 009 2106
Coding: 0004790
Shop #: WSC 47423 000 1048576
VCID: 39245ED9155896A2889-806C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 343A6FED323A6BCA5BF-8060
Part No SW: 5K0 959 702 J HW: 5K0 959 702 J
Coding: 0005046
VCID: 3A2641D5105E9DBA813-806E
Address 56: Radio
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
VCID: 353C52E9394072C26C1-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 363E55E5244679DA65B-8062
End----------(Elapsed Time: 00:58, VBatt start/end: 12.2V/11.9V)-----------
------------------------------4 Faults Found-------------------------------
