2015 Volkswagen Transporter T6 2.0TDI 150hp EURO6 7 speed DSG
bamus
Belgium
C?ID=21808
Ignore the faultcodes concerning 5F - Information Electr. as I enabled rear speakers before fitting them.
Wednesday,23,December,2015,15:41:36:64626
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WV2ZZZ7HZGH036268   License Plate:
Mileage: 360km-223mi   Repair Order:
Chassis Type: 7H (7E0)
Scan: 01 02 03 08 09 10 13 15 17 19 25 55 5F 61 69
VIN: WV2ZZZ7HZGH036268   Mileage: 360km-223miles
Address 01: Engine (2D2D2-CXFA)       Labels: None
   Part No SW: 04L 906 056 FE    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 2526
   Revision: 23002001
   Coding: 00254014437401080000
   Shop #: WSC 14504 002 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056FE 002003
   ROD: N/A
   VCID: 75EA6D05D43D449652-8020
No ASAM data for: "EV_ECM20TDI03004L906056FE" (VN75)
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BT 300 046 A    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5204
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_SE36.rod
   VCID: 346C90019FC71D9EA5-8060
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 61985000000420
   Coding: 347E4098256584842C77027CA48A21D378F700
   Shop #: WSC 02739 790 50316
   ROD: EV_Brake1ESCCONTIVN75XGP2.rod
   VCID: 4084CCD1DB7FB13E31-8014
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7E0 907 047 S    HW: 7E0 907 047 S
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 3A70BE39BDA3EBEE7F-806E
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 239151312
   Coding: 22A0393A0A61349293284F606CEB8EF4C0A4738960CD79603204003F0860
   Shop #: WSC 02737 022 344100
   VCID: 68D434719B8FA97ED9-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 170815 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  003 8654
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  003 8654
   Coding: 1400A1
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A
   Component: E221__MFL-DC1  H01 0103
   Coding: B4FFFF
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 M    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0205
   Revision: --------    Serial number: 32931516000596
   Coding: 310101
   ASAM Dataset: EV_VW75XParkAssis4K 001008
   ROD: EV_VW75XParkAssis4K_VN75.rod
   VCID: 3C7CB821B797D5DE6D-8068
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 7N0 907 572 A    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0110
   Serial number: 22071577091404
   Coding: 00005000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001004
   ROD: EV_ACCBEGVW361_SE36.rod
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH000URGW
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 3776A70D8EB1F68680-8062
   Part No SW: 7E0 920 870 L    HW: 7E0 920 870 L
   Component: KOMBI         H05 1008
   Coding: 160B01
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 3260961965D313AEB7-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042207
   Component: IMMO          H05 1008
   VCID: 6AD04E798D839B6ECF-803E
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0FCA020001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0241
   Serial number: VWZAZ2R8806039
   Coding: 06570001BE00000011110001000808001F010094002001004F
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: 20446C513B3F913E51-8074
   Engine Control Module 2:
   Subsystem 1 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
0512 - Rear Right Bass Speaker
          B1067 13 [008] - Open Circuit
                    Reset counter: 54
                    Mileage: 322 km
                    Date: 2015.12.20
                    Time: 13:12:06
0527 - Rear Left Bass Speaker
          B1065 13 [008] - Open Circuit
                    Reset counter: 54
                    Mileage: 322 km
                    Date: 2015.12.20
                    Time: 13:12:06
Address 61: Battery Regul. (J840)       Labels: None
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Towbar module H10 0110
   Revision: 3A001001    Serial number: ÀÁ006789,-'0((
   Coding: 410D000101000000
   VCID: 3162991568D528B6CE-8064
End-------------------------(Elapsed Time: 03:28)--------------------------
Peadar_911
C?ID=268813
Hi Bamus,
I hope you can help, I'm trying to enable the rear speaker option after installing rear speakers in my T6, but I can't find the options in VCDS (not too familiar with VCDS). Can you point me in the right direction?
Peter
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Make sure you're using VCDS 15.7.4 and then head for 5F - Information Electronics II > Coding - 07 > Coding Assist / Long Coding Helper and scroll through the options. :)
Peadar_911
C?ID=268813
Hi Sebastien,
Thanks for your reply. The problem is I don't see any options when I go into Coding, perhaps I need to update the my software.
Peter
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please post your Auto-Scan, so we can take a closer look at what's up with that.
Peadar_911
C?ID=268813
This is sorted now Sebastian, I upgraded to 15.7.4 from 15.7.0 and options are now visible in 5F-Information Electr. I do still, however, have "No info available for this ECU" on some modules.
Peadar_911
C?ID=268813
As suggested, my Auto-Scan is attached.
Peter
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Tuesday,01,March,2016,15:22:16:25958
Scan: 01 02 03 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZGX015029   Mileage: 3840km-2386miles
Address 01: Engine (J623-CFCA)       Labels: 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 HL    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 8372
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 01254012232401080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019HL 003005
   ROD: EV_ECM20BTD01103L906019HL.rod
   VCID: 7CF79DDBF78E01DE22-8028
   Part No SW: 0BT 300 045 T    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 2402
   Revision: 00H11V01
   VCID: 46833F33F9C28B0E04-8012
   Revision: 00000000    Serial number: 43495000000366
   Coding: 307E4098656384830C750278A68B21D3390000
   VCID: 3F8D2AD7A618DAC647-806A
   Revision: 00001002
   Coding: 0000000003
   VCID: 3A7B5BC3BD3AFFEE70-806E
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 343150521
   Coding: B8F4793A0A61349393284F746EEB8EF4DFA071FF60CC6D60320400230800
   Shop #: WSC 35110 377 08192
   VCID: 68DFD18B9B16BD7ED6-803C
   Component: RLS 181215 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-801.CLB
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-802.CLB
   Coding: 0400A0
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Coding: A4FFFF
   Part No SW: 7E0 919 475 R    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0210
   Revision: --------    Serial number: 32961530802442
   Coding: 108108
   ASAM Dataset: EV_VW75XParkAssis4K 001012
   VCID: 41892C2FD0ECAC3631-8014
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH00213DL
   Coding: 00000000000000000000000000000000304A
   VCID: 377D42F78E28E2868F-8062
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Coding: 470B010100
   VCID: 336576E79A500EA6B3-8066
   Revision: B9080001
   Coding: 042305
   VCID: 6ADBAB838D1A8F6EC0-803E
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
   Component: MU-E-D-ER     857 6495
   Serial number: 09121500012862
   Coding: 06570000BE00000041111101008000001F0000860000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_SE25.rod
   VCID: 275D92B75E8872061F-8072
   Coding: 030B1A73
End-------------------------(Elapsed Time: 02:36)--------------------------
