- Sep 6, 2021
- 19
- 2
- Northumberland, UK
- C?ID=413821
New scan attachedI would run a new scan and then target the modules that are complaining about the Missing Message - That seems logical to me ?
[09] check Adaptation ENG122979-ENG141968-Networking - Anhaengeranschlussgeraet
[10] > Disable Byte 03 Bit 0
[13] > For 5Q0 907 572 J Disable Byte 03 Bit 3
Apologies NEtech, I didn't follow your full instructions. I have now done the long coding for each of the other two and this has allowed me to clear the fault codes and ther parking sensors are now functional again. Would you give the scan a once over to see if the modifications are correct?
I'm still baffled as to why this became an issue. We've had the car for 3 years now and I've not modified any settings. Unsure as to where this came from and as far as I'm aware the car has never had a towbar fitted?
I still have the ACC issue which is now stating ACC_Standby and would be nice to fix but not so much of an issue for now.
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZJW197228 Mileage: 126863km-78829miles
Address 01: Engine (J623-DCYA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 HB HW: 04L 907 309 R
Component: R4 2.0l TDI H24 3052
Revision: B5H24--- CVN: 957C7264
Coding: 01190012034405082000
ASAM Dataset: EV_ECM20TDI01104L906026HB 004002
ROD: EV_ECM20TDI01104L906026HB_004.rod
VCID: 71BFD184A12477F2704-8024
VINID: 9E69EAAAA465A9A9C12470822055ECDBA1
Part No SW: 5Q0 614 517 CQ HW: 5Q0 614 517 AC
Component: ESC H25 0423
Revision: 00000000 Serial number: 53567000002156
Coding: 01FA8AA1242909734779060260CB2980512490E26006947334605078C002430B00000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 025D8E4894827C6A99E-8056
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 AR HW: 5G0 907 426 AR
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 00120104202110001000000000000002
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 7BA3F3ACF3680DA2DA8-802E
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001803200171 Dataset Number: V03935273ND 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 08499C60B2BE563AC7A-805C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180104 042 0551
Serial number: 180111131048
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S2Y18M01D22H16M32S45
Coding: 00A8DD
Serial number: 000000000ZY1734119DM
Serial number: 00000000000000116167
529173 - Databus
[Anhaenger_01 Datenbus fehlende Botschaft]
Reset counter: 94
Mileage: 126863 km
Date: 2025.04.20
Time: 15:27:04
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.8 V
Outside temperature: 13.5 C
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418018029 Dataset Number: V03935270DP 0001
Coding: 0471051801
VCID: 4BC3636CE3487D222A8-801E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Dataset Number: V03935274RY 0001
Coding: 2B00608151FFC728949C810560400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E253AB8A0FAD88ABD6-806A
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 94
Mileage: 126863 km
Date: 2025.04.20
Time: 15:27:02
Control Module temperature: 48 C
Voltage terminal 15: 11.8 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR3URA5$ Dataset Number: V03935272MG 0001
Coding: 98CCC000000000005C0000CF008800000065
VCID: 094F9964A9B42F32D84-805C
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E31011850741
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E01021880292
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 003 101 18
Serial number: 35700000000327451B27
Subsystem 4 - Part No SW: ----------- HW: 480 003 001 18
Serial number: 358000000000DA307B2J
Subsystem 5 - Part No SW: ----------- HW: 480 403 101 18
Serial number: 35100019B28C22E5A245
Subsystem 6 - Part No SW: ----------- HW: 480 400 102 18
Serial number: 3520001C928B2FC164EL
Subsystem 7 - Part No SW: ----------- HW: 480 403 101 18
Serial number: 3550001A728C22E23730
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Revision: -------- Serial number: 29011808491176
Coding: 0400
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 0D47AD74DDDC3312F4C-8058
Part No SW: 5G1 920 941 C HW: 5G1 920 941 C
Component: KOMBI 202 1440
Coding: 27A429002780060001886B011401000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009008
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 290FF9E449744F32F84-807C
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007328562 Dataset Number: V03935272LR 0001
Coding: 030100045F086800FB00005C080F00010001070000000000000000000000
GVL: 01543C0000000000400C80000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 38292CA082DEE6BA77A-806C
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29180000044610088035
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 9411376604
Component: TSG FS 020 0041
Serial number: 110118DAA17656 Dataset Number: V03935273TN 0001
Coding: 003B0220D001048000001000
VCID: 43D34B4CCB18B562D28-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000019028227
Coding: 0D0000
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Dataset Number: V03935275SH 0001
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B3DB8CDB3845E2828-8026
Component: TSG BFS 020 0041
Serial number: 210118EAJ20779 Dataset Number: V03935273TS 0001
Coding: 003B0020DE01048000801000
VCID: 42DD4E48D402BC6AD9E-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000018935927
Coding: 150000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0867
Serial number: Dataset Number: V03935273RD 0001
Coding: 02731001FF00000051110101008808001F0506C601200100CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 323D1E8864A20CEA49E-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHV0222497
Subsystem 2 - Part No SW: 3G0 919 866 BJ HW: -----------
Component: ECE1 2018 --- 0915
End----------(Elapsed Time: 01:26, VBatt start/end: 13.1V/13.3V)-----------
------------------------------2 Faults Found-------------------------------
