12 Golf R adaptive lighting code
euro_trash
Uniontown, PA, USA
C?ID=415650
If this post doesnt belong here I apologize in advance as this is my first time having to post as i cannot seem to find anything to help thus far. I removed the front bumper to fix a broken wire on the right side DRL as it was flickering and make some fender adjustments to better fit the bumper... ya Im picky. I fix the wire, reinstall the bumper and upon driving maybe 3 miles the AFS code came on. Roughly 14 days or so later and now the left side DRL comes on when I start the car and then goes out. Here is my auto scan as well as the module 55 fault code listing. TIA
Thursday,17,April,2025,19:55:20:45825
VCDS Version: 25.3.1.0 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVWRF7AJ5CW242354   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
          56
VIN: WVWRF7AJ5CW242354   Mileage: 201220km-125032miles
05-Acc/Start Auth. -- Status: Malfunction 1010
08-Auto HVAC -- Status: Sporadic communication error 1000
Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
   Revision: 5BH20---    Serial number:
   Coding: 0403010A180F0160
   VCID: 343A774612305FBA5B3-8060
   VINID: 9E69E258745A1539C21020C51098141B04
Readiness: 0000 0001
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V2.clb
   Revision: 00H31001
   Coding: 144B800C492680FC280E01E9921D0141B70000
   VCID: 7BA89C7A73EE50C2DA9-802E
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0165752723 Dataset Number: 5K0116v____ 5K0B
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 343A77461EB05FBA5B3-8060
1053192 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 29 [00001001] - Signal Implausible
                    Fault Frequency: 220
                    Reset counter: 31
   Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000001002
   VCID: 73B8B45A5B3E1882829-8026
   Part No SW: 1K0 937 084 G    HW: 1K0 937 084 G
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272A04108800C170000C4448052086774D8DB0E48420248040
   Shop #: WSC 55879 002 1048576
   VCID: 3236715EE424518A49F-8066
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 20011  26  0512
   Coding: 009795
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:06:31
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Fault Status: 00101001
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:06:37
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Fault Status: 00101011
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:06:52
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:06:56
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:07:04
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:09:24
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA1CJA0   Dataset Number: 5K0003v__B_ 0068
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FD0286A27F68CE2B61-806A
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--0000306A00
   Serial number: 3572MSME7A43036BZZZ.
   Serial number: 3582MSME4C44106AZZZZ
   Serial number: 3512QSME7A0C6856ZZZ2
   Serial number: 3522QSME762D6858ZZZ4
   Serial number: 35527SME0740092BZZZ9
   Serial number: 35627SME12457129ZZZ8
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20120124101307
   Coding: 100A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DAC92626D7A5EF2E4D-8028
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Component: KOMBI         H04 0617
   Coding: 270D01
   VCID: 3822437602D8BBDA77B-806C
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 140112F6000139
   Coding: 350000
   VCID: 3A26597E3C54A9CA81F-806E
                    Fault Status: 00110100
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:06:56
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2019.09.08.
                    Time: 14:06:32
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45DC3A8249AAD632FCD-8010
   Component: IMMO          H04 0617
   Coding: 000007
   VCID: 6A86A93E0CF4D94A31F-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000299918001
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2E0E652EF09C756A2D7-807A
13634048 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Timeout Message mKessy_4]
                    Reset counter: 70
                    Mileage: 201174 km
                    Date: 2025.04.17.
                    Time: 14:06:30
                    ELV State: 02
                    Information Clamps: 00 00
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 6D
   Revision: A1001003    Serial number: 7661712058
   Coding: 020000
   VCID: 29049632C9F21252F85-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H35 0265
   Serial number: VWZAZ2M8492717
   Coding: 04050001010005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS_VW32.rod
   VCID: 2318841AAB5EC802B29-8076
   Component: NAR_V2  0002
1048652 - Telephone Microphone
          B1048 13 [00001001] - Open Circuit
                    Reset counter: 190
                    Mileage: 199176 km
                    Date: 2025.04.17.
                    Time: 17:46:26
                    Reset counter: 190
                    Mileage: 199176 km
                    Date: 2025.04.17.
                    Time: 17:46:26
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 31347E52ED226A92305-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 251    3305
   Revision: 00H22000
   VCID: 3720404A0346B4A27E1-8062
Address 46: Central Conv.
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0012506 Dataset Number: 1K8050v____ 5K04
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 29049632C9721252F85-807C
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001076
   VCID: 3236715EE824518A49F-8066
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1479708
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Fault Frequency: 116
                    Reset counter: 31
                    Mileage: 200251 km
                    Date: 2019.09.08.
                    Time: 12:19:39
                    Voltage: 12.21 V
                        ABS 1
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
End----------(Elapsed Time: 01:17, VBatt start/end: 12.2V/12.3V)-----------
------------------------------17 Faults Found------------------------------
MODULE 55 faults
Thursday,17,April,2025,20:00:31:45825
VCDS Version: Release 25.3.1 (x64) Running on Windows 11 x64
Control Module Part Number: 5M0 907 357 C    HW: 5M0 907 357 C
  Component and/or Version: AFS-Steuergeraet    0148
           Software Coding: 1479708
            Work Shop Code: WSC 01357 011 00200
           Additional Info: ID-L fehlt  AFS-Lst.-Modul l    ....   7L6941329B  AFS-Lst.-Modul r    0005
                    Reset counter: 31
                    Mileage: 200251 km
                    Date: 2019.09.08.
                    Time: 12:19:39
                    Voltage: 12.21 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
downtime
Finland
C?ID=280813
Write the coding of 55 again to the unit. Just write the same code. It should code the submodules at that time.
That will only work if 55 has communications with both output modules, which is certainly not the case in the scan he posted.
downtime
Finland
C?ID=280813
Yes. Most probably OP has not cleared the errors before taking a scan. The timestamp of that error is from 2019. Or another option is that the laptop time is off pretty badly :)
euro_trash
Uniontown, PA, USA
C?ID=415650
this scan was done literally moments before the post but for some reason vcds time stamp is off and i never really noticed cause when you save the files they have a time stamp in folder. but this car had zero lights on whenever i took the bumper off.
euro_trash
Uniontown, PA, USA
C?ID=415650
as UWE said I cant code 55 because it wont communicate now. i posted this in hopes someone had a similar issue and found like a bad ground or some shit. long shot but i dont think control modules are in the budget right now i just wont drive it
Huh? It shows up fine in your the scan you posted, which is only a few days old. :confused:
downtime
Finland
C?ID=280813
I think @Uwe was only referring to one of the submodules. Based on your scan there's nothing wrong with the module 55. Only one of the submodules is complaining.
Can you clear all dtcs and take a fresh scan and post it here?
euro_trash
Uniontown, PA, USA
C?ID=415650
Sunday,11,May,2025,14:07:11:45825
          56
VIN: WVWRF7AJ5CW242354   Mileage: 203130km-126219miles
   Revision: 00H31001
   Coding: 030C0C
                    Reset counter: 117
   Revision: 00001004
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
   Coding: 00003131
   Coding: 100A140000
   Coding: 820000
   Coding: 270D01
   Coding: 350000
   Coding: 0000005
   Coding: 000007
   Coding: 020000
1048629 - Aux IN Socket
          B1104 13 [00001001] - Open Circuit
                    Reset counter: 117
                    Mileage: 203131 km
                    Date: 2025.05.11.
                    Time: 14:03:17
                    Reset counter: 190
                    Mileage: 199176 km
                    Date: 2025.05.11.
                    Time: 17:46:26
                    Reset counter: 190
                    Mileage: 199176 km
                    Date: 2025.05.11.
                    Time: 17:46:26
   Coding: 0001076
   Revision: 00H22000
   Coding: 0001076
   Coding: 1479708
   Coding: 00000255
   Coding: 00000022
                    Reset counter: 117
                    Mileage: 200251 km
                    Date: 2019.10.02.
                    Time: 12:19:39
                    Voltage: 12.21 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 243
                        Invalid
                        Invalid
                        Invalid
End----------(Elapsed Time: 01:08, VBatt start/end: 12.4V/12.5V)-----------
------------------------------9 Faults Found-------------------------------
this scan is 5/11 2:05pm EST
You need to fix this. Either the Output Stage is bad, or the wiring between it and the main Headlight module has a problem.
