Golf mk5 rear passenger door "no responce from controller"
Aellahi
C?ID=610544 (NRRT)
hi all,
Changed doors on my mk5 golf, i initially did the front one where i disconnected the battery and replaced it as you would, then the rear was changed by my brother where i'd forgotten to tell him to disconnect battery, after installation the rear door does not lock, the prior one did lock however the window didnt work, while now the replacement doesn't not lock but window works intermittently(could be just a switch) now the only error i get is no response from controller, ive switched the original door back on, tried the 3 different locks albeit one was a amazon chinese one and i've also tried different window modules. wiring looks fine i cant see any breaks. Fues is fine have tested it and the other rear door does work.
Address 62: Door, Rear Left
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 006 1206
Coding: 0000144
Shop #: WSC 01279 785 1012552
VCID: 3928F23365518D82885-806C
End----------(Elapsed Time: 01:12, VBatt start/end: 12.0V/12.0V)-----------
------------------------------26 Faults Found------------------------------
Thanks in advance, i apologise in advance if i have left something out im new to the forums and vcds.
Viking
C?ID=151455
Please post a complete Autoscan from the vehicle.
Aellahi
C?ID=610544 (NRRT)
did you change the loom? same loom and same module?
changed the complete door so used the loom in the replacement door
Aellahi
C?ID=610544 (NRRT)
Friday,18,April,2025,14:03:16:33268
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVWZZZ1KZ8W202923   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ8W202923   Mileage: 238530km-148215miles
62-Door, Rear Left -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0GD3N68J9
   Coding: 040300031C070060
   Shop #: WSC 66565 257 00032
   VCID: 3436C307423370EA5B3-8060
   VINID: 9E69EAAAA05BA889C20022420C8AB12E3D
Readiness: 0110 0000
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AE
   Component: GSG DSG         081 1408
   Revision: 04708010    Serial number: 00000711161152
   Shop #: WSC 01279 785 00200
   VCID: 196812B3C591AD82685-804C
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0004738
   VCID: 73B4001B07BD37D2829-8026
   Part No SW: 1K0 907 044 CP    HW: 1K0 907 044 CP
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 77AC340B13C55BF2BE1-8022
00716 - Air recirculation Flap Positioning Motor (V113)
   Revision: 00H54000    Serial number: 00000007880371
   Coding: E58D0E2700041565471400006400000000087D076400010C000000000000
   Shop #: WSC 18207 123 1048576
   VCID: 71B80A137DA105C2705-8024
   Component: Wischer 051207 021  0501
   Coding: 00038805
   Shop #: WSC 18207
   Component: RLS     131207 046  0204
   Coding: 00208933
   Shop #: WSC 18207
7 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 122
                    Mileage: 237020 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.65 V
                    Fault Frequency: 139
                    Reset counter: 156
                    Mileage: 229586 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
                    Fault Status: 01101100
                    Fault Frequency: 234
                    Reset counter: 116
                    Mileage: 223378 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.55 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 116
                    Mileage: 224607 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.05 V
                    Fault Frequency: 112
                    Reset counter: 116
                    Mileage: 237961 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.50 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 136
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.00 V
                    Reset counter: 133
                    Mileage: 237938 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.95 V
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1N2YK0
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D20E6237179B1A2A4D-8068
   Subsystem 1 - Serial number: 6332MSME295158506
   Subsystem 2 - Serial number: 6342MSME0E453436B
   Subsystem 3 - Serial number: 6352QSME4A13504DH
   Subsystem 4 - Serial number: 6362QSME48282379L
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012112
   VCID: 78AE37371EDB548AB7B-802C
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K6 920 964     HW: 1K6 920 964
   Component: KOMBIINSTRUMENT VDD 1214
   Revision: V0002000    Serial number: VWX7Z0GD3N68J9
   Coding: 0001403
   Shop #: WSC 65536 645 577705
   VCID: 70BE0F1776AB0CCA7FB-8024
01312 - Powertrain Data Bus
                    Reset counter: 144
   Revision:   H07 01    Serial number: 281107F1001818
   Coding: ED807F060002020003
   VCID: 303ECF17B62B4CCA3FB-8064
                    Reset counter: 116
                    Mileage: 238532 km
                    Time: 06:23:39
   Component: IMMO            VDD 1214
   Shop #: WSC 00137 211 56823
01179 - Incorrect Key Programming
                    Reset counter: 93
                    Mileage: 237939 km
                    Time: 22:08:41
   Component: Tuer-SG         006 1204
   Coding: 0000692
   VCID: 382EF7375E5B948A77B-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3632F90F544F62FA657-8062
   Coding: 819002005103007F2D048F0F7008DFC490DCA0
   VCID: 035450DB571D0752929-8056
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
                    Reset counter: 153
                    Reset counter: 137
                    Mileage: 237961 km
                    Time: 00:00:01
                    Reset counter: 137
                    Mileage: 237961 km
                    Time: 00:00:01
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 153
                    Mileage: 238146 km
                    Time: 15:27:13
                    Reset counter: 153
                    Fault Frequency: 15
                    Reset counter: 154
                    Mileage: 238411 km
                    Time: 00:29:17
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2374
   Coding: 0000692
   VCID: 372CF40B53459BF27E1-8062
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No: 1K0 035 186 AD
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2G4476986
   Coding: 0040401
   VCID: 688E67774E7BC40A27B-803C
00856 - Radio Antenna
   Coding: 0000144
