6R0 907 379 BC ABS Long Coding Request (ESP9.0i)
@Pascal
South Africa
C?ID=383825
Thursday,17,April,2025,11:12:21:10923
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: AAVZZZ6RZPU021601 License Plate:
Mileage: 28470km-17690mi Repair Order:
Chassis Type: 6R-VW25 (6RU)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: AAVZZZ6RZPU021601 Mileage: 28470km-17690miles
Address 01: Engine (J623-CLPB) Labels: None
   Part No SW: 03C 906 014 GN HW: 03C 906 014
   Component: CLPB-MM7GV H02 4035
   Revision: --H02--- Serial number:
   Coding: 00110012020400000000
   Shop #: WSC 31414 790 00200
   VCID: 6FBA2909D78FA6C2661-51CE
   VINID: 4519AAAAA1A2AA094008118004AFFFBE96
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
   Component: ESP9.0i front H04 0003
   Serial number: --------------
   Coding: 000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
   ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
   VCID: 00587AB5FA81A9BA8FB-8054
0943 - ABS/ESP Control Module
          U10C5 00 [10001001] - No or Incorrect Basic Setting
          [IISOEMCalibrationError]
                    Reset counter: 108
0887 - Control Module
          C104A F0 [00011000] - Incorrect VIN
                    Reset counter: 148
                    Mileage: 28479 km
                    Date: 2015.05.07
                    Time: 00:01:44
0883 - Control module not coded
          U1013 00 [00011000] - -
          [VehicleConfigUncoded]
                    Reset counter: 148
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654 HW: 6R0 959 654
   Component: LENKW.SENSOR H07 0070
   Serial number: 20042313470596
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4044D8075DF4AFD7-802A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
   Part No SW: 6RU 937 086 S HW: 6RU 937 086 S
   Component: BCM IM M+4 H43 0471
   Revision: BY043001 Serial number: 4103 018230097
   Coding: 3AB02BBF08A12400100000002C2904800040600F60040100220000000A00
   VCID: 71BE2F71C1ABB032705-8024
   Subsystem 1 - Part No: 5Z0 947 105 E
   Component: DWA-Sensor 00 003 0008
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 AM HW: 6C0 959 655 AM
   Component: Airbag VW12 002 0607
   Revision: -------- Serial number: 0030191A0BH3AM Dataset Number: V03935349EA 0001
   Coding: 8800C0000000000040000000008000000065
   ASAM Dataset: EV_AirbaVW12TS6VW25X 001510
   ROD: EV_AirbaVW12TS6VW25X_VW25.rod
   Part No SW: 6RF 920 861 E HW: 6RF 920 861 E
   Component: KOMBI H01 0225
   Coding: 1102010000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05735
   VCID: 4DC693817D53B4D234D-8018
   Part No SW: 6RU 909 901 HW: 6RU 937 086 S
   Component: GW-K-CAN TP20 H43 0471
   Revision: BY043001
   Coding: 002300
   VCID: 196E37D1799B1872685-804C
   Component: IMMO H01 0225
   VCID: 6A8C381DECFD43EA31F-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
   Component: EPS_ECU H61 1702
   Dataset Number: V03935248XE 0001
   Coding: 0101010100000000
   ASAM Dataset: EV_SteerAssisNSK 014008
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41DEBFB1B10B60B2C05-8014
   Part No SW: 6RG 035 181 HW: 6RG 035 181
   Component: Radio 023 0135
   Revision: -------- Serial number: VWZGZ1X3070088
   Coding: 0000022002000F
   VCID: 015E7FB1F10BA0B2805-8054
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 110
                    Mileage: 28479 km
                    Date: 2015.05.10
                    Time: 01:47:49
                    Reset counter: 110
                    Mileage: 28479 km
                    Date: 2015.05.10
                    Time: 01:47:42
                    Bin. Bits: 010
End----------(Elapsed Time: 00:50, VBatt start/end: 14.1V/14.1V)-----------
------------------------------5 Faults Found-------------------------------
iichel
Netherlands, Operation Market Garden
C?ID=284912
Could you be more precise in what parts exactly have been changed and what work was done?
@Pascal
South Africa
C?ID=383825
The client brought the car with a Engine Control Module asking for help to start the car. The car starts now but I don't have the original ABS coding.
Westbury, UK
And you didn't do an Auto-Scan before starting work?
@Pascal
South Africa
C?ID=383825
The old ecu is said to have been sent for repairs and the client decided to replace it. The ABS coding was just 0000....
@Pascal
South Africa
C?ID=383825
Thursday,17,April,2025,13:57:12:10923
VCDS Version: Release 25.3.1 (x64)
                Address 01: Engine
Control Module Part Number: 03C 906 014 GN
  Component and/or Version: CLPB-MM7GV    H02 4035
           Software Coding: 00110012020400000000
            Work Shop Code: WSC 31414
Advanced Identification
     Identification: MMJ-MAN
     Revision: --H02---
     Date: 09.02.23
     Manufacturer number: 0003
     Test stand number: 0581
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Status: 00000000
     Flash Date: 0000.00.00
     Flash Tool Code: 00000 000 00000
Misc.
     Hardware number: 03C 906 014
     Workshop System Name: J623
     Workshop ID (Coding): 00200 790 31414
Car Info
     Chassis Number: AAVZZZ6RZPU021601
     Engine code: CLPB
VCDS Info:
     Labels: None
     Readiness: No script available
Thursday,17,April,2025,13:58:07:10923
Control Module Part Number: 6RF 920 861 E
  Component and/or Version: KOMBI         H01 0225
           Software Coding: 1102010000
Advanced Identification/FAZIT
     Identification: A6E-000
     Date: 30.03.23
     Manufacturer number: 7956
     Test stand number: 0101
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Flash Date-Workshop ID-Status:
     00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK)
Software
     OSEK-OS: 05.13.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 6RF 920 861 E
     Workshop System Name: J285
     Workshop ID (Adaptation): 1048576 005 02645
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A05735
Car Info
VCDS Info:
     Labels: 5K0-920-xxx-17.clb-SRI1
@Pascal
South Africa
C?ID=383825
So only the engine ECU was changed? Not the cluster? Can you post advanced ID for cluster and ECU? And the physical VIN in the car please
I am failing to attach the photo of the VIN, it the same as in ECU and cluster
iichel
C?ID=284912
So one RHD 1.4 petrol engine, front 256mm discs, rear drums, manual gearbox for South Africa, first try, go!
62DD2485212503C1461A24698452C088080D
@Pascal
South Africa
C?ID=383825
I will try and report back
