VCDS Session Log
Jef
HQ
A "Session Log" is where VCDS will create a simple text file of data (fault codes, live readings, ect). As you work with the car, you can add to the text file.
To start a Session Log, you will click the [Save Codes] or [Add to Log] button as shown in the 2 examples:
When a Session Log is first started, the text file needs a name. VCDS may have the VIN and Odometer data filled out. Or you can type in information yourself. Notice the file name is based on what data is, or is not, typed into the 4 fields. Click [OK] to start the Session Log:
You will now have the Session Log window open up below VCDS.
  • [View/Print] will open the text file in Windows Notepad, from there, you an print the report.
  • [Show Location] will open the \Logs folder where the text file is saved.
  • [Done, Close] will end the Session Log. It is important you do this before you go to the next car!
As you [Save Codes] or [Add to Log], you will se the number of lines in the text file count up:
Here is an example of what the Session Log report will look like:
Wednesday,16,April,2025,11:16:26:34333
VCDS Version: 25.3.1.0 (x64)  HEX-NET CB: 0.4671.4
Data version: 20250408 DS365.0
VIN:    License Plate: ABCD
Mileage: 8877   Repair Order: 12345
                Address 01: Engine       Labels: 06A-906-018-AEG.lbl
Control Module Part Number: 06A 906 018 JJ
  Component and/or Version: 2.0l R4/2V  MOTR HS V01
           Software Coding: 00031
            Work Shop Code: WSC 08230
                      VCID: 73A6127A43333503C6-4B3C
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -
17987 - Throttle Actuator (J338)
            P1579 - 35-00 - Adaptation Not Started
17952 - Angle Sensor 1 for Throttle Actuator (G187)
            P1544 - 35-00 - Signal too Large
16505 - Throttle Position Sensor (G69)
            P0121 - 35-00 - Implausible Signal
18044 - Powertrain Data Bus
            P1636 - 35-00 - Missing Message from Airbag Controller
Readiness: 0110 1101
                Address 01: Engine  (06A 906 018 JJ)
11:18:28 Group 001: General
  0 /min  Engine Speed (G28)
  -46.5°C  Coolant Temperature (G62)
  0.0 %  Lambda Control Bank 1
    100110  Basic Setting Requirements
Be sure to [Done,Close] to end a session long before you go to the next car, otherwise you will add data from the 2nd car to the report of the first car.
Make sure you keep track of how many times you hit save or log.... otherwise you'll just duplicate the info and your "lines" in the log will keep growing.... ask me how I know ;)
Also not sure if it's worth noting, but you can browse through multiple controllers and it will keep the sections separate for when you go to "review" the log.
Sample of my blabbing.
Readiness Status: 10000010 00001111 11101011 00000000
MIL Status: MIL ON
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 2
                Address 01: Engine  (7P0 907 401 K)
12:41:05
  IDE00432   Particle filter: time since last regeneration 18675 s
  IDE00433   Particle filter: oil ash volume 0.31 l
  IDE00434   Particle filter: soot mass calculated 20.13 g
  IDE00435   Particle filter: soot mass measured 12.96 g
  IDE00436   Particle filter: kilometers since last regeneration 262813 m
  IDE00584   Distance driven since erasing DTC memory 4814 km
  IDE00603   Number of driving cycles since erasing DTC memory 159
  IDE01922   Vehicle distance driven 223165 km
  IDE03386   Long-term adaptation of reduction agent dosage 0.94
  IDE05857   DPF statistics: current measured charging rate 0.0492 g/km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 366 km
  IDE07197   Average reducing agent since lest filling 1.10 l/1000 km
12:41:13
                Address 19: CAN Gateway  (7P6 907 530 J)
12:42:09
  IDE00019   Voltage terminal 30 11.7 V
  IDE01833-MAS03159   Battery version-Manufacturer Varta
  IDE01833-MAS04490   Battery version-Size 110 Ah
  IDE01839   Battery charge level 73 %
  IDE01840   Battery condition for display 70 %
  IDE01842   Usable battery charge 52 Ah
