McGillM
- Mar 22, 2025
- 2
- 0
- Odessa, TX, USA
- C?ID=607572 (NRRT)
I have a 2014 Audi Q7 3.0T with roughly 190k. Maintained well and has ran great since I bought it in 2017. A year or so ago I got a EPC and TPMS sensor codes alert and the vehicle went into sort of a limp mode that I have seen others describe. Rough idle at a stop, if you accelerate it feels nerfed. I let the car sit a day or so and when I went to check on it, problem was gone. Fast forward to a few weeks ago, same problem. This time, it will not go away. I have changed the battery. I have changed out every wheel speed sensor, first cheap amazon replacements, then I bought OEMs to be safe as rear left is still showing not working. I did new coil and plugs. I cleaned the throttle body. VCDS showing rear left speed sensor, when I clear it, it almost simultaneously pops again. I get random misfire codes that jump around cylinders, which is why I did plugs and coils, still random. Once you get past the rough idle and gentle acceleration, it runs and sounds fine. Only when back at a stop does it run roughly and smells like its running rich. I am defeated, any thoughts before I bite the bullet and argue with a shop about the codes showing issues that I have already addressed? Thanks in advance.
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 25.3.0(x64) Data version: 20250311 DS365.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,21,March,2025,21:19:22:39378
VIN: WA1DGAFE3ED006486 License Plate: AUDI.2
Mileage: 318250km-197751mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE3ED006486 Mileage: 318250km-197751miles
4C-Tire Pressure II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000------------------------------------------------------------------------------
Self-Diagnosis Log
Page 2
Address 01: Engine (CTW)
Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI
0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 3632F9A2844EE09A65B-8062
VINID: 9D10545D15950D550000610818EEE83C42
Readiness: 1110 1101------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number: CVN: 354289C1
Coding: 001378
Shop #: WSC 99999 999 83333
ROD: EV_TCMAL991031_002.rod
VCID: 3A2AED92BCD604FA813-806E
12835 - Implausible Data Received from ABS Control Module
U0415 00 [00001001] -
Fault Frequency: 23
Reset counter: 201
Date: 2012.07.09
Time: 00:00:09
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Engine torque: -44 Nm
ATF temperature: 22 °C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
EOP target revolution: 65534 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV 1: Motor normal stop
EOP target current: 65278 mA------------------------------------------------------------------------------
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099409
VCID: 3436C3AA9232F28A5BF-8060
Fault Status: 00101101
Reset counter: 169
Mileage: 318250 km
Date: 2012.07.22
Time: 01:56:27
Count: 128
Count: 12609
Count: 8196
Count: 48640
Fault Status: 01101000
Reset counter: 169
Mileage: 318250 km
Date: 2012.07.22
Time: 01:56:27
Count: 128
Count: 12609
Count: 70
Count: 48896------------------------------------------------------------------------------
Self-Diagnosis Log
Page 5
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702087111
Coding: 0000135
VCID: 25102EEE29E89B02DC1-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
Component: FBSAUDIC6 IDG H01 0053
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 169
00193 - Rear Right Door Handle Touch Sensor (G418)
Fault Status: 01111011
Reset counter: 169
Mileage: 318250 km
Date: 2012.07.27
Time: 01:05:41------------------------------------------------------------------------------
Self-Diagnosis Log
Page 6
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Revision: 00---031 Serial number: 00000030301069
Coding: 000CC026
VCID: 25102EEE25E89B02DC1-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0073143963
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0073143722
Coding: 070000
No fault code found.------------------------------------------------------------------------------
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6E8211C2BC9E985A6DB-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Self-Diagnosis Log
Page 7
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961325401093
Coding: 25011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3436C3AA9EB2F28A5BF-8060
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0CBUS2
Coding: 0014131
VCID: 2B04D8D64F0CAD720A5-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME70364576D
Subsystem 3 - Serial number: 6342QSME413A1966G
Subsystem 4 - Serial number: 6352QSME413A3A76L
Subsystem 5 - Serial number: 6362QSME70360F40D
Subsystem 6 - Serial number: 63734SME7C3328643
Subsystem 7 - Serial number: 63834SME533A086C6
Self-Diagnosis Log
Page 8
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026131700470
Coding: 0012142
VCID: 280E27DA5EFA866AE77-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0317
Revision: 00000000 Serial number: VJ343KJ9E
Coding: 8BD663040900CF05020205
VCID: 44D6936ACE92420AEBF-8010
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M13824095C
Coding: 00C303
VCID: 3FDC9C86A77421D2B6D-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 40250K08494121959389
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---011 Serial number: 00000030301559
Coding: 0000006
VCID: 688E67DA9E7A466A277-803C
Self-Diagnosis Log
Page 9
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000072988691
Coding: 00581B00000011110000
VCID: 323AC5B26426FCBA493-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E02D1C27C1ED85A2DB-807A
Component: J0770_SWA_Slave_H02 0050
Subsystem 3 - Serial number: 5F15.07.1300H02000AMS14515ÿ
Subsystem 4 - Serial number: S14515ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000075607782
Coding: 011F57205E40440004
VCID: 48CE875AF2BA666A077-801C
Self-Diagnosis Log
Page 10
Address 46: Central Conv.
Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01937854290000
Coding: 3569949
VCID: 382EF79A8E5A16EA777-806C
Address 47: Sound System (J525)
Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000013127
Coding: 030000
VCID: 290822DE49F0BF62F89-807C
Self-Diagnosis Log
Page 11
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191022738
Coding: 0693965
VCID: 231430F627DC6532B25-8076
Fault Status: 11101101
Fault Frequency: 8
Reset counter: 170
Mileage: 318250 km
Date: 2012.07.22
Time: 01:40:55
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 13.90 V
Temperature: 22.0°C
(no units): 255.0------------------------------------------------------------------------------
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000154341
Coding: 0012001
VCID: 5EE241024C3E08DADDB-800A
Self-Diagnosis Log
Page 12
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000075624091
VCID: 47CC8466FFA469120ED-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Revision: AB001007 Serial number: 156I70D7903948
Coding: 020007010000000000
VCID: 241633EA2ED2620ACBF-8070
Self-Diagnosis Log
Page 13
Address 5F: Information Electr. (J794)
Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 D HW: 4L2 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 224I-0D7528161
Coding: 180200060004E1EF510023456F632003140000000100000000
VCID: 2F3CCCC67714D15226D-807A
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Component: DU7 High H42 0104
Serial number: A130IS0D2821391
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002135805
Component: CD-Database 5298
Self-Diagnosis Log
Page 14
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000075599292
Coding: 010E57204040230004
VCID: 46D28962F8AE701AF5B-8012
000 -
Reset counter: 169
Mileage: 318250 km
Date: 2012.07.22
Time: 01:40:54
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 169
Mileage: 318250 km
Date: 2012.07.22
Time: 01:40:54------------------------------------------------------------------------------
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000194256553
Coding: 0200000000000000
VCID: 3138CABE6120C7A2309-8064
Self-Diagnosis Log
Page 15
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H08--- Serial number: 525PA8-J3841DS
Coding: 1021201
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C861BCA8A826A4A43F-8038
Subsystem 2 - Serial number: 'ó
Subsystem 3 - Serial number: RD14.09.13--H57001002G0120ÿ
Subsystem 4 - Serial number: 2G0120ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0075265002---
Coding: 0003595
VCID: 261229E254EE901AD5B-8072
Component: J_245_EE16_SKB10H14 0220
Component: J_394_EE16_SKB10H14 0220
Component: J_392_EE16_SKB10H14 0220
