Audi A6 2024 C8 Avant - Rad Fan 1 randomly running 100%
Endeval
Ireland
C?ID=583067
Hi all,
Hope you can help me on what the issue could be and what data I can capture during the fan running 100% to help the garage.
UK Car, RHD, under warranty. Occurring for the last month.
2024 A6 C8 Hybrid 50 TFSIe Avant, Rad Fan 1 (Passenger side) randomly comes on to 100%. Fan 2 off.
- When parked, locked and not interacting with the car, could be on for 10-15 mins
- when unlocking, fan comes on for 2-10 mins
- when driving, fan can stay on for the duration of the journey - both Electric drive and petrol.
One test, parked, when the car came up to operating temp, about 105c, Rad Fan 1 dropped from 100% and BOTH fans came on at low revolution, maybe 15%.
For example, while getting ready in the morning, the rad was blowing 100% at 07:05 morning - note, at the time it was charging (granny charger) - but happens when not charging.
It is as if a demand signal is being generated from something. Is Coolant Fan 1 also cooling coolant for the battery and charging system?
Audi Garage replaced fan, controller and wiring harness - same issue. They then replaced the Thermal ECU - same issue.
Checking some measurements so far, I do see unusual but perhaps benign values, for example;
- Coolant Temperature at engine outlet: specified value 30.7c
- Coolant Temperature at radiator outlet: Actual value 16.0c
- Coolant Temperature at radiator outlet: specified value -48.0c <<<< --- issue?
Is there any adv Controller measurements I should look at when the issue is occurring?
Really appreciate your thoughts.
James
Monday,14,April,2025,18:12:06:42938
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WAUZZZF23RN030231   License Plate:
Mileage: 14903km-9260mi   Repair Order: 14Apr
Chassis Type: F2-AU58 (4KE)
Scan: 01 02 03 09 15 16 17 19 22 23 2B 36 42 44 46 51 52 5F 69 6C
          6D 75 81 8C A5 BA BB BC C0 C5 C6 D6 D7
VIN: WAUZZZF23RN030231   Mileage: 14903km-9260miles
8C-HV Battery -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
Address 01: Engine (J623-DRYA)       Labels: None
   Part No SW: 4K0 906 259 AC    HW: 06N 907 425 A
   Component: R4 2.0l TFSI  H80 0001
   Dataset Number: 06L909102BL 0002 CVN: 55BDB9DB
   Coding: 126540320536050B340A0800000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0204K0906259AC 001001
   ROD: EV_ECM20TFS0204K0906259AC.rod
   VCID: 72BCDCC7A4255A3A893-8026 SFD
   VINID: 9D196AAAA5820E27800C0083045874216E
   Active accelerator pedal:
   Subsystem 1 - Part No SW: 4M2 723 523 E    HW: 4M2 723 523 E
H01 0015
   Part No SW: 4K0 927 156 K    HW: 0HL 927 156 C
   Component: 0CJ 20TFSIRdW H80 0001
   Revision: --H80---    Serial number: 0000000429 CVN: D8E3A993490A80EE
   Shop #: WSC 02664 785 00200
   ASAM Dataset: EV_TCMDL382021 002041
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 38282EEF82D9F06A777-806C
   ATF pump:
   Subsystem 1 - Part No SW: 80A 927 154 A    HW: 0DK 315 149 F
   Component: V671 ATFP-2  009 0061
   Serial number: 75414021230319000217
   MTF pump:
   Subsystem 2 - Part No SW: 0CK 927 152 AB    HW: 0CK 321 281 P
   Component: V553 MTFP  003 0703
   Serial number: 75412031230318003215
   Part No SW: 4N0 907 379 BC    HW: 4N0 907 379 F
   Component: ESP9 Premium  H08 0914
   Dataset Number: 4K0909504CD 0002 CVN: F0A82FFC
   Coding: 44412A0A510822D2D2F5B9C0228254508A10444B4BAF9D03
   ASAM Dataset: EV_ESP9BOSCHCMP 005023
   ROD: EV_ESP9BOSCHCMP_005_VW53.rod
   VCID: 7AACF4E7FC55227AC13-802E SFD
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 NG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H12 0775
   Dataset Number: 4K0909514T  0056
   Coding: 07000143C13900CD070087089FBF8C68130B3390000600970101180039321C810A4509324256150800000100004918180800400044010000000000000000000000
   Shop #: WSC 40848 004 1048576
   ASAM Dataset: EV_BCM1BOSCHAU651 020007
   ROD: EV_BCM1BOSCHAU651_020_VW53.rod
   VCID: 0058860F9A8978AA8F7-8054
   Subsystem 1 - Part No SW: 4K2 955 119 B    HW: 4K2 955 119
   Component: J400FRWISCH  065 0760
   Serial number: 00000002311070400727
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 46082574X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K2 941 501 R    HW: 4K2 941 501 R
   Component: E1 - LTM  H07 0060
   Serial number: 20S18.10.2300304175
   Subsystem 4 - Part No SW: 8W0 857 511 F    HW: 8W0 857 511
   Serial number: GX1CE121092324211399
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0419
   Serial number: A01593574
   Coding: 0D0104
Address 15: Airbags (J234)       Labels:. 80A-959-655.clb
   Part No SW: 4M0 959 655 AL    HW: 4M0 959 655 AL
   Component: AirbagVW33    H07 4428
   Serial number: 00389M036HL3 Dataset Number: 4K0909602DA 0011
   Coding: AACCF0C00CA00000985400FFF08D48AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 003003
   ROD: EV_AirbaVW31SMEAU65x_003_VW53.rod
   VCID: 0556971B85AB5D82BC1-8050 SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 001 611 23
   Serial number: 357000000004B8982C6W
   Subsystem 2 - Part No SW: -----------    HW: 480 001 611 23
   Serial number: 358000000002B254EB6S
   Subsystem 3 - Part No SW: -----------    HW: 480 031 505 23
   Serial number: 351003C143616C70FACF
   Subsystem 4 - Part No SW: -----------    HW: 480 031 505 23
   Serial number: 352003C1437AA820FC3E
   Subsystem 5 - Part No SW: -----------    HW: 480 031 011 23
   Serial number: 355004C006692070F873
   Subsystem 6 - Part No SW: -----------    HW: 480 031 011 23
   Serial number: 356004C00660EAB06BFN
   Subsystem 7 - Part No SW: -----------    HW: 480 031 811 23
   Component: PedP_Sensor_C  002 0149
   Serial number: 230004C00BC87E40FE8S
   Subsystem 8 - Part No SW: -----------    HW: 480 001 511 23
   Serial number: I0M00000000BB2700DEC
   Subsystem 9 - Part No SW: -----------    HW: 480 001 511 23
   Serial number: I0N00000000AB2700DEC
   Part No SW: 4N0 907 129 PM    HW: 4N0 907 129 PM
   Component: Lenks.Modul   H03 0011
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 0B42A123A3CF2BF2EA5-805E
   Part No SW: 4K0 920 794 G    HW: 4K0 920 794 G
   Component: FHybRDW------ H29 0262
   Coding: 2C2447C2EA8006000120E370B304630008002800
   ASAM Dataset: EV_DashBoardAU65X 002039
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 353627DB95CB0D026C1-8060
   Part No SW: 4KE 907 468 M    HW: 4KE 907 468 L
   Component: Gateway       H06 0025
   Serial number: F0956676255701 Dataset Number: 4K0909515Q  0076
   Coding: 02010001000286C02981010000590132C8780000100000000900009E02030000
   GVL: 09D03C0008400208949C08009002C81800080000000000000000000000006500
   ASAM Dataset: EV_Gatew31xUNECE 005014
   ROD: EV_Gatew31xUNECE_AU49.rod
   VCID: 53F279433B7F3332625-8006 SFD
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0010
   Subsystem 2 - Part No SW: 4K0 915 181 F    HW: 4K0 915 181 F
   Component: J367-BDMConti  H05 1076
   Serial number: 7856870000231002021A
4624 - Release / Enable Active
          B184C 00 [00001000] - -
          [ECU unlocked]
                    Reset counter: 170
                    Mileage: 14588 km
                    Date: 2025.04.09
                    Time: 10:22:16
131829 - Ethernet Module for Information Electronics 1
          U1645 00 [00001000] - No Communication
          [Timeout_Node_0xF5_zr_DiagAdress_005F]
                    Reset counter: 172
                    Mileage: 14661 km
                    Date: 2025.04.10
                    Time: 07:43:32
262727 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BAP_Timeout_ConnectionManager]
                    Reset counter: 179
                    Mileage: 14589 km
                    Date: 2025.04.09
                    Time: 15:44:46
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 4K0 927 755 B    HW: 0CJ 927 749 A
   Component: C8_DLE_N_SD2  H02 0024
   Serial number: 2328613823
   Coding: 111C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 34301ADF9EB1140A5BF-8060
   Part No SW: 4M0 909 059 L    HW: 4M0 909 059
   Component: J539 EBKV H12 0291
   Serial number:   085460011402 Dataset Number: 4K0909524AA 0001
   ASAM Dataset: EV_BrakeBoostBOSCHCMP 002008
   ROD: EV_BrakeBoostBOSCHCMP_002_AU49.rod
   VCID: 3D263FFBADFBD542A41-8068 SFD
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 4M0 909 057 B    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0154
   Serial number: 05802861081123074204
Address 2B: Steer. Col. Lock (J764)       Labels: None
   Part No SW: 8B3 905 861     HW: 8B3 905 861
   Component: ELV-MLB_UNECE H05 0063
   Serial number: 23000248419015 Dataset Number: 4K0909564B  0004
   Coding: 8840000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 6A8CC4A78CF592FA313-803E SFD
   Part No SW: 4K0 959 760     HW: 4K0 959 760
   Component: MEM-FS        011 0071
   Serial number: 00000513974678 Dataset Number: 4K8909856F  0022
   Coding: 017812400000B4010003010101010000000000000000000000000000004000
   VCID: 73B2D9C3DB3F5332825-8026
   Part No SW: 4M1 959 593 K    HW: 4M1 959 593 K
   Component: TSG FS        005 0463
   Serial number: YE007WJE17838 Dataset Number: 4K8909872D  0048
   Coding: 001FCE0052010200A000B002
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 45D6571BC52B9D82FC1-8010
   Part No SW: 4N0 909 144 H    HW: 4N0 909 144 D
   Component: EPS_MLBEVO2BS H24 0512
   Dataset Number: 4K0909852BB 0004
   Coding: 94002101010000
   ASAM Dataset: EV_SteerAssisUNECEAU651 001003
   ROD: EV_SteerAssisUNECEAU651.rod
   VCID: 353627DB95CB0D026C1-8060 SFD
   Part No SW: 4N0 907 064 HM    HW: 4N0 907 064 HM
   Component: BCM2 MLBevo H19 0285
   Dataset Number: 4K8909501BA 0006
   Coding: 017500002FB100426309A0000400C80203030000804306502F04000000040030001F06800000350200000000000000000000
   ASAM Dataset: EV_BCM2CONTIAU651 014010
   ROD: EV_BCM2CONTIAU651_014.rod
   VCID: 015E830B918371A2809-8054 SFD
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 177 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA  006 0501
   Serial number: 0000000000000Q3G34KS
   Serial number: 00000000000052081940
   Rear spoiler control module:
65573 - Databus
          [Transmission control module: Getriebe_11: no signal/communication]
                    Reset counter: 182
                    Mileage: 14729 km
                    Date: 2025.04.11
                    Time: 19:18:43
                    Supply voltages-Terminal 30 power supply: 12.263 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.318 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.276 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0  C
                    general_additional_freeze_frame-interior_temperature: -50.0  C
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 18
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 179
                    Mileage: 14826 km
                    Date: 2025.04.12
                    Time: 18:58:21
                    Supply voltages-Terminal 30 power supply: 13.126 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.188 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.139 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 00
   Part No SW: 80A 907 080 D    HW: 80A 907 080 D
   Component: 50A8769791HO0 H12 0106
   Revision: --------    Serial number: -00104.10.23001 Dataset Number: 4K8909106   0012
   Coding: 03000000000000000000
   Shop #: WSC 17625 007 1048576
   ASAM Dataset: EV_DMCMHITACAU426 003007
   ROD: EV_DMCMHITACAU426_003.rod
   VCID: 2516F79B256B7D82DC1-8070
   Part No SW: 4M1 959 592 K    HW: 4M1 959 592 K
   Component: TSG BFS       005 0463
   Serial number: YE007WJF0936D Dataset Number: 4K8909873D  0048
   Coding: 001FCE005E010200A000B000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 44D04A1FCE11A48AEBF-8010
   Part No SW: 4M2 035 070 G    HW: 4M2 035 070 B
   Component: MU-TP-ND-EU   045 4014
   Serial number: GRO-63331.10.23 Dataset Number: 4K1909545J  0044
   Coding: 15820028804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 290EFBAB497359E2F89-807C SFD
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 4K0 919 605 M    HW: 4K0 919 605 M
   Component: DU AU58x Top   H41 0060
   Serial number: INX00103092300220334
   Subsystem 2 - Part No: V03 959 823 KP
   Component: MIB3_EU_       1350
   Compact disc data bank:
   Component: Gracenote2     1010
   Multimedia display unit 5:
   Subsystem 4 - Part No SW: 4K2 919 603 M    HW: 4K2 919 603 M
   Component: DU AU58x Bot   H41 0060
   Serial number: INX00118082300250249
   Volume Control 1:
   Subsystem 5 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8      H33 0110
   Serial number: 00008323000156793014
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
007 0007
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 8W5 907 383 D    HW: 8W5 907 383
   Component: Anhaenger     H12 0204
   Serial number: 000000000006279 Dataset Number: 8Y0909527D  0019
   Coding: 0100000202000100
   ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
   ROD: EV_TrailFunctG3MPFMHella_VW27.rod
   VCID: 46D45017F82D969AF5B-8012 SFD
   Component: RVC Compact   H19 0250
   Dataset Number: 4K0909460B  0012
   Coding: 0285020103002005C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 333219C39BBF1332425-8066
   Part No SW: 4M8 959 107 B    HW: 4M8 959 107 B
   Component: HDSG-Modul    H09 0342
   Revision: --------    Serial number: A2-C765-5001-8 Dataset Number: 4K0909541G  0023
   Coding: 12C0
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_AU49.rod
   VCID: 3A2C34E7BCD5E27A813-806E
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4KE 035 282 M    HW: 4KE 035 282 F
   Component: CB_H_ECE      043 0595
   Serial number: A970K0P0859210 Dataset Number: 4K0909612N  0026
   Coding: 01E0E0F8C04080F6F0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   VCID: 45D6571BC52B9D82FC1-8010 SFD
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4K2 713 041 M    HW: 4K2 713 041 H
   Component: GSM-LL H17 0056
   Serial number: 23.325 40568
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2E0408B7709D3EDA2DB-807A
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4M4 915 233 AE    HW: 4M4 915 233 AE
   Component: BMC_PHEV_PL73 H16 0381
   Dataset Number: 4K0909107A  0002 CVN: 7F58554509BB82EB2D12EA36C2D081082D12EA36C2D081082D12EA36C2D08108
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU58.rod
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4K0 915 254 E    HW: 4K0 915 254 C
   Component: SX6 SFT426D0  H23 0208
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4M0 915 116 M    HW: 4M0 915 116 D
   Component: J991 SFT426D1  H09 0204
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4M0 915 116 L    HW: 4M0 915 116 C
   Component: J992 SFT426D2  H09 0204
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4M0 915 116 M    HW: 4M0 915 116 D
   Component: J993 SFT426D3  H09 0204
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4M0 915 116 L    HW: 4M0 915 116 C
   Component: J994 SFT426D4  H09 0204
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4M0 915 116 M    HW: 4M0 915 116 D
   Component: J995 SFT426D5  H09 0204
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4M0 915 116 L    HW: 4M0 915 116 C
   Component: J996 SFT426D6  H09 0204
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4M0 915 116 M    HW: 4M0 915 116 D
   Component: J997 SFT426D7  H09 0204
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4M0 915 116 L    HW: 4M0 915 116 C
   Component: J998 SFT426D8  H09 0204
49156 - Control Pilot
          P0CF4 00 [00101000] - Implausible Signal
                    Mileage: 14661 km
                    Date: 2025.04.10
                    Time: 07:50:15
                    Unlearning counter according OBD: 32
                    High-volt. battery mode: spec. value: Standby-mode
                    Mode HV battery actual value: Standby-mode
                    H-V battery voltage: 371.20 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 1.70 V
                    Current of H-V / hybrid battery: -0.00 A
                    Battery temperature: 16  C
                    Battery charge level: 23 %
                    Terminal 30 power supply: 12.60 V
                    Voltage terminal 30C: 12.40 V
                    Terminal 15 status via CAN: OFF
                    Power reduction status: not active
                    Malfunction Indicator Lamp-Start request: not active
                    Service Disconnect: Status: connected
                    Pilot line: closed
                    Status of voltage freedom: High voltage power off not recognized
                    Crash signal: not active
                    Protection of posit. terminal of high voltage / hybrid battery: Open
                    Protection of neg. terminal of high voltage / hybrid battery: Open
                    Status pre-loader: Open
                    HV battery: cool. level requirement: no cooling request
                    Pump for HV battery coolant: specified speed value: 12.00 %
                    Pump for HV battery coolant: status: No malfunction
                    HV battery positive terminal insulation resistance-Status: Initialization
                    HV battery positive terminal insulation resistance: 8790 kOhm
                    HV battery minus terminal insulation resistance-Status: Initialization
                    HV battery minus terminal insulation resistance: 2580 kOhm
                    Entire HV system positive terminal insulation resistance-Status: Initialization
                    Entire HV system positive terminal insulation resistance: 20470 kOhm
                    Entire HV system minus terminal insulation resistance-Status: Initialization
                    Entire HV system minus terminal insulation resistance: 20470 kOhm
                    maximum voltage for battery cells-Index 1: 0
                    maximum voltage for battery cells-Value: 3.573 V
                    minimum voltage for battery cells-Index 1: 0
                    minimum voltage for battery cells-Value: 3.568 V
                    Highest measured temperature-Temperature sensor: 0
                    Highest measured temperature-Value: 16  C
                    Lowest measured temperature-Temperature sensor: 0
                    Lowest measured temperature-Value: 16  C
                    Air temperature of H-V / hybrid battery-Intake: -100  C
                    Air temperature of H-V / hybrid battery-Exhaust: 17  C
                    Maximum charge level-Index 1: 0
                    Maximum charge level-Value: 24 %
                    Minimum charge level-Index 1: 0
                    Minimum charge level-Value: 22 %
                    Dynamic limit for charge current-Limit for charge current: 114 A
                    Predictive limit for charge current-Limit for charge current: 49 A
                    Dynamic limit for discharge current-Limit for discharge current: 198 A
                    Predictive limit for discharge current-Limit for discharge current: 65 A
                    Maximum charging voltage: 436.80 V
                    Minimum discharge voltage: 291.20 V
                    Minimum dynamic charging voltage: 386.50 V
                    Minimum predictive charging voltage: 379.10 V
                    Minimum dynamic discharge voltage: 344.60 V
                    Minimum predictive discharge voltage: 360.40 V
49186 - Position Sensor for Battery Charger Coupling Lock
          P0D9E 00 [00101000] - Electrical Malfunction
                    Mileage: 14661 km
                    Date: 2025.04.10
                    Time: 07:41:50
                    High-volt. battery mode: spec. value: Driving mode
                    Mode HV battery actual value: Driving mode
                    Voltage in H-V system-Voltage of hybrid battery after protection: 371.20 V
                    Current of H-V / hybrid battery: -0.85 A
                    Battery charge level: 24 %
                    Terminal 30 power supply: 13.40 V
                    Voltage terminal 30C: 13.20 V
                    Pilot line: closed
                    Protection of posit. terminal of high voltage / hybrid battery: closed
                    Protection of neg. terminal of high voltage / hybrid battery: closed
                    HV battery positive terminal insulation resistance: 20470 kOhm
                    HV battery minus terminal insulation resistance: 20470 kOhm
                    Entire HV system positive terminal insulation resistance: 9170 kOhm
                    Entire HV system minus terminal insulation resistance: 8790 kOhm
                    maximum voltage for battery cells-Value: 3.574 V
                    minimum voltage for battery cells-Value: 3.569 V
                    Air temperature of H-V / hybrid battery-Exhaust: 16  C
                    Minimum charge level-Value: 23 %
                    Predictive limit for discharge current-Limit for discharge current: 66 A
                    Minimum predictive charging voltage: 379.20 V
                    Minimum predictive discharge voltage: 360.50 V
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* Redir Fail!
   Part No SW: 4K4 907 107 P    HW: 4K4 907 107 B
   Component: zFAS Var A    H10 0394
   Dataset Number: 4K0909466AN 0066
   Coding: 04D18600000000000000060000400E2C189D5600000000800000000000000000001900000000000000000000000000000000000000000000000064000000000000007818008000B000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 004016
   ROD: EV_ZFASAU516_004_VW53.rod
   VCID: 3B2231E3B3EFDB729A5-806E
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H11 0132
   Dataset Number: 4K0909578A  0002
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006.rod
   VCID: 303816CF6AA9282A3F7-8064
   Part No SW: 4M1 959 595 K    HW: 4M1 959 595 K
   Component: TSG HFS       006 0463
   Serial number: YE007WHB2220E Dataset Number: 4K8909897F  0050
   Coding: 000FCC0000010200A000B000
   VCID: 47CA5D13FF278F920ED-8012
   Component: TSG HBFS      006 0463
   Serial number: YE007WJL1526B Dataset Number: 4K8909896F  0050
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 4N0 035 751     HW: 976 035 751 A
   Component: PASD_RetroE   H04 0105
   Serial number: AUZ8ZAP2L015RYS Dataset Number: 4K8909470C  0015
   ASAM Dataset: EV_PASDRETROEALPINPO633 001288
   ROD: EV_PASDALPINPO426_AU49.rod
   VCID: 678ABD939FE7AF922ED-8032 SFD
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4M0 965 429 BC    HW: 4M0 965 429 BA
   Component: TME-Max       H09 0401
   Serial number: 1031228 Dataset Number: 4K8909476N  0030
   Coding: 00
   Shop #: WSC 17586 007 1048576
   ASAM Dataset: EV_ThermContrVISAU49X 003048
   ROD: EV_ThermContrVISAU49X_003_AU49.rod
   VCID: 79AEEBEBF9532962C89-802C SFD
   Subsystem 1 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 F    HW: 3Q0 963 231 F
   Serial number: -00104.7A.5B20370783
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 F    HW: 4G0 816 797 F
   Component: J842 EKK es33  H05 0018
   Serial number: 00000000023073100269
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H13 0120
   Serial number: 00000000000153245895
   Shut-off valve 3 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N641 AV3_KaMi  H13 0120
   Serial number: 36000000000000283698
   Shut-off valve 5 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N643 AV5_KaMi  H13 0120
   Serial number: 33000000000000283698
32794 - Coolant Fan Control Circuit 1
          P0480 00 [00101110] - Electrical Malfunction
                    Fault Frequency: 118
                    Mileage: 14733 km
                    Date: 2025.04.12
                    Time: 09:57:20
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-System status: Drive readiness
                    Expanded ambient data 1-Power quota setting by energy management: 1D
                    Expanded ambient data 1-Status of drive readiness hybrid: Electrical travel
                    Expanded ambient data 1-Ambient temperature: 7.50  C
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 02
                    Expanded ambient data 1-previous state of battery low temp.circ.: 00
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 01
                    Expanded ambient data 1-current state of battery cold circuit: 02
                    Expanded ambient data 1-previous state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 00
                    Coolant fan activation: specified value: 10.00 %
                    Coolant fan 1: activation: 10.00 %
32807 - Radiator Fan 1
          U0632 00 [00101000] - No Communication
                    Mileage: 14787 km
                    Date: 2025.04.12
                    Time: 16:49:26
                    Expanded ambient data 1-Vehicle speed: 51 km/h
                    Expanded ambient data 1-Status of drive readiness hybrid: Hybrid driving
                    Expanded ambient data 1-Ambient temperature: 15.00  C
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: FF
                    Expanded ambient data 1-current state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: FF
60016 - Interior Pre-Conditioning
          P13F1 00 [00101110] - Not Started
                    Mileage: 14787 km
                    Date: 2025.04.12
                    Time: 16:49:28
                    Expanded ambient data 1-Vehicle speed: 54 km/h
                    Expanded ambient data 1-previous state of battery low temp.circ.: 02
                    Switch-off conditions for pre-conditioning of interior-HV energy management: not active
                    Switch-off conditions for pre-conditioning of interior-Function canceled: entry in DTC memory: active
                    Switch-off conditions for pre-conditioning of interior-Communication malfunction: not active
                    Switch-off conditions for pre-conditioning of interior-Switch-off due to energy management: not active
                    Switch-off conditions for pre-conditioning of interior-No release by coordinator: not active
                    Switch-off conditions for pre-conditioning of interior-Fuel supply low: not active
                    Switch-off conditions for pre-conditioning of interior-Over The Air Update: not active
                    Switch-off conditions for pre-conditioning of interior-Release status: convert. top ctrl. mod.: not active
                    Switch-off conditions for pre-conditioning of interior-Critical component temperature: not active
                    Switch-off conditions for pre-conditioning of interior-Parking heater error value received: not active
Address C6: Batt. Chrg. (J1050)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 EB    HW: 5QE 915 681 EB
   Component: OBC KOSTAL    H37 1192
   Serial number: EEEEEEEEEEEEEEE Dataset Number: 4K0909811C  0001
   Coding: 11508960700000000000
   ASAM Dataset: EV_OBC2PhaseKLOMLBev16P 003003
   ROD: EV_OBC2PhaseKLOMLBev16P_VW53.rod
   VCID: 1078B64FCAE9082A1F7-8044
2097664 - Charging Socket A
          P33E3 00 [00101000] - Communications Error
                    Reset counter: 29
                    Mileage: 14661 km
                    Date: 2025.04.10
                    Time: 07:50:15
2097922 - Charging Socket A; Charging Plug Lock
          P33E8 00 [00101000] - Mechanical Malfunction
                    Reset counter: 29
                    Mileage: 14661 km
                    Date: 2025.04.10
                    Time: 07:41:49
13705826 - Control Module for Active Park System
          U13AE 00 [00101000] - Implausible
          [error_hold_management_system]
                    Reset counter: 38
                    Mileage: 14678 km
                    Date: 2025.04.10
                    Time: 21:44:36
   Part No SW: 4K0 941 572 DG    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H20 0132
   Dataset Number: 4K0909471M  0022
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 76B4E0D7C84D461AA5B-8022
   Dataset Number: 4K0909472M  0022
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
End----------(Elapsed Time: 02:31, VBatt start/end: 13.1V/13.1V)-----------
------------------------------13 Faults Found------------------------------
Jef
HQ
under warranty.
There is your answer.
So in general, most modern fans are operated by a dumb control module, more or less a solid state relay that pulses the fans on/off at different duty cycles for different speeds. Fan control modules will typically have 4 wires, a main power, main ground, wake up line (ignition switch) and data.
When a fan module gets the wake up signal, it will expect data from the ECM to tell it what speed, if any, to operate. However, if the fan module wakes up and does not see any data signal from the ECM, it will fail to high speed fan operation.
In most cases where this happens, you get a DTC in the ECM about missing message or no communication with fan(s). But in some rare cases, the ECM can clearly see the fan, so no DTCs, but the fan doesn't see the ECM, so high speed fan operation... and that is what I suspect is happening with your car.... and the fan will need to be replaced.
While I'm not 100% sure, I think the technical reason this can happen is the inverse reactive current for use in unilateral phase detractors fails to automatically synchronizing cardinal grammeters. This can cause "side fumbling". Most likely the replacement fan will be an updated version with main winding of the normal lotus-o-delta type placed in panendermic semi-boloid slots of the stator. In more simple terms, let the tech know you want the "turbo encabulator" fan installed if possible.
JMR
Romania
C?ID=432218
what beats me right now is that you have a under warranty car yet you re here trying to fix it yourself.
I would take that car to the dealer and let them deal with it ( if this is a real issue )
  • Agree
Endeval
Ireland
C?ID=583067
Thanks Jef, I have one of those from the 1970's, far better than the recent release from Rockwell.
- So, can VCDS help me identify the combination of a failsafe to 100% situation? either through live measurements, or DTCs?
- example - FAN at 100%, All temps in range (ie no false temp sensor like the one I mentioned above if benign), no signal from ECM, etc.
JMR, The current approach of the garage suggests replacing larger part, after larger part - Fan + Controller + wiring harness (kit) < Therm ECU.
I really don't want half the engine bay ripped out trying to replace wiring when it's not needed, if thats their next step.
I have been trying to find the locations of the Thermal ECU in the car, I think it may be under the rear seat, and if the wiring traverses the main looms and bulk-head, thats a lot of ripping.
So, my own main aim is to assist to gather additional/live data thru VCDS to help truly diagnose the issue. It could be a day or two before the issue reproduces itself.
I am not going to fix anything. Very disappointing for a €95K car in Ireland.
James
JMR
Romania
C?ID=432218
I still dont agree with your battle plan. Even if you fix it yourself....sometimes if another issue comes up while car under warranty , they could discover your fix and void warranty all together. I say..as long as it is under warranty , i would not touch anything related to repair . You paid lots of money for that car..let them deal with it even if it means they will have to take half the car apart..it will be documented properly. But hey , that s just me ,you can proceed however you wish
Endeval
Ireland
C?ID=583067
Wow, this place is turning into Facebook or Twitter.
Remember, I never said I'd fix anything, so jumping into a thread where someone is asking for help and MEME'ing does require accuracy in those MEMEs.
I also just found this:
Calm your tits and read all the correct advice you've already been given.
Did you back probe your fan module to see what PWM it's receiving?
Did you use a PWM signal generator to bypass the ECU and supply the module directly with a duty cycle?
Did you scope the signal wire?
Did you use a tone generator to validate the wire integrity between the module and ECU, and possibly locate your open circuit?
Maybe you should be posting your comment on FB or twitter.... around here, people are into diagnostics not magic. :rolleyes:
Reactions: JMR
I would have liked to see photos of those "two broken wires" the video mentions; wires just don't "break" ??? Especially wrapped tight wires in the main engine harness. Perhaps rodent damage or overheated / short ?? A explanation or cause would have been helpful regarding that video. But, it is still a clue.
  • Haha
Reactions: JMR
Endeval
Ireland
C?ID=583067
Hi Savagesoot,
I thought I had a sincere ask to see how VCDS can help provide insights in a forum for a product I purchased.
I didn't expect a series of comments from people based on an ask for help, which I was surprised by.
Maybe there's an email address I can ask the VCDS support team instead, I will look.
I am not inclined to get a scope, resistance testing etc to do further testing - that's for the garage. But, thank you for the questions/thoughts.
My sole ask was for help from this forum on what I should/could do with VCDS to help provide more insights.
volkshop
C?ID=29187
Why is air con 08, not showing up??
Bruce
Near Philadelphia, PA, USA
While some were creative in answering, they did answer. VCDS can only tell you what the control module knows. The expectation as Jef reported is that you may see an error about a missing message from the fan controller. Apparently, your situation falls into the class where the ECM is not complaining about a missing message and yet the fan is running at 100%. The ECM and therefore VCDS, can offer no further help.
So, Jef, in his crazy humor, suggested you get the fan module replaced under warranty.
Humor can be both funny and also be offensive... obviously @Endeval you were offended. Apology from the forum.
James,
VCDS & the community is providing you support and insights.... you're just being a snowflake about us having some fun with it.
So look at your MVBs and see what you are getting for the fan speeds.
Run output tests on fan/fans to see if they ramp up\down as commanded.
If VCDS is reporting the fan as being idle (~10%-15%) but it's clearly going full bore, then it just confirms what has already been suggested to you... the signal isn't getting to the control module and the "failsafe" is full speed.
Reactions: JMR
Reactions: JMR
Jef
HQ
You should find the ECM's fan speed request under Advance Measuring Values:
  • IDE00380 - Coolant fan 1: activation
  • IDE00381 - Coolant fan 2: activation
I would suspect they be the same, I've never seen any vehicle operate the fans at different speeds by design. If you find those values are the same and one fan works and the other doesn't... that pretty much ties back to my first reply.
Reference Scans and Maps of Non-Broken Cars has plenty of examples of IDE00380 and IDE00381 from known good cars.
Endeval
Ireland
C?ID=583067
Thank you Jeff, yes spot on, both fans with the same values.
I did happen to capture a number of values last night during the 100% Fan #1 issue and luckily enough, I had selected those two amongst others;
  • IDE00380 - Coolant fan 1: activation 10.16%
  • IDE00381 - Coolant fan 2: activation 10.16%
Note, fan 2 was not running at all.
Also EN101437, Fan request from air conditioner: 0.00%
TTT
C?ID=547002
This is pretty much clear:
50% of diagnostics is done!
Reactions: Jef
