A friend has purchased this and is repairing but its not starting ................any one help please.
Sunday,13,April,2025,11:17:10:22644
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WVWZZZAUZJW813602 License Plate: GOLF HYBRID
Mileage: 155506km-96626mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 42 44 4B 51 52 5F 75 8C
A5 A9 C0 C6 D6 D7
VIN: WVWZZZAUZJW813602 Mileage: 155506km-96626miles
42-Door Elect, Driver -- Status: Cannot be reached 0100
8C-HV Battery -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 BN HW: 04E 907 309 F
Component: 1.4l TFSI hy H22 4518
Revision: X3H22--- CVN: 5F3A7D93
Coding: 011D0012636405082008
ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
ROD: EV_ECM14TFS01104E906023BN.rod
VCID: 6D87CB4F9D147922541-8038
VINID: 9E69EAAAA465A9A9C804318008095A6B4C
25011 - Door Control Module - Driver's Door
U0199 00 [00100111] - No Communications
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:22
Engine speed: 0.00 /min
Coolant temperature: 10 °C
Intake air temperature: 11 °C
Voltage terminal 30: 11.960 V
Outside temperature: 10 °C
Absolute intake pressure: 98 kPa abs
Engine torque: 0.0 Nm
Fuel level: 15.00 l
Electric drive torque: actual value: 0.0 Nm
Operating mode control expanded electrical driving: False result
Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
High-volt. battery: charge state: abs. value: 20.34 %
27703 - Door Control Module - Driver's Door
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:21
Voltage terminal 30: 11.980 V
Fuel level: 15.00 l
Readiness: 1110 0001
Part No SW: 0DD 300 046 F HW: 0DD 927 770 C
Component: GSG DQ400E H32 1601
Revision: 00032056 Serial number: TFK01806080049 CVN: 8E28300F
Shop #: WSC 77040 210 00000
ROD: EV_TCMDQ400021_VW37.rod
VCID: 2B0305576380B7120A5-807E
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 DB HW: 5Q0 614 517 AH
Component: ESC H62 0856
Revision: 00000000 Serial number: 61618000001199 CVN: D0A1AA45
Coding: 01FA80A13821216F477D060061C52980011C84E26086947338B15078C22203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003.rod
VCID: 74B1DE2BFE3EA8EA9BF-8020
0297 - Steering angle sensor
B1168 16 [10100111] - Voltage Too Low
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:21
8352 - Databus
U1122 00 [00101111] - Implausible Message
[FCAN: TSG_FT_02 is not received]
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:21
16412 - Display for Tire Pressure Monitoring
C1146 02 [10101111] - Signal Failure
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:23
16413 - Display for Tire Pressure Monitoring
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:23
Part No SW: 5GE 907 044 AN HW: 5GE 907 044 AN
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 0012100420011001050500000010102A
VCID: 08499ADB92B6BC0AC77-805C
Subsystem 3 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00102.6V.1A20370084
Air quality sensor:
A/C compressor sub:
H02
459021 - Databus
[Türsteuergerät Fahrerseite - kein Signal/Kommunikation]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
1048839 - Function limitation due to crash signal
B1397 00 [00001001] - -
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001817600298 Dataset Number: V03935273ND 0001
ROD: EV_BCMBOSCH_018.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180522 042 0551
Serial number: 180605182903
Component: RLHS 052 0107
Serial number: S6Y18M07D02H01M26S38
Coding: 00A8DD
Serial number: 000000000ZY181542XUT
Serial number: 00000000000099451621
262936 - Sensor for anti-theft alarm system
B1330 29 [00001001] - Signal Implausible
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.9 V
Outside temperature: 10.5 °C
549909 - Databus
[TSG_FT_01 Datenbus fehlende Botschaft]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:22
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.9 V
Part No SW: 5QA 919 294 E HW: 5QA 919 294
Component: PDC 8 KanalH07 0443
Serial number: 000308418018169 Dataset Number: V03935270DP 0001
Coding: 1471151811
VCID: 4EC56CC33052A23A4DB-801A
13637426 - Databus
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Dataset Number: V03935253UB 0001
Coding: 550067C159FFC728949C810580400600000000000000000000
VCID: 3C21360B96EE20AA93F-8068
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
Control Module temperature: 13 °C
Voltage terminal 15: 11.9 V
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_MISALIGNMENT_VERTICAL]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
1086 - Databus
[FAULT_TIMEOUT_TSG_FT_02]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR04F3FI Dataset Number: V03935243YN 0001
Coding: 98CCC000002000005C0000CF00C800000065
VCID: 50F972BB2A66B4CA5F7-8004
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E21061830599
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E25061831148
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: SideSensor_Df --- ----
Serial number: -------------------$
Subsystem 4 - Part No SW: ----------- HW: 480 002 606 19
Serial number: 35800000000468751D3K
Subsystem 5 - Part No SW: ----------- HW: 480 402 406 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001C329E737245A2
Subsystem 6 - Part No SW: ----------- HW: 480 402 806 18
Component: SideSensor_Pr 004 6149
Serial number: 3520001262B6CEA4639A
Subsystem 7 - Part No SW: ----------- HW: 480 402 806 18
Component: FrontSensor_D 004 6149
Serial number: 3550001262B6CEA4B6CO
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [10001001] - Open or Short to Plus
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:23
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Part No SW: 5Q0 953 507 GK HW: 5Q0 953 549 E
Revision: -------- Serial number: 28061804220521
Coding: 0C10
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 055793EFA5A4A162BC1-8050
Part No SW: 5G1 920 794 A HW: 5G1 920 794 A
Component: KOMBI 409 3197
Coding: 27AC7B086FC4060001886B131701030000000000
VCID: 2D070B4F5D94B922141-8078
16776994 - Databus
[TSG_FT_02 keine Kommunikation]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Part No SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Component: GW MQB EV 618 6322
Serial number: 09061810520800 Dataset Number: V03935272LR 0001
Coding: 020100176EF11000FB00527C5C1D00000001070100010000000300000000
GVL: 01563C1000000008508C80009000C81800000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 392F2F1F99DC1582889-806C
Subsystem 1 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29180001257260028237
Coding: 2DFFFF
Subsystem 2 - Part No SW: 5QE 915 181 A HW: 5QE 915 181 A
Serial number: 0813117904
131658 - Door Control Module - Driver's Door
U0199 00 [00001001] - No Communications
[Timeout Knoten 0x4A / 42 - Türsteuergerät Fahrerseite]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
Terminal 30 power supply: 11.9 V
Terminal 15: On
8526363 - Crash Shut-Down
B189C F0 [00001001] - Active
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
Terminal 15: On
Address 23: Brake Booster (J539) Labels:| 5QE-909-059.clb
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Serial number: 085460010392
Coding: 02720100331900000002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 52FD78B3246AC6DA693-8006
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861060618101315
180736 - Implausible Data Received from Engine Control Module
U0401 00 [10101111] - -
[iBoVAG_DT_GeneratorFailure]
Mileage: 155506 km
Date: 2025.03.24
Time: 00:06:06
250112 - Implausible Data Received from Engine Control Module
U0401 00 [00101111] - -
[iBoVAG_Scl_Motor_EV_02_TS_Istmoment_Error]
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:22
196352 - Control Module Improper Shut Down
U3001 00 [00101111] - -
[iBoVAG_iB_Not_ShutDown_Right]
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:21
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Dataset Number: V03935277MR 0001
Coding: D1020000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B3DD37FB30AFD2825-8026
16275 - Steering Angle Sensor
B1168 F2 [00001001] - Not Initialized
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Motor status: 00
Supply voltage: 11.75 V
Temperature: 14.0 °C
KFC: 3F
KFA: 00 93
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 11.91 V
uAdSensI_SwitchedKl30_xdu16: 11.82 V
NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
NoInitCause_RackPos_Rohwert: 01 80
RP_VALCNTSAV: activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: activated
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 22061811600691 Dataset Number: V03935262LP 0001
Coding: 000000070100164E00400101020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_001_VW37.rod
VCID: 72BDD833842AA6DA893-8026
66882 - Databus
U1123 00 [10001001] - Received Error Message
[LED_R_falsch_codiert received error value]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 E HW: 5G0 907 080 E
Component: LE Gen 3.3H15 1032
Revision: 00H15000 CVN: 0C4EF12C
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM08530115G0907080E 001008
ROD: EV_DMCM08530115G0907080E.rod
VCID: 290FFF5F697CA502F89-807C
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS002 0287
Serial number: YE007SF619748 Dataset Number: V03935290SY 0001
Coding: 00310020DC01048000001000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 43D34DF7EB105F52D25-8016
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000013980316
Coding: 050000
196642 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Door electronics driver side Function limitation due to missing message]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
196644 - Local Data Bus
U10BA 00 [00001001] - No Communication
[Door electronics driver side rear Function limitation due to missing message]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0867
Serial number: Dataset Number: V03935282WW 0001
Coding: 02731001FF0000005111010100880A001F0509F6012000008E
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 323D183344AAE6DA493-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV1722663
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
0518 - Front Right Treble Speaker
B1064 13 [00001001] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:21
Voltage terminal 30: 11.7 V
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: -------- Dataset Number: V03935278EW 0001
Coding: 02739001EA42980D3FFCBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
0049 - Databus
[CAN TO door front left ECU]
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
Voltage terminal 30: 11.9 V
12866049 - Databus
[Airbag: Error value received]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:24
Address 8C: HV Battery (J840) Labels: None
Part No SW: 5Q0 915 182 D HW: 5Q0 915 182 C
Component: BECM H05 0921
Serial number: W1310025 CVN: B5428CFDC05121EDB797EC16B797EC16B797EC16B797EC16B797EC16B797EC16
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006041
ROD: EV_BECM06020115C6915182_AU37.rod
VCID: 34311E2BBEBEE8EA5BF-8060
Battery interrupt switch:
Subsystem 1 - Part No SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Component: BJB H28 0240
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D1 H14 0481
Serial number: V013C1832930098
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D2 H14 0481
Serial number: V013C1832930099
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D3 H14 0481
Serial number: V013C1832930092
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D4 H14 0481
Serial number: V013C1832930041
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D5 H14 0481
Serial number: V013C1832930093
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D6 H14 0481
Serial number: V013C1832930094
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D7 H14 0481
Serial number: V013C1832930031
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D8 H14 0481
Serial number: V013C1832930032
26623 - Crash Shut-Down Activated
P1609 00 [10100111] - -
[Diag_F_Crash_ShutOff_CAN]
Mileage: 155507 km
Date: 2025.03.18
Time: 17:00:09
Pack Voltage: 340.2 V
Pack Current: -1.50 A
Isolation Resistance: 5100 kOhm
Maxumum charge current limit: 0 A
Maximum discharge current limit: 0.0 A
Contactor Voltage: 328 V
OBD unlearned counter: 40
Crash status: 00
Pilot Line Status: 00
Fuse Status: 00
(Minus) Contactor Status: 00
(Plus) Contactor Status: 00
Terminal 15 status: 01
Max Cell Temperature: 26 °C
Min Cell Temperature: 23 °C
Air inlet temperature: 27 °C
Air outlet temperature: 25 °C
LV Battery Voltage: 14.7 V
Min.cell voltage: 3.538 V
Max.cell Voltage: 3.555 V
Max.cell SOC: 19 %
Min.cell SOC: 19 %
Hybrid Battery Pack Remaining Life: 20.0 %
Max Charge Pack Current(10s duration): 106 A
Max Discharge Pack Current(10s duration): 10.5 A
Max Pack Voltage(10s duration): 356 V
Min Pack Voltage(10s duration): 336 V
Max.cell Voltage(10s duration): 3.715 V
Min.cell Voltage(10s duration): 3.501 V
Accelerator Pedal Position D: 53.3 %
Calculated LOAD Value: 0.0 %
Engine coolant temperature: 89 °C
Engine RPM: 0.00 /min
Vehicle Speed Sensor: 0 km/h
Ambient Air Temperature: 215 °C
Hybrid Battery Pack Remaining Life: 20.00 %
control module system voltage: 14.745 V
absolute load: 0.0 %
Time After Engine Start: 429 s
26624 - Crash Shut-Down Activated
[Diag_F_Crash_ShutOff_HW]
Mileage: 155507 km
Date: 2025.03.18
Time: 17:00:09
Pack Voltage: 340.1 V
Pack Current: -2.70 A
Isolation Resistance: 3120 kOhm
Maxumum charge current limit: 126 A
Maximum discharge current limit: 243.0 A
Contactor Voltage: 340 V
Crash status: 00
Fuse Status: 00
(Minus) Contactor Status: 01
(Plus) Contactor Status: 01
LV Battery Voltage: 14.8 V
Max.cell SOC: 19 %
Min.cell SOC: 19 %
control module system voltage: 14.867 V
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 02061812K13709 Dataset Number: V03935273UR 0001
Coding: 0003070000000401000213448150A90094000E200020
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 197
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:20
Control Module temperature: 18 °C
Vehicle speed: 0.00 km/h
System run time: 25.3 s
Voltage terminal 15: 11.8 V
mid: 02 E0
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5G0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0017
Serial number: 180509203864
VCID: 2E050C435092C23A2DB-807A
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Serial number: EN182318520000 Dataset Number: 5QE035335M 0180
Coding: 90
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007_VW37.rod
VCID: 4BC365D7C34097122A5-801E
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 BG HW: 5QE 915 682 BG
Component: OBC KOSTAL H41 4115
Revision: -------- Serial number: 0207180FR0005R Dataset Number: V03935260RR 0001
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
VCID: 1373BDB7DBF00FD2225-8046
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Component: LED1L H07 0011
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 04518EEBAE9E986AABF-8050
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1R H06 0005
VCID: 7EA5FC03C072F2BAFDB-802A
0019 - Headlamp Type
C119F 00 [10101111] - Implausible
Reset counter: 0
Mileage: 155506 km
Date: 2025.03.24
Time: 00:01:19
End----(Elapsed Time: 02:13, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
------------------------------36 Faults Found------------------------------
