Hi All
I have a 2015 Audi S3 with a HVAC fault
I had the fault below which cleared by doing the ends stops basic setting which says completed successfully
But now this fault code wont clear
Address 08: Auto HVAC Labels: 8V0-820-043.CLB
Control Module Part Number: 8V0 820 043 D HW: 8V0 820 043 D
Component and/or Version: AC Automat H13 0060
Software Coding: 00100004000000011000000000001100
Work Shop Code: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020 (AU37)
VCID: 336F7AAD9A709A030A-8066
329476 - Motor for Fresh Air / Recirculated Air Flap
ORIGINAL FAULT
B108B 71 [00001001] - Actuator Stuck
Fault Frequency: 31
Reset counter: 58
Mileage: 141083 km
Date: 2025.04.08
Time: 17:01:33
Voltage terminal 30: 12.3 V
Inside temperature: 33.6 C
Outside temperature: 20 C
Fresh air/recirculating air/back pressure door specified value: 864
Actual value for fresh air/recirculation air flow flap: 512
Actual value for fresh air/recirculation air flow flap: 86.0 %
Not sure which actuator is causing the issue
ORIGINAL FAULT
Fault Frequency: 31
Reset counter: 58
Mileage: 141083 km
Date: 2025.04.08
Time: 17:01:33
