Adaptive cruise control (ACC) out of alignment - C1103
msoultan
San Francisco, CA, USA
C?ID=186575
Hi,
I accidentally popped out one of the corners of my ACC sensor and unfortunately I didn't realize what I had done until the sensor had disabled itself and now it's throwing an error when I do a system scan. I've been watching a few videos and saw a few posts that show how to reset some of the settings in the Adaptation for the 13-Auto Dist Reg. module, but whenever I try and change the setting, it has the following in the "stored value" box: ERROR: Channel Not Available. Here's a picture:
https://photos.app.goo.gl/XX89uGEgnXTYUhKd6
Does this mean that there's a problem with my ACC module? This is the post I'm referring to:
Below you can find my system scan. Any help would be much appreciated so that I don't have to go to the dealer and spend $500 to get the sensor recalibrated
Monday,14,April,2025,17:09:29:60774
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250311 DS365.0
VIN: 3VWH17AU1HM543762   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 5F 75
VIN: 3VWH17AU1HM543762   Mileage: 183980km-114319miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---    CVN: C87BA4D6
   Coding: 311D00322466002F1000
   Shop #: WSC 00066 790 00195
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS020_VW37.rod
   VCID: 46DE252788293B5AF5B-8012
   VINID: 0E69D80474650587451031C608AB3CFA14
15128 - Cylinder 2
          P0302 00 [01100100] - Misfire Detected
                    Mileage: 183778 km
                    Date: 2025.04.10
                    Time: 11:20:37
                    Engine speed: 1303.75 /min
                    Normed load value: 40.4 %
                    Coolant temperature: 13 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 12.207 V
                    Engine: operating status: IS
                    N_TOOTH: 1289 /min
                    T_AST_SAE: 2 s
                    Engine oil temperature: 12.0 °C
                    STATE_LS_SAE[1]: OL_CDN
                    FUP_H_SAE: 5950.0 kPa
                    FUP_EFP_MES: 11000.8 hPa
   Part No SW: 0D9 300 014 M    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5004
   Revision: 06454104    Serial number: TFK01703281615 CVN: 00003761
   ROD: EV_TCMDQ250021.rod
   VCID: 221699B74441277AB93-8076
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 51087000000524
   Coding: 43FA6AA13424096F807E030680C529C2562C9001C001943C16435052E009430000010312121212B435351919323200
   Shop #: WSC 01383 790 50316
   VCID: 79A49EDB895784A2C89-802C
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0438371570 Dataset Number: V03935252QH 0001
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B2844D3C3EB76B29A5-806E
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 02020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4AC611179C31DF3A113-801E
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86419041702EM Dataset Number: V03935261XH 0001
   Shop #: WSC 00066 790 00208
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0740E823CFA3E252CED-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170315  043 0551
   Serial number: 97022066170404005011
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S7Y17M04D06H18M37S25
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST001IWH1X00000
   Coding: 191800
   Roof shade control module:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST001IVWU400000
   Coding: 191800
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39461704403559 Dataset Number: V03935232XK 0001
   Coding: 0031161011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 47C028238F2322520ED-8012
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Dataset Number: V03935253UC 0205
   Coding: 3500478101FFC428949C810520301600000000000000000000
   VCID: 3C2A47CFC6E5718A93F-8068
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 149
                    Mileage: 183778 km
                    Date: 2025.04.08
                    Time: 22:29:23
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 12.1 V
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Reset counter: 143
                    Mileage: 183778 km
                    Date: 2025.04.08
                    Time: 22:29:23
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 143
                    Mileage: 183778 km
                    Date: 2025.04.08
                    Time: 22:29:23
   Serial number: 003GCR0885LE Dataset Number: 5GM003V____ 0044
   Serial number: IBH0000000000075X8JW
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 804 17
   Serial number: 35700000000428449227
   Subsystem 3 - Part No SW: -----------    HW: 480 001 904 17
   Serial number: 35800000000E8051C22H
   Subsystem 4 - Part No SW: -----------    HW: 480 402 004 17
   Serial number: 35100019924A8C62832%
   Subsystem 5 - Part No SW: -----------    HW: 480 401 204 17
   Serial number: 3520001A924A8C519454
   Subsystem 6 - Part No SW: -----------    HW: 480 401 504 17
   Serial number: 3550002A92439CE5A12A
   Subsystem 7 - Part No SW: -----------    HW: 480 401 504 17
   Serial number: 3560002AD24F38239177
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 19041704220578
   Coding: 0410
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BA4101DA590CF0502886A011000000000000000
   VCID: 261E85A72869DB5AD5B-8072
   Component: GW MQB High   518 5286
   Serial number: 11061700841463 Dataset Number: V03935252FW 0001
   Coding: 0901000870085900FB0020181E0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   GVL: 01D43C0000000600400C80008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F30608307939A1226D-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 39170001068030097154
   Coding: 35FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H55 0041
   Serial number: 0326235
   Serial number: HA1-00019.11.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   Revision: 00000000    Serial number: 17000101078001
   Coding: 5D00000000000000
   VCID: 343A6FEFEEB5B9CA5BF-8060
   Serial number: 190517A00804E8 Dataset Number: V03935249RC 0001
   Coding: 003A13200000020000000000
   VCID: 43D83C33BB1B0E72D25-8016
   Serial number: 00000000000006344024
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Dataset Number: V03935245KL 0001
   Coding: 8302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FF000036753FA1246D-801A
   Revision: 00000001    Serial number: VWZ8Z1HBA03F43X Dataset Number: V03935259DN 0001
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D8CBA8BCD1F2802541-8038
   Serial number: 020617A0085JV3 Dataset Number: V03935249RE 0001
   VCID: 42D63937A401077AD93-8016
   Serial number: 00000000000006510494
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0757
   Serial number:                Dataset Number: V03935258KM 0001
   Coding: 027302000000000051220002001808009F0108F40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D0C7A8B0D9FE802141-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW02WE9
   Dataset Number: V03935263QC 0001
   Coding: 02730202C2823A017F1E06020000
   ROD: EV_OCULowMQB_VW37.rod
End----(Elapsed Time: 01:35, VBatt start/end: 11.7V/11.8V. VIgn 11.9V)-----
------------------------------4 Faults Found-------------------------------
downtime
Finland
C?ID=280813
Make sure the radar is seated properly in it's holder and just drive the car in traffic situations. In some cases it fixes itself when the dynamic calibration gets back to right level
msoultan
C?ID=186575
If only it were that simple - I've already driven thousands of miles with the sensor back in it's correct position but it's still malfunctioning :(
downtime
Finland
C?ID=280813
Ok, then you need to reset it. For that you probably need something else than VCDS
msoultan
C?ID=186575
According to the link I provided, it seems like people were able to make it work with VCDS, but those instructions don't seem to work for me. I'm hoping that someone can let me know if I'm doing something wrong or if it's not possible because of my hardware.
AINils
Germany (AIB)
C?ID=56975
downtime
Finland
C?ID=280813
@AINils you're right. But I want to add to your statement that ",and also if you know what you are doing" :)
msoultan
C?ID=186575
Not true it is possible with VCDS, but only if sensor is fitted correctly :p
@msoultan
Use these instructions, they are in german, but it should be usable without any issues:
https://wiki-online.vcds.de/de/Dokumentation/Grundeinstellungen/ACC_kalibrieren (Section: 5Q0 907 572 - Dynamische Kalibrierung)
I'll give that a try again (I saw that page), but as you can see in the picture I linked, it wasn't letting me input any values.
That being said, I input the security codes that VCDS recommended in the popup, but I did miss the security code listed in that article (S56789 - I think that's different? I'll have to look again). Could that be why I'm not allowed to enter values and get the "ERROR: Channel Not Available" message, or is there a malfunction with my unit? It is reporting voltage and temp, so I figured it's still working...
AINils
Germany (AIB)
C?ID=56975
Because you not follow the instructions. These values only are visible and changeable in Dev Session with correct Login
msoultan
C?ID=186575
I did try the security codes and they didn't work, but I gave it another try and low and behold, this time it worked!! I went in and reset the values and my ACC is back!!! I love VCDS :)
msoultan
C?ID=186575
Ok, I think this is what I did:
Make sure your sensor is snapped into place and looks correct. I hit a cone on the freeway so it had popped out of one of the mounts - had I immediately popped it back into place while the computer was freaking out after hitting the cone, I might have avoided this. Anyways, make sure it looks nice and straight and the mount isn't bent out of whack.
open VCDS
select 13-Auto Dist. Reg
Select Security Access
type s12345 (the other code 20103 didn't work, but if you still run into issues, try it)
click Do it!
select Adaptation
Now, if I remember correctly, I selected the following two channels and set them to 0 and then drove the car around:
Misalignment angle: horiz
Vertical deadjustment
Once I did that, it worked for a little bit but then ACC shut off. I went back in to VCDS and reset those values, drove around, and all has been good for thousands of miles.
What took me a while to figure out was when I went to Adaptation first and tried to change the value for Misalignment angle: horiz (or the other one) and the stored value said:
At that point I assumed I could just couldn't change that value and gave up, but the issue was the security code. I think a couple months later I was messing around with this again and I was just trying anything and I guess I just happened to enter all the security codes and then when I went to adaptation again it let me adjust the values.
This was the video I used as reference on what channels to reset:
Hope that helps!
Mike
msoultan
C?ID=186575
One thing I wanted to add - I had to enter in both of the security codes for VCDS to allow me to edit the appropriate values.
