ABS Help! 2017 VW Passat R-Line (MK60EC1)
AcePhins
South Carolina, USA
C?ID=617190
Hi all,
Brand new to the world of VW automotives. My ABS module failed in my 2017 Passat R-Line. I took it to the VW dealership and they wanted to charge me $3800 to replace (which is almost worth more than the car itself!). My brother in law is a mechanic and he recommended I try ordering a salvage part from eBay and he'd install it. Unfortunately he didn't know how intricate the coding process would be AND I didn't know I should've done a scan before replacing the ABS module, so here I am begging for your help. Please forgive my ignorance here. Code is below (I hope I did this right).
Monday,14,April,2025,09:50:57:38697
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: 1VWDT7A34HC020866   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 13 15 16 17 19 25 42 44 46 4F 52 5F 61 62 72
VIN: 1VWDT7A34HC020866   Mileage: 188710km-117258miles
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BJ    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 4891
   Revision: --H13---    CVN: 885AB9B6
   Coding: 001A0092242400170000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K906071BJ 001010
   ROD: EV_ECM18TFS02006K906071BG.rod
   VCID: 74B60271AE325D3A9B3-8020
   VINID: 0669D49074431184C0080206186DC04E85
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 188710 km
                    Date: 2025.04.14.
                    Time: 09:47:53
                    Engine speed: 1348.75 /min
                    Normed load value: 42.4 %
                    Coolant temperature: 47 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.773 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 0101
   Part No SW: 09G 927 158 BD    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3121
   CVN: CBD86859
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 76B23879B84E4F2AA57-8022
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V4.clb
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   Shop #: WSC 00066 000 00000
   VCID: 75B03F75A5C84432ACD-8020
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2019.09.05.
                    Time: 09:47:07
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 195
                    Count: 51200
                    Count: 256
                    Fault Status: 01100101
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2019.09.05.
                    Time: 09:47:07
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 212
                    Count: 51200
                    Count: 256
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2019.09.05.
                    Time: 09:47:07
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 279
                    Count: 51200
                    Count: 256
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2019.09.05.
                    Time: 09:47:07
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 295
                    Count: 51200
                    Count: 256
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2019.09.05.
                    Time: 09:47:07
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 270
                    Count: 51200
                    Count: 256
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0070019002
   VCID: 5AEA4CC92C960B4AA1F-800E
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0184
   Revision: BN122001
   Coding: EF200E18902B08D4088802010400044800F1000640801D20E48062000C70
   VCID: 7F5CDD5D97F40E62F61-802A
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 19071677092341 Dataset Number: V03935236LL 0001
   Coding: 01001000FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361.rod
   VCID: 3530FF75E5C804326CD-8060
1070 - Databus
          [FAULT_CIS_AXV_FAIL]
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2025.04.14.
                    Time: 09:47:07
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 13.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2025.04.14.
                    Time: 09:47:09
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2025.04.14.
                    Time: 09:47:09
1074 - Databus
          [FAULT_CIS_YAW_FAIL]
                    Reset counter: 24
                    Mileage: 188710 km
                    Date: 2025.04.14.
                    Time: 09:47:07
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM081UVQ Dataset Number: 561003V____ 0012
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6394712D1BDCCA82F29-8036
   Serial number: IBH000000000005Q1UP4
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 002 007 16
   Serial number: 35700000000483FC3C1U
   Subsystem 3 - Part No SW: -----------    HW: 480 002 007 16
   Serial number: 35800000000685A41D1L
   Subsystem 4 - Part No SW: -----------    HW: 480 020 208 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001C721DBA14F4CG
   Subsystem 5 - Part No SW: -----------    HW: 480 022 107 16
   Component: SideSensor_Pr  000 0148
   Serial number: 35200019D21816E5045-
   Subsystem 6 - Part No SW: -----------    HW: 480 022 207 16
   Component: FrontSensor_D  000 0189
   Serial number: 35500019F2216EF325BD
   Subsystem 7 - Part No SW: -----------    HW: 480 022 207 16
   Component: FrontSensor_P  000 0189
   Serial number: 35600019F2216EF1A6CM
   Part No SW: 1K5 953 521 CM    HW: 5K0 953 569 BC
   Revision: FF010042    Serial number: 20160725101012
   Coding: 0892440008
   ROD: EV_SMLSNGVOLWSR8C_VW32.rod
   VCID: 7AAA2C498C562B4AC1F-802E
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1971615572201714AC1B
   Coding: 290000
   Part No SW: 561 920 971 B    HW: 561 920 971 B
   Coding: 221E010000
   VCID: 1A6A0CC96C16CB4A61F-804E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 22081603011218
   Coding: 461020
   VCID: 7BA4294D83EC1242DA9-802E
   Component: IMMO          H03 1104
   VCID: 6A8A1C09FCF69BCA31F-803E
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0637
   Revision: 13100010    Serial number: 0010591365
   Coding: 0404B5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1D6007D57D38BC7284D-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14202746160912063359
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 311    3501
   Revision: 00H22000
   VCID: 3928F345C550E052885-806C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 00000008
   VCID: 6FBC0D1DC7947EE2661-803A
   Subsystem 1 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0003
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0637
   Revision: 15100010    Serial number: 0010582424
   Coding: 0404B4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1E6200D9703EA76A9D7-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14202747160912143127
   Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
   Component: MU-S-S-US     H31 0357
   Serial number: VWZAZ2S0402923 Dataset Number: V03935249AS 0001
   Coding: 02140100BE00000011220001001808009F0106D40020010002
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 147662F18EF2FD3A3B3-8040
   Component: Batt.regelung H56 1682
   Coding: E1200859
   VCID: 71B80B65D1A06812705-8024
End----------(Elapsed Time: 01:02, VBatt start/end: 14.1V/14.2V)-----------
------------------------------10 Faults Found------------------------------
Hang in there, I'm sure a member will be able to build you a code to try. I'm pretty sure you will need to do "basic settings" after you enter the coding (during the same VCDS session) so brush up on that while you wait for a code to try.
AcePhins
South Carolina, USA
C?ID=617190
Thanks so much! I'll definitely brush up
JMR
Romania
C?ID=432218
Hmmm..how would an abs unit fail on a 2017 Passat is the question. I thought VW Group had that abs failure crap resolved by now .:eek:
AcePhins
South Carolina, USA
C?ID=617190
When the VW service technician called me and asked me if I was sitting down, I knew I was in some deep trouble lol
JMR
Romania
C?ID=432218
Don t you americans have lifetime warranty on the abs ??
JMR
Romania
C?ID=432218
Hmmm......no recall campaign on it ?
EuroX
Northern NJ USA
C?ID=208579
I normally charge a small fee for coding. I'll consider this another good deed for the year.
Data source:MAGIC
Hardware part number:1K0907379CC
Part number:1K0907379CC
Hardware version number:H46
Software version number:0175
Production date:
Coding:C5 4B C0 F5 49 24 00 FA A3 13 03 EA 92 1F 00 41 20 F0 00 12
Coding:add
Coding:C54BC0F5492400FAA31303EA921F004120F00012
Ability to flash:Flashable
System name:ESP MK60EC1
AcePhins
South Carolina, USA
C?ID=617190
Data source:MAGIC
Production date:
Coding:add
And I would've GLADLY paid your small fee lol. Anything beats $3800+
Thank you SO much
AcePhins
South Carolina, USA
C?ID=617190
Data source:MAGIC
Production date:
Coding:add
So far so good! Had a front sensor error but I stopped the car and started it back up after a minute or two and it's no longer there. Thanks again for you help!
