Comfort Turn Signal
k.mukabi
Nairobi, Kenya
C?ID=611756
I am running VCDS 25.3.1 with my HEX-NET. I want to change the values of Highway Flashing/Comfort Turn Signal on my 2015 VW Toureg. There is no option on 09 Central Electric nor on the 46 Central Convenience Modules. Kindly assist.
Derek
UK (ilexa)
C?ID=56983
Please post the full autoscan so we can see exact car details
Best regards
Derek
Won't happen, so just give up on the dream. ;)
Yup. We also have a 2015 Touareg and never found a way to make that happen in this vehicle.
k.mukabi
Nairobi, Kenya
C?ID=611756
Best regards
Derek
@Derek.Thank you. I have posted the autoscan below. My battery had gone low and one of my EPB actuators are faulty. Waiting for the replacement.
VCDS Version: 25.3.1.0 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVGZZZ7PZFD------   License Plate: XXXXXX
Mileage: 147281km-91516mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 32 36 3C 42 46 52 53
          55 56 57 5F 62 65 6C 72 85 8B 8F 90
VIN: WVGZZZ7PZFD----   Mileage: 147281km-91516miles
32-Differential Locks -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 BT    HW: 03H 907 309 E
   Component: 3.6l FSI EU5J H16 0691
   Revision: M7H16---    CVN: 5DDFC4FF
   Coding: 006A0012434601000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM36FSI01103H906023BT 002005
   ROD: EV_ECM36FSI01103H906023BN.rod
   VCID: 75BC93B42542D232ACD-8020
   VINID: 9E65EAAAA1E0A9650000504600CE9E4891
17403 - Implausible Data Received from Parking Brake Control Module
          U0417 00 [00101111] - -
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:34:59
                    Engine speed: 0.00 /min
                    Coolant temperature: 102  C
                    Intake air temperature: 75  C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 11.591 V
                    Mean injection time: 0.000 ms
                    Relative load value: 45.61 %
                    Engine torque: 0.0 Nm
Readiness: 1010 0001
Address 02: Auto Trans (J217)       Labels: 0C8-927-7XX-V2.clb
   Part No SW: 0C8 927 755 D    HW: 0C8 927 755
   Component: AL1000 AISIN  100 2830
   CVN: 354F35CB
   Coding: 010100011C008400000000000000000000000000
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 323668A894AC850A49F-8066
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 422840010EC010 Dataset Number: 7P0012v____ 0001
   Coding: 4B6B13C309246F58D2F5C89990D2F670F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CCA16501648F3FA233-8018
   Part No SW: 4H0 907 064 FK    HW: 4H0 907 064 EK
   Component: BCM2 2.0      H36 0551
   Coding: 0DB60016000000000000
   VCID: 77A099BC3FCEA022BE1-8022
   Subsystem 1 - Part No SW: 8Tz y59 u4 Cz    HW: 8T: y59 7u4 C"
   Component: FBSAUDIB8 IDG  H50 00}
   Serial number: 081p000p905w700w
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3214000120109004
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CD    HW: 7P6 907 040 CD
   Component: Klima 2 Zonen H23 1406
   Coding: 46A6600A90
   VCID: 78A29A803250AF5AB7B-802C
0235 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:22
0289 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:22
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00000918940001
   Coding: 268000DB912C7F610027400700005D4C431DC7182701424100000002004011011F000004000000
   Shop #: WSC 25414 002 104857
   VCID: 6A86B0C87C7C0DCA31F-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    141009  033 0021
   Serial number: 90243401141014065321
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20418966
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002310140557
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28261428702401
   Coding: 708D04
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44DA3E703E183BBAEB3-8010
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 161
          [Funktionseinschr nkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 161
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Coding: 0C02010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3C2A469046E8437A933-8068
16384 - Function Restricted due to Insufficient Voltage
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:31
                    Control Module temperature: 41  C
                    Voltage terminal 15: 9.078 V
                    Velocity_vehicle_reference: -0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
16640 - Function Restricted due to Insufficient Voltage
          [FAULT_VMON_VZ_LOW1]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:31
17152 - Supply voltage
          [FAULT_VMON_VZ_CONFIRMED_LOW]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:06
                    Voltage terminal 15: 8.176 V
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_EPB_FAIL]
                    Fault Frequency: 65
                    Reset counter: 122
                    Mileage: 147139 km
                    Date: 2025.04.05
                    Time: 15:19:48
                    Control Module temperature: 45  C
                    Voltage terminal 15: 11.942 V
106240 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_EPB_TENSION_FAIL]
                    Fault Frequency: 8
                    Reset counter: 122
                    Mileage: 147139 km
                    Date: 2025.04.05
                    Time: 15:19:48
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag03M H10 0043
   Revision: --------    Serial number: 003NK001CG0W Dataset Number: 7P6003V____ 1603
   Coding: 00000000000000000000000000000000334D
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 43D83D6C3B163C82D29-8016
   Serial number: 3575LRB404P2RDNMD1FD
   Serial number: 3585LRB404P2RDNM8HS
   Serial number: 3517ARB40572SQIGJQ11
   Serial number: 3527ARB40572SQIG11EF
   Serial number: 3557BRB404T2T32GO9H-
   Serial number: 3567BRB404T2T32GM93L
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
   Component: Lenks.Modul   H06 0005
   Revision: --------    Serial number: 01374NJN000C3
   Coding: 000CDD
   VCID: 3D2C4B945D724A72A4D-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0067222 TRW 20140925
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 F    HW: 7P6 920 883 F
   Component: Kombi         H13 0515
   Revision: 13240300    Serial number: 658131014592058
   Coding: 33173200EF08100C01000A
   Shop #: WSC 70320 981 12345
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 41D43764210A2E92C05-8014
          [Supply voltage too low]
                    Reset counter: 161
   Part No SW: 7P6 907 530 N    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H13 6042
   Revision: --------    Serial number: 00000001604752 Dataset Number: 7P6067v____ 0041
   Coding: 002D075600
   GVL: FB5F49651DF5660000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 41252129445701758711
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 14294005397021200181
          U140B 00 [00001000] - -
          [Powermanagement active]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 15:43:48
                    Voltage terminal 30: 10.5 V
                    Voltage terminal 15: 10.6 V
                    Control Module temperature: 46  C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 2
   Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
   Component: TRANSFERCASE        0218
   VCID: 4CCA16501AC8F3FA233-8018
Address 32: Differential Locks        Labels: None
   Part No SW: 0BN 927 771     HW: 0BN 927 771
   Component: Quersperre          5220
   Revision: H05         Serial number: 441618251205
   VCID: 0154F7646D0AEE92805-8054
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000110801969
   Coding: 00781B0000004001000001010101202020202121202020
   VCID: 343A6EB06E388B3A5B3-8060
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:19
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H06 0021
   Serial number: 0350237860 Dataset Number: 7P6764V____ 0009
   Coding: 030312
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 3FD0319C57FE5862B61-806A
   Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0021
   Serial number: 0348776557
   Coding: 030312
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000123525242
   Coding: 011D1620DE01459005080003
   VCID: 7AA680880CDCBD4AC1F-802E
02127 - Exterior Door Handle Light / Mirror Light
                    Fault Status: 00101100
                    Reset counter: 157
                    Mileage: 147252 km
                    Date: 2025.04.06
                    Time: 21:10:02
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:30
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:23
   Revision: 00002001    Serial number: 0350250104
   Coding: 015F1E2028B90081C33004240C0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000121951316
   Coding: 011D1620DE01459005080000
   VCID: 48C22A4002B01FDA07B-801C
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:31
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:24
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C14A2100355    Dataset Number:             A001
   Coding: 01040200
   Shop #: WSC 00078 790 12345
   ROD: EV_ParkbA7.rod
   VCID: 363E54B878C4992A657-8062
   Slave 1:
   Slave 3:
0051 - No Calibration
          B2010 F0 [00001000] - Deviation from Expected Range
          [Steuerger t EPB - Kalibrierung fehlgeschlagen Luftspiel]
                    Reset counter: 122
                    Mileage: 147281 km
                    Date: 2025.04.14
                    Time: 07:47:00
                    Voltage: 11.4 V
0048 - Control Module for Electronic Parking Brake
          C10E2 22 [00001000] - Signal Amplitude Too High
                    Reset counter: 122
                    Mileage: 147281 km
                    Date: 2025.04.14
                    Time: 07:47:00
                    Voltage: 11.4 V
0024 - No Basic Setting
          B2010 00 [00001001] - -
          [Steuerger t EPB - System nicht kalibriert]
                    Voltage: 11.4 V
12652550 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [Steuerger t EPB - Codierungsfehler]
                    Voltage: 11.4 V
0023 - Speed Sensor for Left Parking Brake Motor
          C10BC F0 [00001001] - Malfunction
          [Steuerger t EPB - Drehzahlsensor Fehler - Links]
                    Reset counter: 122
                    Mileage: 147281 km
                    Date: 2025.04.14
                    Time: 07:47:00
                    Voltage: 11.4 V
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0016
   Coding: 01AE02000B000A00
   ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
5275926 - Power Output Module for Left Headlamp
          C1081 16 [00001000] - Voltage Too Low
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:00:55
5276182 - Power Output Module for Right Headlamp
          C1082 16 [00001000] - Voltage Too Low
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:00:55
   Part No SW: 4G0 035 083     HW: 4G0 035 083
   Component: Radio U JP    H50 0055
   Revision: AB001007    Serial number: 448JI0E7668757
   Coding: 000007020100000001
   VCID: 5EEEEC18B034716ADD7-800A
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:05:35
                    Voltage: 8.50 V
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:41
                    Voltage: 8.80 V
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G1 919 129 B    HW: 4G1 919 129
   Component: NGTV-JP       H03 0420
   Revision: R0030000    Serial number: 07001003285401
   Coding: 10000000
   VCID: 2D0C7BD48D12DAF214D-8078
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:05:36
   Part No SW: 7P6 035 678 D    HW: 7P6 035 678
   Component: H-BN-JP       H20 0256
   Revision: --------    Serial number: K5FAN17HAX4FI
   Coding: 010601050040E9EF79100B0E00000003F00001020000000000
   VCID: 3E2E4C985074516ABD7-806A
   Subsystem 1 - Part No: 8R0 060 884 BS
   Component: JPN-25.06.13.  7711
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H52 0046
   Serial number: VWZ8Z9PX7004RU
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  5298
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:55
                    Voltage: 8.10 V
03367 - Supply Voltage for Display Module
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:37
                    Voltage: 8.20 V
02288 - Control Module for Chip Card Reader (J676)
                    Reset counter: 118
                    Mileage: 147270 km
                    Date: 2025.04.12
                    Time: 18:52:59
                    Voltage: 12.00 V
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000123229282
   Coding: 011816200001259005080000
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:32
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:24
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 J    HW: 5Q0 907 273 A
   Component: RDKBERU30     H04 0002
   Serial number: 40000000001247 Dataset Number: 7P6096V____ 0026
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
   Component: TopView       H08 0115
   Revision: 11001001    Serial number: 82330JF0184732
   Coding: 0100000002000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3D2C4B945DF24A72A4D-8068
13701888 - Databus
          [Funktionseinschraenkung durch empfangenen Fehlerwert (ESP_v_Signal = Unterspannung)]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 14:47:44
                    Voltage terminal 30: 10.4 V
                    Terminal 15 status: Terminal 15 on
15729431 - Supply voltage
          [Power supply undervoltage]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:04:21
                    Voltage terminal 30: 8.3 V
9617697 - Function Restricted due to Insufficient Voltage
          [Functional limitation by undervoltage]
                    Reset counter: 161
                    Date: 2025.04.13
                    Time: 16:02:14
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000122991596
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:06:17
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:09
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H26 0035
   Revision: --------    Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
   Coding: 61020000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 39245F8449DA7652885-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007062977_4214
0232 - Function Restricted due to Insufficient Voltage
          [Functional_restrictions_low_voltage]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:31
                    Outside temperature: -34.0  C
                    Voltage terminal 15: 8.8 V
                    Control Module temperature: 58.0  C
0233 - Supply voltage
          [Ubat_too_low]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:31
   Part No SW: 7P6 907 541 C    HW: 7P6 907 541
   Coding: 0C02010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002011
   ROD: EV_AdaptCruisContr2VW526_002.rod
   VCID: 3A2640884CDC7D4A81F-806E
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:31
                    Control Module temperature: 42  C
                    Voltage terminal 15: 9.112 V
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:31
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:07:15
                    Voltage terminal 15: 8.156 V
                    Fault Frequency: 66
                    Reset counter: 122
                    Mileage: 147139 km
                    Date: 2025.04.05
                    Time: 15:20:09
                    Control Module temperature: 48  C
                    Voltage terminal 15: 11.967 V
                    Fault Frequency: 8
                    Reset counter: 122
                    Mileage: 147139 km
                    Date: 2025.04.05
                    Time: 15:20:09
   Dataset Number: 7P0FH1v____ 0010
   Coding: 00660600031F037F00033810594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313467A491AABE12305-8064
12585216 - Supply voltage
          [Powersupply lower threshold fall short of]
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:02:55
   Dataset Number: 7P0FF1v____ 0010
   Coding: 006606000317037F00033810594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
                    Reset counter: 161
                    Mileage: 147273 km
                    Date: 2025.04.13
                    Time: 16:04:21
End----(Elapsed Time: 02:31, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
------------------------------48 Faults Found------------------------------
Derek
UK (ilexa)
C?ID=56983
Unfortunately, from the posts above it doesn't look like it's possible to change on this vehicle
Best regards
Derek
  • Agree
k.mukabi
Nairobi, Kenya
C?ID=611756
Thank you guys. Too bad for the 2015 Toureg
k.mukabi
Nairobi, Kenya
C?ID=611756
Anyone who has been able to set the DRL off when Light switch is on Parking. Mine switches is on both th DRL and the parking lights. DrL does not go off even by unchecking on the radio menu while the light switch is at parking
That should be doable through long coding helper.... you just need to poke around in there to find the correct bit to uncheck.
