2024 Ford Transit/Tourneo Connect (VW Caddy)
NEtech
Denmark
C?ID=56995
No problem with VCDS.
Monday,14,April,2025,12:13:56:22191
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
Workshop Code: 204 00975 023456
VIN: WF0CXXSK4RX031060   License Plate:
Chassis Type: SK-VN3SP PA* (5QS)
Scan: 01 02 03 08 09 10 13 15 17 18 19 23 42 44 52 5F 69 75 A5 D6
          D7 C002 C003
VIN: WF0CXXSK4RX031060   Mileage: 7km-4miles
Address 01: Engine (J623-DXRA)       Labels: None
   Part No SW: 05L 906 023 QS    HW: 05L 907 309 AH
   Component: R4 2.0l TDI   H80 3773
   Revision: NEH80---    CVN: 29F6E58210A70AD289980D21252F1ED389980D2145690194
   Coding: 0125003A0324050920080000001000000000000000000000
   Shop #: WSC 35110 377 00022
   ASAM Dataset: EV_ECM20TDI01105L906023QS 010002
   ROD: EV_ECM20TDI011_VN3SP.rod
   VCID: 094C974869BC28B2D85-805C-R SFD+SFD2
   VINID: 9D6013A288DB122A000C100600CEC7694C
   Heater for exhaust gas catalytic converter:
   Flush-air pump:
   Active oil separating system:
23765 - Control unit for information electronics 1
          U1054 00 [00100000] - No Communication
          [Information electronics control module 1No Communication]
                    Mileage: 6 km
                    Date: 2025.01.17
                    Time: 03:51:47
                    Engine speed: 966.50 /min
                    Normed load value: 29.8 %
                    Coolant temperature: 17 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 13.140 V
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    selected gear-Bits 0-7: 0
43768 - Release / Enable Active
          B184C 00 [00100000] - -
          [Activation active]
14690 - Loading Mode active
          P169A 00 [10101111] - -
          [Transport mode active]
                    Reset counter: 0
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:27:59
                    Engine speed: 0.00 /min
                    Coolant temperature: 55 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 12.460 V
                    Unlearning counter according OBD: 0
                    Cruise Control System (CCS): status-Bits 0-7: 1
Readiness: 1 1 0 0 1
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 555 GE    HW: 0GC 300 058 B
   Component: GSG DQ381     H06 0661
   CVN: 58D2AEBD
   ASAM Dataset: EV_TCMDQ381064 001011
   ROD: EV_TCMDQ381064.rod
   VCID: 0452867C4E9E75DAAB3-8050-R SFD
   Parking lock:
   Subsystem 1 - Part No SW: 5QS 907 483 A    HW: 5QS 907 483
   Component: SB_Auto        H03 0060
   Serial number: 9435671000700008
   Selector lever:
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 16102406S00000027358
   MTF pump:
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700007082409
41683 - PARK Cannot be Engaged
          P07E4 00 [00101000] - -
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:17:27
                    Coolant temperature: 38 °C
                    Clutch: primary stat: Neutral
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -28 Nm
                    Control Module temperature: 32 °C
                    Accelerator pedal position: 14.1 %
                    DTC memory status: 233
31370 - Production Mode Active
          U1103 00 [00101000] - -
                    Fault Frequency: 14
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:28
                    Coolant temperature: 39 °C
                    Clutch: primary stat: New
                    selected gear: GANG_1
                    Driving position: N
                    Engine torque: -100 Nm
                    DTC memory status: 252
41777 - Loading Mode active
          P169A 00 [00101111] - -
                    Fault Frequency: 64
                    Reset counter: 1
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:38
                    Coolant temperature: 57 °C
                    Driving position: N
                    Control Module temperature: 38 °C
                    DTC memory status: 279
41848 - Release / Enable Active
          B184C 00 [00101000] - -
          [Activation active]
                    Fault Frequency: 14
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:28
                    Driving position: N
                    DTC memory status: 303
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 5WA 614 517 DF    HW: 5WA 614 517 BS
   Component: ESC           H31 0379
   Serial number: 62934000013244  Dataset Number: V03935435LC 0001 CVN: DEC6CB68
   Coding: 4A185448A4CB399C4101A5AC9EB701450ACF952149A000
   ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006022
   ROD: EV_Brake1ESCMQB37WUNECE_VN3SP.rod
   VCID: 0F78B95017D80682061-805A-R SFD+SFD2
17156 - No Communications with Airbag Control Module
          U0151 00 [00101000] - -
          [CCan_IMU_05_Timeout]
                    Mileage: 5 km
                    Date: 2024.12.21
                    Time: 05:09:28
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 656 m
                    Voltage_value_KL.30_ESC_V: 12.3 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: not completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: not completed successfully
                    LWS_comparison: not completed successfully
                    Internal_failure_code: 00 7B
                    00 00 00 00 04 0C 10 08 80 00 00 00 00 00 00 48 00 00 21 00 04
591872 - Production Mode Active
          U1103 00 [11101000] - -
          [production_mode_active]
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:28
                    Resolution Mileage: 408 m
                    Voltage_value_KL.30_ESC_V: 12.5 V
                    Comparison_longitudinal_accleration: completed successfully
                    Internal_failure_code: 01 9E
                    00 00 00 00 04 08 10 08 20 00 00 00 80 00 00 40 30 00 21 00 04
1905 - Transport Mode Active
          U1105 00 [00101111] - -
          [Transport_mode_active]
                    Reset counter: 0
                    Mileage: 5 km
                    Date: 2024.12.21
                    Time: 05:09:28
                    Internal_failure_code: 01 A2
590080 - Release / Enable Active
          [SECDIAG_ROLE_UNLOCKED]
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:28
                    Internal_failure_code: 01 DB
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 BE    HW: 5WA 907 727 AG
   Component: AC Manuell    H01 5071
   Serial number: 217102407392750 Dataset Number: V03935451NP 0001
   Coding: 023010014111000000100010001001010000010010000000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002052
   ROD: EV_ACClimaBHBE3ADV_VW49.rod
   VCID: 1472B63C3EFEE55A3B3-8040-R SFD+SFD2
523532 - BCM
          U15BA 00 [00101111] - Received Malfunction Value
          [Body computer 1/vehicle electrical system control module/el.ZE Received malfunction value 2]
                    Fault Frequency: 37
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:27
29097 - Transport Mode Active
                    Fault Frequency: 30
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:37
          B10CD 00 [00101111] - -
          [Function limitation due to energy management 03]
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:57
                    Voltage terminal 30: 12.30 V
                    Static current measuring mode: OFF
                    Energy management deactivation stage: Deactivation stage 0
                    Actual value of windshield heater: OFF
                    Wipe wash: OFF
                    Windshield wiper: OFF
                    Back-up lamp: OFF
                    Rear window heater actual value: On
                    Transport mode: On
524142 - Control unit for information electronics 1
          [Information electronics control module 1 No Communication 7]
                    Mileage: 6 km
                    Date: 2025.01.17
                    Time: 03:51:48
524143 - Control unit for information electronics 1
          [Information electronics control module 1 No Communication 8]
                    Mileage: 6 km
                    Date: 2025.01.17
                    Time: 03:51:48
524144 - Control unit for information electronics 1
          [Information electronics control module 1 No Communication 9]
                    Mileage: 6 km
                    Date: 2025.01.17
                    Time: 03:51:48
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BJ    HW: 5WA 937 086 BJ
   Component: BCM37w_M238 0434
   Serial number: BXJ53F261024940 Dataset Number: V03935446LR 0001
   ASAM Dataset: EV_BCMwBL 004001
   ROD: EV_BCMwBL_004_VW41.rod
   VCID: 1A6ED804DC1AD32A61F-804E-R SFD+SFD2
   Subsystem 1 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53518092400022864
   Subsystem 2 - Part No SW: 2KF 941 501 D    HW: 2KF 941 501 D
   Component: E1-LTM         005 0007
   Serial number: __2024_10_27___00454
   Subsystem 3 - Part No SW: 2KF 925 200 M    HW: 2KF 925 200 M
   Component: DiETa          H03 0003
   Serial number: 93309XJG0007D
   Subsystem 4 - Part No SW: 5H0 959 561 BP    HW: 5H0 959 561 BP
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND14102400013239
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GJ    HW: 5Q1 953 549 F
   Serial number: 00000028082404221313
527872 - Transport Mode Active
                    Fault Frequency: 30
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:42
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating condition: Normal mode
                    Voltage: 12.40 V
                    Outside temperature: 16.00 °C
                    Light switch position: 0
954894 - Switch for Reading Lamp; Rear Left
          B14EC 04 [00101111] - Internal System Fault
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:25
                    Engine run: OFF
                    Voltage: 12.60 V
                    Outside temperature: 21.00 °C
                    Light switch position: automatic
955150 - Switch for Reading Lamp; Rear Right
          B14ED 04 [00101111] - Internal System Fault
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:25
                    Engine run: OFF
                    Voltage: 12.60 V
1074808 - Transport Protection Active
          B1ABB 00 [00101111] - -
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:42
                    Engine run: OFF
                    Voltage: 12.40 V
8511745 - Occupant Detection
          U173E 00 [00101000] - Function Restriction due to Implausible Message
          [Occupant_Presence_Service_Restriction]
                    Fault Frequency: 42
                    Reset counter: 21
                    Date: 2024.12.10
                    Time: 01:51:18
                    Terminal 15 status: OFF
                    Engine run: OFF
                    Status of brake lamp switch: discrete: On
                    Brake lamp switch via CAN: status: On
                    Voltage: 12.30 V
                    Outside temperature: 5.00 °C
8667429 - Databus
          U1123 00 [00101000] - Received Error Message
          [Gurtschloss Fahrerseiteempfangener Fehlerwert]
                    Reset counter: 12
                    Mileage: 5 km
                    Date: 2024.12.10
                    Time: 01:51:23
                    Engine run: OFF
                    Voltage: 11.30 V
   Part No SW: 5QS 919 294     HW: 5QS 919 294
   Component: PDC 08ch low  H01 0427
   Serial number: 000007112495570 Dataset Number: V03935439LG 0001
   Coding: 0040010111
   ASAM Dataset: EV_EPHBO18VW3360000 001010
   ROD: EV_EPHBO18VW3360000_VN3SP.rod
   VCID: 1B60DD00D320AA227A9-804E-R
1114113 - Driver Assistance Systems Audio Output
          B1AE2 F0 [00101111] - Infotainment System; Implausible Signal
          [sound_output_MIB_totally_disturbed]
                    Mileage: 7 km
                    Date: 2025.03.24
                    Time: 23:25:11
   Part No SW: 5WA 907 567     HW: 5WA 907 819
   Component: ACC Bosch MQB H50 0576
   Dataset Number: V03935445MT 0001
   Coding: 09830205007740441257400000C000042E4030000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 005024
   ROD: EV_FRONTRADARBOSCHVW380.rod
0110 - Transport Mode Active
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:38
0766 - Release / Enable Active
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Fault Frequency: 9
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:40
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 D    HW: 5QS 959 655 D
   Component: AirbagVW50    004 0126
   Serial number: 000000003C0RVRC Dataset Number: V03935446GS 0001
   Coding: 88CC000000E00000000000000000000091000000A1000000C000F680002B00A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 6492A6FCAEDED5DA0B3-8030-R SFD+SFD2
   Subsystem 1 - Part No SW: -----------    HW: 480 001 80A 18
   Serial number: 3570000E46891F5F2870
   Subsystem 2 - Part No SW: -----------    HW: 480 001 80A 18
   Serial number: 3580000646812B583470
   Subsystem 3 - Part No SW: -----------    HW: 480 050 60B 18
   Component: FrontSensor_D  000 014A
   Serial number: 3550000C2D1613CFEB80
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 480 050 40B 18
   Component: Side_Sens_B_D  000 0149
   Serial number: I0P0000BCD8C210ECB70
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 480 051 F0A 18
   Component: Side_Sens_B_P  000 0149
   Serial number: I0Q00009ED8C210B4B60
9980928 - Release / Enable Active
          [ECU unlocked]
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:25
Address 17: Instruments (J285)       Labels: None-SRI2
   Part No SW: 2KF 920 310 B    HW: 2KF 920 310
   Component: KOMBI         320 2640
   Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935442EM 0001
   Coding: 04A40C4763840008018062030000080800001C0800
   ASAM Dataset: EV_DashBoardVISMQB37W 005002
   ROD: EV_DashBoardVISMQB37W_002_VW38.rod
   VCID: 343216BC5EBE055A5B3-8060-R SFD
16711684 - Release / Enable Active
          B184C 00 [00001000] - -
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:28
16711686 - Secure Onboard Communication
          U14FE 00 [00001000] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Date: 2024.11.19
                    Time: 10:34:15
16777018 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 9
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:51
8667138 - ROD - Unknown Error Code
          - 00 [00001000]
                    Date: 2020.01.01
                    Time: 00:00:02
Address 18: Aux. Heat (J364)       Labels:* Redir Fail!
   Part No SW: 3J0 963 272 A    HW: 3J0 963 272 A
   Component: STH-VW37x     006 0002
   Serial number: 000000000000440 Dataset Number: V03935440HY 0001
   Coding: 355B14225C121512D86D19
   ASAM Dataset: EV_AuxilHeateWOSVW38X 003004
   ROD: EV_AuxilHeateWOSVW38X.rod
   VCID: 2B000DC083805AA20A9-807E-R
   Auxiliary heating remote control:
   Part No SW: 5QS 907 530 D    HW: 5QS 907 530
   Component: GW MQB 23     005 2086
   Serial number: SMERBG021124007 Dataset Number: V03935441BP 0001
   Coding: 000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000
   GVL: 3D0000000008C08C80008004C800004000004000000000000000000000000044
   ASAM Dataset: EV_GatewMQBwBL 001018
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 55F48B38F5843C528CD-8000 SFD+SFD2
   Generator:
   Component: 5-00-18-01-03
   Subsystem 2 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 2394055306
   Subsystem 3 - Part No SW: 2KF 959 442 K    HW: 2KF 959 442 K
   Component: E221__MFL-PR6  H07 0130
   Serial number: PR6-0440036212244291
9 Faults Found:
2502759 - Ethernet Module for Emergency Call
          U1642 00 [00101110] - No Communication
          [Emergency-call_module_no_communication_vlan]
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:36:21
2498675 - Ethernet Module for Information Electronics 1
          U1645 00 [00101111] - No Communication
          [Information_electronics_control_module_1_no_communication_vlan]
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:27:03
8471553 - Function Restricted due to Missing Message(s)
          U1111 00 [00101000] - -
          [error_communication_Headunit_PaCo]
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:27:16
8471814 - Databus
          U1123 00 [00101111] - Received Error Message
          [error_value_ESC_50_EPB_Fehlerstatus_02]
                    Fault Frequency: 33
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:29
12320 - Transport Mode Active
                    Fault Frequency: 33
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:26:37
8417280 - Diagnostic Filter
          U17A0 00 [00101000] - Not Activated
          [Filter_is_not_active]
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:29
8450315 - Predictive Route Data
          B1630 02 [00100000] - Signal Failure
          [PSD_GW_message_order_inconsistent]
                    Mileage: 6 km
                    Date: 2025.01.17
                    Time: 03:51:49
2175091 - Control unit for information electronics 1
          U1054 00 [00101000] - No Communication
          [Information_electronics_control_module_1_no_communication]
                    Date: 2024.12.19
                    Time: 01:48:22
8389392 - Control Module for Driver Assist Systems
          C12D5 87 [01101100] - Missing Message
          [FAS messsages retention time to long]
                    Fault Frequency: 41
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:33
   Part No SW: 5WA 909 059 AC    HW: 3Q0 909 059 D
   Component: EBKV          H10 0553
   Serial number: BPA085261024013 Dataset Number: V03935436GA 0001
   Coding: 5402C100800000008018638C000049922449922400
   ASAM Dataset: EV_BrakeBoostVW37WUNECE 012002
   ROD: EV_BrakeBoostVW37WUNECE_012_VW42.rod
   VCID: 117CBF2801EC1072105-8044-R SFD+SFD2
1024304 - Release / Enable Active
                    Fault Frequency: 18
   Part No SW: 3WA 959 393 A    HW: 3WA 959 393
   Component: TSG FS        001 0221
   Serial number: YG007XJO07616   Dataset Number: V03935443PN 0001
   Coding: 00208320C000000100001020
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHKLO_VW41.rod
   VCID: 52FE7024C46A2B6A69F-8006-R SFD+SFD2
   Part No SW: 5QS 907 146 D    HW: 5QS 907 146
   Component: BASGEN1MQB37  263 2122
   Serial number: 00575938 Dataset Number: V03935434EL 0001
   Coding: 00000000000000000001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 58EA820CE296013A97B-800C-R SFD+SFD2
2816 - Release / Enable Active
          B184C 00 [01100000] - -
          [DTC_SFD_ROLE_UNLOCK]
   Part No SW: 3WA 959 392 A    HW: 3WA 959 392
   Component: TSG BFS       001 0221
   Serial number: YG007XJO0926B   Dataset Number: V03935443PP 0001
   Coding: 00200120C000000100001020
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
   VCID: 51FC7F28C16C5072505-8004-R SFD+SFD2
   Part No SW: 2KF 035 816 L    HW: 2KF 035 816 H
   Component: MU-O-ND-EU    H10 2574
   Serial number: WG8LGM081024004 Dataset Number: V03935452YV 0001
   Coding: E3521000002020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 002001
   ROD: EV_MUOIMQB37w_002_VW37.rod
   VCID: 46D65C74382287CAF57-8012-R SFD+SFD2
   Subsystem 1 - Part No SW: 5H0 919 605 D    HW: 5H0 919 605 D
   Component: ABT_W_10       H49 2112
   Serial number: APUFM816102400010549
1561 - Predictive Route Data
          B1630 02 [00001001] - Signal Failure
                    Mileage: 7 km
                    Date: 2025.03.24
                    Time: 23:26:17
                    Voltage terminal 30: 12.6 V
4112 - Release / Enable Active
                    Reset counter: 12
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:25
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383 D    HW: 5H0 907 383
   Component: Anhaenger     H12 0204
   Serial number: 000000000006537 Dataset Number: V03935396GS 0001
   Coding: 0100000202001200
   ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
   ROD: EV_TrailFunctG3MPFMHella_VW27.rod
   VCID: 2F3819D0B7982682261-807A-R SFD+SFD2
812817 - Release / Enable Active
          [ECU unlocked]
                    Mileage: 2 km
                    Date: 2024.11.19
                    Time: 09:13:28
   Part No SW: 571 035 284 B    HW: 571 035 284
   Component: OCUMQBW2023_H H09 0626
   Serial number: 0000000408VINV2 Dataset Number: V03935445PN 0001
   Coding: 00010601000000110000010000002607111012111012000010
   ASAM Dataset: EV_OCUMWB2023 001066
   ROD: EV_OCUMWB2023_VW49.rod
   VCID: 1574CB383504FC524CD-8040-R SFD+SFD2
7248 - Function Restricted due to Missing Message(s)
          U1111 00 [00101111] - -
          [InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 7 km
                    Date: 2025.03.24
                    Time: 23:26:35
                    Voltage terminal 30: 12.4 V
   Part No SW: 5WA 980 653 F    HW: 5WA 980 653 A
   Component: MQB MFK 3.0   H12 3602
   Serial number: EE8688004243030 Dataset Number: V03935443PF 0001
   Coding: 0001089011584040409E08001020002000018048600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005071
   ROD: EV_MFK3ValeoMQB_AU38P.rod
1126468 - Databus
          [PSD_04_PSD_Vorgaenger_Segment_ID]
                    Mileage: 7 km
                    Date: 2025.03.24
                    Time: 23:26:18
1126467 - Databus
          [PSD_04_PSD_Segment_ID]
                    Mileage: 7 km
                    Date: 2025.03.24
                    Time: 23:26:18
1126464 - Databus
          [VMM_02_VZM_Warnruckeln_nicht_verfuegbar]
                    Fault Frequency: 29
                    Mileage: 3 km
                    Date: 2024.11.19
                    Time: 10:34:56
   Part No SW: 992 941 571 AJ    HW: 992 941 571 A
   Component: LED1L         H17 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6A8EC8C44CFA83AA31F-803E-R
   Component: LED1R         H17 9204
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.5V)-----------
------------------------------49 Faults Found------------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Please clarify, Tourneo or Transit...
NEtech
Denmark
C?ID=56995
Partslink write: Transit/Tourneo Connect 2022-
Probably easier to call it Ford Connect.
msaflund
Sweden
C?ID=393205
Hi, is there a way to access and enable rear view camera on this model and install 3rd party rearview camera and have it in the display? The model in Sweden comes with 2 setups and 1 setup is without integrated rear view camera, and i would like to install it and have it in the display rather than separate monitor.
