2022 Audi A1 instrument fault codes VC
bowie3000
Wales, UK
C?ID=433037
Hey all, new poster / long time looker here :) I'm hoping for some clarification and guidance on an issue I came across yesterday. I'm looking for an Audi A1 black edition (UK) for my wife and went to see one in a used car dealer. The car is a 2022 35 TFSI black edition with 11,000 miles. Car is straight and mostly in keeping with its age and mileage. I did a test drive and all was well and when we got back to the dealer I asked if he minded if I plugged in and looked for the gearbox mileage to see if it all matched up. As you know, we have issues in the UK with the use of mileage blockers. I went into the auto transmission controller and then adv measuring blocks and picked transmission mileage from the list. This was around 18000km so all pretty much lined up with the instrument cluster mileage.
I then did an auto scan to check for anything else unusual and found quite a few faults. Some were, I think, relating to low battery voltage (maybe due to standing still for some time), some related to the radar sensor on the front, but the instrument controller had four faults for function restricted due to interrupted communications. Now, this had me concerned and, maybe rightly or wrongly , I thought they may be related to a blocker still being fitted. But the transmission mileage was correct, so I'm a bit conflicted !
Am I overthinking this and can anyone shed any light on the codes ? The time and date of the faults on the instruments were fractionally before I scanned !
Also, am I checking the correct place in the gearbox controller for the true mileage ?
Cheers, Chris.
Saturday,12,April,2025,16:08:34:16229
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: WAUZZZGB0NR023769   License Plate:
Chassis Type: GB-AU27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 4B 52 5F 6C 75 A5 BB BC
          D6 D7
VIN: WAUZZZGB0NR023769   Mileage: 18006km-11188miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 CF    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 0806
   Revision: 8AH20000    CVN: 34A64371
   Coding: 0225003223241D0800000000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906018CF 004003
   ROD: EV_ECM15TFS01105E906018CF_004_VW27.rod
   VCID: 6B83CDB2530606024A9-803E
   VINID: 9D196AAAA5D201E8800831C62497CBCBD0
   Part No SW: 0CW 300 051 M    HW: 0AM 927 769 N
   Component: GSG DQ200G2_M H07 1936
   Revision: 00007009    Serial number: CU502112087730 CVN: 744FDD93
   Shop #: WSC 00049 770 00084
   ROD: EV_TCMDQ200021.rod
   VCID: 40D94A1E0A00355ACFB-8014
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 AP    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0262
   Serial number: 08513336220207
   Coding: 42094D4F354342B0B203AC1C37E323A649125106336A24582454285545ECC46592488A60CC56241A242A14AAA255D243BFAA4BC2FD242424242424
   Shop #: WSC 00049 770 00081
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_VW37.rod
   VCID: 7CA1FEEE266891BAD33-8028
   Part No SW: 83A 820 047 G    HW: 83A 820 047 G
   Component: AC Manuell el H04 0070
   Revision: 20026000    Serial number: 00000000839548
   Coding: 231000040000000010000000000001040000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU326 001007
   ROD: EV_AirCondiFrontManAU326.rod
   VCID: 2809F2BE8270ED1AE7B-807C
   Part No SW: 5Q0 937 084 EB    HW: 5Q0 937 084 EB
   Component: BCM MQBAB M+  H44 0511
   Serial number: 01102202500808 Dataset Number: 82A909514F  0045
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   Subsystem 1 - Part No SW: 81A 955 559 B    HW: 81A 955 559   Labels: 5Q0-955-547.CLB
   Component: G397_RLS  H06 0004
   Serial number: 40121169X81A955559B0
   Coding: 80004D
   Subsystem 2 - Part No SW: 4K2 941 501 R    HW: 4K2 941 501 R
   Component: E1 - LTM  H07 0060
   Serial number: 18S02.02.2200300879
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY22001245W
   Serial number: 00000000000050554173
   Steering Column Switch:
   Subsystem 5 - Part No SW: 82A 953 521 MP    HW: 5Q1 953 549 D
   Serial number: 00000015122120241086
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058322032 Dataset Number: 82A909526E  0034
   Coding: 8471151011
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: 53F37552EB76BEC2629-8006
   Part No SW: 2Q0 907 572 AA    HW: 5Q3 907 572 B
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: 82A909863H  0005
   Coding: 320060C208FF8728747C61650050A700080000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 73B3D5D20B36DEC2829-8026
196740 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SENSOR_BLOCKAGE]
                    Reset counter: 32
                    Mileage: 17806 km
                    Date: 2025.02.07
                    Time: 21:18:14
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 12 °C
                    Vehicle speed: 31.44 m/s
                    Longitudinal acceleration: -0.06 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
196800 - Internal Fault
          B200F F0 [00001000] - -
          [VDY_FS_VEH_CORR_MONITOR]
                    Reset counter: 32
                    Mileage: 17809 km
                    Date: 2025.02.07
                    Time: 21:19:46
                    Vehicle speed: 28.84 m/s
                    Longitudinal acceleration: 0.13 m/s²
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 AS    HW: 2Q0 959 655 AS
   Component: VW22Airbag    020 0411
   Revision: --------    Dataset Number: 82A909602H  0001
   Coding: 88CCC0C0000000005C5400DF008840A80065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0E45A42600D4932A0D7-805A
   Subsystem 1 - Part No SW: -----------    HW: 442 060 102 22
   Serial number: 3577Y51B104BB5E24501
   Subsystem 2 - Part No SW: -----------    HW: 442 060 102 22
   Serial number: 3587Y51B104BB5E214FD
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 702 22
   Serial number: 3517712B5091E751E3CM
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 712 21
   Serial number: 3527711BD084F6F4746X
   Subsystem 5 - Part No SW: -----------    HW: 442 130 411 21
   Component: FrontSensor_D  290 118A
   Serial number: 355AG73C8C6D5B330654
   Part No SW: 82A 920 710 D    HW: 82A 920 710 D
   Component: KOMBI         H03 6170
   Coding: 2CA40008698026000180A0401000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_001_AU27.rod
   VCID: 221DE096E44C074AB9F-8076
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 11
                    Mileage: 18006 km
                    Date: 2025.04.12
                    Time: 15:04:16
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 11
                    Mileage: 18006 km
                    Date: 2025.04.12
                    Time: 15:04:16
16777026 - Function Restricted due to Interrupted Communications
          [BAP_MFL_Jokerfunktion_0x34 keine Kommunikation]
                    Reset counter: 11
                    Mileage: 18006 km
                    Date: 2025.04.12
                    Time: 15:04:18
16777030 - Function Restricted due to Interrupted Communications
          [BAP_TEL2_0x29 keine Kommunikation]
                    Reset counter: 11
                    Mileage: 18006 km
                    Date: 2025.04.12
                    Time: 15:04:16
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 02022210800693 Dataset Number: 82A909515G  0001
   Coding: 030100F42F0857005B100248180B00000000000000000000000000000000
   GVL: 01463C0000000000408C80008002C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 79AFE7FA295AA492C85-802C
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 82A 951 523 B    HW: 82A 951 523 B
   Component: E221__MFL  H50 0053
   Serial number: 50S50005373062421204
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 102322CD
8526361 - LV Energy Management
          B1802 F1 [00001000] - Warning Triggered
                    Reset counter: 46
                    Mileage: 17991 km
                    Date: 2025.03.20
                    Time: 11:28:09
                    Terminal 30 power supply: 11.4 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000461022462  Dataset Number: 82A909872E  0004
   Coding: 00180220F001020000001000
   VCID: 52FD7056D46CB7CA69F-8006
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000057321626
   Coding: 2D0000
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V1.clb
   Part No SW: 2Q2 909 144 S    HW: 2Q2 909 144 S
   Component: TRW_G4L_MQBA0 622 6042
   Serial number: 02883827CB2N033 Dataset Number: 82A909852L  0001
   Coding: 010000000100000101010201010001010000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 43D345121B162E42D29-8016
10591488 - Internal Fault
          [DEM_LATE_HALL_EDGE_FAULT]
                    Reset counter: 135
                    Mileage: 6647 km
                    Date: 2023.03.10
                    Time: 12:25:48
                    Engine speed: 826 /min
                    System status: Driving mode
                    Terminal 15 status: On
                    Voltage terminal 30: 14.83 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.6 A
                    End stage temperature: 6 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 351 °
                    Electric motor speed: -1 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.1 Nm
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0367
   Serial number: 03022210800271 Dataset Number: 82A909583A  0009
   Coding: 000000070900204600002900020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B21C25FCE72E27E1-8062
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000460342652  Dataset Number: 82A909873E  0004
   Coding: 00180020FC01020000001000
   VCID: 51FF7F5AD16ACCD2505-8004
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000057683950
   Coding: 350000
   Dataset Number: 82A909460A  0007
   Coding: 0272000102002001400040
   VCID: 392F27FA69DA6492885-806C
   Part No SW: 5WA 035 284 E    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0141
   Serial number: 0000000109VICL7 Dataset Number: 82A909612J  0013
   Coding: 012700101FE028009005460120012607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 48C9523E22300D1A07B-801C
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Mileage: 18006 km
                    Date: 2025.04.12
                    Time: 14:47:27
                    Voltage terminal 30: 12.2 V
1644017 - Online Services
          B1915 F1 [00001000] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Reset counter: 35
                    Mileage: 17990 km
                    Date: 2025.02.17
                    Time: 15:16:02
                    Voltage terminal 30: 11.8 V
                    Remaining long term energy budget: 2932 mAh
                    Remaining short term energy budget: 1 mAh
                    Wake up cycles counter: 1827
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004220380 Dataset Number: 82A909466K  0001
   Coding: 0004090801484020489E00000020000000010000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW48.rod
   VCID: 35372BCA45C280F26CD-8060
   Part No SW: 4K0 941 572 CC    HW: 4K0 941 572 C
   Component: LMS_MQB       H06 0032
   Dataset Number: 82A909471C  0001
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71BFDFDA712AECD2705-8024
   Dataset Number: 82A909472C  0001
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
End----(Elapsed Time: 01:17, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
------------------------------10 Faults Found------------------------------
Yes the radar sensor is faulty, a huge problem to such an extent that they get stollen, part number 5Q3 907 561 G and £795.60 plus install and calibration so at least a grand. That steering assist fault is also worrying, these electric steering columns are a joke across the PQ26 platform and another £2076 plus labour.
IDE02820-ENG99004 -- Transmission mileage - Transmission mileage (km)
The ACC sensor has an internal fault, as does the steering rack. My guess is there are reasons why the original owner dumped a 3 year old car with less than 12,000 miles on it. If you buy this car, what kind of warranty does it come with? ;)
The rack (steering gear) is a dumb part on this platform, the assistance is via a motorised steering column and they are being a pain. In some cases, there has been no UK stock.
  • Informative
bowie3000
Wales, UK
C?ID=433037
I'm imagining at least a 3 month but maybe their used programme is a bit more. Its an official Mercedes satellite site that sells new and used. I will find out more. I was thinking about getting an official Audi UK extended warranty but would there be an issue with pre-existing faults ?
Thanks for clarifying all. Appreciate this very much!
Chris.
bowie3000
Wales, UK
C?ID=433037
The radar sensor fault was from 2023 when the car was just under a year old. If it had happened again since would the time and date on the fault update ?
Are we thinking the instrument faults are related to anything ?
Chris.
JMR
Romania
C?ID=432218
new cars :banghead:
And it is only going to get worse. I did a Tiguan yesterday that had missing messages on various controllers for the steering angle sensor but it didn't say what and ODIS was no help.
  • Wow
Reactions: JMR
