Sensor location ide05389
sq5 faster
Sheffield, UK
C?ID=518552
Hi all I have read this forum so much and thought i was able to fix my sq5 but NO. Got a IDE 05389 Sensor reading -20 degrees. this has a description of exhaust gas model temperature 3. ? The others exhaust sensors read ok. anyone got any idea where this sensor is ? it wont regen till i sort it Its on a SQ5 2016 Thanks
  • Haha
Reactions: TTT
sq5 faster
Sheffield, UK
C?ID=518552
WILL SEND ANOTHER
sq5 faster
Sheffield, UK
C?ID=518552
Sunday,13,April,2025,12:45:47:57721
VCDS Version: Release 25.3.1 (x64)
                Address 01: Engine
Control Module Part Number: 8K5 907 589 C
  Component and/or Version: 3.0BTD EDC17  H23 0008
           Software Coding: 2A2A4032252603030000
            Work Shop Code: WSC 01286
                      VCID: 41DF4BF4C107DD92C05-8014
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: 54H23---
     Date: 25.10.16
     Manufacturer number: 1409
     Test stand number: 0280
Flash Status
     Programming Attempts(application): 4/3/3/3/3
     Successful Attempts(application): 4/3/3/3/3
     Flash Date-Workshop ID-Status:
     0C.0B.18 08256 386 01286 (OK) | 0C.0B.18 08256 386 01286 (OK) | 0C.0B.18 08256 386 01286 (OK) | 0C.0B.18 08256 386 01286 (OK)
Misc.
     Hardware number: 4G0 907 589 B
     Workshop System Name: J623
     Workshop ID (Adaptation): 00000 000 00000
     Workshop ID (Coding): 08256 386 01286
     ASAM Dataset: EV_ECM30BTD0118K5907589C
     ASAM Dataset Revision: 001010
Car Info
     Chassis Number: WAUZZZ8R0HA078320
     Engine code: CVUB
Immobilizer
     General immobilizer info :
          Life status: 2
          Identity counter: 1
          Brand identification: 3
          Power class: 0
          Count of adapted keys: 0
          Count of keys to be adapted by adaptation: 0
          Minutes remaining for Terminal 15 ON: 0
          Configuration status: 0
          Reserved: 0
     Lock times in minutes :
          Lock time password reset: 0
          Lock time login/Terminal 15 ON: 0
          Lock time key adaptation: 0
          Lock time leaving key adaptation: 0
          Lock time login special function: 0
     Immo Challenge: 3476D34A
VCDS Info:
     Labels: 059-907-401-V2.clb
     Readiness: No script available
     ROD: EV_ECM30BTD0118K5907589C.rod
sq5 faster
Sheffield, UK
C?ID=518552
Sunday,13,April,2025,12:46:32:57721
VCDS Version: Release 25.3.1 (x64) Running on Windows 11 x64
                Address 01: Engine       Labels: 059-907-401-V2.clb
Control Module Part Number: 8K5 907 589 C    HW: 4G0 907 589 B
            Work Shop Code: WSC 01286 386 08256
              ASAM Dataset: EV_ECM30BTD0118K5907589C 001010 (AU48)
5188 - Particle Filter
          P2463 00 [10100111] - Excessive Soot Accumulation
                    Mileage: 171198 km
                    Date: 2025.04.13
                    Time: 12:43:01
                    Engine speed: 0.00 /min
                    Coolant temperature: 14 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.300 V
                    P Flt Ld fac Ash Cor: 1.0000
                    Particul.filter diff.pressure: -4 hPa
                    Exh t Adap T Oxi Cat Ds: 16.3 °C
                    Exh t Adap TP Flt Ds: 15.4 °C
                    Current operating mode_2-Bits 0-7: 128
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 16
5189 - Particulate Trap Bank 1
          P2002 00 [00100111] - Efficiency Below Threshold
                    Mileage: 171198 km
                    Date: 2025.04.13
                    Time: 12:43:01
                    Ambient temperature: 11.0 °C
                    DPF: offset for differential pressure: -2 hPa
                    Particle filter: soot mass measured: 30.00 g
                    Particle filter: soot mass calculated: 18.09 g
                    Particle filter: kilometers since last regeneration: 414211 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Westbury, UK
Interesting, but neither of those is an Auto-Scan, so please post an Auto-Scan (that's a link to a How To).
  • Agree
sq5 faster
Sheffield, UK
C?ID=518552
Sunday,13,April,2025,15:35:06:57721
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: WAUZZZ8R0HA078320   License Plate:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D
          72 A9 AC C0
VIN: WAUZZZ8R0HA078320   Mileage: 171210km-106384miles
Address 01: Engine (J623-CVUB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---    CVN: C296770FC19C7771B866C2ADB866C2AD9B0058CB
   Shop #: WSC 01286 386 08256
   VINID: 9D196AAAA2220184401C80C200DE981D4F
                    Mileage: 171213 km
                    Date: 2025.04.13
                    Time: 15:18:07
                    Coolant temperature: 89 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.340 V
                    Particul.filter diff.pressure: -3 hPa
                    Exh t Adap T Oxi Cat Ds: 266.7 °C
                    Exh t Adap TP Flt Ds: 226.0 °C
                    Mileage: 171213 km
                    Date: 2025.04.13
                    Time: 15:18:07
                    Ambient temperature: 13.5 °C
                    DPF: offset for differential pressure: -3 hPa
                    Particle filter: soot mass calculated: 34.01 g
                    Particle filter: kilometers since last regeneration: 429256 m
   Part No SW: 8R0 927 158 AR    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H22 1006
   Revision: --H22---    CVN: D230B98D
   VCID: 0D47A7C4CDDF49F2F4D-8058
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Component: ESP8 quattro  H09 0020
   Coding: 35DDCC01
   VCID: 05579FE4952F31B2BCD-8050
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 01B54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 7F5B0D0CF7F36B62F61-802A
   Subsystem 1 - Part No SW: 8K0 959 754 BM    HW: 8K0 959 754 BM
   Serial number: 0816000090739005
   Serial number: 3216000243420008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01241020161434
   Coding: 3625028080
   VCID: 78A9E610D2DD5C5AB7B-802C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001506219902
   Coding: 260000108034AFE0018140C300001D0D0F9DE70827090201000008004400030100000024000000
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 161011  H13 0050
   Serial number: 90243015161005101641
   Coding: 01DD13
   Serial number: 62396447
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002010161508
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 8748C65800PAG0MUFU03
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 169
                    Mileage: 171198 km
                    Date: 2025.04.13
                    Time: 11:05:28
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD3LTSP   Dataset Number: 8R0909602H  0001
   Coding: 30473531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C956D0E23DECDA07B-801C
   Serial number: 6334MSME5B096A1CR
   Serial number: 6344MSME595A4367N
   Serial number: 6352QSME776E467A
   Serial number: 6362QSME18703C62H
   Serial number: 63732SME1B700562V
   Serial number: 63832SME1B700554X
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 91560PJV00103
   Coding: 000037
   VCID: 48C956D0E2BDECDA07B-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 T    HW: 8R0 920 950 T
   Component: KOMBIINSTR.   H35 0567
   Revision: 00300000    Serial number: 03F318XAH
   Coding: 33A7220003012600010000
   VCID: 47CB55ECEFA3E3A20E1-8012
   Part No SW: 8R0 907 468 AE    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0071
   Revision: 1Y100033    Serial number: 3341Y16A260274
   Coding: 80CD07FF00
   VCID: 025D84F88401068A99F-8056
   Subsystem 1 - Part No SW: 80A 915 181 A    HW: 80A 915 181 A
   Component: J367-BDMHella  H06 9070
   Serial number: 0271271904
   Serial number: 16307000673021200181
                    Reset counter: 209
                    Mileage: 171198 km
                    Date: 2025.04.13
                    Time: 12:44:58
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
   Component: TSG FA        H03 0511
   Revision:             Serial number: 0000222713065
   Coding: 011D02214001440004
   VCID: 4FFB7DCC07D33BE2461-801A
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000001    Serial number: 0000337435 Dataset Number: 8R0909852K  0025
   Coding: 100000010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46D558E8E829FAAAF57-8012
   Revision: 00002001    Serial number: 0420401735
   Coding: 013B0622A0B9300087200536A0040047
02615 - Fuel Tank Cap; Lock
                    Reset counter: 169
                    Mileage: 171198 km
                    Date: 2025.04.12
                    Time: 19:02:13
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 169
                    Mileage: 171198 km
                    Date: 2025.04.12
                    Time: 23:16:57
   Component: TSG BF        H03 0511
   Revision:             Serial number: 0000225796194
   VCID: 4EC560C800D932EA4D7-801A
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 10000000712081
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D3C18ACD18E4A81F-806E
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109J10G2627618
   Coding: 010103020100000001
   VCID: 2D0707446D1F29F214D-8078
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 H
   Component: H-BN-EU       H50 1036
   Revision: --------    Serial number: 515IB0GS020192
   Coding: 1A0101060205A1ED05808B5E00000403E40000020000000000
   VCID: 42DD44F8C481C68AD9F-8016
   Subsystem 1 - Part No: 8R0 060 884 DP
   Component: EUR 2016/2017  2302
   Component: DU7 High  H42 0104
   Serial number: A130JY0G3646144
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002626155
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000224273152
   Coding: 010C02204001240004
   VCID: 46D558E8E8A9FAAAF57-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: ConWys Trailer H09 0100
   Revision: 1G001001    Serial number: 00000173782896
   Coding: 0100000000000000
   Shop #: WSC 00375 223 87350
   VCID: 35372F24854F61326CD-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D273704BD7FB972A4D-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000224403216
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 160913200399
   VCID: 79AFE314E9574552C85-802C
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 162780166 Dataset Number: 8R0909571G  0019
   ROD: EV_RDCMA00100.rod
   VCID: 2F3B1D4C67935BE2261-807A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0008
   Serial number: 160930201761
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS_VW37.rod
   VCID: 323D143874A1760A49F-8066
End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------6 Faults Found-------------------------------
sq5 faster
Sheffield, UK
C?ID=518552
Sunday,13,April,2025,15:50:02:57721
VIN: WAUZZZ8R0HA078320   License Plate: N999DDS
Mileage: 171210km-106384mi   Repair Order:
          72 A9 AC C0
                    Mileage: 171213 km
                    Date: 2025.04.13
                    Time: 15:18:07
                    Mileage: 171213 km
                    Date: 2025.04.13
                    Time: 15:18:07
   Coding: 35DDCC01
   Coding: 3625028080
   Coding: 01DD13
   Coding: 02005C
                    Reset counter: 169
                    Mileage: 171198 km
                    Date: 2025.04.13
                    Time: 11:05:28
   Coding: 000037
   Coding: 80CD07FF00
                    Reset counter: 209
                    Mileage: 171198 km
                    Date: 2025.04.13
                    Time: 12:44:58
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Reset counter: 169
                    Mileage: 171198 km
                    Date: 2025.04.12
                    Time: 19:02:13
                    Reset counter: 169
                    Mileage: 171198 km
                    Date: 2025.04.12
                    Time: 23:16:57
End----(Elapsed Time: 01:57, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Just done another to check after clearing codes Thanks
iichel
Netherlands, Operation Market Garden
C?ID=284912
So it has a few temp sensors
In the EGR system
before starter catalyst
before DPF
after DPF
pretty standard for a TDI
howeverrrr
Some cars have some calculated measures as well, based on lambda and other temp sensors.
So i'm not sure which one is the one in the IDE measurement value you quote.
But since it has model in it, i'm speculating it could be virtual
sq5 faster
Sheffield, UK
C?ID=518552
I did think it might be virtual. Just going to disconnect the battery and rescan
sq5 faster
Sheffield, UK
C?ID=518552
After reconnecting the battery i rescanned and the car it did a regen correctly and now looks to be ok , doing a test drive this morning. It would not do a regen before at all
