2015 Audi T TDi cut out while driving, and will now crank but not start.
MitchC
C?ID=443944
Good evening,
I have an issue with my daughter's Audi TT TDI in which it cut out while driving and would crank but not start. here is the scan:
Wednesday,09,April,2025,20:45:58:11279
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 ED    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 8240
   Revision: 81H22---    CVN: BF1E8D5D
   Coding: 02190012030501083000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TDI01104L906021ED 002010
   ROD: EV_ECM20TDI01104L906021ED_002.rod
   VCID: 6BD2159E82A9FFCE06-803E
   VINID: 92296AAAA5A601604000824920FF439CAA
5211 - Fuel Rail/System Pressure
          P0087 00 [01100101] - Too Low
                    Mileage: 249648 km
                    Date: 2025.04.08
                    Time: 17:25:04
                    Engine RPM: 2296.50 /min
                    Normed load value: 76.9 %
                    Vehicle speed: 20 km/h
                    Coolant temperature: 85 °C
                    Intake air temperature: 83 °C
                    Voltage terminal 30: 14.720 V
                    Unlearning counter according OBD: 80
                    Fuel temperature sensor 1: B1: raw value: 57.6 °C
                    Mean injection quantity: 38.67 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high pressure sensor: actual value: 278600 hPa
                    Fuel high pressure sensor: nominal value: 1674400 hPa
                    Pressure control valve adaptation factor: 1.1335
                    Fuel level: 8.00 l
5212 - Fuel Rail/System Pressure
                    Mileage: 249648 km
                    Date: 2025.04.08
                    Time: 17:25:08
                    Engine RPM: 2297.00 /min
                    Normed load value: 100.0 %
                    Intake air temperature: 85 °C
                    Fuel temperature sensor 1: B1: raw value: 57.9 °C
                    Mean injection quantity: 20.60 mg/stroke
                    Fuel high pressure sensor: actual value: 249100 hPa
                    Fuel high pressure sensor: nominal value: 1317500 hPa
                    Fuel level: 8.00 l
20557 - Heater support pump
          P16C7 00 [00100000] - locked
   Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
   Component: ESC           H31 0504
   Revision: 00000000    Serial number: 63474000000510
   Coding: 13AA108D1A9915B1009A006DC299830624C80858A8000043C16024
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_052.rod
   VCID: 40889232DBAFCC9683-8014
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 19
                    Mileage: 247712 km
                    Date: 2025.03.09
                    Time: 11:08:38
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0355054959 Dataset Number: 8S0909577D  0001
   Coding: 000F0F1620
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 77FA39EECEE14B2EF2-8022
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0030
   Revision: 20009000    Serial number: 14110000009000
   Coding: 411040002011101100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6CD0168287A7F8F60F-8038
   Humidity sensor: exterior:
   Rear A/C Control Head 1:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H06 0020
   Serial number: 00000000000000006168
   Rear A/C Control Head 2:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H06 0020
   Serial number: 00000000000000006194
   Rear A/C Control Head 3:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H06 0020
   Rear A/C Control Head 4:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H06 0020
   Rear A/C Control Head 5:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H06 0020
   Serial number: 00000000000000006223
332038 - Position Sensor for Side Defrost Flap; Left
          B1661 15 [00001000] - Open or Short to Plus
                    Reset counter: 24
                    Mileage: 249305 km
                    Date: 2025.04.01
                    Time: 13:21:21
                    Voltage terminal 30: 14.6 V
                    Outside temperature: 16.0 °C
                    Defrost flap motor for left side window: actual value: 0.00 %
                    Defrost flap motor for left side window: actual value: 949
                    Defrost flap motor for left side window: spec. value: 900
   Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0136
   Serial number: 01011435100893 Dataset Number: 8S0909514B  0026
   Coding: 07054D46C20106FD03044004B31807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 091E4F16A8154DDE94-805C
   Subsystem 1 - Part No SW: 8S2 955 119 A    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 43x RL 140703  032 0371
   Serial number: 00000001407010600503
   Coding: 1BC7F7
   Serial number: 23572266
   Coding: 00005D
   Serial number: 23 10 2014  00000081
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY143210PE8
   Serial number: 00000000000031448399
          B1263 01 [00001001] - Electrical Failure
                    Fault Frequency: 68
                    Reset counter: 253
                    Mileage: 221783 km
                    Date: 2023.11.19
                    Time: 13:10:52
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.6 V
                    Outside temperature: 11.0 °C
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 88
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 7.0 °C
786954 - Heater for Spray Nozzles
          B1224 15 [00001000] - Open or Short to Plus
                    Reset counter: 25
                    Mileage: 248911 km
                    Date: 2025.03.30
                    Time: 09:45:57
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.4 V
                    Outside temperature: 9.5 °C
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39291435201968 Dataset Number: 8S0909526A  0012
   Coding: 0000050001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 3B72E5DEB249AF4ED6-806E
          U1400 00 [00001000] - -
                    Reset counter: 38
                    Mileage: 249655 km
                    Date: 2025.04.09
                    Time: 19:32:08
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R007ZY6 Dataset Number: 8S0909602A  0026
   Coding: 88CCF0C00C8000005C5000CFC0C800000065
   VCID: 4D96BB061CFD11FE78-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 001 312 14
   Serial number: 357000000008236D321A
   Subsystem 2 - Part No SW: -----------    HW: 480 001 312 14
   Serial number: 358000000009E36D321O
   Subsystem 3 - Part No SW: -----------    HW: 480 012 909 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A01DD52E032EEF
   Subsystem 4 - Part No SW: -----------    HW: 480 400 409 14
   Serial number: 3550002A9175A8D2A116
   Subsystem 5 - Part No SW: -----------    HW: 480 400 409 14
   Serial number: 3560002AB175A8D1A08E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 411 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2300002A51860BC3807Z
   Subsystem 7 - Part No SW: -----------    HW: 480 001 911 14
   Serial number: I0M000000007416D221X
   Subsystem 8 - Part No SW: -----------    HW: 480 001 911 14
   Serial number: I0N000000006A68C2212
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8S0 907 129 R    HW: 8S0 907 129 R
   Component: Lenks. Modul  H07 0140
   Revision: --------    Serial number: 91335NLG01470
   Coding: 0008
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_010_SE37.rod
   VCID: 499E8F16E8950DDE54-801C
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8S0 920 790     HW: 8S0 920 790
   Component: FBenRDW       H32 0295
   Coding: 240D0110298406000123E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001023
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 76E434EAC9EB3226E9-8022
   Part No SW: 8S0 907 468 A    HW: 8S0 907 468
   Component: GW MQB TT3    012 0203
   Revision: --------    Serial number: 26111410801437 Dataset Number: 8S0909515A  0015
   Coding: 030100040F0276004B000268080000000000000000000000000000000001
   GVL: 01543C1000000600408C10000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewContiAU33X 011002
   ROD: EV_GatewContiAU33X_011.rod
   VCID: 3E74ECCAA15BBA66F1-806A
   Generator:
   Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
   Component: J453 MFL  H06 0001
   Serial number: 20140916124500 RD311
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 9118435003
   Serial number: 14000306487001
   Coding: 0100000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71EE07F6A085151E3C-8024
   Serial number: 061214BL40690A Dataset Number: 8S0909872B  0016
   Coding: 001346224001040100001402
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 428C983AD5A3DE8695-8016
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 8S0909852B  0007
   Coding: 8103
   VCID: 377AF9EE8E618B2E32-8062
Address 47: Sound System
   Serial number: 161214BLG0308A Dataset Number: 8S0909873B  0016
   Coding: 001346224C01040100001402
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 418E9736D0A5C59E8C-8014
   Revision: --------    Serial number: -------------- Dataset Number: 8S0909865C  0023
   Coding: 03DE00102B230200
   Shop #: WSC 15017 002 1048576
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
   VCID: 3460CEE29F17603617-8060
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 980 653     HW: 5Q0 980 653
   Component: MQB_MFK       H06 0002
   Serial number: 10000179191    Dataset Number: 8S0909466A  0012
   Coding: 0001010001010305000501000000010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 7AFC20DAFDF356468D-802E
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 141116201218
End-------------------------(Elapsed Time: 05:45)--------------------------
So I checked for voltage and earth at the Fuel Pressure Sensor, and signal, which was 0.75v when I was expecting 1.5-2 v,
Checked for 12v and switching signal at the FPR, which were fine.
Suspected the FPR was at fault, so I swapped it with my Scirocco, which had the same part. Didn't start and the Scirocco did with the TT FPR.
Then I tried the solenoid on the HPFP, which had signal and 12v I so swapped that with the Scirocco too. When I cranked the TT, it now sounds like it is trying to fire but still no start.
I fired up the Scirocco, which ran for a few seconds, then cut out and would only crank but not try to fire. I tried priming the pump for a couple of minutes but still no luck. I then swapped the FPR and HPFP solenoid back to the original car, primed the Scirocco again but it is just spinning over but not firing, so now I have two disabled cars.
Is there a way to bleed the HP fuel system so I can get the Scirocco working so I can drive it to work on Monday?
On this TT, I would run the Basic Setting:
IDE00459 -- Test of transfer fuel pump
Our the Output Test for:
IDE00219-ENG167462 -- Fuel pump electronics
You may need to run them several times to get fuel all the way though the system.
And without seeing a scan from the Scirocco, it's just a guess whether it's the same.
Jef
HQ
So I checked for 12v and earth at the Fuel Pressure Sensor, and signal, which was 0.75v when I was expecting 1.5-2 v,
:confused:
Fuel pressure sensor (G247) should have about 5V across /1 and /3.
Was there "glitter" to be found with the HPFP?
MitchC
C?ID=443944
:confused:
Sorry, I meant voltage and earth, not 12v at the sensor. It was 12v and switching at the regulator. There are a lot of Scotch induced spelling mistakes in my first post, I'll edit it later 🙃
And yes, I found the HPFP issue on the TT later on yesterday unfortunately after being prompted to look for it. There is zero on the Scirocco.
MitchC
C?ID=443944
Thanks. I tried running the fuel pump for a couple of minutes in the output test but wasn't sure if it would bleed the high pressure side.
Here is the Scirocco scan;
Saturday,12,April,2025,12:24:06:11279
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BB    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H23 9977
   Revision: 42H23---    Serial number:                CVN: 7CB84C0D
   Coding: 00190012042500080000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BB 003008
   ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
   VINID: 9E69EAAAA043A929800C10081822095E8A
                    Mileage: 322714 km
                    Date: 2025.04.12.
                    Time: 11:37:53
                    Engine RPM: 646.50 /min
                    Coolant temperature: 19 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 13.500 V
                    Fuel temperature: 16.1 °C
                    Mean injection quantity: 36.34 mg/stroke
                    Fuel high-pressure: actual value: 56000 hPa
                    High fuel pressure: specified value: 725000 hPa
                    Pressure control valve adaptation factor: 1.1016
                    Fuel level: 23.00 l
5215 - Fuel Rail/System Pressure
                    Mileage: 322714 km
                    Date: 2025.04.12.
                    Time: 11:37:53
                    Engine RPM: 1500.50 /min
                    Normed load value: 99.6 %
                    Voltage terminal 30: 14.520 V
                    Mean injection quantity: 38.20 mg/stroke
                    Fuel high-pressure: actual value: 60800 hPa
                    High fuel pressure: specified value: 1250300 hPa
                    Fuel level: 23.00 l
5132 - Valve for Fuel Metering (N290)
          P0090 00 [00100100] - Open Circuit
                    Mileage: 322714 km
                    Date: 2025.04.12.
                    Time: 11:39:03
                    Engine RPM: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.240 V
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
   Revision: 00H31001
   Coding: 763B60F5492500FB6E0B06EC921F0082350000
   Shop #: WSC 00020 790 00000
   VCID: 76E434EAC1EB3226E9-8022
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   VCID: 6ED41C8AB1BB0AE621-803A
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 48180A388025E100408800843400016643513B88536D85605C8000000040
   VCID: 3B72E5DEBA49AF4ED6-806E
   Subsystem 1 - Part No SW: 1K8 955 119 G    HW: 1K8 955 119 G  Labels: 1KX-955-119.CLB
   Component: Wischer 17121  10  0603
   Coding: 009795
   Component: RLS 080211 05  54  0403
   Coding: 0330ED
                    Reset counter: 170
                    Mileage: 322714 km
                    Date: 2019.09.03.
                    Time: 12:10:09
                    Voltage: 11.70 V
                    Reset counter: 169
                    Mileage: 322714 km
                    Date: 2019.09.03.
                    Time: 09:47:52
                    Voltage: 11.60 V
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 03021103590001
   Coding: 000180
   VCID: 275A29AE56C11BAEA2-8072
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D03D0HK
   Coding: 0012360
   VCID: 6FEA018E7EB103EE2A-803A
   Subsystem 1 - Serial number: 6332MSME5B26290DJ
   Subsystem 2 - Serial number: 6342MSME5B45286ER
   Subsystem 3 - Serial number: 6352QSME6C001B58K
   Subsystem 4 - Serial number: 6362QSME26014A6EL
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110216100597
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79FE3FD6F8F55D5E84-802C
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
   Part No SW: 1K8 920 972 A    HW: 1K8 920 972 A
   Coding: 170B01
   Shop #: WSC 00020 999 12345
   VCID: 326CC8FA65036E0605-8066
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 060211F1001191
   Coding: 354001
   VCID: 3068C2F2630F5C1673-8064
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101011
                    Fault Frequency: 8
                    Reset counter: 184
                    Mileage: 321358 km
                    Date: 2019.09.03.
                    Time: 10:18:38
01304 - Radio
                    Reset counter: 210
                    Mileage: 315284 km
                    Date: 2019.09.03.
                    Time: 11:32:39
03272 - Control Module for Audio Interface
                    Reset counter: 27
                    Mileage: 315284 km
                    Date: 2019.09.03.
                    Time: 11:31:25
   Component: IMMO          H20 0420
   VCID: 6ADC109A8D53E6C67D-803E
Address 2E: Media Player 3
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2130
   Coding: 0016949
   VCID: 397EFFD670759D5EC4-806C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 178    3201
   Revision: 00H20000
   VCID: 3460CEE25717603617-8060
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016948
   VCID: 3A7CE0DA75739646CD-806E
Address 56: Radio
End-------------------------(Elapsed Time: 02:36)--------------------------
Address 0x01,03L 906 018 BB,UDS Selective Output Tests,IDE00217-Electric Fuel Pump (FP) Relay
Address 0x01,03L 906 018 BB,UDS Selective Output Tests,IDE00786-Auxiliary Fuel Pump (FP) Relay
Address 0x01,03L 906 018 BB,UDS Basic Settings,IDE00470-ENG98891-Initial fuel filling
So you found sparkle dust in the TT and transferred the contaminated valve to the Scirocco?
Same Basic Setting:
Output Tests are a bit different.
Only the mechanically driven high-pressure pump can bleed the high-pressure side, but that can only happen after the low pressure side is supplying fuel.
Let's hope you did not actually do this:
MitchC
C?ID=443944
I wasn’t aware at the time that that was a thing until afterwards, though I did clean the valves out with brake cleaner first.
MitchC
C?ID=443944
Same Basic Setting:
I figured the HPFP wasn’t going fast enough to create sufficient pressure, so I sprayed brake cleaner into the air intake and it started, so I left it running a while before switching off and trying again. Left it a while and tried a few more times, then took it for a drive with no issues. Scanned it and no engine faults came up, so I’m hoping that’s it for the Scirocco. I still have the issue on my daughter’s TT but that’s almost certainly the HPFP.
Thanks all for the assistance, it’s much appreciated.
If the HPFP on that car has failed, the car needs a whole bunch of new parts starting with injectors, as well as the whole fuel system being thoroughly cleaned. Simply replacing the HPFP would be a fools errand if there is any "glitter" contamination anywhere, since that will trash a new pump in short order.
  • Agree
Reactions: JMR
MitchC
C?ID=443944
Yep, I’m finding that out from looking deeper into it. Thanks though.
VW state to replace the entire high pressure system including the injectors but we clean the hoses and piping to save money. The trouble is, we have also seen particles in the low pressure side so it becomes a huge job. When we do a fuel filter, we always check for the early warning signs hoping to catch it before total failure
MitchC
C?ID=443944
Thanks.
I think it might be better to break or sell as it is, as she wanted to sell it anyway and it seems a lot of money and effort to repair only for her to sell it straight afterwards.
Reactions: Jef
JMR
Romania
C?ID=432218
Thanks.
yeeeah, there are some crazy repair prices in UK , par with USA prices :) . Send the car to Romania, I'll fix it for you for less than half , shipping included. How's 1.399 euros sound ? :cool:
Jef
HQ
When I was at the dealer, if there was glitter, you were to replace the fuel cap and the fuel injectors... and EVERYTHING in between. I think now days it is generally accepted to flush out some stuff like fuel lines and such... but getting the fuel tank cleaned out might be a tall task.
The reason at the time for replacing everything... the fuel system loops back to the fuel tank, so glitter back there to be pumped up to the engine bay again and again. It becomes possible for partials pass through the fuel filter and damage the injectors. Injectors, while to too difficult to replaced, are not cheap.
And over the years I've seen a good number of cases of HPFP glitter bomb and then people try to short cut the repairs only to have the replacement HPFP glitter bomb.
Then there is the whole DPF issues that can't be legally fixed.... :banghead:
MitchC
C?ID=443944
Too good to be true, so…..
JMR
Romania
C?ID=432218
Oooh..but we do... ! No , shipping it s not included , that was in the spirit of making a joke :thumbs:
