Sunday,13,April,2025,19:11:17:50063
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: WVWZZZ1JZ2W373680 License Plate:
76
VIN: WVWZZZ1JZ2W373680 Mileage: 140700km-87426miles
Address 01: Engine Labels: 06A-906-033-AVU.lbl
Part No: 06A 906 033 M
Component: SIMOS33 1,6l 2VG00AT3558
Coding: 00233
Shop #: WSC 01317
VCID: 290CF44420E51AB2F85-5160
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 35-00 - Implausible Signal
17701 - Map Controlled Engine Cooling Thermostat (F265)
P1293 - 35-00 - Short to Plus
18042 - Accelerator Position Sensor 2 (G185)
P1634 - 35-10 - Signal too High - Intermittent
Readiness: 1010 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JH
Component: AG4 Getriebe 01M 4830
Coding: 00000
VCID: 7F580A1C8EE14402F61-0962
00777 - Accelerator Position Sensor (G79)
27-00 - Implausible Signal
35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0011266
Shop #: WSC 01317 785 00200
VCID: 2C020D502A170F9A033-5160
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 01010
Shop #: WSC 01317
VCID: 211CEC6458D5D2F2A05-5160
37-00 - Faulty
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 01317
VCID: 35342834FC5D4E526CD-4B3C
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 846 A
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 19314
VCID: 290CF44420E51AB2F85-513C
WVWZZZ1JZ2W373680 VWZ7Z0A4356756
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01317
VCID: 70BAD920C3BF2B7A7FB-513C
Address 37: Navigation Labels: 3B0-919-887.lbl
Part No: 3B0 919 887 H
Component: Navigation BNO 0102
Coding: 00002
Shop #: WSC 05311
VCID: 3728223CE651BC427E1-4AE0
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4H Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 01317
VCID: 045285F0E70727DAAB3-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 4H Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4H Tõrsteuerger. BF0002r
35-00 - -
Address 55: Headlight Range Labels: 1J0-941-651.lbl
Part No: 1J0 941 651
Component: Leuchtweitenregel. V07
Coding: 00001
VCID: 6594B8740C7DFED21CD-4CD8
Address 56: Radio Labels: 3B0-035-186.lbl
Part No: 3B0 035 186 D
Component: Radio BNO 0102
Coding: 01405
Shop #: WSC 05311
VCID: 201AE96053DFDBFAAFB-4AE0
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s); Rear
Address 76: Park Assist Labels: 1J0-919-283.lbl
Part No: 1J0 919 283
Component: Einparkhilfe 0001
Coding: 01103
Shop #: WSC 01317
VCID: 6B80CE4CEA99C8A24A9-4A48
End----(Elapsed Time: 04:17, VBatt start/end: 12.1V/11.9V. VIgn 11.8V)-----
------------------------------12 Faults Found------------------------------
