Software Update Needed -- Reductant Ad Blue Fault
Tim N
County Durham, UK
C?ID=555194
Friday,28,March,2025,16:24:23:45195
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
Dealer/Shop Name: Tim Norman VAG DIAGS
VIN: WAUZZZ4G6FN092569   License Plate: TN09SEP
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 30 36 3B 42 44 46 52 53 55
          5F 62 69 6D 72 82 85 AC 47
VIN: WAUZZZ4G6FN092569   Mileage: 242960km-150968miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H34 0007
   Revision: 92H34---    CVN: F2CCE87515D91B8D92F1EF3C
   Coding: 1A254012053601030800
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
   ROD: EV_ECM30TDI011_AU57.rod
   VCID: 2411FE655E50F79ACBF-8070
   VINID: 9D196AAAA117196780242146246CA004D0
5211 - Fuel Rail/System Pressure
          P0087 00 [01100000] - Too Low
                    Mileage: 241864 km
                    Date: 2025.03.15
                    Time: 14:44:42
                    Engine speed: 3615.50 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 86 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.140 V
                    Fuel temperature: 24.0 °C
                    Mean injection quantity: 81.63 mg/stroke
                    Rail press. regulation: operating condition-Bits 0-7: 1
                    Fuel high-pressure: actual value: 464500 hPa
                    High fuel pressure: specified value: 2040000 hPa
                    Fuel low pressure: actual value: 183.1 kPa
                    Fuel level: 73.00 l
5212 - Fuel Rail/System Pressure
                    Mileage: 242580 km
                    Date: 2025.03.24
                    Time: 09:29:33
                    Engine speed: 3306.00 /min
                    Normed load value: 58.8 %
                    Vehicle speed: 119 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.200 V
                    Fuel temperature: 16.9 °C
                    Mean injection quantity: 40.03 mg/stroke
                    Fuel high-pressure: actual value: 518300 hPa
                    High fuel pressure: specified value: 1745600 hPa
                    Fuel low pressure: actual value: 184.7 kPa
                    Fuel level: 44.00 l
5227 - Fuel Rail/System Pressure
                    Mileage: 241784 km
                    Date: 2025.03.14
                    Time: 12:33:56
                    Engine speed: 2430.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 53 km/h
                    Coolant temperature: 46 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.220 V
                    Unlearning counter according OBD: 27
                    Fuel temperature: 8.9 °C
                    Mean injection quantity: 79.18 mg/stroke
                    Rail press. regulation: operating condition-Bits 0-7: 3
                    Fuel high-pressure: actual value: 1031400 hPa
                    High fuel pressure: specified value: 1853300 hPa
                    Fuel low pressure: actual value: 165.8 kPa
                    Fuel level: 66.00 l
7039 - Thermostat for Mapped Engine Cooling (F265)
          P0598 00 [00101111] - Short to Plus
                    Mileage: 241669 km
                    Date: 2025.03.12
                    Time: 16:59:37
                    Engine speed: 898.00 /min
                    Normed load value: 40.0 %
                    Coolant temperature: 43 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.340 V
                    Shut-off timer: last engine shut-off time: 2391 s
                    Control module temp.: max. value: 54.0 °C
                    Mean injection quantity: 6.62 mg/stroke
                    Ambient temperature: 8.5 °C
                    Control Module temperature: 13.0 °C
9645 - Reductant
          P20E8 00 [11101101] - Pressure too Low
                    Mileage: 242936 km
                    Date: 2025.03.28
                    Time: 15:11:22
                    Engine speed: 1640.00 /min
                    Normed load value: 76.9 %
                    Vehicle speed: 21 km/h
                    Coolant temperature: 71 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.160 V
                    Outside temperature: 13.0 °C
                    Pressure sensor for reducing agent: measured pressure: -500 hPa
                    Pump for reducing agent: speed: 2960.0 /min
                    Sensor for reducing agent tank temperature: temperature: 15.0 °C
                    Reducing agent pump: activation: 50.00 %
Readiness: 1 1 0 0 0
   Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0009
   Revision: --H03---    CVN: 000092A8
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2D071B410D9A36D2141-8078
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A69E43E86579C2BB00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF57F1A102C2B2C09-8014
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01BA704E000000000000
   VCID: 7AADE01D8CD4516AC13-802E
   Serial number: 3215000067716005
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 23041500111122
   Coding: 36231178350000
   VCID: 6393BD791BDEB0A2F25-8036
0193 - Position Sensor in Left Center Vent
          B10E1 11 [00001001] - Short to Ground
                    Reset counter: 209
                    Mileage: 241078 km
                    Date: 2025.03.07
                    Time: 12:33:20
                    Voltage terminal 30: 14.48 V
                    Terminal 15 status: Terminal 15 on
                    Supply voltage for external components: 5.00 V
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [00001000] - Signal Amplitude Too Low
                    Fault Frequency: 30
                    Reset counter: 12
                    Mileage: 241078 km
                    Date: 2025.03.07
                    Time: 12:33:20
                    Compressor current: actual value: 0 mA
                    Outside temperature: 14.0 °C
                    Temperature downstream of evaporator: 17.78 °C
                    Engine speed: 768 /min
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001052665301
   Coding: 0105C01441349FE041014083800018000F9DE30A2F080201000008946100130200400024030000
   VCID: 71BFC731D1A21232709-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150319  H37 0080
   Serial number:         150326214802
   Coding: 0045F7
   Serial number: 23911531
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 15 04 2015  00000765
   Serial number: 0B0883A7000000000001
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 215
                    Mileage: 242045 km
                    Date: 2025.03.16
                    Time: 17:50:02
00496 - Sensor for Vehicle Leveling; Front
                    Fault Status: 00101010
                    Fault Frequency: 39
                    Reset counter: 12
                    Mileage: 242045 km
                    Date: 2025.03.17
                    Time: 12:55:29
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10049MR5 Dataset Number: 4G8909602J  0001
   Coding: 30333046313130313235554A305234473853
   VCID: 3B232519C3EEA8629A5-806E
   Serial number: 3575HRB400Q5312U58SF
   Serial number: 3585HRB400Q5312UK9DH
   Serial number: 3515JRB404P36F9SGPH8
   Serial number: 3525JRB405P36F9QP18R
   Serial number: 3554VRB400454Q469P34
   Serial number: 3564VRB400454Q46JPS/
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862ODI000EP
   Coding: 000034
   VCID: 3B232519C36EA8629A5-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 01 04 2015  10004371
   Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
   Component: TDieGb        H08 0043
   Revision: 04001037    Serial number: 658160415596062
   Coding: 33A702020B432600010100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod (VIN: N/A)
   VCID: 40D952F5AA08CBBACF7-8014
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001818260 Dataset Number: 4G8909515H  0017
   Coding: C0CD078118
   GVL: FD81E858DCA5680300040000
   ROD: EV_GatewPkoUDS_001_AU57.rod (VIN: N/A)
   VCID: 75B7F321A54A3E12AC1-8020
   Serial number: 8004946203
   Voltage stabilizer:
   Serial number: 15020800000000000065
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 24041500111777
   Coding: 22
   VCID: 3D272B01DDFAA652A41-8068
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000077312
   Coding: 01010101000000000001000202
   VCID: 6491BE651E50B79A0BF-8030
   Revision: AA000000    Serial number: 00000143507884
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77ABF929BFC64C02BED-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8209CC60 Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635342DF8CC750A65B-8062
   Component: TSG FA        H03 0507
   Coding: 011C56034E21620002080402
   VCID: 47CB49E98FA6FC820ED-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0028564115 Dataset Number: 4G8909852P  0032
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392F3F11C9D29A72889-806C
   Revision: 00002001    Serial number: 0366296705
   Coding: 013F0622A0B9B800C3200A0420010D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120634000012834788
   Component: TSG BF        H03 0507
   VCID: 46D544ED88ACE58AF5B-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001443298 Dataset Number: 4G8909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   Revision: --------    Serial number: -------------- Dataset Number: 4G8909865D  0019
   Coding: 05F602202A130200
   Shop #: WSC 12345 123 61029
   VCID: 34310E25EEB0671A5BF-8060
   Coding: E02100
   Coding: E02100
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E02100
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
13705473 - Databus
          U1121 00 [10001001] - Missing Message
          [Timeout CAN-Message Fahrwerk_01_FR (0x108)]
                    Reset counter: 215
                    Mileage: 242045 km
                    Date: 2025.03.16
                    Time: 18:03:02
5275220 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 215
                    Mileage: 242045 km
                    Date: 2025.03.16
                    Time: 18:03:03
5350720 - Left Matrix High Beam
          C1175 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 215
                    Mileage: 242045 km
                    Date: 2025.03.16
                    Time: 18:03:03
5350976 - Right Matrix High Beam
          C1176 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 215
                    Mileage: 242045 km
                    Date: 2025.03.16
                    Time: 18:03:03
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 D    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0389
   Serial number: A588D0F7511230 Dataset Number: 4G9909545D  0028
   Coding: 017503010000000013111102000A00132F000CE7F1700100DF
   VCID: 1B63C599632EC8627A5-804E
   Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
   Component: ECE 2015  --- 0105
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY8018Q9
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349ODL0002C
   Compact disc data bank:
   Component: Gracenote2  --- 1012
3073 - Cellular Antenna
          B1053 13 [00001000] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 11
                    Mileage: 242345 km
                    Date: 2025.03.20
                    Time: 16:53:47
                    Voltage terminal 30: 12.6 V
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Reset counter: 215
                    Mileage: 242045 km
                    Date: 2025.03.16
                    Time: 18:09:10
                    Voltage terminal 30: 14.9 V
2565 - GPS Antenna
          B1054 13 [00001000] - Open Circuit
          [GPS aerial - open circuit]
                    Fault Frequency: 11
                    Reset counter: 11
                    Mileage: 242203 km
                    Date: 2025.03.18
                    Time: 15:40:34
                    Voltage terminal 30: 15.0 V
3086 - Antenna for Telephone Mount
          B1564 01 [00001001] - Electrical Failure
                    Fault Frequency: 73
                    Reset counter: 227
                    Mileage: 242045 km
                    Date: 2025.03.17
                    Time: 12:55:27
                    Voltage terminal 30: 11.4 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Component: TSG HL        H03 0507
   Coding: 010814024021620002080002
   VCID: 49CF4FD199B20AF2189-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0365071595 Dataset Number: 4G8909527B  0009
   Coding: 0100000202000000
   VCID: 33330D39EBBE6022425-8066
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 106501250 Dataset Number: 4G8909541G  0001
   Coding: 0A3305C003
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 45D743E1B52AEE92FC1-8010
   Component: TSG HR        H03 0507
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H07 0304
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7_AU57.rod
   VCID: 3E252C0DD0FCBD4ABDB-806A
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G8909547E  0006
   Coding: 60140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01164536803FDA03F-8078
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150841149 Dataset Number: 4G8909571H  0017
   ROD: EV_RDCMA00100.rod
   Part No SW: 4G5 035 223 C    HW: 4G5 035 223
   Component: MIB2_amp_P    H02 0420
   Serial number: 00000000034514 Dataset Number: 4G9909510K  0011
   Coding: 01750308018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 221DF87D4444F9AAB93-8076
End----(Elapsed Time: 02:41, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
------------------------------17 Faults Found------------------------------
As I said in my reply the garage that I repairing my car say I have a TPI for the reductant adblue fault and I needa new heater pump fitted and the TPI software update . They have so far replaced the Themostat|oil filter housing, the egr oil cooler and associated parts. The costs for this are overwhelming for my financial position. I greatly appreciate all the help I can be supplied with
Tim N
County Durham, UK
C?ID=555194
Hello all, Well I had the ad blue pump replaced with a genuine audi unit, I drove for around forty miles and the dreaded check engine light came on. I will be data logging a run tomorrow to monitor the nox and dpf. I think its one of two things, a blocked dpf or a failing/intermittent nox sensor on bank 1. I will carry out a regeneration to clear out any excess urea in exhaust system, If the regen fails I'm sure its going to be the sensor for nox on bank 1, this I will take out and soak it over night. Has anyone else tried these methods before. Happy touring people
