Golf gtd 2017 cornering lights disable
EARN456
C?ID=536294
hi im looking to see if anyone can helping me disable cornering lights in the headlights not the fog lights
Friday,11,April,2025,15:08:58:18023
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
Dealer/Shop Name: EARNHILL
VIN: WVWZZZAUZHW065572   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZHW065572   Mileage: 180260km-112008miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BR    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H23 1540
   Revision: B5H23---    CVN: 66340941
   Coding: 01190012034505083000
   ASAM Dataset: EV_ECM20TDI01104L906026BR 002003
   ROD: EV_ECM20TDI01104L906026BR_002.rod
   VCID: 7BA3FB03F36106A2DA9-802E
   VINID: 9E69EAAAA465A989C018514708D3AC5645
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 62086000002311
   Coding: 01FA8AA134260971477C060741C52980512C90E26082947514605078C00903
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 7AADFE07FC5B3FAAC1F-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0413738406 Dataset Number: V03935230CS 0001
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B233B03B3E1C6A29A9-806E
1053192 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 29 [00001000] - Signal Implausible
                    Reset counter: 5
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:39:59
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 13 [00001000] - Open Circuit
                    Reset counter: 5
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:29:30
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00120104202110011005000000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 72BDD627A42B47EA89F-8026
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [00001001] - Too Low
                    Reset counter: 220
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:24:56
                    Outside temperature: 16.0 °C
                    Engine speed: 0 /min
                    Temperature downstream of evaporator: 23.3 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061621802117 Dataset Number: V03935237LD 0001
   Coding: 03010A46C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045180FF8E9F795AAB3-8050
   Component: WWS    160728  042 0551
   Serial number:         160805155805
   Component: RLHS  042 0105
   Serial number: S6Y16M08D05H17M25S07
   Coding: 00A8DD
   Serial number: 000000000ZY161870LGB
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035385644
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [00001001] - Alert Emergency Activation Stage 1
                    Reset counter: 220
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:25:04
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.0 V
   Revision: --------    Serial number: 39331622407271 Dataset Number: V03935236FM 0001
   Coding: 0071051001
   VCID: 43D343E3CB11BE62D29-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: V03935239PQ 0001
   Coding: 2D00408151FFC428949C8045000006
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR20HDDW Dataset Number: V03935211YX 0001
   VCID: 7F5B0F13E7791A82F61-802A
   Left seat belt tensioner:
   Serial number: 34169677D10081641094
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676D11081640409
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 608 16
   Serial number: 357670000006324D5D1W
   Subsystem 4 - Part No SW: -----------    HW: 480 001 908 16
   Serial number: 35867000000BE5349B11
   Subsystem 5 - Part No SW: -----------    HW: 480 402 907 16
   Serial number: 3516502B7209506471D1
   Subsystem 6 - Part No SW: -----------    HW: 480 402 907 16
   Serial number: 3526502BD209506542B5
   Subsystem 7 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3556502AD209507412C5
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10081604220362
   Coding: 0400
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 074B97F3BFA95242CE1-8052
   Part No SW: 5G1 920 957 B    HW: 5G1 920 957 B
   Component: KOMBI         304 8311
   Coding: 27AD09102F80260001886B011400000000000000
   VCID: 2F3B1F5377992A02261-807A
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005183603 Dataset Number: V03935242HR 0001
   Coding: 030100041F086800FB00027E080F00010001050000000000000000000000
   GVL: 01543C1000000600400C90000000480000000000000000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7CA1F81FF66F019AD33-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160001510690066322
   Coding: 2CFFFF
   Serial number: 5530011104
   Revision: 00000000    Serial number: 16000130071003
   Coding: 5500000000000000
   VCID: 3431103F9EBF09DA5B3-8060
   Serial number: 130716EGC33822 Dataset Number: V03935229LV 0001
   Coding: 003F1220D001048000001000
   Serial number: 00000000000010965325
   Coding: 0D0000
   Dataset Number: V03935242LM 0001
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D3E07BCDBFFAA81F-806E
   Serial number: 080716EG719947 Dataset Number: V03935229LW 0001
   Coding: 003F1020DE01048000801000
   VCID: 42DD46E7D40BB76AD9F-8016
   Serial number: 00000000000011002327
   Coding: 150000
589843 - Window Regulator; Front Passenger Side
          B1320 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 220
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:25:04
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0001
   Coding: 029E01000B000200
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D94CEFDA07A57ACFB-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
5275927 - Power Output Module for Left Headlamp
          C1081 17 [10001001] - Voltage Too High
                    Reset counter: 220
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:42:03
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Serial number:                Dataset Number: V03935247LK 0001
   Coding: 02730001FF00000051110101008808001F0202C601200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F192B61AD3CF2305-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU033EV
   Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
   Component: ECE1 2016/17  --- 0635
0512 - Rear Right Bass Speaker
          B1067 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
                    Reset counter: 220
                    Mileage: 180260 km
                    Date: 2025.04.11
                    Time: 13:24:59
                    Voltage terminal 30: 11.9 V
   Component: SAS-GEN 2     H06 0014
   Serial number: 160708200992
   VCID: 6B83CB43830196224A9-803E
End----------(Elapsed Time: 01:36, VBatt start/end: 13.5V/13.5V)-----------
------------------------------7 Faults Found-------------------------------
downtime
Finland
C?ID=280813
If the AFS lights are controlled via light control module, then not possible.
EARN456
C?ID=536294
ok thanks
