MK6 Golf ABS Coding Help! (MK60EC1)
vdubber79
Abersoch, N.Wales, UK
Hi Everyone ive got a mk6 golf that had an abs module that wouldn't communicate at all, its now had a new pump/module with identical part numbers but still need the coding, if anyone can help it would be much appreciated, ill upload a copy of the scan, the car is
vw golf 1.6 tdi mk6 2010 UK model
VIN: WVWZZZ1KZAW403606   License Plate: FT10 HNG
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAW403606   Mileage: 115970km-72060miles
   Part No SW: 03L 997 557 M    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9983
   Revision: --H23---    Serial number: 00000000000000 CVN: C9BED9C6
   Coding: 00114014030500080000
   ASAM Dataset: EV_ECM16TDI02103L997557M 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 46831ED1F99C77ABB1-8012
   VINID: 9E69EAAAA05BA919C400318018B2207C3D
10165 - Glow Plug Module 1; Glow Plug Circuit
          P0670 00 [10101101] - Electrical Malfunction
                    Mileage: 115973 km
                    Date: 2025.04.11.
                    Time: 02:36:48
                    Engine speed: 877.50 /min
                    Normed load value: 26.3 %
                    Coolant temperature: 12 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 12.198 V
                    Glow status-STATE_GLOW: 48
                    Fuel temperature-TFU: 12 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 7 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Shop #: WSC 00028 028 00001
   VCID: 78FFA029CBE8D15BF3-802C
03306 - Coding Not Valid
                    Reset counter: 48
                    Mileage: 115973 km
                    Date: 2019.09.02.
                    Time: 04:10:30
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 4161
                    Count: 44544
                    Reset counter: 46
                    Date: 2019.09.02.
                    Time: 04:45:50
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 43520
                    Fault Status: 01100101
                    Reset counter: 46
                    Mileage: 115973 km
                    Date: 2019.09.02.
                    Time: 04:09:17
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 279
                    Count: 44544
                    Count: 256
                    Reset counter: 46
                    Mileage: 115973 km
                    Date: 2019.09.02.
                    Time: 04:09:17
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 295
                    Count: 44544
                    Count: 256
                    Reset counter: 46
                    Mileage: 115973 km
                    Date: 2019.09.02.
                    Time: 04:09:17
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 270
                    Count: 44544
                    Count: 256
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6DD1817DBCAA64F310-8038
   Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
   Component: BCM PQ35  B+  103 0575
   Revision: 00103 AG
   Coding: 40180A3A9025189044000080000000E443010088524D8160648000200000
   VCID: 306F58096318C91B7B-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 15041  21  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 17
                    Reset counter: 47
                    Mileage: 115973 km
                    Date: 2019.09.02.
                    Time: 02:36:55
                    Voltage: 14.40 V
                        Term 50 Off
01506 - Bulb for Rear Fog; Right (L47)
                    Fault Status: 01101100
                    Reset counter: 47
                    Mileage: 115977 km
                    Date: 2019.09.02.
                    Time: 19:59:53
                    Voltage: 12.10 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA6C9GW   Dataset Number: 5K0003v____ 0085
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B757F25B25E3A43DE-806E
   Serial number: 3572MSME7D6A0453ZZZ+
   Serial number: 3582MSME17730452ZZZN
   Serial number: 3512QSME0E4D5424ZZZ.
   Serial number: 3522QSME38005848ZZZS
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 0305C7C5422E8283D6-8056
   Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
   Component: KOMBI         H04 0308
   Coding: 470B00
   VCID: 387F60298368115B33-806C
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 190410F1001114
   Coding: E9801F06000202000003
   VCID: 69D9F56D404278D37C-803C
   Component: IMMO          H04 0308
   VCID: 6ADB8A618D4473CB75-803E
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2114
   Coding: 0000564
   VCID: 31695D0DA812C01374-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0000564
   VCID: 326B5201AD14FB0B0D-8066
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2284508
   Coding: 0000020001
   Shop #: WSC 02734 790 00000
   VCID: 224BA2413DF46B8BFD-8076
End-------------------------(Elapsed Time: 02:32)--------------------------
------------------------------8 Faults Found-------------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
You can try: 163B400D092200FD681102E4901F0081300000
vdubber79
Hi Boki , awesome that coding was accepted. managed to do the basic setting on only one out of the 3 or 4 sensors to calibrate though so still getting these 2 faults, the others just say error when i goto the channels , i have logged on each time just in case that was needed but wont do it
Address 03: ABS Brakes Labels: 1K0-907-379-EC1-V1.clb
Control Module Part Number: 1K0 907 379 AH HW: 1K0 907 379 AH
Component and/or Version: ESP MK60EC1 H30 0107
Software Coding: 163B400D092200FD681102E4901F0081300000
Work Shop Code: WSC 00028 028 00001
Reset counter: 47
Mileage: 115977 km
Date: 2063.14.31
Time: 23:19:45
Count: 3
Count: 2
Count: 20992
Count: 279
Count: 42752
Count: 256
Count: 65024
Reset counter: 47
Mileage: 115977 km
Date: 2063.14.31
Time: 23:19:45
Count: 3
Count: 2
Count: 20992
Count: 295
Count: 42752
Count: 256
Count: 65024
vdubber79
its ok ive managed to do it after closing abs module and re opening it the other sensors would then calibrate , awesome so happy .
Boki im happy to send you some pennies for your help if you want to pm me your paypal address . much appreciated:)
Boki Ar
C?ID=57300
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
Prerequisites:
[Select]
Group 005
[Go!]
Check field 1, the value has to be between -8.0 and +8.0 bar.
[Done, Go Back]
[Do it!]
Group 066
[Go!]
[Done, Go Back]
