Cruise Control - Change the MFSW button MPH adjustment?
TJD123
C?ID=150899
Hello -
So with the MFSW buttons when cruise control (ACC) is active the speed adjustment is 5 MPH per press - e.g. 70 to 75, 75 to 80 mph.
Can I adapt this to be 1mph increments as per my MK6 CC?
I've plugged in and had a look but don't know which controller it'd be in or which adaption parameter, there's millions of them with the Hex V2
Thank you
The HEX-V2 doesn't determine how many Adaptation channels there are in a module, the module itself, or the data defining it does.
Note that your question is utterly lacking in context. We don't have any idea what car you want to make this change in, or how that car is equipped or configured. But I think you've been here long enough to know how to fix that. ;)
TJD123
C?ID=150899
Apologies, rushed it. Here's the context (scan). Mk7.5 Golf Rline 2l diesel 2019. Standard fit out.
I understand where the Adaption channels come from, it's the sheer No. available that Hex v2 can see that surprised me. All good tho'!
N.B - Any idea why my scan says I've done half a million miles + ?
Thursday,10,April,2025,13:13:59:33153
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: WVWZZZAUZKW131903   License Plate:
Mileage: 1048575km-651554mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75
VIN: WVWZZZAUZKW131903   Mileage: 1048575km-651554miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 NF    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 6380
   Revision: B4H25---    CVN: EC4069A55D3F3C3E5D3F3C3E
   Coding: 01250412036405082000
   ASAM Dataset: EV_ECM20TDI01104L906026NF 004007
   ROD: EV_ECM20TDI01104L906026NF.rod
   VCID: 7BA2F012D36D78C2DA9-802E
   VINID: 9E69EAAAA465A9B9C10C12400C74795351
   Part No SW: 0GC 300 044 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V07    CVN: 27291857
   ROD: EV_TCMDQ381061.rod
   VCID: 2A0C05566C77314AF1F-807E
   No subsystems:
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60369000003264
   Coding: 01FA8AA12023096D4780060060C62980510490E26006947338625078D2024B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AEEA1AD9514AD2C85-802C
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 198
                    Mileage: 71877 km
                    Date: 2025.04.03
                    Time: 11:16:26
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120104202110001000000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 7AACF516DC5741CAC1F-802E
   Part No SW: 5Q0 937 084 DB    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H38 0273
   Serial number: 00001904400352 Dataset Number: V03935292FD 0001
   ROD: EV_BCMBOSCH_019_VW37.rod
   Component: WWS    190120  042 0551
   Serial number:         190129233620
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S7Y19M02D13H19M38S29
   Coding: 00A8DD
   Serial number: 000000000ZY190023WBV
   Serial number: 00000000000046370254
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000008021920240315
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019031 Dataset Number: V03935287MF 0001
   Coding: 0471051811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC063CEC6430F7A233-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Dataset Number: V03935282JS 0001
   Coding: 3300678151FFC728949C810580400600000000000000000004
   Shop #: WSC 12345 123 61029
   VCID: 44D04BEEEE13C73AEB3-8010
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 178
                    Mileage: 69573 km
                    Date: 2025.02.12
                    Time: 16:41:49
                    Control Module temperature: 31 �C
                    Voltage terminal 15: 13.3 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s�
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR4YYS73 Dataset Number: V03935279BC 0001
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1372B8B2DBFD9082229-8046
   Left seat belt tensioner:
   Serial number: 34169677E15021930174
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E15021951281
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 302 19
   Serial number: 3570000000085678993R
   Subsystem 4 - Part No SW: -----------    HW: 480 001 402 19
   Serial number: 358000000004FC69193W
   Subsystem 5 - Part No SW: -----------    HW: 480 401 902 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A32EE4F41D4BJ
   Subsystem 6 - Part No SW: -----------    HW: 480 400 702 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001222BF5A83637%
   Subsystem 7 - Part No SW: -----------    HW: 480 401 102 19
   Serial number: 3550001322C0A8D4E7BE
Address 17: Instruments
   Serial number: 05011911601622 Dataset Number: V03935293G  0001
   Coding: 030100045F087300FB00005C1C0F00010001070000000000000000000000
   GVL: 01443C0000000000400C80008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod (VIN: N/A)
   VCID: 6E84C946901F1D6A6D7-803A
   Generator:
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29190000216000099052
   Coding: 2DFFFF
   Serial number: 6379930405
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SAV11634 Dataset Number: V03935290SS 0001
   Coding: 003B0220D001048000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027573649
   Coding: 0D0000
196665 - Switch for Central Locking
          B122D 29 [00001000] - Signal Implausible
                    Fault Frequency: 20
                    Reset counter: 208
                    Mileage: 69654 km
                    Date: 2025.02.22
                    Time: 13:22:36
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935288GZ 0001
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B0DB2EFE3337BA9B3-8020
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SB223232 Dataset Number: V03935290SY 0001
   Coding: 003B0020DC01048000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 43D248F2EB1DC002D29-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027498401
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:                Dataset Number: V03935282VN 0001
   Coding: 02731001FF00000041110101008808001F0506C601200100CE
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323C1D3644A7798A49F-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW0423990
   Subsystem 2 - Part No SW: V03 959 821 MR    HW: -----------
   Component: ECE DL2 2025  --- 2310
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935278EW 0001
   Coding: 02730001EA42180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D263E0A8DF9B6F2A4D-8068
End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.0V)-----------
------------------------------3 Faults Found-------------------------------
Address 13: DTCs cleared
Address 03: DTCs cleared
Address 17: DTCs cleared
Address 42: DTCs cleared
Hmm. 1048575 in binary full of ones, or in hexadecimal: FFFFF.
Oh, look:
Address 17: Instruments Cannot be reached
I do not know what went wrong accessing your instrument cluster, but I would say that FFFFF did not actually come from there.
I don't see an obvious way to adjust the ACC increment. If anyone else knows something I don't, please post.
TJD123
C?ID=150899
Thanks for the info & quick reply!
Address 17.... I'll see what I can do there. Any ideas at all?
Ant idea where to start looking, which module, for ACC/Cruise control adaptions?
What happens if you access 17-Instruments directly?
I would suppose 09, since the steering column switches are a sub-system of it. But there's couple of metric tons of adaptation channels in that module.
