2011 A8 random loss of ACC and Brake guard
conor
C?ID=612277 (NRRT)
looking for some help on ACC and brake guard unavailable. the codes in the scan automatically come back as fast as I can clear them. I thought the issue originally was caused by the battery falling below 12v, after I fixed that issue and got all the modules back over 13v I tried going back through and clearing the faults with no success. I have went through and checked the (j852) and (j851) the connection for the data cable are all clean clear and undamaged, I was unsuccessful at testing the cable from the 2 modules due to meter not fitting into the connectors and didn't want to risk damaging the cable. voltage at pin 15 and 30 both read a over 13v also. I was reading through threads the last few days and couldn't find one that had the exact faults with a fix, most due lead me to believe its in the camera module. if there are any test I could run through on VCDS to further diagnose and narrow down the issue I'd appreciate them, I'm fairly new to VCDS switched over from using snap-on zeus and trying to learn as I go. any and all help is appreciated.
Thursday,10,April,2025,13:13:00:24948
VCDS Version: 25.3.0.4  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WAUAVAFD0BN025005   License Plate:
Mileage: 400710km-248989mi   Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 34 36 3B 3C 42 46 47
          52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90
VIN: WAUAVAFD0BN025005   Mileage: 400710km-248989miles
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0005
   Revision: N5H07---    CVN: 77388BB1
   Coding: 0106000A290F0268
   Shop #: WSC 41106 001 1048576
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
   ROD: EV_ECM42FSI011_AU64.rod
   VCID: 2A0ADCAB4C793E1AF13-807E
   VINID: 9D19519915940127800850001430AF8B5E
2926 - Knock Sensor 2 (G66)
          P0332 00 [00100110] - Signal too Low
                    Mileage: 400705 km
                    Date: 2025.04.09
                    Time: 01:01:18
                    Engine speed: 3228.00 /min
                    Normed load value: 94.9 %
                    Vehicle speed: 78 km/h
                    Coolant temperature: 102 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 13.523 V
                    AFS dm: 443.8 kg/h
                    Mean injection time: 3.410 ms
                    Engine operating condition: Part throttle
                    Engine operating condition-Test_Program_Channel 87: 6
Readiness: 0110 1101
   Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1006
   Revision: --H08---    CVN: B88C26AF
   Coding: 000002
   Shop #: WSC 40332 444 84071
   ASAM Dataset: EV_TCMALX51011 002018
   VCID: 72BA04CBA42936DA893-8026
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Component: ESP PREMIUM   H10 0273
   Coding: 44E6B20022674D00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 323AC4CB64A976DA493-8066
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H24 0510
   Coding: 0D872000000000000000
   Shop #: WSC 45048 000 1048576
   VCID: 6E8210BBB091123A6DB-803A
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000077415006
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000006087419
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 3530FFD7954761E26C1-8060
03766 - Motor for Seat Belt Height Adjustment
                    Fault Status: 01100101
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:14
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 3 Zonen H14 0063
   Coding: 4881202E8C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 221A348B3449E65AB93-8076
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [00001001] - Signal Amplitude Too High
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:51:21
0378 - Coolant Circulation Pump
          B10D0 04 [00001001] - Internal System Fault
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:46
0324 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:16
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000001028467
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   VCID: 2C06DAB3460D202A03F-8078
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110320  H32 0040
   Serial number:         110329110100
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10077242
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 31 03 2011  00000430
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0FH906
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000023031100010412
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000023031100010315
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA102408000000236453
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 77284F95000000000001
03608 - Humidity Sensor in Fresh Air Intake Duct
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:00
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901107000218
   Coding: 300902
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001_AU64.rod
   VCID: 372CF5DF8FCB93F27ED-8062
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Serial number: 00000000000000 Dataset Number: 4H0909863B  0018
   Coding: 3601010201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 290823A7497F3502F89-807C
93440 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 70
                    Mileage: 400710 km
                    Date: 2025.04.09
                    Time: 01:19:21
                    Control Module temperature: 59 °C
                    Voltage terminal 15: 13.945 V
                    Velocity_vehicle_reference: -0.02 m/s
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS0013G4V Dataset Number: 4H0909602D  0003
   Coding: 303143303230303030314A55304C34483053
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1132301CPX
   Serial number: 3575HRB404R0G6903H4-
   Serial number: 3585HRB405F0G6904OQD
   Serial number: 3515JRB40590G94431A7
   Serial number: 3525JRB40510HBR0I96+
   Serial number: 3554VRB405J0ESC64GVA
   Serial number: 3564VRB405L0ESC6FPAC
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KD10002V
   Coding: 0004BC
   VCID: 323AC4CB642976DA493-8066
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H04 0009
   Serial number: 27 01 2011  33047356
   Part No SW: 4H0 920 980 C    HW: 4H0 920 980
   Component: TBenUSAACC--- H30 0312
   Revision: 31110017    Serial number: 658060411593059
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU64.rod
   VCID: 2B04D9AF438327120A5-807E
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H05 0224
   Serial number: 1110401000029
   Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000132080
   Coding: 00C1034A00
   GVL: FFAFE80CFAE3E0CCC0
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3334C1CF9BB37FD2425-8066
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650125612
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Dataset Number: 4H0909553D  0030
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2C06DAB3468D202A03F-8078
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000006087360
   Coding: C0183B0085053201010001010101112131313333203333
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:14
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100H80N0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C861AB3860DE02A43F-8038
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0100
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   Coding: 0000001
   VCID: 6D8017B7B197E922541-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0100
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F14.04.1100H010003CH11183ÿ
   Subsystem 4 - Serial number: H11183ÿ
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000114643516
   Coding: 011F13205E00628202000003
   VCID: 3B24E9EFB363B7929A5-806E
   Revision: 00002001    Serial number: 0147975498
   Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000027156
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H07 0006
   Serial number:     WOO1182202X
   Coding: 001F00
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000372127
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO1000E4JC
00510 - Motor for Wind Deflector (V252)
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:18
            014 - Defective
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:18
   Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0070
   Revision: CJ007000    Serial number: 00000000030204
   VCID: 1B64096F13A3D7927A5-804E
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000115179707
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000062995
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 A    HW: 4H0 035 082
   Component: Radio U SIRIU H51 0068
   Revision: AB001007    Serial number: 155D.0B7501976
   Coding: 020007010000000001
   VCID: 1F1C3D7F07BBCBB296D-804A
   Part No SW: 4H0 035 664 B    HW: 4H0 035 664
   Component: H-BN-NA       H48 0294
   Revision: --------    Serial number: 098D%0B7503298
   Coding: 020200000001F9EF7D128B0E00000003F400010000000000
   VCID: 2612289B58E11A7AD5B-8072
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDB1100JAFG
   Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0063
   Serial number: 00000000035359
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000114996855
   Coding: 010F13204000628202000003
   VCID: 3A2AECEBBC598E9A813-806E
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J13D1GS
   Coding: 1020002
   Shop #: WSC 02391 785 00200
   VCID: 65906F976967D1621C1-8030
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 099100266 Dataset Number: 4H0909541C  0016
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B24E9EFB3E3B7929A5-806E
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000029453 Dataset Number: 4F0000000__ U001
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6394718F6BD3AF52F25-8036
Address 72: Door, Rear Right
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H05 0081
   Revision: 0L0D5012    Serial number: SN110301  0051
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono_AU64.rod
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0038
   Coding: ED060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2612289B58611A7AD5B-8072
0734 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [AFS_Timeout]
                    Reset counter: 70
                    Mileage: 400704 km
                    Date: 2025.04.09
                    Time: 00:47:18
                    Outside temperature: -34.5 °C
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 39.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00000598012501 Dataset Number: 4H0909880D  0017
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt_AU64.rod
   VCID: 2F3CCDBF779B5B3226D-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00000243468101 Dataset Number: 4H0909881D  0017
   Coding: 364FF2
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601010201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
   VCID: 270C259F5F6B0372EED-8072
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0034
   Serial number: 000040180404117
   Coding: 01A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 25102F9725671162DC1-8070
0161 - Video Cable for Image Processing
          C1107 02 [00001001] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 70
                    Mileage: 400710 km
                    Date: 2025.04.09
                    Time: 01:21:32
                    Outside temperature: 33.0 °C
                    Control Module temperature: 44.0 °C
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Dataset Number: 4H0909614A  0014
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBC0DBFB71B1B3266D-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   Dataset Number: 4H0909615A  0014
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70BE0EC3AA2504CA7F7-8024
End----------(Elapsed Time: 02:51, VBatt start/end: 14.1V/14.0V)-----------
------------------------------12 Faults Found------------------------------
Please code wrap as per how to post an auto scan
Based on the faults I see in that scan, this is most likely a failing front camera, which is very common in cars of that vintage than had them.
conor
C?ID=612277 (NRRT)
update: i sent camera out to be fixed, got it back and reinstalled into car cleared codes and was able to have cruise and lane assist for about 20 miles. after 20 miles acc and brake guard message came back and scan shows same codes. I'm now leaning more towards the cable since the camera did work for that time but was lost while in cruise. or is there any insight on the (j851) image processing modules failing causing brief operation after be disconnected for periods of time. I am going to try and find a better connector for meter to test cable to see if possibly disconnecting and reconnecting it damaged it.
Failures of that module are not unheard of, but they are also not very common.
gnecop
New Jersey, USA
C?ID=617631
I'm getting the same error code (and same dashboard error: ACC and Audi Braking guard: Unavailable). I purchased acc lane departure camera from ebay, installed it and continue to get the same error. Should I now plan to replace the cables that attached to the acc lane departure camera?
Here is my scan results for the
Monday,28,April,2025,21:10:40:60042
VCDS Version: 25.3.1.1 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN:    License Plate:
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
          46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
VIN:    Mileage: 233149km-144872miles
20-High Beam Assist. -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Cannot be reached 0100
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUA)       Labels:. 079-907-560-CFS2.clb
   Part No SW: 4H0 906 014 L    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0005
   Revision: NCH62---    CVN: 7AEC306B
   Coding: 022A00326546010E1000
   Shop #: WSC 55562 002 1048576
   ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
   ROD: EV_ECM40TFS0114H0906014L.rod
   VCID: AC0AF70BF6851FCA832-80F8
   VINID: 9D19620915941157800051C9086CD8AE42
10530 - EVAP System
          P0456 00 [01100000] - Very Small Leak Detected
                    Mileage: 233084 km
                    Date: 2025.04.27
                    Time: 09:54:49
                    Engine speed: 1359.50 /min
                    Normed load value: 8.2 %
                    Vehicle speed: 48 km/h
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 13.664 V
                    Unlearning counter according OBD: 35
                    Engine status: COENG_RUNNING
   Part No SW: 4H1 927 158 EE    HW: 0BK 927 156 AG
   Component: 0BK 40TFSIUSA H16 1002
   Revision: --H16---    CVN: 22131AD3
   Shop #: WSC 03984 002 1048576
   VCID: F7A018677F436C123E0-80A2
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: C4E5F30023A7CF00E200
   ASAM Dataset: EV_ESPPremi 005013
   VCID: B43AEF6B2EB5470ADB2-80E0
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 DD
   Component: BCM2 2.0      H35 0510
   Coding: 0DA72046000000000000
   VCID: EE8E3D0300992DDAED6-80BA
   Serial number: 2313000131879010
   Revision: AA000000    Serial number: 00000072955088
   Coding: C018320085047201010001010101112131313333283333
   VCID: B53CD26F254F5E02ECC-80E0
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 4 Zonen H20 0130
   Coding: 688122BE7C
   VCID: A9040E1FF9770AE2784-80FC
0315 - Function Restricted due to Missing Message(s)
                    Reset counter: 108
                    Mileage: 232927 km
                    Date: 2025.04.23
                    Time: 20:51:18
0369 - Function Restricted due to Missing Message(s)
                    Fault Frequency: 27
                    Reset counter: 104
                    Mileage: 232162 km
                    Date: 2025.04.14
                    Time: 19:03:29
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001476174
   Coding: 09072091077C9FE38B000804A0003800009CD3088E0001218001085C7B00
   VCID: EFB02007079324D2E60-80BA
   Component: WWS641 130704  H35 0080
   Serial number:         130722182957
   Coding: 0045F7
   Serial number: 10337616
   Coding: 025523
   Serial number: 26 08 2013  00001230
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R78L003
   Serial number: 00000002091300010344
   Coding: 100000
   Serial number: 00000003091300010491
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106231000004260034
   Coding: 020300
   Serial number: 390883C6000000000001
03395 - Control Module for High Beam Assistant
                    Reset counter: 108
                    Mileage: 232927 km
                    Date: 2025.04.23
                    Time: 19:00:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061324001584
   Coding: A80B0E
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004_AU64.rod
   VCID: F1B4267F11273222F04-80A4
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H19 0410
   Serial number: 00000000000000 Dataset Number: 4H0909863D  0030
   Coding: 7E01020101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002_AU64.rod
   VCID: AA06F113FC7101FA71E-80FE
                    Fault Frequency: 16
                    Reset counter: 108
                    Mileage: 233130 km
                    Date: 2025.04.28
                    Time: 01:16:48
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 11.653 V
   Component: Airbag10.43   H45 0042
   Revision: --------    Serial number: 003JS001LEKK Dataset Number: 4H0909602D  0004
   VCID: B720D8673FC3AC12FE0-80E2
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R1381608WMU
   Serial number: 3575HRB400K50JEAE22-
   Serial number: 3585HRB400O50JEA4PCL
   Serial number: 3515JRB401G50LKOA257
   Serial number: 3525JRB401G50LKOP8TA
   Serial number: 3554VRB404R25JQENPFZ
   Serial number: 3564VRB404R25JQEMPFZ
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815MHT0000R
   Coding: 0004BC
   VCID: B822DB5B325DA36AF7A-80EC
   Component: E221 - MFL  H09 0010
   Serial number: 30 05 2013  B1161154
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Fault Frequency: 35
                    Reset counter: 104
                    Mileage: 232162 km
                    Date: 2025.04.14
                    Time: 19:03:26
   Part No SW: 4H0 920 980 K    HW: 4H0 920 980 K
   Component: TBenUSAACC--- H50 0515
   Revision: 36081079    Serial number: 658300813592045
   Coding: 0B4608015740D705020000
   ASAM Dataset: EV_RBD4K 004046
   VCID: B338EC772BBB4032C28-80E6
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0225
   Serial number: 2130801000668
16776969 - Function Restricted due to Missing Message(s)
          [LDW_02_FR keine Kommunikation]
                    Fault Frequency: 27
                    Reset counter: 104
                    Mileage: 232162 km
                    Date: 2025.04.14
                    Time: 19:03:28
   Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000001072709 Dataset Number: 4H0909515F  0071
   Coding: 00E5074800
   GVL: FFAFE94CFAE3E0CCC100
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: F2B629731421093A09E-80A6
   Voltage stabilizer:
   Subsystem 1 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 13246001269021200410
5701 - High Beam Assistant Control Module
          U1070 00 [00001001] - No Communication
                    Reset counter: 108
                    Mileage: 232927 km
                    Date: 2025.04.23
                    Time: 18:59:10
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 11.8 V
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4888 - Camera control module
          U107A 00 [00001001] - No communication
                    Fault Frequency: 26
                    Reset counter: 104
                    Mileage: 232162 km
                    Date: 2025.04.14
                    Time: 19:03:25
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 34 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6656 - Control unit for battery monitoring
          U1050 00 [00001001] - No Communication
                    Reset counter: 136
                    Mileage: 217206 km
                    Date: 2024.05.16
                    Time: 14:59:28
                    Voltage terminal 30: 13.7 V
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 26 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 20: High Beam Assist.
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0121
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: B822DB5B32DDA36AF7A-80EC
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Dataset Number: 4H0909553G  0036
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   VCID: AE0EFD03C0996DDAAD6-80FA
          C10C8 00 [00001000] - -
                    Reset counter: 111
                    Mileage: 232202 km
                    Date: 2025.04.15
                    Time: 17:10:36
   Revision: AA000000    Serial number: 00000072951302
   Coding: C0183B0085057201010001010101112131313333203333
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA77012WHH
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: AE0EFD03CC196DDAAD6-80FA
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0050
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F26.08.1300H02000AMS15765ÿ
   Subsystem 4 - Serial number: S15765ÿ
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000072084921
   Coding: 011F1F005E0062C202003017
   VCID: C8C2AB9B42BDD3EA87A-809C
                    Fault Status: 01101100
                    Fault Frequency: 9
                    Reset counter: 75
                    Mileage: 232328 km
                    Date: 2025.04.16
                    Time: 18:37:46
   Revision: 00002001    Serial number: 0313999667
   Coding: 0106023A00FA759FB0B0C784020301070000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000171649
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 333200087932
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H13 0080
   Serial number: A2013000000000729778
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 333500090015
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 333200087935
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 333500090032
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84379492
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 9
                    Reset counter: 1
                    Mileage: 217213 km
                    Date: 2024.05.17
                    Time: 08:36:46
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 219
                    Mileage: 217213 km
                    Date: 2024.05.17
                    Time: 10:38:58
00216 - Signal EC-mirror Fade Out
                    Fault Status: 00101100
                    Reset counter: 133
                    Mileage: 232927 km
                    Date: 2025.04.23
                    Time: 18:59:14
00218 - Humidity Sensor (G355)
                    Reset counter: 108
                    Mileage: 232927 km
                    Date: 2025.04.23
                    Time: 18:59:13
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000002050
   Coding: 030000
   VCID: 9C6A27CBA6A5EF4AF32-80C8
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000072875183
   Coding: 011F1F005E0062C202003006
   VCID: BC2AC74B06658F4A132-80E8
                    Reset counter: 75
                    Mileage: 217209 km
                    Date: 2024.05.17
                    Time: 08:32:36
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000798535 Dataset Number: 4H0909522C  0011
   VCID: AB08F417F38B18F28A8-80FE
10554390 - Supply voltage
          U1011 00 [00000000] - Voltage too Low
          [FC_LOW_V_BATT]
327936 - Function Restricted due to Missing Message(s)
          U1111 00 [00000000] - -
          [FC_ACC_05_MESSAGE_TIMEOUT]
461568 - Function Restriction due to Faults in Other Modules
          U1113 00 [00000000] - -
          [FC_SIGNAL_KBI_AUSSEN_TEMP_GEF_ERROR_VALUE]
   Part No SW: 4H0 035 082 H    HW: 4H0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 155H.0D7573070
   VCID: A61E0523E8E9259A556-80F2
   Part No SW: 4H0 035 746 M    HW: 4H0 035 746 F
   Component: H-BNT-NA      H40 1038
   Revision: --------    Serial number: 183IY0D7513125
   Coding: 020200000001F9EF7D128B1E00000003140001000000000000
   VCID: B236E973D421493AC9E-80E6
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC900P6E
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000126979
   Component: CD-Database  5298
                    Fault Frequency: 25
                    Reset counter: 108
                    Mileage: 233149 km
                    Date: 2025.04.28
                    Time: 21:05:11
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000010 00000000
03787 - Rotation Mechanism for Display Module Front
                    Fault Status: 00100011
                    Reset counter: 148
                    Mileage: 217639 km
                    Date: 2024.06.01
                    Time: 10:19:39
                    Voltage: 12.40 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0273
   Revision: --------    Serial number: 0000072854422
   Coding: 010F1F00400062C202003006
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0227219
   Coding: 020A000001010000000102000000
   Shop #: WSC 39380 001 1048576
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
9616922 - Supply Voltage for Front Surroundings Camera
          B1284 14 [00001000] - Open or Short to Ground
                    Mileage: 228502 km
                    Date: 2025.01.13
                    Time: 10:07:07
                    Voltage terminal 30: 11.5 V
                    Terminal 15 status: Terminal 15 on
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [Functional limitation by undervoltage]
                    Voltage terminal 30: 7.2 V
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 200300421 Dataset Number: 4H0909541E  0022
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001032
   VCID: EE8E3D0300192DDAED6-80BA
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [00001000] - Short to Plus
                    Fault Frequency: 42
                    Reset counter: 127
                    Mileage: 229643 km
                    Date: 2025.02.13
                    Time: 20:47:34
                    Voltage terminal 30: 13.85 V
   Revision: --------    Serial number: 000000120454 Dataset Number: 4F0000000__ U001
   Coding: 200000
   ROD: EV_Ambie.rod
   VCID: E3985C37DBDB90B2728-80B6
   Component: TSG HR        H06 0273
   Revision: --------    Serial number: 0000072854424
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN130731  0361
   Serial number: 00012477046101 Dataset Number: 4H0909880D  0019
   Coding: 766FF2
   VCID: AF30E007C79364D2A60-80FA
   Serial number: 00012477035301 Dataset Number: 4H0909881D  0019
   Coding: 366FF2
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01020101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002_AU64.rod
   VCID: A8020B1BE27D33EA67A-80FC
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120208137
   Coding: 02A19A000111
   ROD: EV_BC7.rod
0091 - Function Limitation due to Missing Video Data
          C1108 00 [00001001] - -
          [DPC_SystemError]
                    Reset counter: 108
                    Mileage: 233149 km
                    Date: 2025.04.28
                    Time: 19:29:00
                    Outside temperature: 48.5 °C
                    Control Module temperature: 32.0 °C
          C1107 02 [00001000] - Signal Failure
                    Fault Frequency: 82
                    Reset counter: 148
                    Mileage: 232366 km
                    Date: 2025.04.16
                    Time: 21:16:32
                    Outside temperature: 16.5 °C
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 25.0 °C
   Dataset Number: 4H0909614C  0003
   Coding: 0066F609031F0376070308014240C2010000
   ROD: EV_RGS_L.rod
   VCID: B134E67FD1A77222B04-80E4
   Dataset Number: 4H0909615C  0003
   ROD: EV_RGS_R.rod
   VCID: B236E973D4A1493AC9E-80E6
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H07 0006
   Revision: 00001001    Serial number: 97809002390000 Dataset Number: 4H0909578A  0011
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU64.rod
   VCID: E69E452328E9E59A956-80B2
0533 - Databus
          U1122 00 [00001000] - Implausible Message
          [FC_Signal_Klemmen_Status_01_MessageCounter]
                    Reset counter: 141
                    Mileage: 233078 km
                    Date: 2025.04.26
                    Time: 20:13:38
End----(Elapsed Time: 03:35, VBatt start/end: 11.8V/11.9V. VIgn 11.8V)-----
------------------------------28 Faults Found------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
1 Fault Found: 0161 -
That is very specific pointing to the Cable
Then you need to invest in the correct tooling to enable you to test it correctly. Either that or replace it for fun !
Trouble is that the Image Processing module can't tell the difference between a bad video input, bad cable, or a bad camera. With this fault code, the only way to be sure is process of elimination.
Given that these cameras have a very high failure rate, how confident are you that a used one from fleaBay is actually in working condition?
should I now plan to replace the cables that attached to the acc lane departure camera?
I would try a cable. Just disconnect the existing video cable at both ends and connect a new one without bothering to route it nicely as a test. If it fixes the problem, only then go through the hassle of routing it properly.
gnecop
New Jersey, USA
C?ID=617631
I communicated with the seller on ebay regarding the state of functionality of the acc camera. He was not able to attest that he had a clean vcds scan of the acc camera operating flawlessly without error prior to he taking it out of the original car, hence, no evidence that it ever worked properly. I will get a new cable and connect it to see if that remedies the matter. I will report back once I do that. I have to procure the cable, it will take some days.
Dr Sheldon
Windsor UK
C?ID=334979
Normally I would concur.
However having come across this scenario before on several occasions I can confirm that every time that DTC has been thrown it has been the cable.
How it does it I dont know !
On a VW it can differentiate Cable from Camera or Module.
Jaguar Land Rover Products cannot !!
Dr Sheldon
Windsor UK
C?ID=334979
Of course I / this theory may be proved wrong this time ??
davisev5225
C?ID=263265
I can personally attest that it is not always the case. I owned a 2013 A6 that threw that exact error code, a replacement cable did nothing. Eventually I got my insurance to fix it, and the repair order said they replaced the camera, not the cable. Apparently the camera responded to diagnostics requests just fine, but completely failed to output a video signal.
gnecop
New Jersey, USA
C?ID=617631
I just sent me camera (4G0 907 217 A) in for repair (in Georgia). I expect to get a fully functioning camera in a week or so and will see if that correct my ACC and Audi Brake Guard dashboard error message. If not, I guess I may need to replace the Image Processing Module (4G0 907 107) or the cable.
