Reconfigure Following Can Bus Gateway Module Change
Trev1958
Mid Wales, UK
C?ID=610810
Hi Folks,
I am a new user here so completely in the dark with regard to the use of VCDS, so apologies for any ridiculous questions or statements here.
I have a mk6 Golf GTD which developed the dreaded "button for driver assistance system faulty" error. Sure enough the Can Bus Gateway Module cover was about 15mm deep in water, presumably condensation. I managed to find an almost identical module on Ebay so installed it, having purchased the HEX-V2 kit from one of your UK distributors so as to configure the replacement item. The car now starts and runs okay basically but there is a ton of fault messages, I imagine because my car is of different spec to that of the gateway's original vehicle. An example being an error message for the Automatic Transmission controller not available and that's because my car is a 6 speed manual. Any tutorials that I have watched on YouTube shows the items in the Gateway Installation list having a tick box alongside the description of that particular controller which I believe would allow for me to look in detail of that particular controller so as to change the value, i.e. in my example change the number 2 item from automatic to 6 speed manual.
I would like to bet that I am doing something stupidly wrong so would be grateful for any help or guidance please.
Trev1958
Mid Wales, UK
C?ID=610810
Hi, many thanks for your reply. Here is my auto scan as requested..............................
Thursday,10,April,2025,14:23:23:02875
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVWZZZ1KZCW209137   License Plate:
Mileage: 137390km-85370mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZCW209137   Mileage: 137390km-85370miles
02-Auto Trans -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BB    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H24 9977
   Revision: 42H24---    Serial number: 00000000000000 CVN: 7CB84C0D
   Coding: 00190012040500080000
   Shop #: WSC 43956 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018BB 003008
   ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
   VCID: 6B841870230543E24A9-803E
   VINID: 9E69EAAAA05BA939C20090431CD86B21A5
5282 - Intake Air Temp. Sensor (G42)
          P0113 00 [00100000] - Signal too High
                    Engine speed: 0.00 /min
                    Coolant temperature: 14  C
                    Intake air temperature: -38  C
                    Voltage terminal 30: 11.560 V
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [00101000] - -
                    Mileage: 137394 km
                    Coolant temperature: 10  C
                    Intake air temperature: 11  C
                    Voltage terminal 30: 11.160 V
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 4
                    selected gear-Bits 0-7: 0
4714 - Steering Column Control Module
          U0212 00 [00101000] - No Communications
                    Mileage: 137394 km
4715 - No Communication with Instrument Cluster
          U0155 00 [10101000] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 137394 km
                    Voltage terminal 30: 11.240 V
4719 - Diagnostic Gateway
          U0146 00 [00101000] - No Communications
          [Lost Communication With Serial Data Gateway Module "A"]
                    Mileage: 137394 km
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [00101100] - -
          [Engine Control Module (ECM) locked]
                    Engine speed: 1026.50 /min
                    Coolant temperature: 11  C
                    Intake air temperature: 12  C
                    Voltage terminal 30: 11.720 V
                    Immobilizer snapshot A-Sia Error Snap A: 14 80 0A
                    Immobilizer snapshot B-Sia Error Snap B: 03 00 00
Readiness: 1 1 0 0 0
Address 02: Auto Trans
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V2.clb
   Revision: 00H31001
   Coding: 163B600D09228003680C06E790200182310800
   VCID: 7BA4283053E5D362DA9-802E
8 Faults Found:
                    Reset counter: 237
                    Count: 2
                    Count: 12
                    Count: 4608
                    Count: 8213
                    Count: 41216
                    Count: 2
                    Reset counter: 237
                    Mileage: 137395 km
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 8194
                    Count: 43520
                    Count: 2
                    Reset counter: 237
                    Count: 12
                    Count: 4096
                    Count: 8208
                    Count: 42240
                    Count: 2
03391 - Coding Not Possible
                    Reset counter: 237
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 8254
                    Count: 43776
                    Count: 3
                    Reset counter: 237
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 8211
                    Count: 43776
                    Count: 3
                    Reset counter: 237
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 8233
                    Count: 43776
                    Count: 3
                    Reset counter: 237
                    Count: 2
                    Count: 12
                    Count: 4608
                    Count: 166
                    Count: 40960
                    Count: 3
                    Reset counter: 237
                    Count: 2
                    Count: 12
                    Count: 4608
                    Count: 294
                    Count: 41216
                    Count: 2
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000004002
   VCID: 005E5FDC3A83B0BA8FB-8054
13701408 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Diagnoseinterface f r Datenbus - kein Signal/Kommunikation]
                    Fault Frequency: 39
                    Reset counter: 239
13701456 - Function Restricted due to Missing Message(s)
          [Steuerger t im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Fault Frequency: 37
                    Reset counter: 239
   Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 48180A3A8025F1C0400800C0340001E44B511588536D8520648000200040
   VCID: 3A2AED341C5F2A6A81F-806E
   Component: RLS 281111 05  54  0403
   Coding: 0230AD
11 Faults Found:
                    Reset counter: 236
                    Mileage: 137375 km
                    Date: 2019.09.01.
                    Time: 15:35:21
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 239
                    Mileage: 137395 km
                    Date: 2019.09.01.
                    Time: 13:48:13
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 22
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 22
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 22
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 239
                    Mileage: 137395 km
                    Date: 2019.09.01.
                    Time: 00:00:60
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 22
                    Voltage: 12.10 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 22
                    Voltage: 11.50 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 22
                        Term 15 Off
                    Voltage: 12.05 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 237
                    Voltage: 11.60 V
                        Term 50 Off
                    Reset counter: 199
                    Mileage: 137395 km
                    Date: 2019.09.01.
                    Time: 00:01:02
                    Voltage: 12.05 V
                        Term 50 Off
Address 10: Park/Steer Assist
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RADBPG/   Dataset Number: 5K0003v____ 0174
   Coding: 00003958
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3138CA18C1A9E932305-8064
   Serial number: 3572MSME37273267ZZZU
   Serial number: 3582MSME2F5A6566ZZZ6
   Serial number: 3512QSME483D6706ZZZ
   Serial number: 3522QSME561C6521ZZZU
12670208 - No Communication with Instrument Cluster
          U0155 00 [00001000] - -
                    Reset counter: 22
12666368 - Diagnostic Gateway
          U0146 00 [00001000] - No Communications
          [Lost Communication With Gateway]
                    Reset counter: 239
12674816 - Immobilizer Control Module
          U0167 00 [00001000] - No Communications
          [Lost Comminication with Immobilizer]
                    Reset counter: 239
   Part No SW: 5K0 953 507 BB    HW: 5K0 953 549 D
   Revision: --------    Serial number:  90422KKT00194 Dataset Number: 5K0953507BB D005
   Coding: 1082040000
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 71B80A180129A932705-8024
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0738222
   Coding: 820000
332564 - Databus
                    Reset counter: 0
332580 - Databus
                    Reset counter: 0
332596 - Databus
                    Reset counter: 237
   Part No SW: 5K6 920 972 A    HW: 5K6 920 972 A
   Coding: 470B00
   VCID: 3436C30C3EBBDC1A5B3-8060
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [00001000] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 239
12671232 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Steuerger t f r Einparkhilfe: keine Kommunikation]
                    Reset counter: 199
                    Mileage: 137395 km
                    Date: 2025.04.10.
                    Time: 00:01:02
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 231211F2001507
   Coding: 350003
   Shop #: WSC 00028 028 00001
                    Reset counter: 199
                    Mileage: 137395 km
                    Date: 2019.09.01.
                    Time: 00:01:01
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 199
                    Mileage: 137395 km
                    Date: 2019.09.01.
                    Time: 00:01:02
   VCID: 6A8A1D742CFF5AEA31F-803E
   Revision: A1001003    Serial number: 7661450795
   VCID: 29082278E9F991F2F85-807C
                    Reset counter: 239
                    Reset counter: 22
                    Fault Status: 00101110
                    Reset counter: 22
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2106
   Coding: 0000692
   VCID: 372CF400234D37027E1-8062
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   VCID: 3530FE083941C5126CD-8060
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.6 V
                        PD
                    Temperature: 13.0 C
                    Count: 2
                    Steering Angle: 0.00
                        SteerAng n.Init
02391 - Terminal 30 Reference
                    Voltage: 11.88 V
                        PD
                    Temperature: 18.0 C
                    Speed: 50.0 km/h
                    Torque: 0.0 Nm
                    Torque: 0.000 Nm
01312 - Powertrain Data Bus
                    Fault Frequency: 24
                    Voltage: 11.38 V
                        DU
                    Temperature: 20.0 C
                    RPM: 1498 /min
                    Speed: 44.0 km/h
                    Count: 3
                    Reset counter: 239
                    Voltage: 10.88 V
                        DU
                    Temperature: 20.0 C
                    RPM: 1498 /min
                    Speed: 43.0 km/h
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0000692
   VCID: 382EF73C2E53387A77B-806C
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2L3258632
   Coding: 01000400040005
   VCID: 72BA051404AF922A89F-8026
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 239
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 63
                    Mileage: 114943 km
                    Date: 2019.05.13.
                    Time: 13:48:32
                    Fault Status: 00100111
                    Fault Frequency: 32
                    Reset counter: 239
                    Mileage: 136050 km
                    Date: 2019.09.01.
                    Time: 08:47:09
                    Reset counter: 239
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Coding: 0000144
   VCID: 3632F9042447CE0A657-8062
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661444144 Dataset Number: 5K0035730D  0001
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 26122944F867BE8AD57-8072
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
------------------------------52 Faults Found------------------------------
[Select]
[19-CAN Gateway]
[Installation List]
- look at the top section of your scan. Uncheck the addresses that say "Cannot be reached", like 02-Auto-Trans.
[Write Coding]
Clear all fault codes, cycle the ignition, re-scan, and let's see where you are then.
Trev1958
Mid Wales, UK
C?ID=610810
Hi, sorry for my late reply.
Many thanks for your advice, it was a great help in getting rid of many of the faults. There are still one or two issues so I have run another scan which is copied below. I cant see any reference to it but neither the front nor rear wipers are working. The only thing working on that steering wheel stalk is the rear washer. Bizarrely the horn is showing a fault but seems to work perfectly.
Saturday,12,April,2025,14:23:15:02875
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
   Revision: 00H31001
   Revision: 00001004
   Coding: 0000004002
   Revision: 00110 AC
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 29111  26  0512
   Coding: 009795
   Coding: 0230AD
                    Reset counter: 199
                    Mileage: 137395 km
                    Date: 2019.09.03.
                    Time: 00:01:56
                    Voltage: 12.05 V
                        Term 50 Off
   Coding: 00003958
   Coding: 1082040000
   Coding: 820000
   Coding: 470B00
   Coding: 350003
   Coding: 0000692
   Revision: 00H22000
            000 - - - MIL ON
                    Mileage: 137395 km
                    Date: 2019.09.03.
                    Time: 00:01:03
                    Battery Volts: 12.2 V
                        DD
                    Temperature: 19.0 C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
   Coding: 0000692
                    Reset counter: 199
                    Mileage: 137395 km
                    Date: 2019.09.03.
                    Time: 00:01:21
   Coding: 0000144
   Coding: 0000144
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:22, VBatt start/end: 12.1V/12.1V)-----------
------------------------------3 Faults Found-------------------------------
TTT
C?ID=547002
How did you tested the horn?
Trev1958
Mid Wales, UK
C?ID=610810
I pressed the centre of the steering wheel and the horn sounded
TTT
C?ID=547002
I thought so. But that is not the Alarm Horn.
Trev1958
Mid Wales, UK
C?ID=610810
That's brilliant, many thanks for your help. Actually that area under the bonnet is where I was am working to get to the Can Bus Gateway. I wonder if I disturbed or damaged the cabling. Something to look into
Trev1958
Mid Wales, UK
C?ID=610810
Hi Everyone. Thank you all very much for your help, everything is cleared now and the car is running perfectly.
TTT
C?ID=547002
What was wrong and can we have an up to date autoscan please?
Trev1958
Mid Wales, UK
C?ID=610810
The reason my wipers weren't working was due to the bonnet being open! A little quirk that I was unaware of, where neither the wipers nor washers work if the bonnet is open. As far as the alarm horn is concerned it looks to be an issue with the device itself so I need to source a replacement.
Reactions: TTT
