MIB3 - want wireless android auto to work (2020 Seat Leon)
churp
C?ID=208727
hi, mib3 adaption to 5f module, i require security access to change android auto to change function from usb to wireless. have tried 20103 which isnt accepted and have used s12345 development code, but still no joy. :( also have popped bonnet.
TTT
C?ID=547002
24 messages and not yet auto-scan in post? You will have to.
churp
C?ID=208727
Thursday,10,April,2025,16:37:49:25600
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
Dealer/Shop Name: Richsandr
Workshop Code: 000 06784 000000
VIN: VSSZZZKLZLR002136   License Plate:
Chassis Type: KL-SE38 (5WA)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 3C 42 44 52 5F 61
          6C 75 A5 BB BC C4 CC D6 D7 811E 811F 8120 8121 C002 C003
VIN: VSSZZZKLZLR002136   Mileage: 105121km-65319miles
C4-DC/DC Converter -- Status: Malfunction 0010
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DFYA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 012 B    HW: 05E 907 309 G
   Component: R4 1.5l TFS   H20 9974
   Revision: 89H20000    CVN: 90F8370A
   Coding: 012500322364150830086000000000000000000000000000
   Shop #: WSC 43948 005 1048576
   ASAM Dataset: EV_ECM15TFS01105E906012B 002010
   ROD: EV_ECM15TFS01105E906012B.rod
   VCID: 1E64287FC03195FA9D7-804A
   VINID: 9A38EAAAA6DCA9C88000204318F1C047AF
23765 - Control unit for information electronics 1
          U1054 00 [00100000] - No Communication
          [Information electronics control module 1No Communication]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:34
                    Engine speed: 0.00 /min
                    Coolant temperature: 97  C
                    Intake air temperature: 36  C
                    Voltage terminal 30: 13.060 V
                    Outside temperature: 18  C
                    Absolute intake pressure: 102 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 32.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
   Part No SW: 0CW 906 556     HW: 0CW 300 050 K
   Component: GSG DQ200G2.1 H06 0361
   Revision: 00006009    Serial number: CU502001295850  CVN: DA7304AD
   ASAM Dataset: EV_TCMDQ200022 001001
   ROD: EV_TCMDQ200022.rod
   VCID: 094E6B2369BF0242D85-805C
   Subsystem 1 - Part No SW: 5WA 713 033 AF    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1033
   Serial number: 20200114000057988740
   Subsystem 2 - Part No SW: 5FA 713 059 B    HW: 5FA 713 059 B
   Component: ZSB_SB_Mono    H03 0013
   Serial number: 92478TB300489
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BB    HW: 5WA 614 517 B
   Component: ESC           H10 0020
   Serial number: 60150000000379a Dataset Number: V03935338ZP 0001
   Coding: 2404249832204C6E5278940329C96186ADB558F08AC8670880BCA231018FF141822814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
   ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
   VCID: 094E6B2369BF0242D85-805C SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: --------------- Dataset Number: V03935332QB 0001
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003.rod
   VCID: 54F08A57FE7D0FAA7B3-8000
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 T    HW: 5WA 907 727 T
   Component: Climatronic   H01 0240
   Coding: 000100010011120010000000101011110000112100200000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005062
   ROD: EV_ACClimaBHBVW38X_SE38.rod
   VCID: 619E5383B1CFEA02E05-8034
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H01 0002
   Serial number: 00000000000000056665
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00001291219113629514
459025 - Databus
          U1121 00 [00101000] - Missing Message
          [Databus missing message radio]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:38
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 F    HW: 5WA 937 086 J
   Component: BCM 37W BOSCH 016 0159
   Serial number: BXJ53F230120940 Dataset Number: V03935353YR 0007
   ASAM Dataset: EV_BCM37w 006001
   ROD: EV_BCM37w_006_VW41.rod
   VCID: 54F08A57FE7D0FAA7B3-8000 SFD
   Subsystem 1 - Part No SW: 5FC 955 113     HW: 5FC 955 113
   Component: FWISCHER_MYJT  067 0052
   Serial number: 907453F0401935001732
   Component: G397_RLFSS     H06 0002
   Serial number: 24291068X81A955555A0
   Subsystem 3 - Part No SW: 5H0 941 193 AA    HW: 5H0 941 193 AA
   Component: LiSi           H04 0513
   Serial number: TW571429012000010739
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000000909257
   Subsystem 5 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA    005 0316
   Serial number: 000000000ZY2002012RG
   Subsystem 6 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92661TAO00758-------
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000031012004221067
   left tail lamp 1:
   left tail lamp 2:
   Right rear tail lamp 1:
   Part No SW: 5WA 919 298     HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0026
   Serial number: 000013121994560 Dataset Number: V03935308RE 0008
   Coding: 9300026011
   ASAM Dataset: EV_EPHBO2CVW3800000 002027
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   VCID: 1372494B3BF3C892229-8046
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H03 0245
   Dataset Number: V03935308Z  0009
   Coding: 2E03007F507740451247400000000005A84020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003_VW38.rod
   VCID: 4CC09237264D576A233-8018
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:34
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:34
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:34
1230 - Databus
          [FAULT_TIMEOUT_MAINUNIT_01]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:38
Address 14: Susp. Elect. (J250)       Labels: 1EA-907-376.clb
   Part No SW: 1EA 907 376 B    HW: 1EA 907 376
   Component: DAEMPFUNGS-SG H04 0455
   Serial number: 2C7673240925111 Dataset Number: V03935309UM 0005
   ASAM Dataset: EV_DCC3CONTITEMIC 002003
   ROD: EV_DCC3CONTITEMIC_002_VW38.rod
   VCID: 392EDBE379DFD2C2885-806C
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 EF    HW: 1EA 959 655 EF
   Component: VW40Airbag    010 0177
   Serial number: W315TcE12B2     Dataset Number: V03935349KD 0001
   Coding: 88CC000000C0C000000000400000000051540000205400004000F68000930065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   Subsystem 1 - Part No SW: -----------    HW: 440 001 812 19
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ00000072049E243
   Subsystem 2 - Part No SW: -----------    HW: 440 001 812 19
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ00000097149E24A
   Subsystem 3 - Part No SW: -----------    HW: 440 000 801 20
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJ0C62F15E5B7000X
   Subsystem 4 - Part No SW: -----------    HW: 440 001 601 20
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJC53251D03F5000I
   Subsystem 5 - Part No SW: -----------    HW: 440 000 701 20
   Component: FrontSensor_P  00A 014A
   Serial number: 356CJ322C061D283700I
   Subsystem 6 - Part No SW: -----------    HW: 440 000 701 20
   Component: FrontSensor_D  00A 014A
   Serial number: 355ck322C061D3E3E00W
   Part No SW: 5FA 920 790     HW: 5FA 920 790
   Component: KOMBI         221 1401
   Coding: A4A400407B9C06000180620B2000080800300C00
   ASAM Dataset: EV_DashBoardVDDMQB37W 002029
   ROD: EV_DashBoardVDDMQB37W_002_SK38.rod
   VCID: 77AA1DDB0F4B04B2BE1-8022
16777018 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 143
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:36
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 143
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:36
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 143
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:35
   Part No SW: 5WA 907 530 N    HW: 5WA 907 530 C
   Component: GW2020 High   752 7310
   Revision: --------    Serial number: 150160901041034 Dataset Number: V03935353BQ 0002
   Coding: 0000810D6700000003000000010301177101610902000300030100010001010000000000000000000000000000000000
   GVL: 3D000000020842CC80008002CC00204004104000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 004008
   ROD: EV_GatewMQB2020_004_VW41.rod
   VCID: 53F2894BFB730892629-8006 SFD
   Subsystem 1 - Part No SW: 5WA 915 181 D    HW: 5WA 915 181 D
   Component: J367-BDMConti  H04 1070
   Serial number: 7640710300191216008C
   Subsystem 2 - Part No SW: 5FA 919 719 F    HW: 5FA 919 719 F
   Component: E221__MFL-PR6  H02 0020
   Serial number: PR6-0440059027200165
2175091 - Control unit for information electronics 1
          U1054 00 [00101000] - No Communication
          [Information_electronics_control_module_1_no_communication]
                    Reset counter: 38
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:36
   Part No SW: 5WA 909 059 E    HW: 3Q0 909 059 A
   Component: EBKV          H06 0092
   Serial number: BPA085010220013 Dataset Number: V03935307DA 0003
   Coding: 1302C504240000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
   ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
   VCID: 52FC8C4FC469019A69F-8006 SFD
107024 - Transmission Control Module
          U14E4 00 [00100000] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H08 0040
   Serial number: 20000006660014
   Coding: 0800000000000000
   Shop #: WSC 00049 770 00398
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323CECCFA4A9219A49F-8066
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 D    HW: 2Q0 907 686 D
   Component: HRE_Master    H25 0276
   Serial number: 00000539948528  Dataset Number: V03935321TG 0001
   Coding: 9A9545D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001013
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: 3B22C1EB73E3E0D29A9-806E
   Subsystem 1 - Part No SW: 2Q0 907 685 D    HW: 2Q0 907 685 D
   Component: HRE_Slave      H25 0276
   Serial number: 00000539509947
2232357 - Databus
          [databus message missing - MainUnit_01]
                    Reset counter: 39
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:38
   Part No SW: 5Q4 959 593 L    HW: 5Q4 959 593 L
   Component: TSG FS        010 0686
   Serial number: 0000401921109  Dataset Number: V03935273ZK 0010
   Coding: 00351020D001020000001020
   Shop #: WSC 00049 770 00399
   VCID: 4EC4983FD051657A4D7-801A
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000038153537
   Coding: 3D0000
196726 - Motor for mirror fold-in
          B11F6 13 [00001000] - Open Circuit
                    Reset counter: 142
                    Mileage: 105071 km
                    Date: 2025.04.09
                    Time: 16:05:18
   Part No SW: 5WA 907 145 H    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  501 1030
   Serial number: 00035772 Dataset Number: V03935315GM 0004
   Coding: 0000000000000101000002010000010000000101000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
   ROD: EV_SteerAssisBASGEN1MQB37_006.rod
   VCID: 4FFA853BD75B6C72461-801A
   Part No SW: 5Q4 959 592 L    HW: 5Q4 959 592 L
   Component: TSG BFS       010 0686
   Serial number: 0000401926330  Dataset Number: V03935273ZT 0008
   Coding: 00351020DC01020000001020
   VCID: 4DC69F33DD575E6234D-8018
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000038079201
   Coding: 250000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5FA 035 862 K    HW: 5FA 035 862
   Component: MU-O-ND-EU    H56 1896
   Serial number: WG8LGM230120000 Dataset Number: V03935320UN 0001
   Coding: 43800008000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_SE38.rod
   VCID: 3FDAB5FB67FBFCF2B61-806A SFD
Address 61: Battery Regul. (A6)       Labels: None
   Part No SW: 5WA 915 107     HW: 5WA 915 107
   Component: BMS_48V_LiIon H07 0455
   Serial number: 471900017987300
   ASAM Dataset: EV_BMSmHevCATL 003004
   ROD: EV_BMSmHevCATL.rod
   VCID: 04507A174E9D5F2AAB3-8050
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20150623010 Dataset Number: V03935340RX 0001
   Coding: 04033200843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   Part No SW: 5WA 035 284 C    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0142
   Serial number: 0000000210VIKEC Dataset Number: V03935352QV 0002
   Coding: 043800009068A8209005460061502607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 46D4A01F3821AD3AF57-8012 SFD
7248 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [InfotainmentSettings (0x50) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 105028 km
                    Date: 2025.04.08
                    Time: 11:51:43
                    Voltage terminal 30: 12.2 V
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H06 3129
   Serial number: E57830712210190 Dataset Number: V03935334CE 0002
   Coding: 000309082168C040509E08801020002001018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_AU38.rod
1122626 - Databus
          [Timeout_Mainunit_01]
                    Reset counter: 2
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:38
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 2
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:34
Address C4: DC/DC Converter (A7)       Labels: 4K0-959-663.clb
   Part No SW: 5WA 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0111
   Serial number: DC20057001398 Dataset Number: V03935290NN 0002
   ASAM Dataset: EV_DCDC48VFLEXAU581 004003
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
11491585 - Databus
          [CAN_Message_Radio_01_ tout]
                    Reset counter: 143
                    Mileage: 105098 km
                    Date: 2025.04.09
                    Time: 16:54:38
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 G    HW: 05E 903 018 G
   Component: iBSG4U_000    H16 0225
   Serial number: 5200205213924
   ASAM Dataset: EV_SGCM600210005E903018G 002004
   ROD: EV_SGCM600210005E903018G_SK38.rod
   VCID: 2614009F98614D3AD57-8072
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 65964793A5E786221CD-8030
   Component: LED1R         H08 9202
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0632
   ASAM Dataset: EV_RSADVL37w 002012
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 47CAAD1B3F2BB4320E1-8012
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002012
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002012
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002012
End----(Elapsed Time: 01:50, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------17 Faults Found------------------------------
downtime
Finland
C?ID=280813
I don't think your MIB3 is able to do wireless Android Auto. AFAIK H57 is minimum hardware it works on.
And you probably need SFD unlock the 5F, it's not traditional security code.
You could check from East Yorkshire Retrofits. They have done these to Seats. They can confirm if your unit support it or not.
AINils
Germany (AIB)
C?ID=56975
Entry MIB3 aren't able for Wireless Carplay. Only MOI3 can do it
churp
C?ID=208727
Not sure why in the title it says seat arona when it should say seat leon
