Thursday,15,May,2025,12:31:50:14651
VCDS Version: 25.3.1.1 (x64) HEX-NET2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WAUZZZ4EX5N000196 License Plate:
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Control Module Part Number: 4E0 910 018 B HW: 4E0 906 018 *
Component and/or Version: 6.0L W12/4V *A ª0030
Software Coding: 0007773
Work Shop Code: WSC 00000 000 00000
VCID: 1E6D81167CB4464A9D6-804A
20 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low
17987 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 002 - Signal too Small
19505 - Control Circuit for Starter Relay 2
P3049 - 004 - Open Circuit
16999 - Output for Starter Relay
P0615 - 004 - Open Circuit
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 002 -
17070 - ECM Power Relay Control Circuit
P0686 - 002 - Short to GND
18044 - Powertrain Data Bus
P1636 - 008 - Missing Message from Airbag Controller
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 001 -
17949 - Fuel Pump Relay (J17)
P1541 - 004 - Open Circuit
18037 - Powertrain Data Bus
P1629 - 008 - Missing Message from Auto-Distance Controller
18347 - Powertrain Databus
P1939 - 008 - Missing Message from Controller for Access & Start Auth.
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High
Readiness: 0110 1101
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Control Module Part Number: 4E0 910 018 E HW: 4E0 906 018 *
Component and/or Version: E5eTws2 *A ªXE48
Software Coding: 0011773
Work Shop Code: WSC 02729 823 00099
VCID: 2117BAEA4DCA79B2A04-8074
14 Faults Found:
19482 - Angle Sensor 1 for Throttle Drive 2 (G297)
P3026 - 002 - Signal too Small
19485 - Angle Sensor 2 for Throttle Drive 2 (G298)
P3029 - 002 - Signal too Small
19490 - Intake Air Temperature Sensor 2 (G299)
P3034 - 002 - Signal too Large
18348 - Powertrain Databus
P1940 - 008 - Missing Message from Control Module for Battery Monitoring
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster
16580 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Address 31: Engine other Labels: 07C-910-018-BHT3.lbl
Additional Info: 4E0910018B 6.0L W12/4V *A ª0030
Additional Info: Geraet 00000
Address 01: 20 Faults Found:
P1172 - 002 -
P1923 - 008 -
P1647 - 001 -
Address 11: No Faults Found
Address 31: Engine other (4E0 910 018 B)
12:35:08 Group 001: General
0 /min Engine Speed (G28)
-48.0°C Coolant Temperature (G62)
0.0 % Lambda Control Bank 1/3
0.0 % Lambda Control Bank 2/4
0 /min RPM
-48.0°C Temperature
0.0 % Lambda
0.0 % Lambda
