- Mar 21, 2025
- 10
- 2
- Perth, Australia
- C?ID=614824
I'm debugging a CKDA touareg with a air flow imbalance issue between the two banks. It has two ECUs so address 31-Engine other shows up. I need to watch some of the actuator channels of bank 1/2 at the same time with VCDS to get to the bottom of whats going on.
When I open the virtual 31 controller VCDS starts reading info and populates the VAG Number field correctly as 7P1907409A but then gets stuck with an eventual "no response from controller."
I'm pretty sure this mode used to work when I first got this car, any suggestions for things I could try here? I'm really struggling to troubleshoot while only looking at the data from one ECU at a time.
Cheers!
Here is a typical scan
Cheers!
Thursday,06,March,2025,18:17:50:06059
VCDS Version: 24.7.1.0 (x64) HEX-NET CB: 0.4643.4
VIN: WVGZZZ7PZDD042887 License Plate:
Mileage: 178210km-110734mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 11 31 13 15 16 17 19 28 34 36 3C 42
46 47 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZDD042887 Mileage: 178210km-110734miles
Address 01: Engine (J623-CKDA) Labels:. 057-907-409-V2.clb
Part No SW: 7P1 907 409 A HW: 7P0 907 409
Component: 4.2TDI EDC17 H21 0001
Revision: 52H21--- CVN: E55BCDC9
Coding: 292A4012437E00020000
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM42TDI1117P1907409A 001001
ROD: EV_ECM42TDI111_VW52.rod
VCID: 3620E77F8950D62621-8062
VINID: 9E65EAAAA1E0A945001022081C5C94EA5C
10380 - Engine Control Module
P166D 00 [00100000] - Incorrect Installation
Mileage: 177981 km
Engine RPM: 0.00 /min
Coolant temperature: 88 °C
Intake air temperature: 43 °C
Voltage terminal 30: 13.700 V
Unlearning counter according OBD: 24
Mean injection quantity: 0.00 mg/stroke
Fuel high-pressure: actual value: 2500 hPa
Setpoint generation interior torque: 0.0 Nm
10262 - Mass or Volume Air Flow Sensor A/B Correlation
P010F 00 [01100000] - -
Mileage: 178171 km
Date: 2025.03.06
Time: 09:34:57
Engine RPM: 1106.00 /min
Vehicle speed: 45 km/h
Coolant temperature: 87 °C
Voltage terminal 30: 14.060 V
AFS dm B1: 87.4 kg/h
AFS dm B2: 87.4 kg/h
AFS r Norm B1 mp: 1.8361
AFS r Norm B2 mp: 0.6930
10264 - Mass Air Flow Sensor (G70)
P0101 00 [01100000] - Implausible Signal
Mileage: 178171 km
Date: 2025.03.06
Time: 09:34:57
AFS dm B1: 47.6 kg/h
AFS dm B2: 126.2 kg/h
AFS r Norm B2 mp: 0.6941
10267 - Mass Air Flow Sensor (G246)
P010B 00 [01100000] - Implausible Signal
Mileage: 178171 km
Date: 2025.03.06
Time: 09:34:57
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 BE HW: 0C8 927 750 BE
Component: AL1000 AISIN 002 2270
Serial number: CVN: 6876320A
Coding: 00B168
Shop #: WSC 40952 002 104857
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002_VW52.rod
VCID: 70AC1167ABB4B8163B-8024
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 412330010EC815 Dataset Number: 7P0012v____ 0001
Coding: 5B6B53C34B286F55DAFCCA9BD2D9F640F700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4AD8A38FEDA8A2C655-801E
Part No SW: 4H0 907 064 CM HW: 4H0 907 064 CM
Component: BCM2 2.0 H33 0433
Coding: 05960016000000000000
VCID: 76A0277FC1D09626E1-8022
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 2313000067973004
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 120
Mileage: 177947 km
Date: 2025.02.18
Time: 08:29:47
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000059952652
Coding: 0038330000004201000001010101202020202121202020
VCID: 3424DD77972CC4361F-8060
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 4 Zonen H20 1305
Coding: 38B620BEC0
VCID: 7EB03F5FE1E0DE66B9-802A
0258 - Control Module for Air Blower
B10BB 04 [00001001] - Internal System Fault
Reset counter: 139
Mileage: 178210 km
Date: 2025.03.06
Time: 18:09:29
0237 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
Reset counter: 139
Mileage: 178210 km
Date: 2025.03.06
Time: 18:09:08
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001723914
Coding: 26001019D1345D030121000780005D0CC31D670803010241800000220C00
Shop #: WSC 10674 001 104857
VCID: 6C9405178F9C5CF607-8038
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 130425 031 0021
Serial number: 90243401130429144328
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20111537
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000001105130017
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA105265000003445638
Coding: 020300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28231312001198
Coding: 518D01
Shop #: WSC 10674 001 1048576
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: 43C68EABCA82738E96-8016
Address 11: Engine II (J624) Labels: None
Revision: 52H21--- CVN: 3E0213E4
ASAM Dataset: EV_ECM42TDI2117P1907409A 001001
ROD: EV_ECM42TDI211_VW52.rod
Part No SW: 7P6 907 561 B HW: 7P6 907 561
Component: ACC3 H19 0340
Coding: 3704010101
ASAM Dataset: EV_AdaptCruisContrVW526 002011
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3B36F64BB2720B4EDE-806E
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 D HW: 7P0 959 655 D
Component: VW10Airbag00T H06 0026
Revision: -------- Serial number: 003L50010JLR Dataset Number: 7P5003p____ 0019
Coding: 000000000000000000000000000000003054
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 42C88BAFD5987A869D-8016
Serial number: 3575LRB4053217NU4H69
Serial number: 3585LRB401450FBCC0V3
Serial number: 3515RRB400G50IC2Q0LB
Serial number: 3525RRB400G50IC2HPRY
Serial number: 3555NRB401G50EN8I1IF
Serial number: 3565NRB401G50EN871PC
Part No SW: 4H0 953 568 H HW: 7P6 953 507 T
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815ME20000D
Coding: 000CFD
VCID: 383CE9478B44205633-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0251863
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 881 N HW: 7P6 920 881 N
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658100513592044
Coding: 331D33007F0C080800010C
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 47DE9ABBFEBA5FAE4A-8012
Part No SW: 7P6 907 530 G HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H11 6028
Revision: -------- Serial number: 00000000905010 Dataset Number: 7P6067v____ 0026
Coding: 0001037D00
GVL: FF7F44E55D7F6E0000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3C34F557B77C0C76D7-8068
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 30123633104191327401
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00001000] - -
Reset counter: 167
Mileage: 178059 km
Date: 2025.02.22
Time: 14:25:03
Voltage terminal 30: 13.1 V
Voltage terminal 15: 0.0 V
Control Module temperature: 37 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 7P6 907 049 Q HW: 7P6 907 049 Q
Component: Klima Fond H14 1305
Coding: 0000000000
ASAM Dataset: EV_AirCondiHeck 001007
ROD: EV_AirCondiHeck.rod
VCID: 4BD6A68BE2D2BBCE6E-801E
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 AA HW: 7P0 907 553 AA
Component: PASM H04 1800
Revision: 00000000 Serial number: 00000131300359
Coding: 15210001
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 76A0277FC9D09626E1-8022
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000060483584
Coding: 00383B0000004201000001010101202020202121202020
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7P6 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH04 0120
Revision: 00H04000 Serial number: 6PZ 010 316-01
Coding: 0011151
Shop #: WSC 43941 003 1048576
VCID: 7EB03F5F29E0DE66B9-802A
Subsystem 1 - Part No: 7P6 907 568
Component: J770 SWA Slave H02 0120
Subsystem 2 - Serial number: 6PZ 010 316-21
Subsystem 3 - Serial number: 5F30.04.1300H02000AMS14441ÿ
Subsystem 4 - Serial number: S14441ÿ
Revision: 00002001 Serial number: 0306982576
Coding: 018A1E2028B91095832006202F0000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO21737745
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO2166603+
Coding: 191100
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Reset counter: 177
Mileage: 177981 km
Date: 2025.02.20
Time: 08:51:35
02616 - Fuel Tank Cap; Unlock
Reset counter: 175
Mileage: 178008 km
Date: 2025.02.20
Time: 12:45:49
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002383707
VCID: 75A22073DCD69D3EE8-8020
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000061109527
Coding: 011D1620DE01459205080000
VCID: 3B36F64BBA720B4EDE-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1351200465 Dataset Number: A001
Coding: 01040100
ROD: EV_ParkbA7.rod
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0009
Coding: 012E00000F000200
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CB43557F7FCCC7697-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227E40D7738935
Coding: 040005010000000003
VCID: 2600373F51F0A6A691-8072
02984 - Connection between Impedance Converter 2 and Window Antenna
Reset counter: 119
Mileage: 177942 km
Date: 2025.02.17
Time: 15:57:35
Voltage: 13.00 V
Part No SW: 7P6 035 764 K HW: 7P6 035 764
Component: H-BNT-RW H46 0934
Revision: -------- Serial number: 479E+0D7525009
Coding: 010A01050040FFFFFF38FF2600400003F80001030300000300
VCID: 41CA84A3D89E619E84-8014
Subsystem 1 - Part No: 8R0 060 884 GC
Component: ROW 2019 1104
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9NA2005ZZ
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 4949
Reset counter: 119
Mileage: 177942 km
Date: 2025.02.17
Time: 15:57:30
Text: DUA001,Front,M,0,0,6
03389 - Data Set Implausible
Reset counter: 119
Mileage: 177942 km
Date: 2025.02.17
Time: 15:57:28
Voltage: 12.70 V
Bin. Bits: 010
Fault Frequency: 13
Reset counter: 138
Mileage: 178199 km
Date: 2025.03.06
Time: 12:37:02
Bin. Bits: 00000000 01000000
Bin. Bits: 00000000 00000000
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000061866825
Coding: 011C14200001259005080000
VCID: 3A38F34FB5483246C5-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 20000000018422 Dataset Number: 7P6096v____ 0019
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FCE825BA66A176EF2-806A
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H11 0110
Revision: 5A001001 Serial number: 00000192650503
Coding: 030D000000000000
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 E HW: 7P6 907 441 D
Component: TopView H05 0100
Revision: 11001001 Serial number: 82330JF0088195
Coding: 0100000001000000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 091300328 Dataset Number: 7P6959107C D045
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000061868341
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H27 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: E9030000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 393AEC43B84E395ECC-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007055876_4174
Part No SW: 7P6 907 541 B HW: 7P6 907 541
Coding: 3704010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002010
ROD: EV_AdaptCruisContr2VW526_002.rod
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H31 0035
Serial number: 005000011604137
Coding: 0AA03F041021
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
VCID: 373EEA7B8E5A2F2E3A-8062
Component: RGS-VL H13 0080
Dataset Number: 7P0FH1v____ 0010
Coding: 00660600031F037F00033810594097000000
Shop #: WSC 00001 790 00001
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 312AD463603EF11E74-8064
Component: RGS-VR H13 0080
Dataset Number: 7P0FF1v____ 0010
Coding: 006606000317037F00033810594097000000
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 3228DB6F6538CA060D-8066
End----(Elapsed Time: 02:44, VBatt start/end: 12.8V/12.7V. VIgn 0.0V)------
