Adaptation failed with "ERROR: Request out of range"!
Kowa92
Pirate
Walking the Plank
Italy
LP/IP
I'm trying to change some values (through Adaptaion function) to make the start & stop of my Audi A3 SPB 2014 184CV work again, but unfortunately i can't do it because the VCDS gives me the ERROR "Request out of range" even though i previously entered the right Access Code to possibly unlock the parameters protected by security.
This is the error message:
This is my Auto-Scan result:
Removed.  Data from clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
I need to change this values (The previous owner of the car told me that to disable the start & stop he had touched these parameters here):
  • -EM_start_stop_requirement_ambient_temperature-Minimum_temperature
  • -EM_start_stop_requirement_ambient_temperature-Maximum_temperature
I know that these default values are set to -50.0 °C but unfortunately i can't change them..
  • Do you have any tips to give me about this to be able to solve this error and change the values in question?
Thanks to all!
