MK5 Rabbit PODs Reset Issue
   #21
davisev5225
C?ID=263265
They may take issue with the errors in your 16 Steering Wheel module, since there is an airbag in the steering wheel, but I don't see anything else that could potentially cause you issues getting your airbags certified.
   #22
user55645
CT, USA
Understood
What about trying to clear all the codes outside the Airbag 15 section?
I should do this, cycle, and rescan, correct?
If so, is the Security Access button similar to the one in the Airbag 15 section?
   #23
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0AKGRK
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C81D3E23A8A7EDA433-8038
That looks good to me.
The faults at address 16 suggest this car likely needs an ignition switch.
davisev5225
C?ID=263265
Unnecessary, and no security access is needed to read or clear codes. And Per Uwe, you can probably make the steering wheel errors go away with a new ignition switch, though that might not be necessary for your airbag certification.
user55645
CT, USA
The ignition switch you speak of is 1K0905849B?
I found this vid on how to access, remove, and replace.
Seems straightforward and not too involved. Does this require recoding, etc once replaced?
   #26
davisev5225
C?ID=263265
I believe so; at least, that's the part number that FCP Euro returns. I don't have the Etka subscription to confirm by VIN...
   #28
user55645
CT, USA
Well, good news. I cleared the codes and only the Cruise Control Switch came back. Looks like I should be good to go.
Thank you for all your time and help.
