MK5 Rabbit PODs Reset Issue
user55645
CT, USA
Hey, everyone. I have an 08 Rabbit that needed the PODs module replaced. My issue is that the Basic Settings screen looks completely different than any video or thread I've read. There is no MAS00041 Resetting seat occupied recognition nor MAS00042-Seat occupied recognition serial number option.
This is NOT what the Basic Settings screen looks like.
This is the screen I get
Does this sound familiar to anyone and what are the steps I should take to reset the module?
Thanks in advance.
Please post an Auto-Scan so we can see exactly how this car is equipped and configured.
user55645
CT, USA
I'll have to do this tomorrow, as the car is at work.
In the mean time, can you say why I'm not getting the screen as described?
I read section 17 of the manual, but I'm not understanding how you get from the screen on 17-A to the one on 17-B.
The first screen-shot you posted is from an Airbag module that uses the newer UDS protocol. The second is from an older pre-UDS one.
user55645
CT, USA
Understood.
With this being known, what would be the workflow to reset the module (using the screen provided)?
Just trying to get this worked out ASAP as I need this completed before it can go to the dealer, then to an auto shop, then to emissions, all before I can get it registered. I've been borrowing a vehicle and I've stretched the favor a bit thin.
user55645
CT, USA
Wednesday,09,April,2025,07:25:29:06299
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WVWDB71K98W266310   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
Address 01: Engine (CBU)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BG    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1565
   Revision: 1NH01---    Serial number: VWX7Z0H13NL8WH
   Coding: 0000003
   Shop #: WSC 02982 002 1048576
   VCID: 6FBBC4EE0B9C85C266D-803A
   VINID: 9E69D448705B2489C21860C100D25B26E2
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -
                    Fault Status: 01100001
                    Mileage: 187208 km
                    Time: 21:02:00
                    Temperature: 27.0 C
                    Temperature: 16.0 C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.065 V
Readiness: 0110 1101
   Part No SW: 09G 927 750 HE    HW: 09G 927 750 HE
   Component: AQ 250 6F           1090
   Revision: 00H69000    Serial number:
   Coding: 0000584
   Shop #: WSC 01279 785 00200
   VCID: 7BA3E0BE4FE4E962DA5-802E
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.clb
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3FDB54AE1B7C3542B6D-806A
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CA1E3A24AEAEE5AD3F-8028
   Revision: 00H54000    Serial number: 00000007982609
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71BFC2961DA89332709-8024
   Component: Wischer 150208 021  0501
   Coding: 00038805
Address 0F: Digital Radio
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0AKGRK
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6C81D3E23A8A7EDA43F-8038
   Subsystem 1 - Part No: 000 000 000 000
   Component: BF-Gewichtsens. 000 0000
   Subsystem 2 - Serial number: 6332MSME3D0428506
   Subsystem 3 - Serial number: 6342MSME182923401
   Subsystem 4 - Serial number: 6352QSME5B421067D
   Subsystem 5 - Serial number: 6362QSME4D174E0F-
   Subsystem 6 - Serial number: 63727SME13306806U
   Subsystem 7 - Serial number: 63827SME134A0630V
02511 - Control Module for Seat Occupied Recognition (J706)
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0100
   Coding: 0010042
   VCID: 77ABFC8E73CCCD02BED-8022
00895 - Cruise Control Switch (E45)
            014 - Defective
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments
   Revision:   H07 01    Serial number: 130208F2001515
   Coding: ED807F070003020002
   VCID: 30390792D622DA3A3F7-8064
                    Fault Frequency: 48
                    Reset counter: 16
                    Mileage: 187208 km
                    Time: 21:01:59
   Part No SW: 1K0 920 974 J    HW: 1K0 920 974 J
   Component: IMMO            VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H13NL8WH
   Shop #: WSC 31508 001 1048576
   VCID: 353736862940FF126C1-8060
   Component: Tuer-SG         006 1219
   Coding: 0001205
   VCID: 38293FB23E52027A777-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
   Coding: 139006885103281B0904058FB0080F0488DC00
   VCID: 04519B42321A969AABF-8050
   Component: Tuer-SG         006 120A
   Coding: 0001204
   VCID: 392F3AB605581B72889-806C
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Coding: 0100101
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
End----(Elapsed Time: 01:21, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
------------------------------14 Faults Found------------------------------
user55645
CT, USA
I have been both successful and unsuccessful with this walkthrough.
It took 3 tries before the dash light disappeared. About 1min after the 3rd try, after starting the car, the light reappeared.
Maybe a dozen more tries and all unsuccessful.
A couple questions:
For the "Prerequisites" under "Special Procedures", it lists "no faults in the system". I tried clearing the codes after each reset, but they always reappeared; even on the attempt which seemed successful (albeit for ~1min). Am I doing it correctly?
I had the vehicle at VW and my diag report states:
116322 air bag light is on. has fault 2511. ran test plan and tested wiring from air bag control module to right front seat occupant sensor, found ok. test plan indicated the j=706 pods module is the cause.
With this being said, is all the focus on the module?
What would be the reason for it to appear to reset and, then, fault almost immediately?
If I knew, I'd be happy to tell you. ;)
davisev5225
C?ID=263265
Coding: 0013899
You've got a comms issue, so no amount of reset attempts is going to fix it. You can't just go by the error number, you also have to go by the description. This one doesn't say "No or incorrect basic setting/adaption", which could be solved by running Basic Settings, this one says "No Signal/Communication", which cannot be solved by running Basic Settings.
Either you've got a bad connection (likely, and can be either unplugged, loosely plugged, or bad wiring), or you've got a faulty module (unlikely, but possible).
Also, get a charger on that battery!
user55645
CT, USA
Thank you for the clarification on the comms reading/code
Let's assume the harness is firmly seated in the module and the harness from it to the under-seat connection is also correctly seated as well as intact. Could this exact error/fault still exist? If so, where do I focus my attention to? I ask because the VW dealer's diag report now has me confused. I'm not one to loosely seat a connector (designing and building/assembling industrial controls is part of my job) and it would seem I now must double-check the dealer's work (which cost me >$400 to have performed).
davisev5225
C?ID=263265
Lack of communication is pretty self-explanatory. Either the module doesn't have power or the comms lines aren't connected all the way through (loose pins, broken wire, etc.), or both. No matter what, you're going to have to grab a wiring diagram <--- clickable link and start tracing/testing wires.
If all wiring is good, you get the appropriate voltage between the power and ground pins, all the comms wires have good continuity, etc., then the dealer is probably correct that the module itself is defective.
user55645
CT, USA
@davisev5225 @Uwe
Thank you, gentlemen. I believe it is all sorted and rests solely on a dishonest VW tech. The #4 fuse was not only blown, but there was enough corrosion on the supply side that even with a fresh fuse there was no continuity to 12V+. Also, there was no continuity to the T10e harness and, subsequently through to the PODS module. I cleaned everything and checked continuity to all connectors off the PODS T18 harness. Original Occupancy module reset, adapted, and still in the vehicle.
Not sure why the scan said the batt was @11.8V. I read it with a Fluke 179 and it was 12.7V at rest, 12.58V ACC, and >14V running (had me worried there as it's a 3wk old AGM Platinum batt).
davisev5225
C?ID=263265
Wow, did you take photos? If so, I'd go back to the dealer and demand your money back! :eek:
user55645
CT, USA
I still need them to perform a state required airbag system certification. I'll start making waves after payment 😉
Sounds like excessive resistance somewhere between the battery and the diagnostic socket.
user55645
CT, USA
Makes sense.
On a slightly different note, but same topic. I emailed the service manager, to get a better understanding of what the airbag certification encompasses. His exact words were:
For the airbag certification we would simply look at the airbag system only & verify the system has no faults active or in history
I cleared the codes when I did the module reset/adaption. Are these going to show or otherwise cause an issue when they do their scan for the above? If so, is there anything I can do with the VCDS tool in my possession to get my system to a status that will pass said certification?
davisev5225
C?ID=263265
Post up a new, fresh auto scan so we can see the current state of the car. Without that, we can only guess and throw darts in the dark. ;)
user55645
CT, USA
Roger
Should I go through and clear the faults in the other systems, to see what pops back up?
Will I need the Security Code, similar to accessing the Airbag 15 system, for the others?
Thursday,10,April,2025,10:07:08:06299
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
Mileage: 187200km-116320mi   Repair Order:
VIN: WVWDB71K98W266310   Mileage: 187200km-116320miles
   Coding: 0000003
   VCID: 6FBBC4EE0B9C85C2661-803A
               P1698 - 001 -
                    Mileage: 187208 km
                    Time: 21:02:00
                    Temperature: 48.0 C
                    Temperature: 27.0 C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.573 V
   Coding: 0000584
   VCID: 7BA3E0BE4FE4E962DA9-802E
   Coding: 0017025
   VCID: 3FDB54AE1B7C3542B61-806A
   VCID: 7CA1E3A24AEAEE5AD33-8028
   VCID: 71BFC2961DA89332705-8024
   Coding: 00038805
   Coding: 0013899
   VCID: 6C81D3E23A8A7EDA433-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Coding: 0010042
   VCID: 77ABFC8E73CCCD02BE1-8022
00576 - Terminal 15
   Component: KOMBIINSTRUMENT VDD 2216
   Coding: 0007203
   Shop #: WSC 08057 067 57207
   VCID: 353736862940FF126CD-8060
   VCID: 30390792D622DA3A3FB-8064
                    Fault Frequency: 86
                    Reset counter: 16
                    Mileage: 187208 km
                    Time: 21:01:59
   Coding: 0001205
   VCID: 38293FB23E52027A77B-806C
00915 - Window Regulator Switch; Rear Right; Driver (E55)
   VCID: 04519B42321A969AAB3-8050
   Coding: 0001204
   VCID: 392F3AB605581B72885-806C
Address 56: Radio
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
