Golf 8 databus errors
Thymo
C?ID=609468
Hi,
I'm trying to add the VW-190-H1 towbar module from ECS electronics to my golf 8. In the process of doing this I'm getting all kinds of databus errors and the accompanying errors on the dashboard.
I've reversed all the wiring changes I did. I've measured the CAN bus using a multimeter. This gave me 120 ohms at the wires going into plug A on the BCM. I expected 60 here but since I also get 120 ohms on the BCM itself I deduce that the termination resistors are not at fault here. At this point I'm not really sure what the next step is. I would love some pointers.
Here's an auto-scan:
Monday,07,April,2025,12:26:54:05346
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250311 DS365.0
VIN: WVWZZZCDZMW028603   License Plate:
Mileage: 89707km-55741mi   Repair Order: can_error
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 52 5F 6C 75
          A5 D6 D7 8107
VIN: WVWZZZCDZMW028603   Mileage: 89707km-55741miles
6C-Back-up Cam. -- Status: Cannot be reached 0100
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DPBA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 012     HW: 05E 907 309 D
   Component: R4 1.5l TFS   H20 9971
   Revision: 8AH20000    CVN: 41CF9861
   Coding: 011900322364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012 002009
   ROD: EV_ECM15TFS01105E906012.rod
   VCID: 5CE092CA66AAC9CAB3F-8008
   VINID: 9E69EAAAA4D4A9D9C00881800C58F0213C
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:52
                    Engine speed: 0.00 /min
                    Coolant temperature: 11 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 11.980 V
                    Cruise Control System (CCS): status-Bits 0-7: 6
                    Drive train coordinator irreversible switch off conditions: 0
                    Drive train coordinator reversible switch off conditions: 25198592
                    Drivetrain coordinator: brake fault status: 517
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BL    HW: 5WA 614 517 N
   Component: ESC           H13 0134
   Serial number: 62390000001836  Dataset Number: V03935359XC 0001 CVN: C61607EC
   Coding: 34FC2C9022224474527D50000AC661862DB458F042D067C0019CA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 1372B9F6CBF4C6B2225-8046 SFD
8563 - Control Module for Steering Assist
          U10BB 00 [00100111] - Implausible Signal
          [CCan_EPS_BLW_QBit]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:53
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 340 m
                    Voltage_value_KL.30_ESC_V: 11.9 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: completed successfully
                    LWS_comparison: completed successfully
                    Internal_failure_code: 00 56
                    00 40 40 00 04 08 10 08 40 00 00 00 80 00 00 40 30 00 21 00 04
          C1146 02 [00100111] - Signal Failure
          [RKA+: missing input signal(s)]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:19:02
                    Voltage_value_KL.30_ESC_V: 11.8 V
                    Internal_failure_code: 00 F8
0294 - Steering Angle Sensor
          B1168 F2 [10100111] - Not Initialized
          [Swa_init_fail]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:52
                    Internal_failure_code: 01 B6
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 B    HW: 5WA 959 436 B
   Component: Kessy IOBOX   070 0706
   Serial number: --------------- Dataset Number: V03935342RF 0001
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003.rod
   VCID: 53F279F60B7406B2625-8006
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 Q    HW: 5WA 907 007 K
   Component: AC Automat    H31 3440
   Coding: 002000010211120010000000101011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001100
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 55F687EE058018828C1-8000
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000000226738
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001240820233209520
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 E    HW: 5WA 937 086 H
   Component: BCM 37W BOSCH 016 0159
   Serial number: BXJ53F110920940 Dataset Number: V03935362UZ 0001
   ASAM Dataset: EV_BCM37w 006001
   ROD: EV_BCM37w_006_VW38.rod
   VCID: 53F279F60B7406B2625-8006 SFD
   Subsystem 1 - Part No SW: 5H1 955 119     HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0051
   Serial number: 907453F0402022701076
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: S6Y20M09D09H12M40S36
   Subsystem 3 - Part No SW: 5H0 941 193 AD    HW: 5H0 941 193 AD
   Component: LiSi           H05 0007
   Serial number: 92471THV001VI
   Subsystem 4 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471TI1000Z5
   Subsystem 5 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92413THR00839-------
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 FP    HW: 5Q1 953 549 D
   Serial number: 00000024082020240327
   Part No SW: 5WA 919 298 B    HW: 5WA 919 298
   Component: PLA 12 Kanal  H04 0578
   Serial number: 000030082094560 Dataset Number: V03935357TV 0001
   Coding: 8200026001
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
13637426 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
13647889 - Databus
          [Bremsensteuergerät - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:52
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H10 0246
   Dataset Number: V03935317ZN 0001
   Coding: 060318F70007404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003_VW38.rod
   VCID: 4CC0628AD64A594A23F-8018
7 Faults Found:
2055 - Databus
          U1122 00 [10101111] - Implausible Message
          [FAULT_ALP_STEERING_WHEEL_INIT]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
209153 - Databus
          U1123 00 [10101111] - Received Error Message
          [FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM_ERROR]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
0567 - Databus
          [FAULT_HMS_FAILURE_STATUS_ERROR]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
0577 - Databus
          [FAULT_VZM_SYSTEM_STATUS_ERROR]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
0723 - Databus
          [FAULT_BV_RELEVANT_ERROR]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 H    HW: 5WA 959 655 H
   Component: AirbagVW40    007 0636
   Serial number: 000000003C0HZR6 Dataset Number: V03935332FT 0001
   Coding: 88CC000000C0C000000000000000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 5CE092CA66AAC9CAB3F-8008 SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 401 609 20
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001AAF0D42775647
   Subsystem 2 - Part No SW: -----------    HW: 480 401 509 20
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A4F4531A4527
   Subsystem 3 - Part No SW: -----------    HW: 480 000 508 20
   Serial number: 35700000000A39FC694/
   Subsystem 4 - Part No SW: -----------    HW: 480 002 808 20
   Serial number: 358000000001AC55F94Y
   Subsystem 5 - Part No SW: -----------    HW: 480 400 809 20
   Component: FrontSensor_D  002 614A
   Serial number: 355000108637E836653/
1075462 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
                    Reset counter: 210
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:55
1075463 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
                    Reset counter: 210
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:55
1075465 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
                    Reset counter: 210
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:55
1075461 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
                    Reset counter: 210
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:56
1075464 - Databus
          [NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
                    Reset counter: 210
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:56
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 A    HW: 5H0 920 340 A
   Component: KOMBI         203 3450
   Coding: 04A40000639C00080180620B2000080800300800
   ASAM Dataset: EV_DashBoardVDDMQB37W 003032
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 2018E63A0A42AD2AAF7-8074 SFD
16777020 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 250
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:53
   Part No SW: 5WA 907 530 N    HW: 5WA 907 530 C
   Component: GW2020 High   752 7310
   Revision: --------    Serial number: 771049050020251 Dataset Number: V03935349UB 0001
   Coding: 0000808D0F00000000000000010301307301610902000100030100000001010000000000000000000000000000000000
   GVL: 3D000000020840DC800080024800004004004000004400000000000000000044
   ASAM Dataset: EV_GatewMQB2020 004008
   ROD: EV_GatewMQB2020_004_VW38.rod
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 7803655305
   Subsystem 3 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440066246215105
   Subsystem 4 - Part No SW: 5H0 959 542 F    HW: 5H0 959 542 F
   Component: KLR_JSS_1Zone  076 0022
   Serial number: 3133020AB21239130401
2494569 - Ethernet Module for Back-Up Cam
          U1643 00 [00101111] - No Communication
          [Rearview_camera_system_control_module_no_communication_vlan]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:21:41
   Part No SW: 5WA 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0111
   Serial number: BPA085010920013 Dataset Number: V03935325GA 0001
   Coding: 1002C140730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 013023
   ROD: EV_BrakeBoostG2BoschVW37W_013_VW38.rod
   VCID: 54F07AEA0E7A018A7BF-8000 SFD
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 20000202137001
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323C1C7254AE2FBA493-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0361
   Serial number: 2082701KA00949
   Coding: 015892400000A0508803010101010000000000212100000000000000215000
   VCID: 59EE8BDE69983CE2A89-800C
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 D
   Component: HRE_Master    H25 0284
   Serial number: 00000555854594  Dataset Number: V03935341JU 0001
   Coding: 569945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: 3C20324A86EAE9CA93F-8068
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 D
   Component: HRE_Slave      H25 0284
   Serial number: 00000555256483
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 0005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 0005
2236426 - Databus
          U1122 00 [00101111] - Implausible Message
          [databus unreasonable message - LWI_Lenkradwinkel]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
2236417 - Databus
          [databus unreasonable message - LWI_QBit_Lenkradwinkel]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
2236437 - Databus
          [databus error value received - Parkhilfe_04 - APSOPS_PaCo_MainState]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:56
2252891 - Databus
          [databus error value received - VMM_02 - VZM_Systemstatus]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:51
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007THA0500A Dataset Number: V03935328LM 0001
   Coding: 003B0320DE00040000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 49CE5B9ED9384C62189-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 C    HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000042508922
   Coding: 110000
   Part No SW: 5WA 907 144 H    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  101 1030
   Serial number: 00303230 Dataset Number: V03935331WD 0001
   Coding: 0000000000000000000102010100010000000101010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
   ROD: EV_SteerAssisBASGEN1MQB37_006.rod
   VCID: 4EC4688220566B5A4DB-801A
5423 - Steering Angle Sensor
          [DTC_RACKPOS_NOINIT]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
                    MonitorId: 00 00
                    HybridDriveReady: 00000000
                    IgnitionEnabled: 00000001
                    Communication control: 00000000
                    Diagnostic session: 00000001
                    ComM_ModeType: 00000000
                    NM_Signal_Fahrbereit: 00000000
                    NM Signal V gr 7: 00000000
                    System status: 3
                    ECU Status: 4
                    HWLib Status: 1
                    Support power reduction: 0.0 %
                    Voltage terminal 30: 12.063 V
                    Temperature circuit board: 19 °C
                    Output stage temperature: 14 °C
                    Rackposition: 0.00 mm
                    Rackspeed: 0.00 mm/s
                    pinion angle dependent amplitude factor: 0 °
                    Steering wheel angle: 0.25 °/s
                    SupplierFreezeFrameData: 01 00 00 00 02 01 00 00 4A 48 08 00 01 00 00 00 01 00 00 00
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TH83045E Dataset Number: V03935328LS 0001
   Coding: 003B0120DE00040000801000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 48C85E9AC232B56A077-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 C    HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000043072053
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 816 K    HW: 5H0 035 816
   Component: MU-O-ND-EU    H56 1985
   Serial number: WG8LGM070920000 Dataset Number: V03935362LB 0001
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW38.rod
   VCID: 2F3A1506479C025226D-807A SFD
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H46 2091
   Serial number: APUF8414092000020122
   Subsystem 2 - Part No SW: V03 959 806 MG    HW: -----------
   Component: EU 2019/30     --- 2020
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 C    HW: 5WA 980 556 A
   Component: RV eCompact   H21 0314
   Serial number: FCLK20260720000 Dataset Number: V03935342HG 0001
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009023
   ROD: EV_CamSysRVCCompaFicos_009_VW38.rod
   VCID: 51FE73FE316874A2509-8004
13706006 - Databus
          [Errorvalue-monitoring VMM_02.VZM_Systemstatus]
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0144
   Serial number: 0000000006VIBB5 Dataset Number: V03935364ZT 0001
   Coding: 023800109068A8209405460071502E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 49CE5B9ED9384C62189-801C SFD
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3129
   Serial number: E26735112202630 Dataset Number: V03935332VC 0001
   Coding: 00000888216CC040109E00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 4DC66F8E2D505042341-8018
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 0
                    Mileage: 89707 km
                    Date: 2025.04.07
                    Time: 12:18:50
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6596B72E55E088021C1-8030
   Component: LED1R         H08 9202
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0083
   Serial number: 0000000006VIPA3 Dataset Number: V03935364CE 0001
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D249B6FB149632D25-8016 SFD
End----(Elapsed Time: 01:27, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
------------------------------28 Faults Found------------------------------
JeniCzech92
Prague, Czech Republic
C?ID=594546
regarding the impedance - two parallel 120ohm resistors terminate a CAN bus, if both are present, the resulting impedance is halved. This is why you expected 60 ohm, but since only one bus termination was present when you took the measurement, you correctly got 120 ohm. The resistors are inside the controllers, not in wiring - meaning the bus itself is in practice just two wires and controllers.
Only device that is unreachable in your vehicle is reversing camera, but, lane change assistance and A5 cam module is reachable. The bus therefore works, but the camera is not responding. It is either disconnected from the bus, power (check fuses! Fuse holder C, position 21), or defective. Fixing this will clear some of the myriad problems your controllers are reporting.
I'd start with the back up cam repair, and then scan again, hopefully having more clear autoscan.
Thymo
C?ID=609468
That's right. I was sure the bus was okay as the impedance was okay. I measured on the disconnected BCM plug so the 120 ohm was expected.
What threw me off, especially since this is my first time retrofitting stuff, was the fact that those modules were throwing faults.
In the end the solution was quite simple. I just had to drive around for a while to allow all the modules to initialize themselves. I didn't understand the databus errors but found out that they were the result of other modules saying they were not initialized. This was seen as error and implausible messages.
Regarding the back-up camera fault in the CAN bus. I found an Audi TSB for the same part that says it's a non-issue. There does exist an update for the backup cam that fixes it but the instruction is to just ignore it: https://static.nhtsa.gov/odi/tsbs/2023/MC-10236649-0001.pdf
