Coding of headlight control passat
mohamed
Egypt
C?ID=211960
The fault which appear at headlight control , that its not coded and adaption is not applied
I want to know the code and how to code it , and how to do the adaption .
thanks in advance
This the full autoscan
Monday,21,December,2015,07:52:11:43156
VCDS Version: 14.10.1.1
Data version: 20150130
VIN: WVWZZZ3CZ7P034023   License Plate:
Mileage: 134790km-83754mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72 76
VIN: WVWZZZ3CZ7P034023   Mileage: 134790km-83754miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 AA    HW: Hardware No
   Component: MED9.5.10       G00 9312
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000075
   Shop #: WSC 00028 028 00001
   VCID: 62CF4D5ABDE72531184-8037
012408 - Throttle Control
               P3078 - 002 - Airflow at Idle too Low
                    Fault Status: 01100010
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    Temperature: 215.0*C
   Part No SW: 09G 927 750 R    HW: 09G 927 750 R
   Component: AQ 250 6F           0761
   Revision: 00H38000    Serial number:
   Coding: 0000072
   VCID: 408BA7D2132B57212E0-8015
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667696970
   Coding: 0046469
   VCID: 326FFD1AAD87F5B1A84-8067
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 67D95C4E56C54019CFA-8032
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000004249194
   Coding: E6868F0700041A00000A00000F000000000B5D435C0000
   VCID: 306BF712A38BC7A1DE0-8065
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     280606 014  1201
   Coding: 00208933
   Shop #: WSC 00028
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 03 AIRBAG VW8   030 2522
   Revision: 10030000    Serial number: 003B1PEK5R7R
   Coding: 0012339
   Subsystem 1 - Serial number: 6332MSME0F7F244E
   Subsystem 2 - Serial number: 6342MSME10785C12
   Subsystem 3 - Serial number: 6351HTS6PLLQ4643
   Subsystem 4 - Serial number: 6361HTS6PLL6MNA3
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00007000    Serial number: 3C5953507P
   Coding: 0001111
   VCID: 2E57E96AB9BFD151CCC-807B
   Part No SW: 3C0 920 870 T    HW: 3C0 920 870 T
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 36002 360 89777
   VCID: 3463FB025793FB81BA8-8061
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 33
                    Mileage: 134107 km
                    Date: 2015.12.13
                    Time: 10:22:55
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C066210F80
   Coding: 7FFD1C04C21002
   VCID: 214D0256F8617E2941E-8074
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 397DCA3670F106E969E-806C
   Subsystem 1 - Part No: 3C0 905 861 F
   Component:    ELV          026 0380
   3C0905861F     ELV          026 0380
   Component: J386  TUER-SG FT    1123
   Revision: 12006001    Serial number: 00000645068711
   Coding: 0000245
   VCID: 3B71D03E7ACD34F97B2-806E
00914 - Window Regulator Switch; Rear Left; Driver (E53)
                    Fault Status: 01101000
                    Reset counter: 3
                    Mileage: 117883 km
                    Date: 2015.06.26
                    Time: 15:45:27
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.133 H07 1806
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570084F0B607800
   Component: J387  TUER-SG BT    1123
   Revision: 12006001    Serial number: 00000613868712
   Coding: 0000244
   VCID: 3C73D3227FC333C1728-8069
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
Address 55: Headlight Range        Labels: 5M0-907-357-V1.lbl
   Part No SW: 5M0 907 357     HW: 5M0 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000001
   VCID: 71ED321668018EA991E-8024
   Subsystem 1 - Part No: 7L6 941 329
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 3
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 3
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 3
                    Fault Status: 11100101
                    Reset counter: 3
02234 - Right Headlight Power Output Stage (J668)
                    Fault Frequency: 16
                    Reset counter: 43
                    Mileage: 134790 km
                    Date: 2015.12.20
                    Time: 17:49:06
   Part No: 1K0 035 186 R
   Component: Radio GR0       019 0023
   Revision: 0001905S    Serial number: VWZ2Z2F1749878
   Coding: 0040400
   VCID: 3565C6065CE9E2898D6-8060
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1113
   Revision: 11004001    Serial number: 00000000333649
   Coding: 0000208
   VCID: 3D75DE2664D93AC9456-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1113
   Revision: 11004001    Serial number: 00000000330839
   Coding: 0000208
   VCID: 3E77D92A69DF21D15CC-806B
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930618805008
   Coding: 0001014
   VCID: 285B1F729B5B8F61060-807D
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 93
                    Reset counter: 234
                    Mileage: 118047 km
                    Date: 2015.06.29
                    Time: 15:38:43
End-------------------------(Elapsed Time: 02:26)--------------------------
You must fix whatever is causing the lack of communications between the Headlight Range module and the Right Power Stage before you can code it.
Dex
Serbia
C?ID=25360
Uwe, fault is intermittent, so maybe there is no more problem. Just erase that error and perform coding and basic settings.
I disagree. Look at this part of the scan:
   Coding: 00000035
   Coding: 00000255
So while I see that the DTC is flagged "Intermittent" the problem that set it occurred on that very cycle and must be addressed.
mohamed
Egypt
C?ID=211960
thanks for your response , i will fix the problem , can u tell me how to code it to do it after the fixing
Gone But Not Forgotten
Subsystem 2 say's "my part # is missing" ............ because I have a bad ground headache........ HELP/HILFE!
Please fix me........"subsystem said"
The coding appears to be correct: 0000001 = VW Passat (3C) Left-Hand-Drive / Rest of World. The complete chart for this module 5M0-907-357 is located on the VW Golf (1K) Headlight Aim Control (Xenon with AFS) page.
You need to recode it to the same value after that communication issue is resolved and the Coding - 07 function is explained on the following page of our Interactive Manual.
