Skoda Fabia VRS 2011. Self inflicted headlight problems. Hoping so point me in the right direction.
HattersSoton
Hi
As explained in the title, I have caused myself some issues whilst attempting to fit an aftermarket auto headlights kit.
Tried posting this on the Skoda specific forum but have had no replies.
I have investigated to the limits of my knowledge. I was hoping someone could advise on how to repair.
Fabia VRS 2011. Old style "big" 17 pin light switch.
Fitted auto headlight box + switch and the following happened:
Dipped headlights permanently on. No control from switch.
Rear lights permanently on. No control from switch.
Speedo and Rev counter illumination does not light.
Dash "Dipped lights" tell tale light on.
Realising there was a problem, I removed the box and refitted original switch:
Dipped headlights permanently off. No control from switch.
Rear lights permanently off. No control from switch.
Speedo and Rev counter illumination still does not light.
Dash "Dipped lights" tell tale light off.
I can go between these 2 states by swapping components back and forth.
All fuses look OK but if any can suggest specific one to check, I can double check
Main beam/flash works as normal in either state.
My assumption is that I have cooked the BCM / Headlight control module. Any advice would be much appreciated.
Ben
HattersSoton
A friend kindly took a scan for me. Hopefully I have posted it correctly
Saturday,29,March,2025,17:40:00:28988
VCDS Version: 24.7.1.0
VIN: TMBKP65JXC3xxxxxx   License Plate:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 2E 37 44 56
VIN: TMBKP65JXC3038489   Mileage: 80670km-50126miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 CE    HW: 03C 906 027 CE
   Component: 1.4l R4/4V TS H15 9252
   Revision: L2H15---    Serial number:                CVN: 9DA2A7A4
   Coding: 00250012000400000000
   Shop #: WSC 13765 031 00000
   ASAM Dataset: EV_ECM14TSI01103C906027CE 001010
   ROD: EV_ECM14TSI01103C906027CE.rod
   VCID: 66C588F99916F1A651-8032
   VINID: 91D49B80615AA130C00C8108243FB17849
7 Faults Found:
14627 - Fuel Pump Control Module
          P025A 00 [00100000] - Electrical Fault
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
          U1025 00 [00101000] - -
                    Mileage: 60684 km
                    Date: 2023.03.05.
                    Time: 15:11:56
                    Engine RPM: 1108.00 /min
                    Normed load value: 31.8 %
                    Vehicle speed: 2 km/h
                    Coolant temperature: 13 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.418 V
                    Unlearning counter according OBD: 35
                    CAN TimeOut meter - transmission-Bits 0-7: 0
                    Generator performance: 0 W
                    CAN TimeOut meter - gateway-Bits 0-7: 0
8221 - System Voltage
          P0562 00 [00100000] - Too Low
4629 - ECM Power Relay Load Circuit
          P068A 00 [00100000] - Opens Too Early
4024 - Oxygen (Lambda) Sensor B1 S2
          P0137 00 [01100000] - Signal too Low
4106 - Bank 1; System too Rich at Idle
          P2188 00 [01100000] - -
4261 - System Voltage
          P0562 00 [01100000] - Too Low
   Part No SW: 0AM 300 052 B    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2711
   Revision: 00043014    Serial number: TFK01107140372
   Shop #: WSC 13765 790 00014
   VCID: 2A5D3CC9868E15C6B5-513C
   Part No SW: 6R0 907 379 AL    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 430148DB437000BAC22912EAC2DA00811700
   Shop #: WSC 13765 790 00000
   VCID: 0819A641BF4207D683-805C
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 5J0 820 045 C    HW: 5J0 820 045 C
   Component: Man AC         02 0101
   Revision: 0003S 02
   VCID: 2547CFF52C903ABE98-8070
                    Fault Frequency: 144
                    Reset counter: 39
                    Date: 2015.06.06.
                    Time: 11:37:01
   Part No SW: 6R7 937 087 H    HW: 6R7 937 087 H
   Component: PQ25 BCM      H12 0022
   Revision: -1------    Serial number: 1002480801
   Coding: 25980B3808C92400922808003E2B08C00040420F600000000000
   VCID: 499F6345E0C83EDE5C-801C
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3211
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3211
   Coding: 020000
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor       03   03 1209
   Component: LIN BACKUP HORN H11  H11 9005
   Subsystem 5 - Part No: 5J0 951 172
   Subsystem 6 - Part No SW: 3T0 959 537 E    HW: 3T0 959 537 E
   Component: E221__MFL-URO  H07 0012
   Serial number: 2164143
   Coding: 810000
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475     HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0003
   Revision: --H10---    Serial number: 32901120100139
   Coding: 100102
   ASAM Dataset: EV_SK25XParkiAssis2 S01002
   ROD: EV_SK25XParkiAssis2.rod
   VCID: 72EDE4A9A5DE1D06CD-8026
          U1400 00 [00001000] - -
                    Reset counter: 76
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10AirbagT2C H09 0020
   Revision: --------    Serial number: 003GY0044VLR Dataset Number: t00301725J0 0001
   Coding: 003243
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4B93594DE2B42CCE6E-801E
   Serial number: 3495RRB40690M98E3OFS
   Serial number: 3505RRB404V0N3MO28N7
   Serial number: 3515RRB404V0N3MO40VA
   Serial number: 3525RRB404V0N3MONP0O
   Part No SW: 5J0 920 941 F    HW: 5J0 920 941 F
   Component: KOMBI         H03 0305
   Coding: 410A01
   Shop #: WSC 13765 031 00014
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
   VCID: 2E5530D9716679E669-807A
   Part No SW: 6N0 909 901     HW: 6R7 937 087 H
   Component: GW-K-CAN TP20 0022
   Revision: -1------
   Coding: 232300
   VCID: 70E9EEA1A3D22F163B-8024
   Component: IMMO          H03 0305
   VCID: 6ADDFCC98D0ED5C675-803E
   Revision: A1001003    Serial number: 7660403846
   VCID: 295FC3C540881EDEBC-807C
   Part No SW: 3T0 035 192 G    HW: 3T0 035 192 G
   Component: RNS315-EU   H52 0319
   Serial number: SKZAZ2M9267840
   Coding: 000004010403000000000002
   Shop #: WSC 33361 790 00999
   ROD: EV_RNS315EUV2UDS_SK25.rod
   VCID: 326D24A9655E5D060D-8066
   Component: EUR_W_0038  0038
1048582 - GPS Antenna
          B1054 13 [00001000] - Open Circuit
                    Fault Frequency: 75
                    Reset counter: 96
                    Mileage: 189435 km
                    Date: 2025.03.29.
                    Time: 00:12:44
1048636 - Digital Radio Antenna
          B1103 13 [00001001] - Open Circuit
                    Reset counter: 175
                    Mileage: 189435 km
                    Date: 2025.03.29.
                    Time: 00:12:44
1048652 - Telephone Microphone
          B1048 13 [00001000] - Open Circuit
                    Reset counter: 1
                    Mileage: 189435 km
                    Date: 2025.03.29.
                    Time: 00:12:44
   Part No: 6R0 423 156 B
   Coding: 11241
   Shop #: WSC 13765
   VCID: 2F6B2DDDEA6C70EE62-807A
End-------------------------(Elapsed Time: 03:35)--------------------------
Ignore the CAN error, it is picking up a CAN nav system that isn’t registered or compatible. There are no errors in the J519 so it isn’t apparent what is wrong but the low voltage errors could be responsible.
iichel
Netherlands, Operation Market Garden
C?ID=284912
this car doesn't have a headlight module so you're in luck there. your bcm also doesn't operate the dipped headlights, so thats lucky as well, that one isn't broken.
i'm not sure what is though...
Did this kit have some sort of dongle that you plugged into the diagnostic port (DLC) ? What kit is this?
HattersSoton
Thanks everyone for the information. This has not been my best work :facepalm:
Looks like I ordered an auto headlight kit for a VW T5, which is the reason for the problem. Same plug, different pins.
After the information offered above, I started again from the beginning with assistance from a friend. Turns out it was a blown fuse after all.
On a Fabia VRS 2011 dipped headlights/tail lights are on Fuse 35 "Power supply of ignition switch" 5A according to the owners manual. The icon on the fuse panel is a book with a question mark.
NEtech
Denmark
C?ID=56995
@Uwe
They have changed all EU erwin addresses and also login.
  • Informative
