08 Jetta 2.5L Auto - Drive-train Can Bus
unsalVAGable
Atlanta, GA, USA
C?ID=407836
First, I have have long appreciated the Ross-Tech team and the community. While having never posted, my VCDS and this forum have been a great resource for my VWs and Audis. So Thanks!
My daughter bought a 2008 VW Jetta 2.5L w/ automatic late last year. I have had two of the MKV generation myself, and after a test drive it looked and felt like a pretty decent deal. As an aside I have done quite a lot with these except internals... and electronic issues.
About 4 weeks ago her power steering light came on. It felt fine, checked everything over and it looked ok. Cleared codes and went about our way.
Within a few days it came back. Cleared codes and was fine for a few days. Then the light came back on and while driving at highway speeds it speeds the transmission went into limp mode (3rd gear, I assume). She got to a safe spot and I came to check it out. Traction control light, check engine, and power steering light on. Cleared codes and the same sequence happened to me driving home.
I checked everything over and got to the TCU and ECU and everything looked ok. No water intrusion, no corrosion on the pins, nothing looking amiss with the wiring.
I drove it for three days without another issue, until it all happened again. This time I could not clear the codes. It is also worth noting that the power steering light cycles amber, red, green now, not sure when that change happened. It will go steady amber after a few minutes of ACC or running. When starting it will run rough and or die and then run fine when turning over again.
The only real item of concern to me was that whoever installed the aftermarket radio placed a fuse duplicator (I don't know what it is called) on the can bus fuse. I ordered a new gateway after some research.
The following are a sequence of 5 scans, all with some notes I added to the top. While I knew that I couldn't just replace the gateway, the 5th scan is after installing, starting and running, and clearing DTCs. The 3rd scan is the only one that the ECU is able to be communicated with in these sessions. I have more previous scans when this started and they are similar, including the ECU only being communicaated with intermittantly.
Any help would be greatly appreciated. It is also worth noting that while I have done some coding, it has only been when there is clear and concise directions and I was fairly certain I knew what I was doing. So links and references for me to educate myslef are welcome along with actual proceedures.
Scan 1
Note, Scan after sitting for 3 days. Clearing codes
Friday,28,March,2025,19:10:24:23542
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: 3VWRZ71K88M071894   License Plate: SIV3704
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
Address 01: Engine
   Part No SW: 09G 927 750 HE    HW: 09G 927 750 HE
   Component: AQ 250 6F           1090
   Revision: 00H69000    Serial number:
   Coding: 0000584
   Shop #: WSC 00066 000 00000
   VCID: 7BA3F24EFFE0DFB2DA2-802E
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 43801 002 1048576
   VCID: 73B3DA6ED7B097F2822-8026
   Part No SW: 1K0 820 047 GG    HW: 1K0 820 047 GG
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6FBBD61EBB98B31266A-803A
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000595679
   Coding: 14058E234004150007140000001400000008730B5C000100000000000000
   Component: Wischer 211007 020  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 01101100
                    Reset counter: 105
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.95 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0176315
   VCID: 2E050B1A7C12FA1A2DC-807A
                    Reset counter: 35
                    Mileage: 21575 km
                    Time: 20:49:11
02788 - Internal Communications Error
                    Fault Frequency: 9
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 17:41:10
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:09:28
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M039UJH
   Coding: 0013889
   VCID: 6C81C1128A8E480A438-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME16071A141
   Subsystem 3 - Serial number: 6342MSME1C49066FP
   Subsystem 4 - Serial number: 6351HSME104C440E6
   Subsystem 5 - Serial number: 6361HSME104B637CC
   Subsystem 6 - Serial number: 63727SME0F1E4B14A
   Subsystem 7 - Serial number: 63827SME0F4A4D16E
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenks ulenmodul 036 0070
   Coding: 0010021
   VCID: 005985A29606BC6A8F0-8054
00002 - Transmission Control Unit
Address 17: Instruments
   Revision:   H07 01    Serial number: 011007F2001866
   Coding: ED807F070003021002
   VCID: 303915626626ECEA3F0-8064
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 17:42:19
   Part No SW: 1K0 920 954 F    HW: 1K0 920 954 F
   Component: IMMO            3HL 1212
   Revision: V0002000    Serial number: VWX7Z0G924G1MD
   Shop #: WSC 36288 003 1048576
   VCID: 2F3B161E7B18F31226A-807A
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000129579001
   Coding: 0001205
   VCID: 3B23324EBF601FB29A2-806E
Address 44: Steering Assist
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 045189B2821EA04AAB8-8050
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000020078915
   Coding: 0001204
   VCID: 3C213152BA6E188A938-8068
Address 56: Radio
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000002182172
   Coding: 0001168
   VCID: 3E253B5AAC720A9ABDC-806A
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000002223323
   Coding: 0001168
   VCID: 3FDB465EAB780392B6A-806A
End----(Elapsed Time: 01:21, VBatt start/end: 11.0V/11.1V. VIgn 11.1V)-----
------------------------------8 Faults Found-------------------------------
Scan 2
Note, After clearing codes. Running up to temp then clearing and checking codes
Friday,28,March,2025,19:13:47:23542
Mileage: 318060km-197633mi   Repair Order:
VIN: 3VWRZ71K88M071894   Mileage: 318060km-197633miles
Address 01: Engine
   Coding: 0000584
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 105
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.95 V
                    Reset counter: 35
                    Mileage: 21575 km
                    Time: 20:49:11
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:10:50
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:09:28
   Coding: 0013889
   Coding: 0010021
   Component: KOMBIINSTRUMENT 3HL 1212
   Coding: 0023203
   Shop #: WSC 26149 444 53656
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 19:11:07
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 19:11:09
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 17:42:19
   Coding: 0001205
   Coding: 0001204
Address 56: Radio
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----(Elapsed Time: 01:18, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
------------------------------12 Faults Found------------------------------
Scan 3
Note: Started car, died. Started again, runs very rough for a 15 seconds and levels off. Clearing codes and checking again.
Friday,28,March,2025,19:27:22:23542
02-Auto Trans -- Status: Malfunction 1010
Address 01: Engine (CBU)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BG    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1565
   Revision: 1NH01---    Serial number: VWX7Z0G924G1MD
   Coding: 0000003
   VINID: 0E69E2A8705B2087401C120910D1A68104
8 Faults Found:
049153 - Powertrain Databus
               U0001 - 008 - Unspecified Malfunction - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 317812 km
                    Time: 12:24:32
                    RPM: 866 /min
                    Load: 18.0 %
                    Speed: 49.0 km/h
                    Temperature: 84.0 C
                    Temperature: 45.0 C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -  - Intermittent
                    Fault Frequency: 31
                    Mileage: 317823 km
                    Time: 12:57:53
                    RPM: 762 /min
                    Load: 32.9 %
                    Temperature: 51.0 C
                    Temperature: 24.0 C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
049478 - Diagnostic Gateway
               U0146 - 008 - No Communications - Intermittent
                    Mileage: 317823 km
                    Temperature: 82.0 C
                    Temperature: 40.0 C
                    Voltage: 12.192 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -  - Intermittent
                    Mileage: 317886 km
                    Time: 06:15:26
                    RPM: 1284 /min
                    Load: 33.3 %
                    Temperature: 18.0 C
                    Temperature: 24.0 C
                    Voltage: 11.176 V
049409 - No Communication with Transmission Control Module
               U0101 - 008 -  - Intermittent
                    Fault Frequency: 13
                    Mileage: 317936 km
                    Time: 07:36:59
                    Temperature: 18.0 C
                    Temperature: 24.0 C
                    Voltage: 11.049 V
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent
                    Mileage: 317961 km
                    Time: 06:19:28
                    RPM: 1810 /min
                    Load: 39.2 %
                    Speed: 85.0 km/h
                    Temperature: 69.0 C
                    Temperature: 14.0 C
                    Voltage: 14.605 V
001281 - Vehicle Speed Sensor
               P0501 - 002 - Implausible Signal - Intermittent
                    Mileage: 318060 km
                    Time: 17:06:07
                    RPM: 3138 /min
                    Load: 16.1 %
                    Temperature: 81.0 C
                    Temperature: 37.0 C
                    Voltage: 14.351 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -
                    Fault Status: 01101000
                    Mileage: 318066 km
                    Time: 19:17:07
                    RPM: 831 /min
                    Load: 35.3 %
                    Temperature: 18.0 C
                    Temperature: 22.0 C
                    Voltage: 14.097 V
   Coding: 0000584
01312 - Powertrain Data Bus
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 106
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.95 V
                    Reset counter: 145
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.05 V
                    Reset counter: 35
                    Mileage: 21575 km
                    Time: 20:49:11
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:10:50
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:09:28
   Coding: 0013889
   Coding: 0010021
   Coding: 0023203
                    Fault Frequency: 9
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 19:11:07
                    Fault Frequency: 25
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 19:11:09
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 19:15:52
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 17:42:19
   Coding: 0001205
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 353724769944C9C26C6-8060
            014 - Defective - MIL ON
                    Mileage: 318060 km
                    Temperature: 16.0 C
                    Voltage: 11.00 V
                    Voltage: 10.80 V
                    Mileage: 318060 km
                    Temperature: 19.0 C
                    Voltage: 9.10 V
                    Voltage: 8.90 V
   Coding: 0001204
Address 56: Radio
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----(Elapsed Time: 01:23, VBatt start/end: 12.2V/12.0V. VIgn 12.0V)-----
------------------------------26 Faults Found------------------------------
Scan 4
Note: Final check. Codes will not clear. I have a drive train can bus gateway module on the way. FYI, (aftermarket) radio can not be found is ok. However, the fuse (add-a-fuse?) was on the can network system fuse. I removed it two weeks ago and has not been attached since / for these scans. Waiting for new gateway module
Friday,28,March,2025,19:31:49:23542
Address 01: Engine
   Coding: 0000584
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 106
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.95 V
                    Reset counter: 145
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.05 V
                    Reset counter: 35
                    Mileage: 21575 km
                    Time: 20:49:11
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:10:50
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 19:09:28
   Coding: 0013889
   Coding: 0010021
   Coding: 0023203
                    Reset counter: 146
                    Mileage: 318066 km
                    Time: 19:11:07
                    Fault Frequency: 26
                    Reset counter: 146
                    Mileage: 318066 km
                    Time: 19:11:09
                    Reset counter: 145
                    Mileage: 318066 km
                    Time: 19:15:52
01304 - Radio
                    Reset counter: 105
                    Mileage: 318066 km
                    Time: 17:42:19
   Coding: 0001205
                    Mileage: 318060 km
                    Temperature: 16.0 C
                    Voltage: 11.00 V
                    Voltage: 10.80 V
                    Mileage: 318060 km
                    Temperature: 19.0 C
                    Voltage: 9.10 V
                    Voltage: 8.90 V
   Coding: 0001204
Address 56: Radio
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----(Elapsed Time: 01:20, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
------------------------------18 Faults Found------------------------------
Scan 5 - New (Used) Gateway
Note: New (used) gateway module installed. Started, died. Started again, rough idol and leveled off. Cleared codes, scanned again, results below.
Saturday,05,April,2025,13:26:43:23542
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 62 65 72
02-Auto Trans -- Status: Not registered 0001
04-Steering Angle -- Status: Not registered 0001
0F-Digital Radio -- Status: Not registered 0011
44-Steering Assist -- Status: Not registered 0011
62-Door, Rear Left -- Status: Not registered 0001
65-Tire Pressure -- Status: Not registered 0001
72-Door, Rear Right -- Status: Not registered 0001
Address 01: Engine
   Coding: 0000584
   VCID: 7BA3F24EFFE0DFB2DA5-802E
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3DA6ED7B097F2825-8026
   VCID: 6FBBD61EBB98B31266D-803A
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 6
                    Mileage: 318066 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.25 V
   VCID: 2E050B1A7C12FA1A2DB-807A
                    Reset counter: 35
                    Mileage: 21575 km
                    Time: 20:49:11
                    Reset counter: 146
                    Mileage: 318066 km
                    Time: 19:10:50
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
01304 - Radio
                    Reset counter: 6
                    Mileage: 318066 km
                    Time: 13:21:19
   Coding: 0013889
   VCID: 6C81C1128A8E480A43F-8038
   Coding: 0010021
   VCID: 005985A29606BC6A8F7-8054
   Revision:   H07 01    Serial number: 031207F1001955
   Coding: 89801F060000027400
   Shop #: WSC 35110 377 00157
   VCID: 303915626626ECEA3F7-8064
                    Mileage: 318066 km
                    Time: 13:25:06
   VCID: 2F3B161E7B18F31226D-807A
   Coding: 0001205
   VCID: 3B23324EBF601FB29A5-806E
   VCID: 045189B2821EA04AABF-8050
   Coding: 0001204
   VCID: 3C213152BA6E188A93F-8068
   Coding: 0001168
   VCID: 3E253B5AAC720A9ABDB-806A
   Coding: 0100101
   Coding: 0001168
   VCID: 3FDB465EAB780392B6D-806A
End----(Elapsed Time: 01:24, VBatt start/end: 11.3V/11.3V. VIgn 11.3V)-----
TTT
C?ID=547002
There is no such thing as can bus fuse.
Wiring diagram, power and grounds, comms check and done.
If above is unclear, youtube is your best friend for a crash course.
unsalVAGable
Atlanta, GA, USA
C?ID=407836
Hello TTT,
I agree, and my mistake for not clearly stating / specifying.
The additional fuse was on SC1 (see image below from my Bentley manual), and I made the assumption based on power bus SC1 through SC6 relating to most of the can bus errors I am having.
Thanks!
