Tiguan - Park/Steer Assist - Missing Message
Tregged
C?ID=171560
I have bought a car, the park assist does not function, fault finding and investigation has led to me finding that the steering control module has been replaced in the last year, it's DOM is March 2024.
I do not know what was fitted originally and there is no record of this work having been carried out. I do know that the garage that sold me the car, have also replaced the rear wiper stalk and had issues getting it working, but apparently needed to code it in.
My suspicion, is that there is a problem with this new module. The car was bought with the fault in existence, but having no history of the module swap, which is probably prior to the car dealership taking ownership of the car, I am somewhat at a disadvantage, so I'm trying to ascertain what should be fitted. The fault resolution was a priority up to now, as I envisaged a fairly simple recoding, but there doesn't appear to be any other obvious coding option.
In parallel, I would like to retrofit cruise control, this will require a new stalk or set of stalks and another steering control module compatible with my chassis build. I cannot reliably back work from what I have fitted, as it might not be correct, so I need to know what SCM options I have, hence the question in the retrofit section, where I thought someone might know the answer.
Once I know what is likely to work in terms of the retrofit, I believe that I can accomplish the fault resolution and cruise control fit in one intervention.
Tregged
C?ID=171560
So, based on my two provided scans, is anyone able to clarify which modules could be used if I need to retrofit cruise control to mr Tiguan?
For example, can I use a SCM that is ordinarily for an auto transmission, if mine is manual?
Also, what does the Yes or No mean in the steering control sensor option? Is this critical to functionality?
   #43
Tregged
C?ID=171560
Have you retrofitted something? My understanding was that you're trying to repair a car in which someone else may have installed an incorrect part.
I posted a rather longwinded reply, but in essence, I have a fault and that fault might be resolved by my intention to retrofit at a later date.
   #44
I just did a search for your 1K5 953 521 CA steering column mode and only found a three cars with it, all were 2015 Jettas. So I do suspect you don't have the proper one for this vehicle, but given that two of those Jettas were GLIs, I'm pretty confident that the module does support cruise control.
Tregged
C?ID=171560
Thank you for that, trawling eBay for cruise control stalks and the rarity of them makes me wonder just how few were configured with cruise.
So really, I'm looking for a set of stalks with the 5K0 prefix?
In the UK? I'm sure it's far fewer than here. Pretty much every car VW sold here for the last 25 years came with cruise as standard.
Tregged
C?ID=171560
Yes and with the proliferation of average speed cameras, they're a useful fine prevention tool...
   #48
Tregged
C?ID=171560
I've just sourced a 5K0953521GL, stalk module, it's for a 2015 car, so should be in the correct age bracket. If I have the ECM wiring in place, I might be in business, we'll see.
Edit: Just wondering, are any of these modules made in China? OEM products that is? Because the newish 5K0953569AG certainly looks to be.
Yes, the Tiguan I am fighting had the same codes, I put three hours into it on ODIS then had to give up and rebook. This is the scan from last wek.
Monday,07,April,2025,11:44:00:32095
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
Dealer/Shop Name: C&R Enterprises
Workshop Code: 210 01523 000001
VIN: WVGZZZ5NZFW054898
License Plate:
Mileage: 114950km-71426mi
Repair Order: For Steve Smith Autotechnic Nottingham
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4C 52 53
          55 56 61 62 72
04-Steering Angle -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFGC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 QP    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9977
   Revision: 41H28---    Serial number: 00000000000000 CVN: DD7BBD5A
   Coding: 00250032040701080000
   Shop #: WSC 00466 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018QP 003005
   ROD: EV_ECM20TDI01103L906018QP_VW36.rod
   VCID: 0842F3B0B2B4EEBAC77-805C
   VINID: 9E65EAAAA15EA969C0144209204ACE478D
4729 - Steering Effort Control Module
          U0130 00 [00101111] - No Communications
                    Mileage: 114343 km
                    Date: 2025.03.07.
                    Time: 00:57:55
                    Engine speed: 829.50 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 13.200 V
                    Cruise Control System (CCS): status-Bits 0-7: 4
                    selected gear-Bits 0-7: 0
   Part No SW: 0BH 300 012 A    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 2235
   Revision: 00H08V01    CVN: 8AE8EEE6
   ROD: EV_TCMDQ500021.rod
   VCID: 21148E14314E3FF2A09-8074
10686 - Databus
          U1121 00 [00101111] - Missing Message
                    Fault Frequency: 70
                    Mileage: 114343 km
                    Date: 2025.03.07.
                    Time: 00:57:55
                    Engine speed: 832.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 215 °C
                    selected gear: GANG_UNDEFINIERT
                    Engine torque: 0 Nm
                    Control Module temperature: 88 °C
                    Accelerator pedal position: 15.2 %
                    DTC memory status: 255
10730 - Databus
                    Fault Frequency: 70
                    Mileage: 114343 km
                    Date: 2025.03.07.
                    Time: 00:57:55
                    Engine torque: 0 Nm
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VDA7 0021
   Revision: --H07---    Serial number: 00000008559347
   Coding: 0056647
   Shop #: WSC 39593 004 1048576
   VCID: 78A28370CED49E3AB77-802C
                    Fault Frequency: 65
                    Reset counter: 207
                    Mileage: 114343 km
                    Date: 2019.07.29.
                    Time: 01:04:10
                    Speed: 2.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 219
                    Hex Value: 0x0000
                    Fault Frequency: 71
                    Reset counter: 167
                    Mileage: 114343 km
                    Date: 2019.07.29.
                    Time: 01:04:21
                    Speed: 4.0 km/h
                    Hex Value: 0x0000
                    Voltage: 13.00 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   VCID: 7AA69978FC588C2AC13-802E
9473137 - Motor for Left Temperature Flap
          B108C 71 [00001001] - Actuator Stuck
                    Reset counter: 167
                    Mileage: 114956 km
                    Date: 2025.04.07.
                    Time: 07:28:22
9474161 - Motor for Defroster Flap
          B1090 71 [00001000] - Actuator Stuck
                    Reset counter: 207
                    Mileage: 114456 km
                    Date: 2025.03.14.
                    Time: 12:22:17
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0174
   Revision: BC122001
   Coding: 48180A3F8025F1C0408800C0340009644BD5AB08636D8520E48487000041
   VCID: 42D62198D48804EAD93-8016
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 17101  013 0204
   Serial number: N2955119   °204!
   Coding: 009795
   Component: RLS 051114 05  54  0403
   Coding: 02304D
   Subsystem 3 - Part No: 5C0 951 171
   Component: Sensor, DWA 0  005 0402
                    Reset counter: 184
                    Mileage: 114349 km
                    Date: 2019.08.03.
                    Time: 06:42:51
                    Voltage: 10.85 V
                    Reset counter: 144
                    Mileage: 114343 km
                    Date: 2019.07.29.
                    Time: 00:57:58
                    Voltage: 12.95 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56201428101643
   Coding: 149303
   ASAM Dataset: EV_EPHVA2C000000000 002014
   ROD: EV_EPHVA2C000000000_002_VW36.rod
   VCID: 4BC80CBCE342C5A22A5-801E
   Component: J234__20E VW10 HI   2518
   Revision: 28020000    Serial number: 003L7PNGCKNL
   Coding: 0012357
   VCID: 7CAA9F60FAECB21AD3F-8028
   Subsystem 1 - Serial number: 6332MTS606123024
   Subsystem 2 - Serial number: 6342MTS634753024
   Subsystem 3 - Serial number: 6351HTS6T7SF8DKR
   Subsystem 4 - Serial number: 6361HTS6GEUF8DKR
   Part No SW: 5K0 953 569 AK    HW: 5K0 953 569 AK
   Revision: --X01---    Serial number: 20240521000354
   Coding: 1882040000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 0154EE94918EDFF2809-8054
   Serial number: 0652913
   Coding: 820000
   Part No SW: 5N0 920 983 G    HW: 5N0 920 983 G
   Component: KOMBI         H03 0705
   Coding: 411F01
   Shop #: WSC 33377 001 1048576
   VCID: 39244674B9DE4732889-806C
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 311014F1000052
   Coding: 356003
   Shop #: WSC 00000 288 25683
   VCID: 7F50686CE7FAA902F6D-802A
                    Reset counter: 144
                    Mileage: 114343 km
                    Date: 2019.07.29.
                    Time: 00:57:58
   Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
   Component: Haldex4Motion H52 7522
   Serial number: HA1-00001.10.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 52F611D80468946A693-8006
16653 - Databus
          [Lenkwinkelsensor -TO -- LWL_01]
                    Fault Frequency: 72
                    Reset counter: 167
                    Mileage: 114343 km
                    Date: 2025.03.07.
                    Time: 00:57:55
   Component: IMMO          H03 0705
   VCID: 6A86A9388CF83CAA313-803E
   Revision: A1001003    Serial number: 7666816907
   Coding: 020100
   VCID: 2B086C3C4302E5A20A5-807E
   Part No SW: 2K0 035 279 C    HW: 2K0 035 279 C
   Component: RNS315-EU   H85 0501
   Serial number: VWZAZ2P0568199
   Coding: 0400040104000C0000009002
   ROD: EV_RNS315EUV2UDS_VW32.rod
   VCID: 2A0669384C78FCAAF13-807E
   Component: EUR_W_V7  0066
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0504
   Revision: 13110009    Serial number: 0009123394
   Coding: 0202BC
   VCID: 3822437082D45E3A777-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000009041267
   Coding: 000090
          B11EC 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 188
                    Mileage: 114343 km
                    Date: 2025.03.07.
                    Time: 00:57:55
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 203    3501
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 40D22B90D68416FACF7-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0504
   Revision: 15110009    Serial number: 0009112251
   Coding: 0202BC
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000009039529
   Coding: 000090
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000364478
   Coding: 0026167
   VCID: 382243708E545E3A777-806C
   Component: AFS-ECU       H04 0111
   Revision: --------    Serial number: -------------- Dataset Number: 5N005Mv____ 0F01
   Coding: 049E00000B000200
   VCID: 3720404C8FCA51427ED-8062
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
13705474 - Databus
          U1121 00 [10001001] - Missing Message
          [Timeout mLW_1]
                    Reset counter: 144
                    Mileage: 114343 km
                    Date: 2025.03.07.
                    Time: 00:57:56
   Component: Batt.regelung H58 1653
   Coding: 030F1859
   VCID: 71B4BE54A1AECF72709-8024
   Component: J367-BDM  H07 0180
   Serial number: 41297A09421491940846
End----(Elapsed Time: 01:51, VBatt start/end: 11.8V/11.8V. VIgn 12.0V)-----
------------------------------13 Faults Found------------------------------
This was after fitting and coding (on ODIS) two new genuine TPS supplied column controllers, suffix AK to replace AD and confirmed byty TPS. The original fault was the airbag and steering wheel buttons/horn, after fitting a new controller these new codes came up.
  • Informative
Tregged
C?ID=171560
Problem resolved.
The solution was to fit a compatible steering wheel control module, in this case a 5K0 953 969 AE.
The part removed was 5K0 953 569 AG and not OEM, but of Chinese origin. I think the previous garage that tried to fix the issue, cheaped out.
I will also update the cruise control retrofit when I finish the project. At the moment, I still need to run in the wire at T16/5.
For reference, my Tig is a '12 plate TDi, manual transmission with MFSW and no CC from standard. I will post the latest scan so that it can be used for reference.
